  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
    @rejoe2 the repeater feature is disabled by default, so Dick must have activated it by a define.
    DickD
    DickD
    Dick
    @mfalkvidd For your info, I started the sketch cleareeprom to clear my Nano, loaded the script mentioned already and the log I posted is the same so the log must fit the sketch for the DallasTemperatureSimple. The repeater is activated or is it better to turn it off?
    • DickD Dick
      #96
      @Dick the repeater feature is turned off by default so there is something very fishy going on.
      Have you modified any of the MySensors library files?
      DickD 1 Reply Last reply
      • rejoe2R rejoe2
        @Dick Besides the inclusion mode, in FHEM one also has to activate a feature called "autocreate". Is there a comparable routine, and in case if: did you turn it on?
        If you have a look in your domoticz log, there most likely appear further trials to register, or not?
        DickD
        DickD
        Dick
        @rejoe2 What I see in the Log of Domoticz is that all the nodes are registered and are visible in Black the only blue one is only the Dalles node
        2017-08-19 12:44:48.339 MySensors: Node: 3, Sketch Name: Relay
        2017-08-19 12:44:48.340 MySensors: Node: 3, Sketch Version: 1.0
        2017-08-19 12:47:28.520 MySensors: Node: 48, Sketch Name: Temperature Sensor
        2017-08-19 12:47:28.530 MySensors: Node: 48, Sketch Version: 1.2
        2017-08-19 12:48:00.005 (GW Mysensors) Light/Switch (Voor Gor Pir)
        2017-08-19 12:48:39.405 MySensors: Node: 48, Sketch Name: Temperature Sensor
        2017-08-19 12:48:39.405 MySensors: Node: 48, Sketch Version: 1.2
        2017-08-19 12:49:36.059 MySensors: Node: 48, Sketch Name: Temperature Sensor
        2017-08-19 12:49:36.060 MySensors: Node: 48, Sketch Version: 1.2
        2017-08-19 12:51:47.939 MySensors: Node: 12, Sketch Name: Temperature Sensor
        2017-08-19 12:51:47.939 MySensors: Node: 12, Sketch Version: 1.2
        2017-08-19 12:51:54.329 MySensors: Node: 12, Sketch Name: Temperature Sensor
        2017-08-19 12:51:54.330 MySensors: Node: 12, Sketch Version: 1.2
        2017-08-19 12:54:56.992 (GW Mysensors) Light/Switch (Serre IRbui)
        2017-08-19 12:55:44.429 MySensors: Node: 12, Sketch Name: Temperature Sensor
        2017-08-19 12:55:44.440 MySensors: Node: 12, Sketch Version: 1.2
          DickD
          DickD
          Dick
          @mfalkvidd I changed the dalles lib with an older one, because in a disussion a wile ago it was advised to get it working. Now this modified Sketch is available I replaced the dalles lib again the latest one. For the rest nothing.
          • DickD Dick
            #99
            @Dick this part
            2201 !MCO:SLP:REP
            of the initial log you posted says that the node cannot sleep because it is a repeater.
            This part of the sketch:
              sleep(conversionTime);
            explains that if the node is a repeater, the sleep call must be replaced by wait. If it is not replaced, the temperature sensors will not be ready when getTemp... is called, so the node will not send any values. Domoticz only lists sensors that have sent a value.
            DickD 2 Replies Last reply
              @Dick this part
              2201 !MCO:SLP:REP
              DickD
              DickD
              Dick
              @mfalkvidd I chaned the Sleep into Wait but the same log in both Domoticz and on my Arduino. I thought it was an easy go but it appear not to be.
              rejoe2R mfalkviddM 2 Replies Last reply
              • DickD Dick
                rejoe2R
                rejoe2R
                rejoe2
                @Dick Did you change it at both places ( sleep(conversionTime);)?
                • rejoe2R rejoe2
                  DickD
                  DickD
                  Dick
                  @rejoe2 Yes on both location I replaced the sleep into a wait
                    @Dick this part
                    2201 !MCO:SLP:REP
                    DickD
                    DickD
                    Dick
                    @mfalkvidd In the Arduino log he Sleep error is not i anymore so that is solved but still no new device in Domoticz
                    • DickD Dick
                      #104
                      @Dick if you get the same log on the Arduino as before changing to wait, the sketch upload must have failed. Perhaps your Arduino is broken?
                      Edit: Sorry, didn't see your last reply.
                      What does the node log say now?
