  3. Mysensorized Roomba
Mysensorized Roomba
18 Posts 9 Posters 9.1k Views 10 Watching
  • emkaE
    emkaE
    emka
    Hi Eoreh
    Maybe problem is in this line:
    digitalWrite(D3, HIGHT); delay(2);
    Did you defined HIGHT symbol?
    Actually I did it this way:
    void WakeUp()
      pinMode(DEVICE_DETECT_PIN, OUTPUT);
      digitalWrite(DEVICE_DETECT_PIN, HIGH);
      delay(1000);
      digitalWrite(DEVICE_DETECT_PIN, LOW);
      delay(1000);
    and it works flawlessly (Ihave other problem with hanging NRF24, but it is another case)
    • E
      E
      Eoreh
      wrote on last edited by Eoreh
      Hi !
      My bad. I type mistake in post on forum. In code is good version. Of course You have right should be "HIGH"
      But You give me some idea on "problem in line D3" . I plugin my logic analizer (Saleae) and bingo!. In my egz. arduino this port was "broken" and dont give any change signal. I plugin into D5 and all works. :heart_eyes:
      I have one small issue / feature. After play song -> (in my code upper this song is Jingle bell for Chrismas) - roomba dont react on buttons. I think i will change this. Also statistic is very bad write. It's also for rewrite.
      Now i have to do more test, and next make looking good case for "node" on roomba. (cos mother-in-law - kill me :) ). But right now im very happy.
      Thank you @emka for your replay.
      • EmielAE
        EmielAE
        EmielA
        Hello Eoreh,
        I have a older Roomba and had the same idea to control it by my sensors. I only did a other approach.
        I did not mondify the Roomba with a serial interface and a MySensors node on the Roomba. But I did put a MySensors node on the docking station. And control the clean/spot/max command by imitation of the IR commands with a IR Led on the MySensors Node. And I also detect with my nod if the Roomba is in his dock charging or not. With this dock notification I measure the amount of time the Roomba is on its way before it returns to its dock charging (which is also a indication of the quality of the Roomba battery, short time away is a bad battery). I also measure the room temperature and humidity with the same node.
        If you want to know the code let me know I show you.
        With this approach you don't need to put anything on top of the Roomba which wil get broken off (is my experience) when its e.g. working under the bench.
        See the pictures in the link of this setup: alt text
        • E
          E
          Eoreh
          HI !.
          I have only 1 dock station and many rooms :). My roomba dont going "under the bench" so i dont have experience like yours with sensor on top.
          But will be interested looks for code in your approach so please show it.
          Thank You.
          • EmielAE
            EmielAE
            EmielA
            Eoreh,
            I used different pieces of code from different projects.and combined them to one sketch. I used some from this project : link text
            And the sketch from the MySensors Relay Actuator. I switch the Node/Relay on for about 10 seconds and then off. In the 10 seconds the IR sends the CLEAN command. With a LDR I detect if the Roomba dock led is on or off. So I detect if the Roomba is on its dock. Here under the code I hope it helps you.
            // Example sketch showing how to control physical relays.
            // This example will remember relay state even after power failure.
