  3. Yet another simple roller shutter (cover) node
19 Posts 3 Posters 8.6k Views 3 Watching
  • dpressleD
    dpressleD
    dpressle
    Boards can be found at Dirty Pcbs
    • G
      G
      gryzli133
      Great job! Do you have an alternative that I can connect the nodes to gateway through Wire (i2c, RS485 etc)?
      dpressleD 1 Reply Last reply
      • G gryzli133
        dpressleD
        dpressleD
        dpressle
        @gryzli133 The only way i can see is using the radio pins 9, 10, 11, 12, 13 if they can be used with RS485 or i2c then you are good to go
        • G
          G
          gryzli133
          did you already try to change the radio module with RS485 module?
          • G gryzli133
            dpressleD
            dpressleD
            dpressle
            @gryzli133 No, Sorry. Let us know if you make it happen.
            • H
              H
              hummeruli
              wrote on last edited by hummeruli
              @dpressle can you give me the Code for the Arduino?
              • H hummeruli
                dpressleD
                dpressleD
                dpressle
                @hummeruli its here:
                https://forum.mysensors.org/topic/7386/mysensors-cover-node
                H 1 Reply Last reply
                • dpressleD dpressle
                  H
                  H
                  hummeruli
                  @dpressle said in Yet another simple roller shutter (cover) node:
                  Thank you, but it does not work.
                  145: error: 'getConfig' was not declared in this scope
                  • H hummeruli
                    dpressleD
                    dpressleD
                    dpressle
                    @hummeruli It compiles just fine on my machine, what version of mysensors do you have? i am using v2:
                    0_1503471248864_upload-3a44b137-4947-4a14-85e0-bf877f6da2a8
                      H
                      H
                      hummeruli
                      @dpressle i'm using 2.1.1 on IDE 1.8.3 for Arduino Pro Mini 5V 16MHz.
                      • H hummeruli
                        dpressleD
                        dpressleD
                        dpressle
                        @hummeruli can you check "Show verbose output during: " for compilation in the Preferences page and send me the detailed compilation log?
                        • H
                          H
                          hummeruli
                          Sorry, i'm stupid. Your Code works fine. I get another Code, this was wrong and i renamed the wrong File.
                          But i have two Problems:
                          1. I need on my shutter, he is open with 0% and closed with 100%. If i change the values for UP and DOWN to my values, it would'nt work.
                          2. If the shutter stay on 40% and i restart it, then he run UP and after he stop, he send the V_percentage 40.
                          Normaly he must send the stored value in EEPROM, i think.
                          Thanks a lot
                          • H hummeruli
                            Thanks a lot
                            dpressleD
                            dpressleD
                            dpressle
                            @hummeruli
                            for #1 try switching also these variables:
                            #define DIRECTION_DOWN 1
                            #define DIRECTION_UP 0
                            for #2 can you send debug output?
                            • G
                              G
                              gryzli133
                              What controller did you test already? I have domoticz, but it seems like domoticz has problem with percentage...
                              • G gryzli133
                                dpressleD
                                dpressleD
                                dpressle
                                @gryzli133 Its tested and working on Homeassistant, you will probably will have to modify the code to make it work with other controllers, let me know if you need help with that.
                                • G
                                  G
                                  gryzli133
                                  is there any way to see all the communication between Node and Domoticz? I have already successfully changed the programm to compile on ESP8266, so I could use WiFi gateway and connected to serial check what happend in the communication. But i'm still too new to mysensors to get the full debug info...
                                  • G gryzli133
                                    dpressleD
                                    dpressleD
                                    dpressle
                                    @gryzli133 Sorry but i dont know how to debug Domoticz
                                      @hummeruli
                                      H
                                      H
                                      hummeruli
