  3. nRF5 action!
nRF5 action!
    #822
    So, to make the above code work as a PPI, all I would need is some kind of linkage such that whenever the "event" of TXIDLE occurs, then a "task" (in this case it would be TASKS_START) is executed to move the radio back into the TX state.
    Hmmm.. Still not obvious though from just the datasheet how to actually setup even that simple linkage.
    d00616D 1 Reply Last reply
      d00616D
      d00616D
      d00616
      wrote on last edited by d00616
      #823
      This is a use case for shortcuts. PPI is not required.
      There is no TXIDLE event but looking at the state diagram is TXIDLE a result of ether READY or END event. You can enable following shortcurts:
      NRF_RADIO->SHORTS = RADIO_SHORTS_READY_START_Msk | RADIO_SHORTS_END_START_Msk;
      In PPI this should be the code (untested):
      #define CHANNEL (1)
      NRF_PPI->CH[CHANNEL].EEP = (uint32_t)&NRF_RADIO->EVENTS_END;
      NRF_PPI->CH[CHANNEL].TEP = (uint32_t)&NRF_RADIO->TASKS_START;
      NRF_PPI->CH[CHANNEL+1].EEP = (uint32_t)&NRF_RADIO->EVENTS_READY;
      NRF_PPI->CH[CHANNEL]+1.TEP = (uint32_t)&NRF_RADIO->TASKS_START;
      NRF_PPI->CHENSET = (1 << CHANNEL) | (1 <<( CHANNEL+1));
        Thanks! That helps my understanding quite a bit. I've tested the following shortcut code, and it works:
        #include <nrf.h>
          //guarantee RESET pin is working
          if (((NRF_UICR-> PSELRESET[0])==0xFFFFFFFF) && ((NRF_UICR-> PSELRESET[1])==0xFFFFFFFF)) { //if the two RESET registers are erased
            NRF_UICR-> PSELRESET[0]=21;  //designate pin P0.21 as the RESET pin
            NRF_UICR-> PSELRESET[1]=21;  //designate pin P0.21 as the RESET pin
          NRF_RADIO->FREQUENCY=123;
          NRF_RADIO->MODE=2;  //set 250kbps datarate.  May as well stretch out the NULL packet as much as possible.
          NRF_RADIO->TASKS_DISABLE=1;  //turn-off the radio to establish known state.
          while (NRF_RADIO->STATE!=0) {}  //busy-wait until radio is disabled
          NRF_RADIO->SHORTS = B100001;  //Implement shortcuts: READY_START and END_START
          NRF_RADIO->TASKS_TXEN=1;  //wake-up the radio transmitter and move it into state TXIDLE.
          //The shortcuts will take-over the moment the state TXIDLE becomes activated.
          Is there any example code which illustrates the use of interrupts on the nRF52832?
            #include <nrf.h>
            #826
            Looks as though it should be possible to send tightly packed meaningful packets, not just null packets, using almost the same methodology.
              d00616D
              d00616D
              d00616
              https://github.com/sandeepmistry/arduino-nRF5/issues/52
              https://github.com/mysensors/MySensors/blob/development/drivers/NRF5/Radio_ESB.cpp#L500
                Interestingly enough, it turns out all I need to do is transmit one packet, and afterward just leave the radio in TXIDLE mode. That's because, as indicated in the datasheet, it transmits a carrier wave of one's (or any pattern you program) after the packet, expecting that another packet will be sent soon. This is illustrated in Figure 37 of the DS.
                  #829
                  So, I've got the transmit side of this problem figured out. Next up: the receiver side, which already works using the MCU.
                  The next step will be to see whether I can setup timed events from the RTC which can be used to trigger the PPI to measure the RSSI without waking up the MCU. Also, I'll need some way for the PPI to evaluate the magnitude of the RSSI without involving the MCU. Ideally it would also trigger a Rx sequence if the RSSI is above threshold and wake the MCU if something gets received. Not sure how much of this will be possible, but that's the wish list.
                  I'd say the energy consumption is already pretty good after switching to the RSSI paradigm, but if this succeeds, then it may cut what remains of the energy consumption roughly in half. At that point, I think we will have wrung just about every possible bit of efficiency out of this radio, with the remaining to-do's as mostly mop-up and maybe some fine tuning (e.g. to better mitigate against false positives on the RSSI threshhold trigger).
                    #830
                    So, I figure the way to get started is to do something "easy", like maybe use the PPI to blink an LED.
                    We want the lower power RTC, not the system clock. We want to use the RTC TICK event, so that the mpu can be powered down while the PPI is running.
                    So, because I want a timer event every 100ms, that means the prescaler should be 3276.
                      #831
                      So, just starting on this, where I'm at is:
                      #include <nrf.h>
                      #define LED_PIN 18
                      bool toggle=false;  //track whether or not to toggle the LED pin
                        NRF_RTC1->TASKS_STOP=1;  //stop the RTC so that we can set the prescaler
                        NRF_RTC1->PRESCALER=3276;  //once per 100ms
                        NRF_RTC1->TASKS_START=1;  //start the RTC so that we can start getting TICK events
                        hwPinMode(LED_PIN,OUTPUT_H0H1);  //establish P0.18 as the LED pin.
                        if (NRF_RTC1->EVENTS_TICK) {
                          toggle=!toggle;
                          digitalWrite(LED_PIN,toggle);
                      Unfortunately, this does not work because (NRF_RTC1->EVENTS_TICK) always reads as zero. Not sure why(?).
