  3. nRF5 action!
nRF5 action!
    #693
    I'm realizing I can live with it. It just means I need to add a separate nRF24 gateway if I want to use nRF24's. I'm already adding separate gateways to support RFM69's and LoRa's, so, actually, it's no big deal.
    Meanwhile, I've found that the RadioHead and the MySensors libraries are at least minimally compatible. So, presently I'm using RadioHead for my low power transmissions, but I'm using the sleep(...) function from MySensors to sleep the nRF52 and wake it up. :)
    The only weirdness I'm noticing is that immediately after sending the very first packet in this configuration, there's a mysterious several second delay that occurs before the code continues. However, after the initial hiccup, everything appears to run exactly as fast as it should. I have no clue as to what is causing that initial delay though. It doesn't happen if I don't #include the MySensors.h file.
    • rmtuckerR
      rmtuckerR
      rmtucker
      wrote on last edited by rmtucker
      #694
      I was playing with sleep tonight and found the following problem.
      when using sleep as below it always returns a figure 252 ms bigger than the sleep figure.
      ie sleep 10000 always returns 10251
      ie sleep 3000 always returns 3251.
      I know the nrf51822 has a 32khz rtc so why is this?
        oldmillis = hwMillis();
        hwSleep(10000);
        newmillis = hwMillis();
        Serial.println(newmillis - oldmillis);
      • rmtuckerR
        rmtuckerR
        rmtucker
        Seems it may have something to do with this in the code.
        // Calculate sleep time
        		// 8 Hz -> max 582.542 hours sleep.
        		MY_HW_RTC->PRESCALER = 4095;
        		// Set compare register to 1/125ms + 2 to garantee event triggering
        		MY_HW_RTC->CC[0] = (ms / 125) + 2;```
        • rmtuckerR
          rmtuckerR
          rmtucker
          It seems the +2 above is adding 250ms.
          Why is it done like this???
          d00616D 1 Reply Last reply
            #697
            What more can be done to reduce current consumption on an nRF52832 when the MySensors "sleep" function is being used with RTC wakeup. I've measured a 300mv drop on a 10F capacitor over a 12 hour time period. Of that 300mv, perhaps 20mv was lost due to self-discharge of the supercap. So, that still leaves 280mv of loss due to the nRF52832 . That is too high a rate of loss.
            rmtuckerR d00616D 2 Replies Last reply
              rmtuckerR
              rmtuckerR
              rmtucker
              Seeing Your sketch would help?
              • rmtuckerR rmtucker
                d00616D
                d00616D
                d00616
                A minimum of two ticks are required to be sure the CC[0] is triggered.
                What accuracy is your requirement? I can add more code here to dynamical change the pre scaler plus a check if ms/125>=2
                rmtuckerR 1 Reply Last reply
                • d00616D d00616
                  rmtuckerR
                  rmtuckerR
                  rmtucker
                  @d00616
                  My initial thoughts were how the nrf51822 could be used for energy meters (counting pulses and the gap between them),But unlike the arduino's which can not run timers when in sleep mode,The nrf5 can of course do this.
                  So the nrf5 would be able to report watts and usage while still using sleep mode.
                  But seeing the inaccuracy of the timer has put the brakes on that.
                  Yes being able to change the prescaler dynamically would help a great deal as 125ms / 582.542 hours is not really useful for most applications with a 250ms overrun.
                  • rmtuckerR
                    rmtuckerR
                    rmtucker
                    Just wondering what the prescaler etc would have to be set to for ms accuracy and how long before overflow.(aint got my maths head on today):blush:
                      d00616D
                      d00616D
                      d00616
                      wrote on last edited by d00616
                      #702
                      Wh = 0.5 * 10F * 280mV = 0.392 Wh = 0.0326667 W
                      I=0.0326667/2.56V = 12.76mA
                      Looks like the node is most time fully active.
                        @d00616
                        d00616D
                        d00616D
                        d00616
                        @d00616
                        If you have the idea to store the results into the EEPROM like storage the nRF5, then read the hints about this: https://github.com/d00616/arduino-NVM/#nvramh
                        The virtual EEPROM, the radio or debugging output are adding latency to the main loop. You will see more timing errors in long term run when you trust the sleep() time.
