  3. Problem getting BMP180 to show correct readings.
9 Posts 3 Posters 5.2k Views 3 Watching
  • R Offline
    R Offline
    royson84
    So as the topic says, im having problems getting a working sketch to my BMP180. It shows some really weird readings:
    Temperature = 200.30 *C
    Pressure = 108908 Pa
    Altitude = -613.66 meters
    Pressure at sealevel (calculated) = 108914 Pa
    Real altitude = -599.14 meters
    I've tried the "sensorapi" sketch from "Adafruit BMP085 Unified" and the "BMP085test" från "Adafruit BMP085 Library".
    Its connected like the guide says:
    VIN<->3.3V
    GND<->GND
    SCL<->A5
    SDA<->A4
    My plan is to use this on a node together with a UV sensor and a DHT22.
    Anyone how wants to take a shoot at what im doing wrong? Cause I suspect thats the case.... =)
    • R royson84
      VIN<->3.3V
      GND<->GND
      SCL<->A5
      SDA<->A4
      @royson84 with that temp and altitude I would guess that you're in Hell :-D I hope that's no the case.
      How are you powering the BMP180? (where does 3.3V come from?)
      Can you test with a different Arduino?
      Can you test with a different BMP180?
      Do you get the exact same value for every reading, or do they vary (if you heat the sensor with your hand for example)?
      Do you get the exact same value from the two libraries?
      R 1 Reply Last reply
        R Offline
        R Offline
        royson84
        @mfalkvidd said in Problem getting BMP180 to show correct readings.:
        @royson84 with that temp and pressure I would guess that you're in Hell :-D I hope that's no the case.
        Its now connected to an UNO that is powered from USB on my laptop. It get around 4V when a measure with multimeter. Might that be the problem? Will that destroy the poor little thing?
        Might have a Pro mini to give it a shot with.
        Nope, only bought one so far.
        Same value from both libraries and sketches. And since the temp is 200C, I think I might have a difficult time getting another reading in my hand, but I'll give it a shot ;)
        • R royson84
          @royson84 the adafruit description says
          connect the VIN pin to the 5V voltage pin
          and
          Vin: 3 to 5VDC
          so I think any voltage between 3 and 5V will work.
            and
            Vin: 3 to 5VDC
            R Offline
            R Offline
            royson84
            and
            Vin: 3 to 5VDC
            Ok. Gonna give it a shot tomorrow with a Pro mini and see if that gives any different results.
            • R Offline
              R Offline
              royson84
              It seems like the sensor might be broken. Tried it just now with the library from Sparkfun following this guide: https://learn.sparkfun.com/tutorials/bmp180-barometric-pressure-sensor-hookup-
              BMP180 Init fail. The sensor is powered but that seems to be about it. Big disappointment.
                Maybe get a bme280 next time 😀
                  R Offline
                  R Offline
                  royson84
                  @gohan I might just do that. Any seller to recommend?
                  gohanG 1 Reply Last reply
                  • R royson84
                    @royson84 https://www.aliexpress.com/item/High-Accuracy-BME280-Digital-Sensor-Temperature-Humidity-Barometric-Pressure-Sensor-Module-GY-BME280-I2C-SPI-1/32672210336.html
                    This is what I got. Keep in mind that bme280 tends to report temperatures 0.7/0.8C higher than actual, so make a comparison and add a temperature offset in code