                        This whole topic has been brewing in the back of my mind for a couple years now:
                        https://forum.mysensors.org/topic/1788/nrf51822-as-an-all-in-one
                        and
                        https://forum.mysensors.org/topic/3836/anyone-besides-me-looking-into-long-range-bluetooth-for-their-wireless-nodes
                        With the nRF52840, it looks as though the moment has finally arrived to tie it all together and give it a try. :)
                        I just have no idea where to even begin though. Just order the nRF52840 preview DK? Is it fairly quick to get something up and running, or is it a fairly steep learning curve?
                        JokgiJ
                        JokgiJ
                        Jokgi
                        @NeverDie you will need long range capabilities on both sides of the link. So two preview kits work great. Long range is supported by SDK 14 and the current softdevice.
                        • scalzS scalz
                          nrf52832 is definitely better than nrf24l01. if i'm not wrong, 4db can double range in theory.
                          For range, an important point is the antenna, as you already know.
                          Chip antenna can be ok, depending on the environment and usecase, but can't compete with a rfm69. These antennas are not for long range, so the adafruit board. How to miniaturize antennas without loosing performance..
                          JokgiJ
                          JokgiJ
                          Jokgi
                          @scalz the nRF52832 has a hotter receiver. ( better sensitivity.) at 1 mb/ s then the nRF24l series. Overall link Budget is better. 840 even better with a 8dB output.
                            #834
                            @Jokgi
                            of course I agree !
                            that's why in the past i preferred rfm69 modules (better range of course, but more power hungry). 832 being better than nrf24, i'm now using it. And I also like the 840dk (neat package) :+1:
                            That said, if i remember well, nrf52832 is not fully BLE5 long range compatible as 840 is.
                            • JokgiJ Jokgi
                              #835
                              I'm not disagreeing, but presently modules for it (other than the preview DK) aren't yet available. Meanwhile, hopefully nearly all of what's being learned here about the nRF52832 will be of direct relevance. For instance: PPI.
                                #include <nrf.h>
                                #define LED_PIN 18
                                    toggle=!toggle;
                                #836
                                It should be working, but it isn't. Nor do I see a way to check it with an oscilliscope. So, my current theory is that it gets set but cleared so quickly that it can't be read by the MCU. So, the next step will be to assume that it is, in fact, working, and to use it as a PPI trigger, which is what this is all building toward anyway.
                                On the other hand, perhaps there's an easy way to have the EVENTS_TICK set an interrupt bit, which would persist until it was cleared? Hmmm. No, not quite, but there is INTENSET, which will set an interrupt on an EVENT_TICK. That will do. Exactly which interrupt gets triggered though? Figure 46 shows that an IRQ signal is sent to NVIC ( the Nested Vectored Interrupt Controller). According to the table in sectoin 7.3, the NVIC has 37 interrupt vectors. According to section 15.8:
                                A peripheral only occupies one interrupt, and the interrupt number follows the peripheral ID. For example, the
                                peripheral with ID=4 is connected to interrupt number 4 in the Nested Vectored Interrupt Controller (NVIC).
                                So, based on that, we need to know the ID number for the RTC, and then we'll know which interrupt number to track. According to Table 10, the Peripheral ID for the RTC is 11 (well, at least it is for the RTC0, so I will recode to use RTC0 instead of RTC1).
                                Now, according to Table 10, the memory location that corresponds to Peripheral ID 11 is 0x4000B000. Therefore, it is this memory location we need to examine to know if a TICK interrupt has occured.
                                  #837
                                  Close, but no cigar. What I found out is that if I set the TICK interrupt with:
                                        NRF_RTC0->INTENSET=1;  //set the TICK interrupt bit
                                  then at the following memory addresses, the value stored there immediately becomes 1:
                                  4000B300
                                  4000B304
                                  4000B308
                                  and if I clear the TICK interrupt with:
                                        NRF_RTC0->INTENCLR=1;  //clear the TICK interrupt bit
                                  then the values at those same memory addresses immediately becomes zero. I can toggle back and forth as much as I want, and this is always true.
                                  However, none of this is telling me whether the TICK interrupt has actually triggered. Where do I find that?
                                  Based on the current pre-scaler, COUNTER increments once every TICK (i.e. once every 100ms). However, is there an actual TICK flag somewhere that goes high at those times and then low again after getting cleared? Or, is it only accessible indirectly by using PPI?
                                    #838
                                    OK, I came up with a simple equivalent. Basically, every time COUNTER is incremented, I reset it to zero. It then effectively acts much the way a TICK should. For whatever reason, once EVENTS_TICK goes high, it just stays high forever. So, it doesn't seem very useful per se, though maybe there's a way to clear it that I haven't yet found.
                                      #839
                                      Strangely enough, the overflow is the same: once it goes HIGH, it stays that way:
                                      https://pastebin.com/vypuVJeh
                                      So, I would think there must be some way (?) to clear them.
                                        #840
                                        I found the answer. Unlike EVENTS in other peripherals, which are read-only, the EVENTS in RTC are RW. So, the way you clear the TICK and OVRFLW events is just by setting them to zero manually:
                                        e.g.
                                        NRF_RTC0->EVENTS_TICK=0;
                                        LOL. Of course, the DS never mentions this.
                                        In any case, with that change, it can now work properly:
                                        https://pastebin.com/nHWAGFkd
                                          #841
                                          However, it does raise the question: if I were to use EVENTS_TICK to trigger some PPI actions, how could PPI also be used to set EVENTS_TICK back to zero so that those actions can be repeated on the next TICK? I haven't yet found an PPI TASKS that can directly manipulate, or even just clear, a particular memory location.
