  3. SCT-013-030 Energy Meter
35 Posts 15 Posters 40.0k Views 25 Watching
  • john7845J
    john7845J
    john7845
    Hello, now with the new code I get this error:
    Arduino: 1.6.9 (Windows 10), Board: "Arduino/Genuino Uno"
    C:\Users\LENOVO\Desktop\arduino_code\Voltage_sensor_5\Voltage_sensor_5.ino:58:19: fatal error: DHT.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    Talat KeleşT 1 Reply Last reply
    • john7845J john7845
      exit status 1
      Talat KeleşT
      Talat KeleşT
      Talat Keleş
      @john7845
      Error is related to missing library of DHT. If you will use DHT temperature/humidity sensor in your circuit, you should add DHT library to your Sketchbook/libraries folder. If you don't use that sensor, clear or comment out dht related codes in sketch.
      • john7845J
        john7845J
        john7845
        I use this code just to see if the current sensor works, but I get 0.0 on the serial! What am I doing wrong?
        ReadAnalogVoltage
        Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
        Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
        Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
        This example code is in the public domain.
        // the setup routine runs once when you press reset:
        // initialize serial communication at 9600 bits per second:
        Serial.begin(9600);
        // the loop routine runs over and over again forever:
        // read the input on analog pin 0:
        int sensorValue = analogRead(A0);
        // Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
        float voltage = sensorValue * (1.0 / 1023.0);
        // print out the value you read:
        Serial.println(voltage);
        • john7845J
          john7845J
          john7845
          Someone??
            Someone??
            @john7845 Try printing the value of sensorValue:
            Serial.println(sensorValue);
            • john7845J
              john7845J
              john7845
              Again, I take zeros.
              • meanmrgreenM
                meanmrgreenM
                meanmrgreen
                Sorry for nuub question but can you use a pro mini 3.3 för this?
                Or do i need a nano or pro mini 5v?
                • meanmrgreenM meanmrgreen
                  Talat KeleşT
                  Talat KeleşT
                  Talat Keleş
                  wrote on last edited by Talat Keleş
                  #28
                  @meanmrgreen
                  Sure you can use 3.3v for this. If you are using sct-013-000 version, adjust your burden according to
                  Burden Resistor (ohms) = (AREF * CT TURNS) / (2√2 * max primary current)
                  where Aref =3.3 (or at worst case, it's lower than 3.3V- if battery powered)
                  Also don't forget to change calibration which is
                  Current Calibration Constant = CT TURNS / burden resistor
                  • B
                    B
                    Bill Thomson
                    One thing to keep in mind with this configuration: you're not actually measuring true power. Rather by not using a voltage reference, you're calculating apparent power, which is measured in VA (Volt Amps) vice Watts.
                    For resistive loads, apparent power and real power are the same, or very nearly so. But with reactive loads, e.g. motors, computer power supplies, compact flourescent or LED lamps, etc. they will differ considerably.
                    • Suresh MaliS
                      Suresh MaliS
                      Suresh Mali
                      Hi @patrick-schaerer ,
                      I got my setup running and was trying your code.
                      I was testing this code on my AC unit which has 1600W max consumption. When I first ran it always reported a value of around 270W even when the AC unit was off from mains and in running condition it reported around 750W with compressor on and around 250W with compressor off.
                      I adjusted the value on line
                      emon1.current(ANALOG_INPUT_SENSOR, 30);             // Current: input pin, calibration
                      Tried values from 10 to 111(default as per emon lib) to calibrate it to report 0 in off condition. finally at 10 it reported zero but now when the AC is on it reports 270W max.
                      Could you please help me figure out where the problem could be. Thanks
                      • D
                        dakipro
                        Thank for sharing the code and schematics, I cannot get it to run however, I always get 0 value whatever I do. Anyone has a suggestion about how to test this sensor the easiest way?