                        DickD
                        DickD
                        Dick
                        @mfalkvidd Ths is what the log says
                        0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
                        3 MCO:BGN:BFR
                        6 TSM:INIT
                        7 TSF:WUR:MS=0
                        14 TSM:INIT:TSP OK
                        16 TSF:SID:OK,ID=12
                        18 TSM:FPAR
                        59 TSF:MSG:SEND,12-12-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                        1016 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                        1021 TSF:MSG:FPAR OK,ID=0,D=1
                        1804 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                        1851 TSF:MSG:READ,4-4-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                        2067 TSM:FPAR:OK
                        2068 TSM:ID
                        2069 TSM:ID:OK
                        2071 TSM:UPL
                        2075 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                        2087 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                        2093 TSF:MSG:PONG RECV,HP=1
                        2095 TSM:UPL:OK
                        2097 TSM:READY:ID=12,PAR=0,DIS=1
                        2102 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                        2111 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                        2119 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                        2128 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                        2144 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        2152 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                        2163 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                        2169 MCO:REG:REQ
                        2173 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                        2183 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                        2188 MCO:PIM:NODE REG=1
                        2190 MCO:BGN:STP
                        2192 MCO:BGN:INIT OK,TSP=1
                        • DickD Dick
                          3 MCO:BGN:BFR
                          6 TSM:INIT
                          7 TSF:WUR:MS=0
                          14 TSM:INIT:TSP OK
                          16 TSF:SID:OK,ID=12
                          18 TSM:FPAR
                          2067 TSM:FPAR:OK
                          2068 TSM:ID
                          2069 TSM:ID:OK
                          2071 TSM:UPL
                          2095 TSM:UPL:OK
                          2169 MCO:REG:REQ
                          2190 MCO:BGN:STP
                          #106
                          @Dick thanks. The node still doesn't send any values so that's why it does not show up in Domoticz.
                          My next step would be to manually add serial debug prints at end of setup(), presentation(), and almost everywhere in loop(), to see why it doesn't attempt to send.
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            Very strange.
                            I just mad the test and copied the code (out of your post above) to my IDE, compiled and uploaded: No problem, worked fine. Node gets registered by FHEM, sends ID once and Temp regularly as expected. For testing, I used just one DS18B20, but that shouldn't make any difference. (And MySensors lib version 2.2-beta, but that also shouldn't be an issue).
                            Btw: what kind of a GW you are using?
                            Recently, I came across a situation with a WiFi-GW that absolutely refused to accept new nodes. Using a serial one, everything was fine... Strange thing, too. (The GW itself was ok, there were several other nodes working without any communication problems. the new HW was also ok. Last, the channel was also correct, as all the existing nodes just switched over to the serial GW.... Reflashing that nasty thing also was no solution.)
                              DickD
                              DickD
                              Dick
                              I put some deug lines i it and after uploadig the sketch it stops here (wait conversationtime.)
                              setup done.
                              2191 MCO:BGN:INIT OK,TSP=1
                              fetch sensors.
                              fetch sensors.
                              fetch sensors.
                              fetch sensors.
                              fetch sensors.
                              fetch sensors.
                              fetch sensors.
                              • DickD Dick
                                setup done.
                                fetch sensors.
                                fetch sensors.
                                fetch sensors.
                                fetch sensors.
                                fetch sensors.
                                fetch sensors.
                                fetch sensors.
                                #109
                                @Dick could you try printing the value of numSensors in presentation()? (or in loop, it should have the same value there)
                                  DickD
                                  DickD
                                  Dick
                                  @mfalkvidd how can I manage that? sorr for the perhaps stupid qestion?
                                  • DickD Dick
                                    @Dick
                                    Serial.print("Number of attached sensors found by the DallasTemperature library: ");
                                    Serial.println(numSensors);
                                    rejoe2R DickD 2 Replies Last reply
                                      @Dick
                                      rejoe2R
                                      rejoe2R
                                      rejoe2
                                      @Dick best place would be after numSensors = ... in presentation()
                                      Just to mention that: The Arduino I used already had a node ID (I usually assign it manually). But your problem seems to be something completely different.
                                        @Dick
                                        DickD
                                        DickD
                                        Dick
                                        @mfalkvidd I tried it in Presentation() and in Loop() inboth no results in the log (copied it as you advised me how to do. so no result bisible). it is getting complex I think!
                                        6 TSM:INIT
                                        7 TSF:WUR:MS=0
                                        14 TSM:INIT:TSP OK
                                        16 TSF:SID:OK,ID=12
                                        17 TSM:FPAR
                                        452 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                        457 TSF:MSG:FPAR OK,ID=0,D=1
                                        561 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                                        2066 TSM:FPAR:OK
                                        2067 TSM:ID
                                        2068 TSM:ID:OK
                                        2070 TSM:UPL
                                        2074 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                        2086 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                        2092 TSF:MSG:PONG RECV,HP=1
                                        2094 TSM:UPL:OK
                                        2096 TSM:READY:ID=12,PAR=0,DIS=1
                                        2101 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                                        2110 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                                        2118 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                                        2127 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                                        2142 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                                        2151 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                                        2161 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                                        2168 MCO:REG:REQ
                                        2172 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                                        2181 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                                        2186 MCO:PIM:NODE REG=1
                                        2189 MCO:BGN:STP
                                        setup done.
                                        2190 MCO:BGN:INIT OK,TSP=1
                                        fetch sensors.
                                        fetch sensors.
                                        fetch sensors.
                                        • rejoe2R
                                          rejoe2R
                                          rejoe2
                                          How are your sensors wired? Parasitic or 3 wires?
                                          Sounds like a broken sensor, wrong wiring or a lot of sensors (to much for the pullup used).
