  2. Announcements
  3. πŸ’¬ Building a wired RS485 sensor network
164 Posts 33 Posters 76.9k Views 35 Watching
  • K kimot
    @nofox
    If you have got one free pair of wires in cat5e cable, it is easy to convert your "star" topology to pure 485 bus topology with terminal resistors on both ends only.
    nofoxN
    nofoxN
    nofox
    @kimot I was thinking about that before I wrote here, and if nothing else can help I will convert star to bus.
    • A
      ArduiSens
      @nofox it's what gohan stated, the 120ohm resistors should only put on the first and last node of you network. And you can only use a "bus" network topology for RS485.You should use the other wires of you Ethernet cable to accomplish this like kimot wrote.
      MySensors 2.3.2; contr:Domoticz; layer: RS485, nRF24; gw: Ethernet, Serial
      • nofoxN
        nofoxN
        nofox
        Ok, so i switched my RS485 network to "bus". I desolder all of 120ohm resistors and have them only on both ends of the bus. RS485 to Ethernet gateway is in the middle of the wire. There are still some problems.. When I switching on the power and reading debug from gate I see that only 4 from 9 nodes are presenting. I need to reset other nodes manually to get them properly presented to the gateway. What am I doing wrong ? I need help I think.. Maybe its caused by the fact that all nodes powering on at the same time and there are many collisions on the RS485 bus ?? Maybe I should add some different delay() to setup part of my sketches to give, a time for every single node to present to the gateway ? Someone have successful working rs485 mysensors network here ?
        This is code for one of my nodes with buttons, relays and temperature sensor:
        #define MY_NODE_ID 8
        // Enable RS485 transport layer
        #define MY_RS485
        // Define this to enables DE-pin management on defined pin
        #define MY_RS485_DE_PIN 2
        // Set RS485 baud rate to use
        #include <OneWire.h>
        #include <OneButton.h>
        // define actions for OneButton function
        typedef enum {
          ACTION_OFF_1,  // set relay "OFF".
          ACTION_ON_1,   // set relay "ON"
          ACTION_OFF_2,
          ACTION_ON_2
        MyActions;
        MyActions nextAction_1 = ACTION_OFF_1;
        MyActions nextAction_2 = ACTION_OFF_2;
        // define Arduino I/O pins for relays
        #define RELAY_1  3 // Arduino Digital I/O pin number for first relay
        #define RELAY_2  5 // Arduino Digital I/O pin number for first relay
        // configure parameters for 1Wire temp sensor
        #define COMPARE_TEMP 1
        #define ONE_WIRE_BUS 6
        // define CHILD IDs for relays and virtual multiaction click/doubleclick/longpress buttons
        #define CHILD_ID_11 11 // child id for first relay and first button single click
        #define CHILD_ID_12 12 // child id for second relay and second button single click
        // #define CHILD_ID_13 13 // child id for first button single click (in this version not active because single click is attached directly to relay state)
        #define CHILD_ID_14 14 // child id for first button double click
        #define CHILD_ID_15 15 // child id for first button long press
        // #define CHILD_ID_16 16 // child id for second button single click (in this version not active because single click is attached directly to relay state)
        #define CHILD_ID_17 17 // child id for second button double click
        #define CHILD_ID_18 18 // child id for second button long press
        // define variables for temperature (and other) 1Wire Sensors
        long previousMillis = 0;
        long sensorInterval = 60000; // interval for temperature measurement
        long HI_interval = 1000;
        int numSensors=0;
        bool recivedConfig = false;
        bool metric = true;
        // define Arduino Digital I/O pins for OneButton function
        OneButton BUTTON_1(7, true); // Arduino Digital I/O pin number for first physical button
        OneButton BUTTON_2(10, true); // Arduino Digital I/O pin number for second physical button
        bool V1_BUTTON_1; // set variable for virtual one click button 1
        bool V2_BUTTON_1; // set variable for virtual double click button 1
        bool V3_BUTTON_1; // set variable for virtual long press button 1
        bool V1_BUTTON_2; // set variable for virtual one click button 2
        bool V2_BUTTON_2; // set variable for virtual one click button 2
        bool V3_BUTTON_2; // set variable for virtual one click button 2
        bool state1; // variable for RELAY_1 states