            #include <IRremote.h>
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define CHILD_ID_DOCK 5
            #define HUMIDITY_SENSOR_DIGITAL_PIN 4 // Temperatuur sensor and Humidity op pin 4 input
            #define DOCK_SENSOR_PIN 5 // Light sensor on pin 5 input
            unsigned long WAIT_TIME = 15000; // Wait time between reads (in milliseconds)
            IRsend irsend; // hardwired to pin 3; use a transistor to drive the IR LED for maximal range
            Bounce debouncer = Bounce();
            DHT dht;
            int oldValue=-1; //light sensor
            float lastTemp;
            float lastHum;
            boolean metric = true;
            MyMessage msgDock(CHILD_ID_DOCK,V_TRIPPED);
              // Setup the DOCK_SENSOR to input
              pinMode(DOCK_SENSOR_PIN,INPUT);
              debouncer.attach(DOCK_SENSOR_PIN);
              debouncer.interval(5);
              gw.sendSketchInfo("Temp Humidity and Roomba IR", "1.0");
              gw.present(CHILD_ID_DOCK, S_DOOR);
              // Fetch relay status
              for (int sensor=2, pin=RELAY_1; sensor<=NUMBER_OF_RELAYS;sensor++, pin++) {
                gw.present(sensor, V_LIGHT);
                pinMode(pin, OUTPUT);
                digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
              if (isnan(temperature)) {
                lastTemp = temperature;
                if (!metric) {
                Serial.print("T: ");
              if (isnan(humidity)) {
                  lastHum = humidity;
                  Serial.print("H: ");
                  Serial.println(humidity);
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue) {
                 // Send in the new value
                 gw.send(msgDock.set(value==HIGH ? 1 : 0));
                 oldValue = value;
              gw.wait(WAIT_TIME); //sleep a bit
              if (message.type==V_LIGHT) {
                 // Change relay state
            //     digitalWrite(message.sensor-1+RELAY_1, message.getBool()?RELAY_ON:RELAY_OFF);
                 roomba_send(136);  // Send "Clean"
                 // Store state in eeprom
            void roomba_send(int code)
              Serial.print("Sending Roomba code ");
              Serial.print(code);
              int length = 8;
              unsigned int raw[length*2];
              unsigned int one_pulse = 3000;
              unsigned int one_break = 1000;
              unsigned int zero_pulse = one_break;
              unsigned int zero_break = one_pulse;
              int arrayposition = 0;
              // Serial.println("");
              for (int counter = length-1; counter >= 0; --counter) {
                if(code & (1<<counter)) {
                  // Serial.print("1");
                  raw[arrayposition] = one_pulse;
                  raw[arrayposition+1] = one_break;
                else {
                  // Serial.print("0");
                  raw[arrayposition] = zero_pulse;
                  raw[arrayposition+1] = zero_break;
                arrayposition = arrayposition + 2;
              for (int i = 0; i < 3; i++) {
                irsend.sendRaw(raw, 15, 38);
                delay(50);
              Serial.println("");
              Serial.print("Raw timings:");
               for (int z=0; z<length*2; z++) {
               Serial.print(" ");
               Serial.print(raw[z]);
               Serial.print("\n\n");
            • E
              E
              Eawo
              Maybe this is off topic but I'm going to buy a roomba but it is so many versions. Will roomba 615 or 616 do the job or is the newer versions smarter cleaner? I have around 80kvd
              parachutesjP 1 Reply Last reply
              • E Eawo
                parachutesjP
                parachutesjP
                parachutesj
                @Eawo I do have a 581 and not 100% sure what has been changed on newer models. Maybe you ask in a roomba forum
                • parachutesjP parachutesj
                  parachutesjP
                  parachutesjP
                  parachutesj
                  All,
                  I did some updates also thanks to @Eoreh I updated my code a bit. Anyhow, no really news on software side but was able to fit it more or less completely inside of the Roomba.
                  1. I wanted to fit all inside and I think there is enough space but wanted to be able to disable it and thought about a dip-switch somewhere but then decided to have it connected via DIN as before. Means also no soldering on Roomba
                  2. finding a spot was easy:
                    There is enough space on the side of the bin. (In picture, the external charging port was already removed)
                  3. I soldered all together and decided to opt for a Nano instead of a Pro Mini due to the lack of 3.3V on board. I know radio might be better powered with a voltage regulator but the reception and reliability is not too important here. Anyhow not experienced any issues so far. I also used the SMD radio to save some extra space.
                    The voltage regulator has a heat sink mounted which is pointing where the charing port was and is getting some "fresh air" ;-)
                  4. all in place and ready to be closed again
                  5. closed without top plate
                  If it stops working or needs a reset, I only need to unplug and replug
                    All,
                    moskovskiy82
                    wrote on last edited by moskovskiy82
                    @parachutesj Mind posting your finished code?
                    Also wonder what is the correct MQTT payload to start for example cleaning?
