  2. Announcements
  3. πŸ’¬ Building a wired RS485 sensor network
164 Posts 33 Posters 79.9k Views 35 Watching
  • A ArduiSens
    Nofox,
    1. The 510 ohm pull up and pull down resistors (between A (D+) and 5V / between B (D-) and ground) are usually mounted on the master side (which is your gateway). Theoretically it would be best to install it in the middle of your bus line.
    2. check if your power supply has enough power to feed all your nodes
    3. check that all the ground lines of your boards are connected with each other.
    nofoxN
    nofoxN
    nofox
    @ArduiSens Thanks for your reply! I have found few post here on MYS Forum about biasing rs485 line with pull up and pull down resistors and I will try to do this tomorrow. I'm using standard rs485 module from aliexpress on the gateway side. There are pullups and pulldowns there but they are two 10k resistors, I will change them to 510 as you mentioned.
    All of my wired sensors, gateway and RPi are powered form 10A buffered power supply. I've checked voltage on every node. I have 5.25V on power supply pins in the middle of the line and 5.21 on both ends of line. I'm using one twisted pair for Vcc and one for GND. The bus is about 15 meter long form one end to another.
    As I mentioned above all of nodes are supplied from one power supply so the grounds are all connected.
    • nofoxN
      nofoxN
      nofox
      Hello again. I've soldered this two pull-ups resistors like @ArduiSens wrote before. Now I think the network works much much better but after 24 hours of using something hangs and i can't turn of the light with buttons and with OpenHab also. I think the gateway freezing because after I reset only gateway all starts to work normal when i'm pressing wall switches. I need to reboot controller because after gateway reset OpenHab won't communicate with the gateway... Please take a look at my gateway sketch:
      // #define MY_RADIO_NRF24
      // #define MY_RADIO_RFM69
      #define MY_NODE_ID 0
      // Enable RS485 transport layer
      #define MY_RS485
      // Define this to enables DE-pin management on defined pin
      #define MY_RS485_DE_PIN 2
      // Set RS485 baud rate to use
      // #define MY_GATEWAY_MQTT_CLIENT
      #define MY_GATEWAY_W5100
      // #define MY_W5100_SPI_EN 4
      // radio on the same spi bus.
      #define MY_SOFTSPI
      // #ifndef MY_RF24_CE_PIN
      // #define MY_RF24_CE_PIN 5
      // #endif
      // #ifndef MY_RF24_CS_PIN
      // #define MY_RF24_CS_PIN 6
      // #endif
      // Enable to UDP
      // #define MY_USE_UDP
      #define MY_IP_ADDRESS 192,168,0,66   // If this is disabled, DHCP is used to retrieve address
      #define MY_PORT 5003
      //#define MY_CONTROLLER_IP_ADDRESS 192, 168, 0, 70
      // #define MY_MQTT_PUBLISH_TOPIC_PREFIX "mygateway1-out"
      // #define MY_MQTT_SUBSCRIBE_TOPIC_PREFIX "mygateway1-in"
      // Set MQTT client id
      // #define MY_MQTT_CLIENT_ID "mysensors-1"
      // Enable inclusion mode
      // #define MY_INCLUSION_MODE_FEATURE
      // #define MY_INCLUSION_MODE_DURATION 60
      // Set blinking period
      // Flash leds on rx/tx/err
      #if defined(MY_USE_UDP)
      #include <EthernetUdp.h>
      #include <Ethernet.h>
      gohanG 1 Reply Last reply
      • nofoxN nofox
        #define MY_RS485
        #define MY_SOFTSPI
        // #endif
        // #endif
        // Enable to UDP
        @nofox why are you using soft SPI? You don't have a nrf24 radio
        nofoxN 1 Reply Last reply
          nofoxN
          nofoxN
          nofox
          wrote on last edited by nofox
          #111
          @gohan I'm using soft SPI ? Where ? I taught that there are
          #define MY_SOFTSPI
          so when #define MY_W5100_SPI_EN 4 is commented I'm using hardware SPI ? What should i change than ? Comment the whole #if .... part ??
