  3. [SOLVED] MySigning cannot write hmac key to eeprom of standalone ATmega328p (sign verify fail)
18 Posts 2 Posters 3.7k Views 2 Watching
  • AnticimexA Anticimex
    @alexanderkind could you enable the verbose signing debug flag on the node please?
    alexanderkind
    wrote on last edited by alexanderkind
    @Anticimex Yeah of course:
    0 MCO:BGN:INIT NODE,CP=RNNNAS-,VER=2.1.1
    32 TSM:INIT
    49 TSF:WUR:MS=0
    81 TSM:INIT:TSP OK
    98 TSM:INIT:STATID=1
    131 TSF:SID:OK,ID=1
    147 TSM:FPAR
    163 Will not sign message for destination 255 as it does not require it
    278 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2375 !TSM:FPAR:NO REPLY
    2392 TSM:FPAR
    2408 Will not sign message for destination 255 as it does not require it
    2523 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4636 !TSM:FPAR:NO REPLY
    4653 TSM:FPAR
    4669 Will not sign message for destination 255 as it does not require it
    4800 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6897 !TSM:FPAR:NO REPLY
    6914 TSM:FPAR
    6930 Will not sign message for destination 255 as it does not require it
    7045 TSF:MSG:SEND,1-1-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    9158 !TSM:FPAR:FAIL
    9175 TSM:FAIL:CNT=1
    9191 TSM:FAIL:PDT
    That's strange, isn't it? I will try it without the request from all flag on the gateway but I thought it would be right to set it if I want signing for all nodes. (At the moment I'm just experimenting with one node.)
    AnticimexA 1 Reply Last reply
      alexanderkind
      @Anticimex Sorry. It was my fault. Now it should be correct. Here is the new debug output:
      32 TSM:INIT
      49 TSF:WUR:MS=0
      81 TSM:INIT:TSP OK
      131 TSF:SID:OK,ID=1
      147 TSM:FPAR
      737 TSF:MSG:READ,0-0-1,s=255,c=3,t=8,pt=1,l=1,sg=1:0
      802 Skipping security for command 3 type 8
      851 TSF:MSG:FPAR OK,ID=0,D=1
      2375 TSM:FPAR:OK
      2392 TSM:ID
      2408 TSM:ID:OK
      2424 TSM:UPL
      2441 Skipping security for command 3 type 24
      2490 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
      2572 TSF:MSG:READ,0-0-1,s=255,c=3,t=25,pt=1,l=1,sg=1:1
      2637 Skipping security for command 3 type 25
      2686 TSF:MSG:PONG RECV,HP=1
      2719 TSM:UPL:OK
      2736 TSM:READY:ID=1,PAR=0,DIS=1
      2768 Signing required
      2801 Skipping security for command 3 type 15
      2850 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
      2932 Waiting for GW to send signing preferences...
      2998 TSF:MSG:READ,0-0-1,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
      3063 Skipping security for command 3 type 15
      3112 Mark node 0 as one that require signed messages
      3162 Mark node 0 as one that do not require whitelisting
      3227 Skipping security for command 3 type 16
      3293 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
      3358 Nonce requested from 0. Waiting...
      3407 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=0:03AC0D8B3CB5CB15A89C1CA0D34A23A3CD126BB074F8B86363
      3538 Skipping security for command 3 type 17
      3588 Nonce received from 0.
      3620 Proceeding with signing...
      Message to process: 01002E0011FF322E312E31
      Current nonce: 03AC0D8B3CB5CB15A89C1CA0D34A23A3CD126BB074F8B86363AAAAAAAAAAAAAA
      HMAC: 42A3503DBB004E69A9D9F7D28B95840D053FC9392FA07DEEB0F7DF77FDE96F28
      Signature in message: 01A3503DBB004E69A9D9F7D28B95840D053FC939
      5062 Message signed
      5160 Message to send has been signed
      5193 TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=OK:2.1.1
      5292 Skipping security for command 3 type 16
      5341 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      5423 Nonce requested from 0. Waiting...