                    Upon start i see the following
                    mys-out/15/255/3/0/11 MYS Roomba
                    mys-out/15/255/3/0/12 2.1
                    mys-out/15/0/0/0/3 Roomba-Stop
                    mys-out/15/1/0/0/3 Roomba-Dock
                    mys-out/15/2/0/0/3 Roomba-Clean
                    mys-out/15/3/0/0/3 Roomba-Spot
                    mys-out/15/4/0/0/3 Roomba-Max
                    mys-out/15/5/0/0/3 Roomba-Power
                    mys-out/15/6/0/0/3 Roomba-Play
                    mys-out/15/100/0/0/6 Roomba-Batt-Temp
                    mys-out/15/101/0/0/39 Roomba-Batt-Proc
                    mys-out/15/102/0/0/30 Roomba-Batt-Volt
                    mys-out/15/103/0/0/30 Roomba-Batt-mAH
                    mys-out/15/104/0/0/36 Roomba-Batt-CHt
                    mys-out/15/105/0/0/36 Roomba-Batt-CHs
                    But publishing to
                    mys-in/15/2/1/0/3
                    mys-in/15/2/1/0/2
                    with payload 1 doesn't do anything
                    • M moskovskiy82
                      But publishing to
                      mys-in/15/2/1/0/3
                      mys-in/15/2/1/0/2
                      parachutesjP
                      parachutesjP
                      parachutesj
                      @moskovskiy82 I did not change too much compared to @EmielA on the code. worked pretty good until I bought a new roomba recently. Haven't tried it on the 980 yet:
                      #define MY_REPEATER_FEATURE
                      #define CHILD_ID_BATT_TEMP          100  // Id of the 2nd msg1_3
                      #define CHILD_ID_BATT_PROC          101   // Id of the 2nd msg1_4
                      #define CHILD_ID_BATT_VOLT          102   // Id of the 2nd msg1_2
                      #define CHILD_ID_BATT_AH            103   // Id of the 2nd msg2_5
                      #define CHILD_ID_BATT_CHARGE_TYPE   104   // Id of the 2nd msg1_1
                      #define CHILD_ID_BATT_CHARGE_SOURCE 105   // Id of the 2nd msg2_2
                      #include <SoftwareSerial.h>
                      //#define RELAY_1  5  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
                      //#define NUMBER_OF_RELAYS 2 // Total number of attached relays
                      //#define RELAY_ON 1  // GPIO value to write to turn on attached relay
                      //#define RELAY_OFF 0 // GPIO value to write to turn off attached relay
                      #define NUMBER_OF_FUNCTION 7
                      #define NUMBER_OF_SENSORS 6
                      #define ROOMBA_READ_TIMEOUT 300
                      #define ROOMBA_WAKE_COUNT 10
                      int ddPin = 6;
                      int rxPin = 3;
                      int txPin = 4;
                      int ledPin = 13;
                      SoftwareSerial roomba(rxPin, txPin);
                      const char SWITCH_NAMES[NUMBER_OF_FUNCTION][14] = { "Roomba-Stop","Roomba-Dock","Roomba-Clean","Roomba-Spot","Roomba-Max","Roomba-Power","Roomba-Play" };
                      const char SENSORS_NAMES[NUMBER_OF_SENSORS][24] = { "Roomba-Batt-Temp","Roomba-Batt-Proc","Roomba-Batt-Volt", "Roomba-Batt-mAH" , "Roomba-Batt-CHt" , "Roomba-Batt-CHs" };
                      uint8_t buf[52];
                      boolean lowBattery = true; // Acts as a debounce
                      long battery_Current_mAh = 0;
                      long battery_Total_mAh = 0;
                      long battery_percent = 0;
                      boolean DeadBattery = false;
                      boolean FullBattery = true;
                      unsigned long chargingState = 0;
                      long voltage = 0;
                      long temp = 0;
                      long OiMode = 0;
                      long ChargeSource = 0;
                      long sensorfrequency = 300000; // 300000 = 5 min - frequency the sensors are read
                      long lastsensorread = 0; // when were the sensors read the last time
                      unsigned long lastsensorssend = 0;
                      const char ChargeTypes[6][34] = { "Not charging","Reconditioning Charging","Full Charging","Trickle Charging","Waiting","Charging Fault Condition" };
                      const char OiTypes[4][14] = { "Off","Passive","Safe","Full" };
                      int packetSizes[58] = {
                          0,0,0,0,0,0, //1-6
                          1,1,1,1,1,1,1,1,1,1,1,1, //7-18
                          2,2, //19-20
                          1, //21
                          2,2, //22-23
                          1, //24
                          2,2,2,2,2,2,2, //25-31
                          1, //32
                          2, //33
                          1,1,1,1,1, //34-38
                          2,2,2,2,2,2, //39-44
                          1, //45
                          2,2,2,2,2,2, //46-51
                          1,1, //52-53
                          2,2,2,2, //54-57
                          1 //58
                      #define bumpright (sensorbytes[0] & 0x01)
                      #define bumpleft  (sensorbytes[0] & 0x02)
                      MyMessage msg1_3(CHILD_ID_BATT_TEMP, V_TEMP); //status of Temperature
                      MyMessage msg1_4(CHILD_ID_BATT_PROC, V_PH); //status of Charge [%]
                      MyMessage msg1_2(CHILD_ID_BATT_VOLT, V_VOLTAGE); //status of Voltage
                      MyMessage msg2_5(CHILD_ID_BATT_AH, V_CURRENT); //status of mAH