        bool state2; // variable for RELAY_2 states
        void before()
         sensors.begin();
        //define messages for diferent type of sensors CHILD_IDs used
        MyMessage msg0(0,V_TEMP); // temperature sensor message
        MyMessage msg11(CHILD_ID_11, V_LIGHT); // first relay & single click message
        MyMessage msg12(CHILD_ID_12, V_LIGHT); // second relay & single click message
        // MyMessage msg13(CHILD_ID_13, V_LIGHT); // button 1 Single click
        MyMessage msg14(CHILD_ID_14, V_LIGHT); // button 1 Double click
        MyMessage msg15(CHILD_ID_15, V_LIGHT); // button 1 Long press
        // MyMessage msg16(CHILD_ID_16, V_LIGHT); // button 2 Single click
        MyMessage msg17(CHILD_ID_17, V_LIGHT); // button 2 Dobule click
        MyMessage msg18(CHILD_ID_18, V_LIGHT); // button 2 Long press
        digitalWrite(RELAY_1, RELAY_OFF); // Set first relay state and pin mode
         pinMode(RELAY_1, OUTPUT);
        state1 = loadState(CHILD_ID_11);  // Set relay to last known state (using eeprom storage)
         digitalWrite(RELAY_1, state1?RELAY_ON:RELAY_OFF);
        digitalWrite(RELAY_2, RELAY_OFF); // Set second relay state and pin mode
         pinMode(RELAY_2, OUTPUT);
        state2 = loadState(CHILD_ID_12);  // Set relay to last known state (using eeprom storage)
         digitalWrite(RELAY_2, state2?RELAY_ON:RELAY_OFF);
        // sending states of relays after node bootup
        send(msg11.set(state1));
        send(msg12.set(state2));
        // attaching physical BUTTON_1 to OneButton function actions
        BUTTON_1.attachClick(singleclick_BUTTON_1);
        BUTTON_1.attachDoubleClick(doubleclick_BUTTON_1);
        BUTTON_1.attachLongPressStop(longpress_BUTTON_1);
        // attaching physical BUTTON_2 to OneButton function actions
        BUTTON_2.attachClick(singleclick_BUTTON_2);
        BUTTON_2.attachDoubleClick(doubleclick_BUTTON_2);
        BUTTON_2.attachLongPressStop(longpress_BUTTON_2);
        // setup for temperature sensor
            sendSketchInfo("pokoiczek_puszka_1", "1.0");
             present(i, S_TEMP);
            present(CHILD_ID_11, S_LIGHT);
            present(CHILD_ID_12, S_LIGHT);
            // present(CHILD_ID_13, S_LIGHT);
            present(CHILD_ID_14, S_LIGHT);
            present(CHILD_ID_15, S_LIGHT);
            // present(CHILD_ID_16, S_LIGHT);
            present(CHILD_ID_17, S_LIGHT);
            present(CHILD_ID_18, S_LIGHT);
          temperatureCheck(); // tmperature check function
          // states for nextAction of OneButton function
          if(state1 == HIGH)
              nextAction_1 = ACTION_ON_1;
          BUTTON_1.tick();  // reading state of first physical button
          if(state2 == HIGH)
              nextAction_2 = ACTION_ON_2;
          BUTTON_2.tick(); // // reading state of second physical button
        void singleclick_BUTTON_1()
          if (nextAction_1 == ACTION_OFF_1 )
              send(msg11.set(HIGH?false:true), true);
            send(msg11.set(LOW?false:true), true);
          // send(msg13.set(LOW ? 1 : 0));
          // send(msg13.set(HIGH ? 1 : 0));
        void doubleclick_BUTTON_1()
           send(msg14.set(LOW ? 1 : 0));
           send(msg14.set(HIGH ? 1 : 0));
        void longpress_BUTTON_1()
           send(msg15.set(LOW ? 1 : 0));
           send(msg15.set(HIGH ? 1 : 0));
        void singleclick_BUTTON_2()
           if (nextAction_2 == ACTION_OFF_2 )
              send(msg12.set(HIGH?false:true), true);
            send(msg12.set(LOW?false:true), true);
          // send(msg16.set(LOW ? 1 : 0));
          // send(msg16.set(HIGH ? 1 : 0));
        void doubleclick_BUTTON_2()
           send(msg17.set(LOW ? 1 : 0));
           send(msg17.set(HIGH ? 1 : 0));
        void longpress_BUTTON_2()
           send(msg18.set(LOW ? 1 : 0));
           send(msg18.set(HIGH ? 1 : 0));
        void temperatureCheck()
         if(currentMillis - previousMillis > sensorInterval)
          wait(conversionTime);
            #if COMPARE_TEMP == 1
              send(msg0.setSensor(i).set(temperature,1));
          if (message.type == V_STATUS && message.sensor == 11) {
            // Change relay state
            state1 = message.getBool();
            // Store state in eeprom
            saveState(CHILD_ID_11, state1);
           // send(msg11.set(state1));
          else if (message.type == V_STATUS && message.sensor == 12) {
            state2 = message.getBool();
            saveState(CHILD_ID_12, state2);
           // send(msg12.set(state2));
        I'm using OneButton library to get different actions when i'm clicking once, twice and holding buttons.