                        I have sct 013 030 sensor, and I connected it using the schematics provided here, I tried even the most basic examples I could find using EmonLib, I tried some basic examples using analog read and what not, but nothing seemed to work properly, I would always get either 0 or some fixed value.
                        I am connecting "first" and "last" conneciton on 3.5mm jack, but I also tried all combinations, and nothing seems to make a diffference.
                        I am using two resistors of 20Kohm as splitters, I am getting 2.43v between both side of them (using nano on 5V).
                        I am wrapping the module around the cable of the water cooker for example, which is 1.5KW, but values never change at all. It is either 0 or some max value (46A f.eks.) either with or without the load.
                        I was trying both nano and pro mini, same thing happens. Checked the circuit and connection between components several times.
                        This is the simplest code I found on the internet (not even mysensorized)
                        	Serial.begin(9600);
                        	analogReference(INTERNAL);
                        	//analogReference(INTERNAL1V1); //solo Arduino Mega
                        	float Irms=get_corriente(); //Corriente eficaz (A)
                        	float P=Irms*220.0; // P=IV (Watts)
                        	Serial.print("Irms: ");
                        	Serial.print(Irms,3);
                        	Serial.print("A, Potencia: ");
                        	Serial.print(P,3);
                        	Serial.println("W");
                        	//delay(100);
                        float get_corriente()
                        	float voltajeSensor;
                        	float corriente=0;
                        	float Sumatoria=0;
                        	long tiempo=millis();
                        	int N=0;
                        	while(millis()-tiempo<500)//Duración 0.5 segundos(Aprox. 30 ciclos de 60Hz)
                        		voltajeSensor = analogRead(A0) * (1.1 / 1023.0);////voltaje del sensor
                        		corriente=voltajeSensor*30.0; //corriente=VoltajeSensor*(30A/1V)
                        		Sumatoria=Sumatoria+sq(corriente);//Sumatoria de Cuadrados
                        		N=N+1;
                        		delay(1);
                        	Sumatoria=Sumatoria*2;//Para compensar los cuadrados de los semiciclos negativos.
                        	corriente=sqrt((Sumatoria)/N); //ecuación del RMS
                        	return(corriente);
                        Could it be that here in Norway we use two "phases" in the house? (or I could be wrong here either).
                        What is the most easy "idiot" proof way of testing this and getting some values? What could I be doing wrong?
                        Should I just order another sensor, can this "simple" sensor even be wrong?
                        Any clues, anyone?
                        • Lawrence HelmL
                          Lawrence HelmL
                          Lawrence Helm
                          I never got this going, have to play around with it again, but one thing I did do wrong was put the clip around both wires, instead of just the positive. I.e. putting it around + and - will give 0.
                          • D
                            dakipro
                            Ok so it will not work around both wires?
                            You can not clamp it around extension cable and measure "something"?
                            I basically just want to detect if stove is on or off, i was hoping to see at least a blip or anything really, can leave without actual numbers..
                            • D
                              dakipro
                              After some research I realized that this cannot work with two wires as they cancel each other.
                              After some googling I have found this https://moderndevice.com/product/a1324-hall-effect-sensor/ in description they mention that it can do what I want, to detect if appliance is on or off even if two wires are in close proximity. They mention that you could detect 100W, although I am planning to monitor if stove is on or off, which is I assume more then 100w.
                              They also have more precise "boosted" version that is more precise https://moderndevice.com/product/current-sensor/ but I think I do not need it for now.
                              • P patrick schaerer
                                I alread updated to MySensors 2.0
                                This is the update code:
                                I also edited the first post.
                                 * EnergyMeterSCT by Patrick Schaerer
                                 * This Sketch is a WattMeter used with a SCT-013-030 non invasive PowerMeter
                                 * see documentation for schematic
                                 * Special thanks to Surge, who optimized my code.
                                 * updated to mySensors Library 2.0
                                #define MY_REPEATER_FEATURE
                                #include <EmonLib.h>
                                #define ANALOG_INPUT_SENSOR 1  // The digital input you attached your SCT sensor.  (Only 2 and 3 generates interrupt!)