                      MyMessage msg1_1(CHILD_ID_BATT_CHARGE_TYPE, V_TEXT); //status of charget type
                      MyMessage msg2_2(CHILD_ID_BATT_CHARGE_SOURCE, V_TEXT); //status of charger source
                          pinMode(ddPin, OUTPUT);
                          digitalWrite(ddPin, LOW);
                          while (!Serial) {
                              ; // wait for serial port to connect. Needed for native USB port only
                          roomba.begin(115200);
                          //Serial.println("Sending start command...");
                          //delay(1000);
                          //// set up ROI to receive commands
                          defsongs();
                          delay(500);
                          rstop();
                          Serial.println("Ready to go!");
                          sendSketchInfo("Roomba", "1.2");
                          for (int sensor = 0; sensor < NUMBER_OF_FUNCTION; sensor++) {
                              present(sensor, S_BINARY, SWITCH_NAMES[sensor]);
                              delay(100);
                          present(CHILD_ID_BATT_TEMP, S_TEMP, SENSORS_NAMES[0]); delay(100);
                          present(CHILD_ID_BATT_PROC, S_WATER_QUALITY, SENSORS_NAMES[1]); delay(100);
                          present(CHILD_ID_BATT_VOLT, S_MULTIMETER, SENSORS_NAMES[2]);    delay(100);
                          present(CHILD_ID_BATT_AH, S_MULTIMETER, SENSORS_NAMES[3]);  delay(100);
                          present(CHILD_ID_BATT_CHARGE_TYPE, S_INFO, SENSORS_NAMES[4]); delay(100);
                          present(CHILD_ID_BATT_CHARGE_SOURCE, S_INFO, SENSORS_NAMES[5]); delay(100);
                          unsigned long now = millis();
                          if (now > lastsensorssend + sensorfrequency)
                              readsensors();
                              lastsensorssend = now;
                          int mySensor = message.sensor;
                          int myComand = message.getBool();
                          //Serial.print(message.sensor-1+RELAY_1);
                          if (mySensor == 0) {
                            if (myComand == 1) {
                              Serial.println("Clean");
                              //clean();
                              rcommand(135);
                            else {
                              Serial.println("Stopp1");
                              //halt();
                              rstop();
                          if (mySensor == 1) {
                              Serial.println("dock");
                              //dock();
                              rcommand(143);
                            else {
                              Serial.println("Stopp2");
                              //halt();
                              rstop();
                          if (mySensor == 2) {
                              Serial.println("song");
                              //dock();
                              rcommand(141);
                              rsong(0);
                            else {
                              //halt();
                              rstop();
                      void halt() {
                        roomba.write(131);  // SAFE
                        byte j = 0x00;
                        roomba.write(137);
                        roomba.write(j);
                        roomba.write(j);
                        roomba.write(j);
                        roomba.write(j);
                      void dock() {
                        delay(1000);
                        roomba.write(143);
                      void clean() {
                        delay(1000);
                        roomba.write(135);
                      void rstop() {
                          if (rwakeup()) {
                              roomba.write(128);  delay(100);
                              roomba.write(131);  delay(100);
                              roomba.write(137);  delay(100);
                              byte j = 0x00;
                              roomba.write(j); delay(100);
                              roomba.write(128);
                      void rsong(int b) {
                          roomba.write(b); delay(100);
                      void rcommand(int command) {
                          if (rwakeup()) {
                              roomba.write(command);
                      void play(char note, int rlong) {
                          roomba.write(rnote(note));  delay(10);  roomba.write(64 / rlong);   delay(10);
                      bool rwakeup() {
                          bool ret = getSensors(6, buf, 52);
                          Serial.print("wakeup: ");
                          Serial.print(ret);
                          if (!ret) {
                              for (int ii = 1; ii < ROOMBA_WAKE_COUNT; ii++)
                                  for (int jj = 0; jj < 3; jj++) {
                                      digitalWrite(ddPin, HIGH); delay(10);
                                      digitalWrite(ddPin, LOW); delay(2);
                                  delay(100);
                                  roomba.write(128);
                                  if (getSensors(6, buf, 52)) {
                                      ret = true;
                                  Serial.print("-");
                          Serial.println(ret);
                          return ret;
                      bool getSensors(uint8_t packetID, uint8_t* dest, uint8_t len) {
