  3. AC Power and/or Relay interface
41 Posts 6 Posters 12.8k Views 6 Watching
    What's the problem with esp8266? If you want really small relays you need to look at zwave products
    E
    E
    exilit
    wrote on last edited by exilit
    @gohan There is no problem. I like the devices very much, but I'd like to have something not WiFi based for that purpose.
    Why Z-Wave? Do you know a Z-Wave device, that serves low voltage output and is externally controllable?
    Black CatB 1 Reply Last reply
    • rozpruwaczR
      rozpruwaczR
      rozpruwacz
      You can find that in any electronic shop, it is called phone charger or just 5v power supply. If You want to put it behind the wall switch You have to search for flush mounted power supply, but it is hard to find realy small one that will fit with another device.
      E 1 Reply Last reply
      • rozpruwaczR rozpruwacz
        E
        E
        exilit
        @rozpruwacz Thank you for your suggestion. I already searched for that for hours (if not days). Most results are either uncased (so not certified) or/and quite expensive.
        The best thing I could find was the Recom RAC03. But the price (and again the missing certification, not sure) make it not suitable.
        • E exilit
          rozpruwaczR
          rozpruwaczR
          rozpruwacz
          @exilit said in AC Power and/or Relay interface:
          Recom RAC03
          I'm no expert in consumer electronics certification but i think that this is the same as HLK module. I'm talking about something like this:
          https://ealarmy.com.pl/produkt-4167/psc12015-12v-15a-62mm-zasilacz-impulsowy-hermetyczny-ip67-pulsar?gclid=Cj0KCQjwierMBRCHARIsAHl9i4G8b3ruKpyNMhiZV7nL7iWaJ4oatzqpXHaiDZJeQOPKOxElJeeoS9oaAvwjEALw_wcB
            Recom RAC03
            E
            E
            exilit
            @rozpruwacz Wow, that looks great. Still missing the relay for my dream product :-) but that's a starting point. Do you know more of that? Like I said, I searched that for days and didn't find anything similar.
            • rozpruwaczR
              rozpruwaczR
              rozpruwacz
              Recom RAC03
              oh, You are talking about this ?
              https://www.digikey.com/product-detail/en/recom-power/RAC03-05SCR-277/945-1702-ND/3844914
              if so then yes this is exactly what I mean and actualy this item looks very good :) about the price I believe that maybe you could find something half the price but not less ...
                http://www.widom.it/it/universal-relay-switch I think this could be an option
                  E
                  E
                  exilit
                  @gohan Thanks, but I believe Z-Wave will be expensive. And apart that I would really like to run MySensors (Not mandatory, but currently my goal).
                  • rozpruwaczR
                    rozpruwaczR
                    rozpruwacz
                    like to run
                    from my personal experience: more You do yourself the cheaper unit price but You spent on it more time - so You have to calculate how much Your time costs.
                    The other issue with making something to fit into wall switch is that it has to be small, so this requires more custom design -> so more made by yourself -> then it won't be certified. Or You choose small but very expensive parts.
                    Personally I wouldn't buy cheap power supply, this is the most important part of the device.
                    So if You have good knowledge how to design safe power supply just do this and don't worry about certification, If You design it well then it will not cause your home tu burn :)
                    • rozpruwaczR
                      rozpruwaczR
                      rozpruwacz
                      other solution would be, considering that there are thick cables in the walls to handle large currents, to run only low DC voltage instead of high AC voltage for the lighting, but it would require to use low voltage (12V DC) led lights everywhere. And this might be a problem, because there is very little bulbs operating on 12V DC axept of led strips and some halogen replacement bulbs.
                        like to run
                        E
                        E
                        exilit
                        @rozpruwacz said in AC Power and/or Relay interface:
                        :-) Yes you are most probably right. But if it does, I will not only lose my house, I will also be bankrupt and homeless.
                        But seriously: This is what I was thinking for some time also. Especially because I have seen In-Wall device that are way unsafer than the ones on this forum using the HLK. But for some reason I'm very unsure for the last few days...
                        So if there is another solution I think I still would like to take that. If not... well, I will do it myself and hope that my house does not burn. Maybe I put a CE sticker on it... :-D
                          You wanted small device that is also certified and the smallest solution I know are Zwave devices. I don't think you can find a certified product running on atmega controller with mysensors and be also certified
                            E
                            E
                            exilit
                            @gohan I know the requirements are very specific and hard to find. I am just searching for ideas.
                              It is just a matter of choosing commercial or DIY, that means certified or not certified :)
                                Recom RAC03
                                E
                                E
                                exilit
                                Recom RAC03
                                Yes, that is what I was talking about. Half the price sounds good.
                                But to be honest, I think the one you posted suits it better. The Recom power supply's use cases seem to be the same as the HLK module.
                                • E exilit
                                  Recom RAC03
                                  rozpruwaczR
                                  rozpruwaczR
                                  rozpruwacz
                                  @exilit the one i posted is much bigger and 12v, so You need buck converter. This makes it harder to fit atmega board, but maybe You will :). for sure there is more 12v flush mounted power supplies and they are cheaper because they are used for led lighting. The cheaper ones will propably draw more power, they will be powered 24/7 so it is important that they draw at lest less than 0.5W.
                                  • E exilit
                                    Black CatB
                                    Black CatB
                                    Black Cat
                                    @exilit what voltage are you needing?
                                    • Black CatB Black Cat
                                      E
                                      E
                                      exilit
                                      @Black-Cat Ideally 5V or 3.3V. But in the end it doesn't matter too much, as converting it down wouldn't be too difficult. Do you know something?
                                      • E exilit
                                        Black CatB
                                        Black CatB
                                        Black Cat
                                        @exilit For Z-Wave control the only device I am aware of that uses those voltages is a Z-UNO. You would need to build your own controller but it's not difficult.
                                        E gohanG 2 Replies Last reply
                                          E
                                          E
                                          exilit
                                          @Black-Cat I'm a little bit confused. This does not address my issue, does it?
