  2. Announcements
  3. 💬 Temperature Sensor
171 Posts 40 Posters 106.8k Views 36 Watching
  • rejoe2R rejoe2
    @Dick Did you change it at both places ( sleep(conversionTime);)?
    DickD
    DickD
    Dick
    @rejoe2 Yes on both location I replaced the sleep into a wait
      @Dick this part
      2201 !MCO:SLP:REP
      of the initial log you posted says that the node cannot sleep because it is a repeater.
      This part of the sketch:
      explains that if the node is a repeater, the sleep call must be replaced by wait. If it is not replaced, the temperature sensors will not be ready when getTemp... is called, so the node will not send any values. Domoticz only lists sensors that have sent a value.
      DickD
      DickD
      Dick
      @mfalkvidd In the Arduino log he Sleep error is not i anymore so that is solved but still no new device in Domoticz
      • DickD Dick
        @mfalkvidd I chaned the Sleep into Wait but the same log in both Domoticz and on my Arduino. I thought it was an easy go but it appear not to be.
        #104
        @Dick if you get the same log on the Arduino as before changing to wait, the sketch upload must have failed. Perhaps your Arduino is broken?
        Edit: Sorry, didn't see your last reply.
        What does the node log say now?
        DickD 1 Reply Last reply
          DickD
          DickD
          Dick
          @mfalkvidd Ths is what the log says
          0 MCO:BGN:INIT REPEATER,CP=RNNRA--,VER=2.1.1
          3 MCO:BGN:BFR
          6 TSM:INIT
          7 TSF:WUR:MS=0
          14 TSM:INIT:TSP OK
          16 TSF:SID:OK,ID=12
          18 TSM:FPAR
          59 TSF:MSG:SEND,12-12-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
          1016 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
          1021 TSF:MSG:FPAR OK,ID=0,D=1
          1804 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
          1851 TSF:MSG:READ,4-4-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
          2067 TSM:FPAR:OK
          2068 TSM:ID
          2069 TSM:ID:OK
          2071 TSM:UPL
          2075 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
          2087 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
          2093 TSF:MSG:PONG RECV,HP=1
          2095 TSM:UPL:OK
          2097 TSM:READY:ID=12,PAR=0,DIS=1
          2102 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
          2111 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
          2119 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
          2128 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
          2144 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
          2152 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
          2163 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
          2169 MCO:REG:REQ
          2173 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
          2183 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
          2188 MCO:PIM:NODE REG=1
          2190 MCO:BGN:STP
          2192 MCO:BGN:INIT OK,TSP=1
          • DickD Dick
            3 MCO:BGN:BFR
            6 TSM:INIT
            7 TSF:WUR:MS=0
            14 TSM:INIT:TSP OK
            16 TSF:SID:OK,ID=12
            18 TSM:FPAR
            2067 TSM:FPAR:OK
            2068 TSM:ID
            2069 TSM:ID:OK
            2071 TSM:UPL
            2095 TSM:UPL:OK
            2169 MCO:REG:REQ
            2190 MCO:BGN:STP
            #106
            @Dick thanks. The node still doesn't send any values so that's why it does not show up in Domoticz.
            My next step would be to manually add serial debug prints at end of setup(), presentation(), and almost everywhere in loop(), to see why it doesn't attempt to send.
            • rejoe2R
              rejoe2R
              rejoe2
              Very strange.
              I just mad the test and copied the code (out of your post above) to my IDE, compiled and uploaded: No problem, worked fine. Node gets registered by FHEM, sends ID once and Temp regularly as expected. For testing, I used just one DS18B20, but that shouldn't make any difference. (And MySensors lib version 2.2-beta, but that also shouldn't be an issue).
              Btw: what kind of a GW you are using?
              Recently, I came across a situation with a WiFi-GW that absolutely refused to accept new nodes. Using a serial one, everything was fine... Strange thing, too. (The GW itself was ok, there were several other nodes working without any communication problems. the new HW was also ok. Last, the channel was also correct, as all the existing nodes just switched over to the serial GW.... Reflashing that nasty thing also was no solution.)
                DickD
                DickD
                Dick
                I put some deug lines i it and after uploadig the sketch it stops here (wait conversationtime.)
                setup done.
                2191 MCO:BGN:INIT OK,TSP=1
                fetch sensors.
                fetch sensors.
                fetch sensors.
                fetch sensors.
                fetch sensors.
                fetch sensors.
                fetch sensors.
                • DickD Dick
                  setup done.
                  fetch sensors.
                  fetch sensors.
                  fetch sensors.
                  fetch sensors.
                  fetch sensors.
                  fetch sensors.
                  fetch sensors.
                  #109
                  @Dick could you try printing the value of numSensors in presentation()? (or in loop, it should have the same value there)
                    DickD
                    DickD
                    Dick
                    @mfalkvidd how can I manage that? sorr for the perhaps stupid qestion?
                    • DickD Dick
                      @Dick
                      Serial.print("Number of attached sensors found by the DallasTemperature library: ");
                      Serial.println(numSensors);
                      rejoe2R DickD 2 Replies Last reply
                        @Dick
                        rejoe2R
                        rejoe2R
                        rejoe2
                        @Dick best place would be after numSensors = ... in presentation()
                        Just to mention that: The Arduino I used already had a node ID (I usually assign it manually). But your problem seems to be something completely different.
                          @Dick
                          DickD
                          DickD
                          Dick
                          @mfalkvidd I tried it in Presentation() and in Loop() inboth no results in the log (copied it as you advised me how to do. so no result bisible). it is getting complex I think!