        • A
          ArduiSens
          Nofox,
          1. The 510 ohm pull up and pull down resistors (between A (D+) and 5V / between B (D-) and ground) are usually mounted on the master side (which is your gateway). Theoretically it would be best to install it in the middle of your bus line.
          2. check if your power supply has enough power to feed all your nodes
          3. check that all the ground lines of your boards are connected with each other.
          nofoxN 1 Reply Last reply
          • A ArduiSens
            Nofox,
            nofoxN
            nofoxN
            nofox
            @ArduiSens Thanks for your reply! I have found few post here on MYS Forum about biasing rs485 line with pull up and pull down resistors and I will try to do this tomorrow. I'm using standard rs485 module from aliexpress on the gateway side. There are pullups and pulldowns there but they are two 10k resistors, I will change them to 510 as you mentioned.
            All of my wired sensors, gateway and RPi are powered form 10A buffered power supply. I've checked voltage on every node. I have 5.25V on power supply pins in the middle of the line and 5.21 on both ends of line. I'm using one twisted pair for Vcc and one for GND. The bus is about 15 meter long form one end to another.
            As I mentioned above all of nodes are supplied from one power supply so the grounds are all connected.
            • nofoxN
              nofoxN
              nofox
              Hello again. I've soldered this two pull-ups resistors like @ArduiSens wrote before. Now I think the network works much much better but after 24 hours of using something hangs and i can't turn of the light with buttons and with OpenHab also. I think the gateway freezing because after I reset only gateway all starts to work normal when i'm pressing wall switches. I need to reboot controller because after gateway reset OpenHab won't communicate with the gateway... Please take a look at my gateway sketch:
              // #define MY_RADIO_NRF24
              // #define MY_RADIO_RFM69
              #define MY_NODE_ID 0
              #define MY_RS485
              // #define MY_GATEWAY_MQTT_CLIENT
              #define MY_GATEWAY_W5100
              // #define MY_W5100_SPI_EN 4
              // radio on the same spi bus.
              #define MY_SOFTSPI
              // #ifndef MY_RF24_CE_PIN
              // #define MY_RF24_CE_PIN 5
              // #endif
              // #ifndef MY_RF24_CS_PIN
              // #define MY_RF24_CS_PIN 6
              // #endif
              // Enable to UDP
              // #define MY_USE_UDP
              #define MY_IP_ADDRESS 192,168,0,66   // If this is disabled, DHCP is used to retrieve address
              #define MY_PORT 5003
              //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 70
              // #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
              // #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
              // Set MQTT client id
              // #define MY_MQTT_CLIENT_ID "mysensors-1"
              // Enable inclusion mode
              // #define MY_INCLUSION_MODE_FEATURE
              // #define MY_INCLUSION_MODE_DURATION 60
              // Set blinking period
              // Flash leds on rx/tx/err
              #if defined(MY_USE_UDP)
              #include <EthernetUdp.h>
              #include <Ethernet.h>
              gohanG 1 Reply Last reply
              • nofoxN nofox
                #define MY_RS485
                #define MY_SOFTSPI
                // #endif
                // #endif
                // Enable to UDP
                @nofox why are you using soft SPI? You don't have a nrf24 radio
                  nofoxN
                  nofoxN
                  nofox
                  wrote on last edited by nofox
                  #111
                  @gohan I'm using soft SPI ? Where ? I taught that there are
                  #define MY_SOFTSPI
                  so when #define MY_W5100_SPI_EN 4 is commented I'm using hardware SPI ? What should i change than ? Comment the whole #if .... part ??
                    Forget it, I was on mobile and couldn't see well the code. Do you have IDE, boards definitions up to date? Did you try latest version of mysensors in development branch?
                      nofoxN
                      nofoxN
                      nofox
                      @gohan I have IDE 1.6.11 and boards definition 1.6.11 because on newer boards definition I've got boot loop on gateway. I'm using 2.1.1 MySensors library. Maybe I should mention that I can ping my gateway without any problems, only rs485 part seems not responding..
                      • nofoxN
                        nofoxN
                        nofox
                        Hello again. After a week of thinking and hard work i finally got RS485 network working very close to what I want. I've done everything like it was mentioned here before. Fully bus-like network, termination only on both ends of line and pull-up and pull-down on the gateway. I also change MySensors library to newest 2.1 beta branch. All nodes working very good for last month but some times one node hanging and I can't control it via OpenHab or built in switch. I don't know what cause this behavior. I turn on watchdog timers in every nodes and theoretically when node hangs, watchdog should reboot arduino after 8 seconds. Practically it won't reboot my node.. It seems like the node don't really hangs but the communication stops.. Is it possible that one node can loose connection while other nodes on the same bus/wires working like a charm ?