                        The nRF5 can help you to count without adding latency by the cpu. You can use a timer in counter mode which TASK_COUNT and TASKS_CAPTURE[0] are triggered by PPI. Then you can compare the hwMillis() with the last seen CC[0] content and do precise calculation of events.
                        With nRF52 there is an unused RTC wich can trigger TASKS_CAPTURE[0] at a specific time. One RTC is used for millis() in arduino-nrf5 and one RTC is used for sleep.
                        I will change this.
                          #704
                          @rmtucker
                          Here it is, though it's rather messy. Nonetheless, all it does is measure the supercap and solar panel voltages, send them, then sleep for 12 hours. Then repeats:
                          // nrf51_client.pde
                          // -*- mode: C++ -*-
                          // Example sketch showing how to create a simple messageing client
                          // with the RH_NRF51 class. RH_NRF51 class does not provide for addressing or
                          // reliability, so you should only use RH_NRF51 if you do not need the higher
                          // level messaging abilities.
                          // It is designed to work with the other example nrf51_server.
                          // Tested on RedBearLabs nRF51822 and BLE Nano kit, built with Arduino 1.6.4.
                          // See http://redbearlab.com/getting-started-nrf51822/
                          // for how to set up your Arduino build environment
                          // Also tested with Sparkfun nRF52832 breakout board, witth Arduino 1.6.13 and
                          // Sparkfun nRF52 boards manager 0.2.3
                          #include <RH_NRF51.h>
                          unsigned long SLEEP_TIME = 43200000; // 12 hour sleep time between measurements (in milliseconds)
                          //unsigned long SLEEP_TIME = 3600000; // 1 hour sleep time between measurements (in milliseconds)
                          //unsigned long SLEEP_TIME = 300000; // 5 minute sleep time between measurements (in milliseconds)
                          //unsigned long SLEEP_TIME = 1000; // 1 second sleep time between measurements (in milliseconds)
                          #define SUPERCAP_PIN A2  //input pin for reading the supercap's voltage
                          #define SOLAR_PANEL_PIN A4  //input pin for reading the solar panel's voltage
                          #define LDO_ENABLE_PIN 8  //D8 (P0.19) is output pin for enabling (HIGH) or disabling (LOW) the LDO
                          #define NUM_MEASUREMENTS_TO_AVERAGE 3  //number of measurements to collect and then average
                          #define MAX_MEASUREMENTS 10 //Maximum number of voltage measurements before returning a result.
                          // Singleton instance of the radio driver
                          RH_NRF51 nrf51;
                          uint8_t data[10];
                          uint16_t batteryVoltage() {
                            uint16_t lastRawVoltage, newRawVoltage;
                            //uint16_t counter=0;
                            //lastRawVoltage = hwCPUVoltage();  //throw away the first voltage measurement
                            newRawVoltage = hwCPUVoltage();
                            return newRawVoltage;
                          uint16_t readRawVoltageOnPin(uint8_t thePin) {
                            uint16_t counter=0;
                            lastRawVoltage = analogRead(thePin);
                            newRawVoltage = analogRead(thePin);
                            while (((newRawVoltage != lastRawVoltage)) && (counter<MAX_MEASUREMENTS)) {  //measure until two consecutive measurements match
                              lastRawVoltage=newRawVoltage;
                              newRawVoltage=analogRead(thePin);
                              counter++;
                            uint32_t sumOfMeasurements=0;
                            for (int i=0;i<NUM_MEASUREMENTS_TO_AVERAGE;i++) {
                              sumOfMeasurements=sumOfMeasurements+analogRead(thePin);
                            return (sumOfMeasurements/NUM_MEASUREMENTS_TO_AVERAGE);
                          void myBaro()
                            uint32_t superCapVoltage=0;
                            uint32_t solarPanelVoltage=0;
                            uint32_t superCapRawVoltage=0;
                            uint32_t solarPanelRawVoltage=0;
                            digitalWrite(LDO_ENABLE_PIN, LOW);  //disconnect solar panel
                            superCapRawVoltage = readRawVoltageOnPin(SUPERCAP_PIN);
                            superCapVoltage = (3048*(((superCapRawVoltage)*3127)/4095))/1591;
                            //Serial.print("SuperCap voltage=");
                            //Serial.println(superCapVoltage);
                            //send(msg1_S_BARO_P.set(superCapVoltage));  //superCap's raw voltage
                          //  wait(500);
                          //  wait(500);
                            //delayMicroseconds(1000);  //wait for voltage to adjust after LDO disabled.  Necessary???