                          roomba.write(142);
                          delay(100);
                          roomba.write(packetID);
                          delay(100);
                          return getData(dest, len);
                      bool getData(uint8_t* dest, uint8_t len)
                          while (len-- > 0)
                              unsigned long startTime = millis();
                              while (!roomba.available())
                                  // Look for a timeout
                                  if (millis() > startTime + ROOMBA_READ_TIMEOUT)
                                      return false; // Timed out
                              *dest++ = roomba.read();
                          return true;
                      //for sensorgetting
                      int getPacketSize(int p) {
                          return packetSizes[p - 1];
                      int getPacketOffset(int p) {
                          int i = 0;
                          for (int s = 1; s < p; s++) {
                              i += getPacketSize(s);
                          return i;
                      //read sensors
                      void readsensors()
                              int off = 0;
                              // Battery Checks
                              off = getPacketOffset(21);
                              chargingState = buf[off + 0];
                              voltage = buf[off + 2] + 256 * buf[off + 1];
                              temp = buf[off + 5];
                              battery_Current_mAh = buf[off + 7] + 256 * buf[off + 6];
                              battery_Total_mAh = buf[off + 9] + 256 * buf[off + 8];
                              if (battery_Total_mAh == 0) battery_Total_mAh = 1;
                              int nBatPcent = battery_Current_mAh * 100 / battery_Total_mAh;
                              battery_percent = nBatPcent;
                              //Oi Mode
                              off = getPacketOffset(35);
                              OiMode = buf[off + 0];
                              //ChargeSource
                              off = getPacketOffset(34);
                              ChargeSource = buf[off + 0];
                              send(msg1_3.set(temp));  delay(100);
                              send(msg1_4.set(battery_percent));  delay(100);
                              send(msg1_2.set(round(voltage / 10), 1));  delay(100);
                              send(msg2_5.set(battery_Current_mAh));  delay(100);
                              send(msg1_1.set(ChargeTypes[chargingState]));  delay(100);
                              send(msg2_2.set(ChargeSource));  delay(100);
                              //send(msg2_5.set(chargingState));  // Send info value to gw
                              //send(msg2_5.set("charging state"));  // Send info value to gw
                              //send(msg2_5.set(battery_Total_mAh));  // Send info value to gw
                              //send(msg2_1.set(OiTypes[OiMode]));  // Send info value to gw
                              lastsensorread = millis();
                          else { send(msg1_1.set("roomba is off")); }  // Send info value to gw
                      void defsongs() {
                          uint8_t zero = 0;
                          roomba.write(128);  delay(100); roomba.write(131);  delay(100); //[128 131](Start the command stream and change roomba mode to "Safe" mode)
                          roomba.write(140);  delay(100); roomba.write(zero); delay(100); //[140 0](Start song definition and define the first song, song number 0)
                          roomba.write(25);   //[16](16 notes will be sent for song number 0)
                          play('E', 4);       //[76 16](play Mi sound for 1 / 4 seconds) // E
                          play('E', 4);
                          play('E', 2);
                          play('E', 4);
                          play('E', 4);
                          play('E', 2);       //[76 32](play Mi sound for 1 / 2 seconds)
                          play('E', 4);
                          play('G', 4);
                          play('C', 4);
                          play('D', 4);
                          play('E', 1);
                          play('F', 4);
                          play('F', 4);
                          play('F', 2);
                          play('F', 4);
                          play('E', 4);
                          play('E', 2);
                          play('E', 4);
                          play('D', 4);
                          play('D', 4);
                          play('E', 4);
                          play('D', 1);
                          delay(100);
                          roomba.write(128);
                      int rnote(char note) {
                          int command = 31;
                          switch (note) {
                          case 'C': command = 72; break;
                          case 'D': command = 74; break;
                          case 'E': command = 76; break;
                          case 'F': command = 77; break;
                          case 'G': command = 79; break;
                          return command;
                      Z 1 Reply Last reply
                        wrote on last edited by gohan
                        Just a question, but wouldn't it be an esp8266 a more compact solution? (Not to mention the quick ota programming) Or the roomba is running 5v serial output?