                        rejoe2R 1 Reply Last reply
                        • nofoxN nofox
                          rejoe2R
                          rejoe2R
                          rejoe2
                          @nofox The problem you describe sounds pretty similar to my observations in this post.
                          There are also some suggestions how to solve this kind of trouble you may apply.
                          • nofoxN
                            nofoxN
                            nofox
                            Hi! It’s me again. I want to precise one thing. Are there anyone here who have succesful working RS485 network without any issues? We are talking here about issues but maybe someone have fully working sensors network?
                            • P
                              P
                              pjr
                              If some node hangs what happens if you recycle the power of rs485 transceiver only?
                              I'm just thinking could it be the protection of max485 that kicks in if there is two nodes sending exactly the same time.
                              • nofoxN
                                nofoxN
                                nofox
                                Hi! My problem still exist. I switched to newest MySensors Library and to HWSERIAL and some nodes acts the same as before... Now i'm thinking that maybe its related to DE_PIN 2 ?? Someone tried to switch to other pin for Enable function for RS485 ?? Now after almost a year I'm thinking about changing my transmission from wired RS485 to wireless nRF.. I choose RS485 because of its stability (thats what I taught over a year ago ). Now I think that RS485 its a piece of garbage..
                                • nofoxN
                                  nofoxN
                                  nofox
                                  Hi! I think I came up with the solution for all our problems but I don't know if it is worth and possible at all. The thing is that RS485 isn't a multimaster bus, thats what we all know. So the best option is to turn the gateway in to master and all other nodes to slaves. I'm thinking if there are any possibilities to make the gateway to ask nodes in the order one by one for its states (child states). The nodes can only talk to the gateway when the gateway ask for their states. This process should take place in endless loop in the highest possible speed (depending on the count of nodes in the network). I think that in this option the baud rate matters, cause higher baud rates makes the time of a single loop shorter minimizing the delay that may occur in the networks with many nodes. Maybe I'm reinventing the wheel now and this type of transmission needs to rewrite all MySensors protocols..
                                  wallyllamaW 1 Reply Last reply
                                  • nofoxN nofox
                                    wallyllamaW
                                    wallyllamaW
                                    wallyllama
                                    @nofox absolutely that is one of the problems. Polling as you describe could be a fix, another is having each node listen before transmitting, there is a (not mysensors) library that does that, CAN bus( a mutli master 485 comaptible bus) is another option. I think that running a common ground to all the rs485 adapters is also wise. This is all in theory as I havent wired up my home yet....
                                    P 1 Reply Last reply
                                    • wallyllamaW wallyllama
                                      P
                                      P
                                      pjr
                                      @wallyllama
                                      How would you describe this functionality in MySensors rs485 code?
                                      https://github.com/mysensors/MySensors/blob/f5ed26c778c18107d1516bd86704f8c8f99ff571/hal/transport/RS485/MyTransportRS485.cpp#L246
                                      If I'm reading the code correctly it is exactly reading the bus and making sure no other node is sending before sending anything.
                                      The place where collision can happen is those 5 microseconds what the node is waiting to get driver tx enabled pin up.
                                      So the collision avoidance is already there. So what MyS R485 transport is missing is collision detection and recovery from collision.
                                      Its disadvantage is small payload size.
                                      @nofox Its quite like how the Modbus works. By polling.
                                      I think there is some better ways to do that. Check these out from google:
                                      • RS-485 Token ring
                                      • uLAN
                                      • RS-485 RRP (Round Robin Protocol)
                                      • CSMA/CA
                                      • wallyllamaW
                                        wallyllamaW
                                        wallyllama
                                        I think you have found most everything that I have. Something akin to csmacd is what I was thinking. Listen, transmit, back off for random time if a collision still happens. Of course full duplex rs485 is another option, hard to find off the shelf modules.
                                        I think this is the library I had found before.
                                        https://github.com/MichaelJonker/HardwareSerialRS485/wiki
                                        • wallyllamaW
                                          wallyllamaW
                                          wallyllama
                                          https://github.com/dukelec/cdbus_doc
                                          This one has some is interesting, not sure if it does multi master or not. There are a few projects that seem to do multimaster/collision avoidance, the trick it to find one with low enough overhead and automatically retransmits if there is a failure, and for this project isolates this enough that my sensors doesnt need restructuring.
                                          Good wiring is crucial so you can use higher speeds. The common ground wire in addition to the differential signals seems almost required.
                                          With your input, this post could be even better πŸ’—