                            solarPanelRawVoltage=readRawVoltageOnPin(SOLAR_PANEL_PIN);
                            digitalWrite(LDO_ENABLE_PIN, HIGH);  //re-connect solar panel
                            solarPanelVoltage=(5500*(((solarPanelRawVoltage)*3181)/4095))/1289;
                            //Serial.print("Solar Panel Voltage=");
                            //Serial.println(solarPanelVoltage);
                            //superCapVoltage=1234;
                            data[0]= (superCapVoltage/1000)+'0';
                            data[1]= ((superCapVoltage%1000)/100)+'0';
                            data[2]= ((superCapVoltage%100)/10)+'0';
                            data[3]= (superCapVoltage%10)+'0';
                            data[4]=',';
                            data[5]= (solarPanelVoltage/1000)+'0';
                            data[6]= ((solarPanelVoltage%1000)/100)+'0';
                            data[7]= ((solarPanelVoltage%100)/10)+'0';
                            data[8]= (solarPanelVoltage%10)+'0';
                            data[9]='\0';
                            nrf51.send(data, sizeof(data));
                            nrf51.waitPacketSent();
                            pinMode(LDO_ENABLE_PIN, OUTPUT);  // Enable/Disable pin for the LDO
                            digitalWrite(LDO_ENABLE_PIN, HIGH);  //enable the LDO.
                            analogReadResolution(12);  //use 12-bit ADC resolution
                            pinMode(SUPERCAP_PIN,INPUT);  //Supercap voltage measurement pin
                            pinMode(SOLAR_PANEL_PIN,INPUT);  //Solar panel voltage measurement pin
                            //delay(1000); // Wait for serial port etc to be ready
                            Serial.begin(250000);
                            //while (!Serial)
                              ; // wait for serial port to connect.
                            if (!nrf51.init())
                              Serial.println("init failed");
                            // Defaults after init are 2.402 GHz (channel 123), 2Mbps, 0dBm
                            if (!nrf51.setChannel(123))
                              Serial.println("setChannel failed");
                            if (!nrf51.setRF(RH_NRF51::DataRate2Mbps, RH_NRF51::TransmitPower4dBm))
                              Serial.println("setRF failed");
                            // AES encryption can be enabled by setting the same key in the sender and receiver
                          //  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                          //                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
                          //  nrf51.setEncryptionKey(key);
                          //  nrf51.printRegisters();
                            Serial.println("Setup of nr51 client completed.");
                            Serial.println("Sending to nrf51_server...");
                            Serial.flush();
                          uint32_t sentCounter=0;
                          uint32_t replyCounter=0;
                            //uint16_t theBatteryVoltage;
                            //theBatteryVoltage=batteryVoltage();
                           // Serial.print("Battery voltage = ");
                            //Serial.print(theBatteryVoltage);
                            //Serial.println(" millivolts.");
                            // Send a message to nrf51_server
                            //uint8_t data[] = "Hello World!";
                            data[0]= (theBatteryVoltage/1000)+'0';
                            data[1]= ((theBatteryVoltage%1000)/100)+'0';
                            data[2]= ((theBatteryVoltage%100)/10)+'0';
                            data[3]= (theBatteryVoltage%10)+'0';
                            data[4]='\0';
                            sentCounter++;
                            myBaro();
                            // Now wait for a reply
                            uint8_t buf[RH_NRF51_MAX_MESSAGE_LEN];
                            uint8_t len = sizeof(buf);
                            if (nrf51.waitAvailableTimeout(500))
                              // Should be a reply message for us now
                              if (nrf51.recv(buf, &len))
                                Serial.print("got reply: ");
                                Serial.println((char*)buf);
                                replyCounter++;
                                Serial.println("recv failed");
                              Serial.println("No reply, is nrf51_server running?");
                            Serial.print("sentCounter=");
                            Serial.print(sentCounter);
                            Serial.print(", replyCounter=");
                            Serial.println(replyCounter);
                            Serial.flush();
                            sleep(SLEEP_TIME); // Sleeps for 12 hours in deep sleep
                          Using Termite to timestamp the output received, what I got was:
                          2017/08/25 17:04:13: got request: 2684,0085
                          2017/08/26 05:04:12: got request: 2396,0076
                          You can ignore the solar panel measurements, because I disconnected it so as to not interfere.