                          parachutesjP
                          parachutesjP
                          parachutesj
                          @gohan ESP is probably a good alternative. but then again you could also buy an after market wireless module for your roomba.
                          I am not sure about the serial output, but I think it is 5v.
                          but there is plenty of space for a nano or pro mini. wemos mini or nodemcu should also fit
                            moskovskiy82
                            ESP is the best solution although couldn't find the code with sensors (only clean/dock commands). I recently made a post on HomeAssistant forum - how wemos D1 fits nicely inside. You only need a buck converter and 4 cat5 wires soldered. And 5V serial output is not such a big problem as you need a voltage divider only on rx pin (didn't put it)
                            P.S. But then one of those "machine revolt weeks happened" so my esproomba didn't respond and then i burned it down. Next day my RPi3 went down with HA and lots of goodies. And today ESXi...
                              Oh man, that sucks a lot. Best luck for your disaster recovery
                              PS if everything you are touching is failing, be careful when you are going to pee 😂
                                int ddPin = 6;
                                int rxPin = 3;
                                int txPin = 4;
                                int ledPin = 13;
                                uint8_t buf[52];
                                long voltage = 0;
                                long temp = 0;
                                long OiMode = 0;
                                    0,0,0,0,0,0, //1-6
                                    2,2, //19-20
                                    1, //21
                                    2,2, //22-23
                                    1, //24
                                    1, //32
                                    2, //33
                                    1,1,1,1,1, //34-38
                                    1, //45
                                    1,1, //52-53
                                    2,2,2,2, //54-57
                                    1 //58
                                    while (!Serial) {
                                    //delay(1000);
                                    defsongs();
                                    delay(500);
                                    rstop();
                                        delay(100);
                                        readsensors();
                                        //clean();
                                        rcommand(135);
                                      else {
                                        //halt();
                                        rstop();
                                        //dock();
                                        rcommand(143);
                                      else {
                                        //halt();
                                        rstop();
                                        //dock();
                                        rcommand(141);
                                        rsong(0);
                                      else {
                                        //halt();
                                        rstop();
                                void halt() {
                                  byte j = 0x00;
                                  roomba.write(137);
                                  roomba.write(j);
                                  roomba.write(j);
                                  roomba.write(j);
                                  roomba.write(j);
                                void dock() {
                                  delay(1000);
                                  roomba.write(143);
                                void clean() {
                                  delay(1000);
                                  roomba.write(135);
                                void rstop() {
                                    if (rwakeup()) {
                                        byte j = 0x00;
                                        roomba.write(128);
                                void rsong(int b) {
                                    if (rwakeup()) {
                                bool rwakeup() {
                                    Serial.print(ret);
                                    if (!ret) {
                                            delay(100);
                                            roomba.write(128);
                                                ret = true;
                                            Serial.print("-");
                                    return ret;
                                    roomba.write(142);
                                    delay(100);
                                    delay(100);
                                    while (len-- > 0)
                                    return true;
                                //for sensorgetting
                                    int i = 0;
                                    return i;
                                //read sensors
                                void readsensors()
                                        int off = 0;
                                        // Battery Checks
                                        //Oi Mode
                                        //ChargeSource
                                void defsongs() {
                                    uint8_t zero = 0;
                                    play('E', 4);
                                    play('E', 2);
                                    play('E', 4);
                                    play('E', 4);
                                    play('E', 4);
                                    play('G', 4);
                                    play('C', 4);
                                    play('D', 4);
                                    play('E', 1);
                                    play('F', 4);
                                    play('F', 4);
                                    play('F', 2);
                                    play('F', 4);
                                    play('E', 4);
                                    play('E', 2);
                                    play('E', 4);
                                    play('D', 4);
                                    play('D', 4);
                                    play('E', 4);
                                    play('D', 1);
                                    delay(100);
                                    roomba.write(128);