      5472 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:4C7070935D33A92B30B5C969B2D73AD1528B7715B3DDBCE1A3
      5586 Skipping security for command 3 type 17
      5636 Nonce received from 0.
      5668 Proceeding with signing...
      Message to process: 01000E2306FF00
      Current nonce: 4C7070935D33A92B30B5C969B2D73AD1528B7715B3DDBCE1A3AAAAAAAAAAAAAA
      HMAC: CB7D06543C6086C9CCB25CF7DB42F0A81613215486A512EDA03238F8E33D3C4D
      Signature in message: 017D06543C6086C9CCB25CF7DB42F0A81613215486A512ED
      7127 Message signed
      7208 Message to send has been signed
      7258 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=1,ft=0,st=OK:0
      9338 Skipping security for command 3 type 16
      9388 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      9469 Nonce requested from 0. Waiting...
      9502 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:39A8009337CE6B2429675B3EE9D1FD11A12CB201C27B7AB731
      9633 Skipping security for command 3 type 17
      9682 Nonce received from 0.
      9715 Proceeding with signing...
      Message to process: 010006000000
      Current nonce: 39A8009337CE6B2429675B3EE9D1FD11A12CB201C27B7AB731AAAAAAAAAAAAAA
      HMAC: 925B0FAED6941FFC943824E7ADBC694D1521C515B5C28BB0445873043CE2A167
      Signature in message: 015B0FAED6941FFC943824E7ADBC694D1521C515B5C28BB044
      11157 Message signed
      11255 Message to send has been signed
      11304 TSF:MSG:SEND,1-1-0-0,s=0,c=0,t=0,pt=0,l=0,sg=1,ft=0,st=OK:
      11370 MCO:REG:REQ
      11403 Skipping security for command 3 type 26
      11452 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=0,st=OK:2
      11534 TSF:MSG:READ,0-0-1,s=255,c=3,t=16,pt=0,l=0,sg=1:
      11599 Skipping security for command 3 type 16
      SHA256: 21F723FE2BC6B783D6180A5D5FD4FA6FEEBC9619DB03AC42F700000000000000
      11894 Skipping security for command 3 type 17
      12009 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:21F723FE2BC6B783D6180A5D5FD4FA6FEEBC9619DB03AC42F7
      12156 Transmitted nonce
      12173 TSF:MSG:READ,0-0-1,s=255,c=3,t=27,pt=1,l=1,sg=1:1
      Signature in message: 01F9F3C6AB0598E633E422941AED25C8326217E59EB80E2D
      Message to process: 00010E231BFF01
      Current nonce: 21F723FE2BC6B783D6180A5D5FD4FA6FEEBC9619DB03AC42F7AAAAAAAAAAAAAA
      HMAC: 4DB8C02FBF9752C441D02C31E770CC7D7E9559C3F0323EB5E85949DB55479125
      Signature bad: 01B8C02FBF9752C441D02C31E770CC7D7E9559C3F0323EB5
      13729 Signature verification failed!
      13828 !TSF:MSG:SIGN VERIFY FAIL
      13860 MCO:BGN:STP
      13893 MCO:BGN:INIT OK,TSP=1
      13926 MCO:SLP:MS=5,SMS=0,I1=255,M1=255,I2=255,M2=255
      13975 MCO:SLP:TPD
      14008 MCO:SLP:WUP=-1
      14024 Skipping security for command 3 type 16
      14090 TSF:MSG:SEND,1-1-0-0,s=0,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      14155 Nonce requested from 0. Waiting...
      14204 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:9C129D83097B589C208D1C9C33B1950DC9EE1C258CF7A93E05