                          On the bright side, it woke up and reported within 1 second of when it was supposed to, after a 12 hour sleep.
                          d00616D rmtuckerR 2 Replies Last reply
                            @rmtucker
                            // nrf51_client.pde
                            RH_NRF51 nrf51;
                            uint8_t data[10];
                              uint16_t counter=0;
                                counter++;
                            void myBaro()
                            //  wait(500);
                            //  wait(500);
                              data[4]=',';
                              data[9]='\0';
                              //while (!Serial)
                              if (!nrf51.init())
                              Serial.flush();
                              data[4]='\0';
                              sentCounter++;
                              myBaro();
                                  replyCounter++;
                              Serial.flush();
                            d00616D
                            d00616D
                            d00616
                            RadioHead sets the radio into the Idle state. The radio isn't powered off. There is no call in RadioHead to power off the radio.
                              @rmtucker
                              // nrf51_client.pde
                              RH_NRF51 nrf51;
                              uint8_t data[10];
                                uint16_t counter=0;
                                  counter++;
                              void myBaro()
                              //  wait(500);
                              //  wait(500);
                                data[4]=',';
                                data[9]='\0';
                                //while (!Serial)
                                if (!nrf51.init())
                                Serial.flush();
                                data[4]='\0';
                                sentCounter++;
                                myBaro();
                                    replyCounter++;
                                Serial.flush();
                              rmtuckerR
                              rmtuckerR
                              rmtucker
                              So your sketch only wakes up every 12hours.
                              What current is it drawing using the radiohead library vs mysensors for an equivalent 12 hour sleep because in past discussions with you i remember you saying 5-6uA while sleeping,is this still correct?
                              I dont see much advantage to the radiohead library if only sending at 12hour intervals.
                                #707
                                The 6ua was measured with it in deep sleep, where it relied on an external interrupt to wakeup. This measurement was intended to see what it would be if it woke-up using the RTC. So, the 12 hour interval is artificial, for measurement purposes.
                                @d00616
                                I had wrongly assumed that the "sleep(...)" command would sleep the radio. Thanks for pointing out my error. How/when is it that Mysensors puts the radio to sleep? Does it just happen automatically at the end of every sending/receiving?
                                  @d00616
                                  d00616D
                                  d00616D
                                  d00616
                                  #708
                                  We are both not 100% correct ;-) The hwSleep() function doesn't disable the radio, but the sleep() function does it, when MY_SENSOR_NETWORK is defined.
                                  After Sleep transportReInitialise() is called. Then you have to initialize RadioHead again.
                                  • d00616D d00616
                                    So, even with RAM retention active while sleeping, each time the radio is awoken, it needs to be re-initialized?
                                      d00616D
                                      d00616D
                                      d00616
                                      The Radio has to be initialized after power down. This doesn't depend on RAM retention.
                                        #711
                                        According to Table 39 of the mRF52832 datasheet, there is only one radio state resembling sleep, and that is the DISABLED radio state where "No operations are going on inside the radio and the power consumption is at a minimum."
                                        Apparently the radio is disabled through register TASKS_DISABLE, offset 0x010, Disable RADIO, as indicated by Table 41 register overview.
                                          #712
                                          But how exactly does one read or write to these registers? It looks like a quite different arrangement than writing to registers for an nRF24 or an RFM69 or a LoRa chip.