                                    int command = 31;
                                    switch (note) {
                                    return command;
                                Z
                                Z
                                zen85
                                wrote on last edited by zen85
                                int ddPin = 6;
                                int rxPin = 3;
                                int txPin = 4;
                                int ledPin = 13;
                                uint8_t buf[52];
                                long voltage = 0;
                                long temp = 0;
                                long OiMode = 0;
                                    0,0,0,0,0,0, //1-6
                                    2,2, //19-20
                                    1, //21
                                    2,2, //22-23
                                    1, //24
                                    1, //32
                                    2, //33
                                    1,1,1,1,1, //34-38
                                    1, //45
                                    1,1, //52-53
                                    2,2,2,2, //54-57
                                    1 //58
                                    while (!Serial) {
                                    //delay(1000);
                                    defsongs();
                                    delay(500);
                                    rstop();
                                        delay(100);
                                        readsensors();
                                        //clean();
                                        rcommand(135);
                                      else {
                                        //halt();
                                        rstop();
                                        //dock();
                                        rcommand(143);
                                      else {
                                        //halt();
                                        rstop();
                                        //dock();
                                        rcommand(141);
                                        rsong(0);
                                      else {
                                        //halt();
                                        rstop();
                                void halt() {
                                  byte j = 0x00;
                                  roomba.write(137);
                                  roomba.write(j);
                                  roomba.write(j);
                                  roomba.write(j);
                                  roomba.write(j);
                                void dock() {
                                  delay(1000);
                                  roomba.write(143);
                                void clean() {
                                  delay(1000);
                                  roomba.write(135);
                                void rstop() {
                                    if (rwakeup()) {
                                        byte j = 0x00;
                                        roomba.write(128);
                                void rsong(int b) {
                                    if (rwakeup()) {
                                bool rwakeup() {
                                    Serial.print(ret);
                                    if (!ret) {
                                            delay(100);
                                            roomba.write(128);
                                                ret = true;
                                            Serial.print("-");
                                    return ret;
                                    roomba.write(142);
                                    delay(100);
                                    delay(100);
                                    while (len-- > 0)
                                    return true;
                                //for sensorgetting
                                    int i = 0;
                                    return i;
                                //read sensors
                                void readsensors()
                                        int off = 0;
                                        // Battery Checks
                                        //Oi Mode
                                        //ChargeSource
                                void defsongs() {
                                    uint8_t zero = 0;
                                    play('E', 4);
                                    play('E', 2);
                                    play('E', 4);
                                    play('E', 4);
                                    play('E', 4);
                                    play('G', 4);
                                    play('C', 4);
                                    play('D', 4);
                                    play('E', 1);
                                    play('F', 4);
                                    play('F', 4);
                                    play('F', 2);
                                    play('F', 4);
                                    play('E', 4);
                                    play('E', 2);
                                    play('E', 4);
                                    play('D', 4);
                                    play('D', 4);
                                    play('E', 4);
                                    play('D', 1);
                                    delay(100);
                                    roomba.write(128);
                                    int command = 31;
                                    switch (note) {
                                    return command;
                                i love this project. i am the owner of a roomba 620 and hooked it up to a arduino-mega. putting "clean()" in the code does what it should and the radiomodules are working fine. but it seems that i dont get values from the sensors and so nothing is showing up in homeassistant... :(
                                i checked the wiring about 5 times already and since starting for example "clean()" works i think it is a different issue...
                                did anyone else try this and ran into the same problem?
                                • B
                                  B
                                  banda banda
                                  Banned
                                  (spam links removed by moderator)