                          6 TSM:INIT
                          7 TSF:WUR:MS=0
                          14 TSM:INIT:TSP OK
                          16 TSF:SID:OK,ID=12
                          17 TSM:FPAR
                          452 TSF:MSG:READ,0-0-12,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                          457 TSF:MSG:FPAR OK,ID=0,D=1
                          561 TSF:MSG:READ,20-20-12,s=255,c=3,t=8,pt=1,l=1,sg=0:1
                          2066 TSM:FPAR:OK
                          2067 TSM:ID
                          2068 TSM:ID:OK
                          2070 TSM:UPL
                          2074 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                          2086 TSF:MSG:READ,0-0-12,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                          2092 TSF:MSG:PONG RECV,HP=1
                          2094 TSM:UPL:OK
                          2096 TSM:READY:ID=12,PAR=0,DIS=1
                          2101 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          2110 TSF:MSG:READ,0-0-12,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          2118 TSF:MSG:SEND,12-12-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.1.1
                          2127 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
                          2142 TSF:MSG:READ,0-0-12,s=255,c=3,t=6,pt=0,l=1,sg=0:M
                          2151 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=11,pt=0,l=18,sg=0,ft=0,st=OK:Temperature Sensor
                          2161 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.2
                          2168 MCO:REG:REQ
                          2172 TSF:MSG:SEND,12-12-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
                          2181 TSF:MSG:READ,0-0-12,s=255,c=3,t=27,pt=1,l=1,sg=0:1
                          2186 MCO:PIM:NODE REG=1
                          2189 MCO:BGN:STP
                          setup done.
                          2190 MCO:BGN:INIT OK,TSP=1
                          fetch sensors.
                          fetch sensors.
                          fetch sensors.
                          • rejoe2R
                            rejoe2R
                            rejoe2
                            How are your sensors wired? Parasitic or 3 wires?
                            Sounds like a broken sensor, wrong wiring or a lot of sensors (to much for the pullup used).
                            • mfalkviddM
                              Ok. I give up. If the node isn't executing the serial prints I know no way of troubleshooting.
                                DickD
                                DickD
                                Dick
                                @mfalkvidd I ony can tell "thanksfo the support ad you time" . Have a nice wekend!!!
                                • skywatchS
                                  skywatchS
                                  skywatch
                                  I have been frustrated with this for weeks now. Today I notice that void loop is not closed with a curly brace and if I add one it does not compile.
                                  So what black magic is going on here?
                                  I have been trying to get sensor readings every 2 mins and battery every half hour. But whatever I try it still gives temp every minute and battery at once a minute too. No wonder my batteries are draining so fast.
                                  • skywatchS skywatch
                                    @skywatch the curly braces were discussed and explained earlier in this thread.
                                    Could you post your sketch and the debug output of your node?
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      @mfalkvidd
                                      Thanks for fast reply! See code below. If you don't see problem there I will debug tomorrow. The battery time is set for 90sec to test, but is taking 18mins between sends!
                                      #define MY_RF24_PA_LEVEL (RF24_PA_LOW)
                                      #define MAX_ATTACHED_DS18B20 3
                                      #include <OneWire.h>
                                      int batteryPcnt = 0;
                                      unsigned long SLEEP_TIME = 117000; // Sleep time between reads (in milliseconds)
                                      int numSensors = 0;
                                      const long interval = 90000;
                                      unsigned long previousMillis = 0;
                                      bool receivedConfig = false;
                                      bool metric = true;
                                      MyMessage msg(0, V_TEMP);
                                      void before()
                                        sensors.begin();
                                        analogReference(INTERNAL);
                                        sendSketchInfo("HW/CH", "0.4");
                                        for (int i = 0; i < numSensors && i < MAX_ATTACHED_DS18B20; i++) {
                                          present(i, S_TEMP);
                                        // get the battery Voltage
                                        if (currentMillis - previousMillis >= interval) {
                                          batteryPcnt = sensorValue / 10;
                                          float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
                                      #if COMPARE_TEMP == 1
                                            send(msg.setSensor(i).set(temperature, 1));
                                            lastTemperature[i] = temperature;
                                        int8_t sleep(1, FALLING, SLEEP_TIME);
                                        @mfalkvidd
                                        int numSensors = 0;
                                        bool metric = true;
                                        void before()
                                          sensors.begin();
                                            present(i, S_TEMP);
                                        #120
                                        @skywatch doing what you want is a bit hard since millis won't update while the node is in power save mode (sleeping). But this should do it:
                                        set SLEEP_TIME = 2 * 60 * 1000 // 2 minutes
                                        and change
                                        to
                                        unsigned int batteryReportFactor = 30*60*1000ul/SLEEP_TIME; // Only report battery every x SLEEP times (x=15 with current values)
                                        unsigned int timesSlept = 0;
                                          if (timesSlept < batteryReportFactor) {
                                            timesSlept++;
                                            timesSlept = 0;
                                        I don't understand why you're using interrupt to sleep though.
                                        skywatchS 1 Reply Last reply
                                          and change
                                          to
                                              timesSlept++;
                                              timesSlept = 0;
                                          skywatchS
                                          skywatchS
                                          skywatch
                                          #121
                                          @mfalkvidd said in 💬 Temperature Sensor:
                                          Thank you very much for helping out with this! - I will try it today if I can. I guess I could use the same principle to send sensor data every 2 minutes instead of every 1 minute and further reduce battery draw. I know the DS18B20 sensors are correctly going into sleep mode, but the node itself is still using too much juice.
                                          There is nothing in the API about this, would be nice if it were added as I don't think I will be the only person with such requirements. Also, what does sleep actually do and are there further things I could do to reduce the power use?
                                          That is because I haven't finished this node yet.... I am working on it systematically and in future a water leak detector will be added. But only when this part is working correctly and I have good battery life from the node.