                                //#define INTERRUPT DIGITAL_INPUT_SENSOR-2 // Usually the interrupt = pin -2 (on uno/nano anyway)
                                EnergyMonitor emon1;
                                MyMessage wattMsg(CHILD_ID,V_WATT);
                                MyMessage kwhMsg(CHILD_ID,V_KWH);
                                MyMessage msgKWH(CHILD_ID,V_VAR1);
                                unsigned long SLEEP_TIME = 60000 - 3735; // sleep for 60 seconds (-4 seconds to calculate values)
                                float wattsumme = 0;
                                float kwh = 0;
                                float wh = 0;
                                int minuten = 0;  //vorher 61
                                boolean KWH_received=false;
                                //Humidity Sensor Code
                                #define CHILD_ID_HUM 2
                                #define CHILD_ID_TEMP 3
                                #define HUMIDITY_SENSOR_DIGITAL_PIN 2
                                DHT dht;
                                float lastTemp;
                                float lastHum;
                                boolean metric = true;
                                //End of Humidity Sensor Code
                                  //energy clamp code
                                  //gw.begin(incomingMessage, AUTO, true,0);
                                  emon1.current(ANALOG_INPUT_SENSOR, 30);             // Current: input pin, calibration.
                                  double Irms = emon1.calcIrms(1480);  // initial boot to charge up capacitor (no reading is taken) - testing
                                  request(CHILD_ID,V_VAR1);
                                  //end of energy clamp code
                                sendSketchInfo("Energy Meter SCT013", "2.0");
                                present(CHILD_ID, S_POWER);
                                present(CHILD_ID_HUM, S_HUM);
                                  //process();
                                  //KWH reveived check
                                  if (!KWH_received) request(CHILD_ID,V_VAR1);
                                  // power used each minute
                                  if (minuten < 60) {
                                    double Irms = emon1.calcIrms(1480);  // Calculate Irms only
                                    if (Irms < 0.3) Irms = 0;
                                    long watt = Irms*240.0; // default was 230 but our local voltage is about 240
                                    wattsumme = wattsumme+watt;
                                    minuten++;
                                    Serial.print(watt);         // Apparent power
                                    Serial.print("W I= ");
                                    Serial.println(Irms);          // Irms
                                  // end power used each minute
                                  // hours KW reading
                                  if (minuten >= 60) {
                                    wh = wh + wattsumme/60;
                                    kwh = wh/1000;
                                    send(kwhMsg.set(kwh, 3)); // Send kwh value to gw
                                    send(msgKWH.set(kwh, 3)); // Send kwh value to gw
                                    wattsumme = 0;
                                    minuten = 0;
                                // end of hourly KW reading
                                // Humidity Sensor Code
                                 if (minuten == 15 || minuten == 30 || minuten == 45|| minuten == 60) {
                                    if (isnan(temperature)) {
                                      lastTemp = temperature;
                                    if (!metric) {
                                    Serial.print("T: ");
                                  if (isnan(humidity)) {
                                      lastHum = humidity;
                                      Serial.print("H: ");
                                      Serial.println(humidity);
                                 wait(SLEEP_TIME);
                                  if (message.type==V_VAR1) {
                                    kwh = message.getFloat();
                                    wh = kwh*1000;
                                    Serial.print("Received last KWH from gw:");
                                    Serial.println(kwh);
                                    //send(kwhMsg.set(kwh, 3)); // Send kwh value to gw
                                    KWH_received = true;
                                Hassan AnsariH
                                Hassan AnsariH
                                Hassan Ansari
                                @patrick-schaerer can I use same code file for measuring current only using sct-013-030 and at other end I'll use other sensor to read ac voltage and with the help of that I'll calculate power.
                                I'm new on this. Just start learning and I'm using esp32 instead of Arduino.
                                Please share your suggestion on this. It will really help me to learn .