            Forget it, I was on mobile and couldn't see well the code. Do you have IDE, boards definitions up to date? Did you try latest version of mysensors in development branch?
              nofoxN
              nofoxN
              nofox
              @gohan I have IDE 1.6.11 and boards definition 1.6.11 because on newer boards definition I've got boot loop on gateway. I'm using 2.1.1 MySensors library. Maybe I should mention that I can ping my gateway without any problems, only rs485 part seems not responding..
              • nofoxN
                nofoxN
                nofox
                Hello again. After a week of thinking and hard work i finally got RS485 network working very close to what I want. I've done everything like it was mentioned here before. Fully bus-like network, termination only on both ends of line and pull-up and pull-down on the gateway. I also change MySensors library to newest 2.1 beta branch. All nodes working very good for last month but some times one node hanging and I can't control it via OpenHab or built in switch. I don't know what cause this behavior. I turn on watchdog timers in every nodes and theoretically when node hangs, watchdog should reboot arduino after 8 seconds. Practically it won't reboot my node.. It seems like the node don't really hangs but the communication stops.. Is it possible that one node can loose connection while other nodes on the same bus/wires working like a charm ?
                rejoe2R 1 Reply Last reply
                • nofoxN nofox
                  rejoe2R
                  rejoe2R
                  rejoe2
                  @nofox The problem you describe sounds pretty similar to my observations in this post.
                  There are also some suggestions how to solve this kind of trouble you may apply.
                  • nofoxN
                    nofoxN
                    nofox
                    Hi! It’s me again. I want to precise one thing. Are there anyone here who have succesful working RS485 network without any issues? We are talking here about issues but maybe someone have fully working sensors network?
                    • P
                      P
                      pjr
                      If some node hangs what happens if you recycle the power of rs485 transceiver only?
                      I'm just thinking could it be the protection of max485 that kicks in if there is two nodes sending exactly the same time.
                      • nofoxN
                        nofoxN
                        nofox
                        Hi! My problem still exist. I switched to newest MySensors Library and to HWSERIAL and some nodes acts the same as before... Now i'm thinking that maybe its related to DE_PIN 2 ?? Someone tried to switch to other pin for Enable function for RS485 ?? Now after almost a year I'm thinking about changing my transmission from wired RS485 to wireless nRF.. I choose RS485 because of its stability (thats what I taught over a year ago ). Now I think that RS485 its a piece of garbage..
                        • nofoxN
                          nofoxN
                          nofox
                          Hi! I think I came up with the solution for all our problems but I don't know if it is worth and possible at all. The thing is that RS485 isn't a multimaster bus, thats what we all know. So the best option is to turn the gateway in to master and all other nodes to slaves. I'm thinking if there are any possibilities to make the gateway to ask nodes in the order one by one for its states (child states). The nodes can only talk to the gateway when the gateway ask for their states. This process should take place in endless loop in the highest possible speed (depending on the count of nodes in the network). I think that in this option the baud rate matters, cause higher baud rates makes the time of a single loop shorter minimizing the delay that may occur in the networks with many nodes. Maybe I'm reinventing the wheel now and this type of transmission needs to rewrite all MySensors protocols..
                          wallyllamaW 1 Reply Last reply
                          • nofoxN nofox
                            wallyllamaW
                            wallyllamaW
                            wallyllama
                            @nofox absolutely that is one of the problems. Polling as you describe could be a fix, another is having each node listen before transmitting, there is a (not mysensors) library that does that, CAN bus( a mutli master 485 comaptible bus) is another option. I think that running a common ground to all the rs485 adapters is also wise. This is all in theory as I havent wired up my home yet....