      14336 Skipping security for command 3 type 17
      14385 Nonce received from 0.
      14417 Proceeding with signing...
      Message to process: 01000E21100000
      Current nonce: 9C129D83097B589C208D1C9C33B1950DC9EE1C258CF7A93E05AAAAAAAAAAAAAA
      HMAC: EB1086A4ED61967A799188580A94ED63AF3FA19D416CDFEBD44533337287719C
      Signature in message: 011086A4ED61967A799188580A94ED63AF3FA19D416CDFEB
      15876 Message signed
      15958 Message to send has been signed
      16007 TSF:MSG:SEND,1-1-0-0,s=0,c=1,t=16,pt=1,l=1,sg=1,ft=0,st=OK:0
      16089 Skipping security for command 3 type 16
      16138 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
      16220 Nonce requested from 0. Waiting...
      16269 TSF:MSG:READ,0-0-1,s=255,c=3,t=17,pt=6,l=25,sg=1:387EA66DC5039E8E6868373832492E019E1A5A055A01A69988
      16400 Skipping security for command 3 type 17
      16449 Nonce received from 0.
      16482 Proceeding with signing...
      Message to process: 01000E2300FF64
      Current nonce: 387EA66DC5039E8E6868373832492E019E1A5A055A01A69988AAAAAAAAAAAAAA
      HMAC: 33644999A7B56076EBC8E6C12C787406C9348F721D1B7AEC56F5430DC1A659CD
      Signature in message: 01644999A7B56076EBC8E6C12C787406C9348F721D1B7AEC
      17924 Message signed
      18022 Message to send has been signed
      18071 TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=OK:100
      18153 MCO:SLP:MS=0,SMS=0,I1=1,M1=1,I2=255,M2=255
      18202 MCO:SLP:TPD
      • A alexanderkind
        32 TSM:INIT
        49 TSF:WUR:MS=0
        81 TSM:INIT:TSP OK
        131 TSF:SID:OK,ID=1
        147 TSM:FPAR
        2392 TSM:FPAR
        4653 TSM:FPAR
        6914 TSM:FPAR
        9158 !TSM:FPAR:FAIL
        9175 TSM:FAIL:CNT=1
        9191 TSM:FAIL:PDT
        AnticimexA
        AnticimexA
        Anticimex
        @alexanderkind from your last log, I don't see the signing presentation data being exchanged so the node have not yet learned of the gw:s signing preferences.
        • A alexanderkind
          32 TSM:INIT
          49 TSF:WUR:MS=0
          81 TSM:INIT:TSP OK
          131 TSF:SID:OK,ID=1
          147 TSM:FPAR
          2375 TSM:FPAR:OK
          2392 TSM:ID
          2408 TSM:ID:OK
          2424 TSM:UPL
          2719 TSM:UPL:OK
          5062 Message signed
          7127 Message signed
          11370 MCO:REG:REQ
          13860 MCO:BGN:STP
          13975 MCO:SLP:TPD
          18202 MCO:SLP:TPD
          AnticimexA
          AnticimexA
          Anticimex
          @alexanderkind ok, everything points to that the GW and the node have different hmac keys. Are you absolutely positive that they are identical?
          You don't need to post them as proof, just make sure that every single bit is the same :)
          The security personalizer can be configured to dump them. Or you can dump eeprom by other means.
          A 2 Replies Last reply
            alexanderkind
            @Anticimex I will try to dump them with the security personalizer. I already did that earlier. Should be no problem. But I thought they were the same :confused:
              alexanderkind
              @Anticimex You're definitely right. For some reason I can't write the key to the eeprom of the ATmega328p. If I upload the sketch and then try to dump the keys, there are only many F's. With the Arduino Nano Gateway everything works fine.
              You're great! I would have never thought that it could be such a problem :) But now I have to solve that :joy:
              • A alexanderkind
                AnticimexA
                AnticimexA
                Anticimex
                @alexanderkind well, sorry to hear that you have a problem with the eeprom. Glad to be able to help out in troubleshooting it.
                Perhaps you have some code on your node that writes to eeprom and happens to write to the wrong place? (only speculating). But now at least you have a reason for the the failed verifications. 👍
                  alexanderkind
                  @Anticimex I think I will try that tomorrow. And I will set up the node with another Arduino Nano instead of the ATmega standalone to see if that works :+1:
                    alexanderkind
                    @Anticimex I couldn't stop trying to fix the problem :) Now it's working. I had to set different fuses with avrdude because EESAVE wasn't enabled. So every upload with the Arduino IDE cleaned the eeprom :)
                    • A alexanderkind
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @alexanderkind great that the root cause was found! And now we have a forum thread for others to read in case they have the same problem! Thanks for reporting!
                      12.5k