                            P 1 Reply Last reply
                            • wallyllamaW wallyllama
                              P
                              P
                              pjr
                              @wallyllama
                              How would you describe this functionality in MySensors rs485 code?
                              https://github.com/mysensors/MySensors/blob/f5ed26c778c18107d1516bd86704f8c8f99ff571/hal/transport/RS485/MyTransportRS485.cpp#L246
                              If I'm reading the code correctly it is exactly reading the bus and making sure no other node is sending before sending anything.
                              The place where collision can happen is those 5 microseconds what the node is waiting to get driver tx enabled pin up.
                              So the collision avoidance is already there. So what MyS R485 transport is missing is collision detection and recovery from collision.
                              Its disadvantage is small payload size.
                              @nofox Its quite like how the Modbus works. By polling.
                              I think there is some better ways to do that. Check these out from google:
                              • RS-485 Token ring
                              • uLAN
                              • RS-485 RRP (Round Robin Protocol)
                              • CSMA/CA
                              • wallyllamaW
                                wallyllamaW
                                wallyllama
                                I think you have found most everything that I have. Something akin to csmacd is what I was thinking. Listen, transmit, back off for random time if a collision still happens. Of course full duplex rs485 is another option, hard to find off the shelf modules.
                                I think this is the library I had found before.
                                https://github.com/MichaelJonker/HardwareSerialRS485/wiki
                                • wallyllamaW
                                  wallyllamaW
                                  wallyllama
                                  https://github.com/dukelec/cdbus_doc
                                  This one has some is interesting, not sure if it does multi master or not. There are a few projects that seem to do multimaster/collision avoidance, the trick it to find one with low enough overhead and automatically retransmits if there is a failure, and for this project isolates this enough that my sensors doesnt need restructuring.
                                  Good wiring is crucial so you can use higher speeds. The common ground wire in addition to the differential signals seems almost required.
                                  • K
                                    K
                                    kimot
                                    https://github.com/gioblu/PJON/wiki
                                    Some works for MySensors done:
                                    https://forum.mysensors.org/topic/3977/transport-based-on-single-wire-pjon-protocol
                                    • K
                                      K
                                      kimot
                                      But PJON uses completely sw bit by bit sending or HW sending with bad bus arbitration.
                                      My idea - combination CAN bus like arbitration and UART message sending.
                                      With ACK possibility.
                                      Time T1 ( two bytes send time for example )
                                      Node sends message and waits T1 time for ACK.
                                      Receiving node must send ACK within T1 interval.
                                      Node, witch needs send message listens bus.
                                      BUT not by HW UART or SoftwareSerial - use directo IO operation.
                                      If recognize bus free time greater then T1, it start sending its own ID.
                                      BUT again not by HW UART or SoftwareSerial - but bit by bit by direct IO pin operation.
                                      And listen if bit I am sending is bit I am receiving.
                                      If not - it means, that other node with higher priority ( lower ID ) is sending - then immediately stop sending other bit and wait for next bus free T1 interval.
                                      If yes - bus is free for me end send my message normally by UART ( HW or SW, maybe with 9 bit addressing support - time less than T1 between characters allowed).
                                      Wait max T1 time for ACK.
                                      CAN bus driver usage TJA 1050 or MCP2551 - no DE RE pins.
                                      • A
                                        Andreas Sieber
                                        I have the problem that I always get this error: !TSM:FPAR:NO REPLY
                                        Once it worked briefly yesterday.
                                        What have I tried everything?
                                        All hardware exchanged - without success.
                                        Now I have just written two small scripts that send RS485 back and forth. without problems. So wiring has to fit. I spent then in the serial montior the data which the node sends me, there comes some. Then I once tried to display the data that sends the GW, because nothing comes.
                                        Does anyone have an idea why my GW does not answer?
                                        • A Andreas Sieber
                                          @andreas-sieber could you post the debug output from the node and the gateway?
                                          With your input, this post could be even better πŸ’—
