  2. Announcements
  3. 💬 Using Arduino
💬 Using Arduino
27 Posts 15 Posters 19.7k Views 15 Watching
  • N
    N
    Newzwaver
    Why do i get this error? Any idea how to fix it?
    Arduino: 1.6.5 (Windows 8.1), Board: "Arduino Uno"
    In file included from C:\Users\Audrey\Documents\Arduino\libraries\MySensors/drivers/RF24/RF24.cpp:23:0,
    from C:\Users\Audrey\Documents\Arduino\libraries\MySensors/MySensors.h:290,
    from GatewayW5100.ino:116:
    C:\Users\Audrey\Documents\Arduino\libraries\MySensors/drivers/RF24/RF24.h:37:17: fatal error: SPI.h: No such file or directory
    compilation terminated.
    Error compiling.
    • N
      N
      Newzwaver
      Messing around with it and got this message, still not idea how to fix it
      Using library MySensors in folder: C:\Users\Audrey\Documents\Arduino\libraries\MySensors
      Using library Ethernet in folder: C:\Program Files (x86)\Arduino\libraries\Ethernet
      C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avr-g++ -c -g -Os -w -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -MMD -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10605 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino -IC:\Program Files (x86)\Arduino\hardware\arduino\avr\variants\standard -IC:\Users\Audrey\Documents\Arduino\libraries\MySensors -IC:\Program Files (x86)\Arduino\libraries\Ethernet\src C:\Users\Audrey\AppData\Local\Temp\build1062139905146989693.tmp\GatewayW5100.cpp -o C:\Users\Audrey\AppData\Local\Temp\build1062139905146989693.tmp\GatewayW5100.cpp.o
      In file included from GatewayW5100.ino:2:0:
      C:\Users\Audrey\Documents\Arduino\libraries\MySensors/MySensors.h:328:2: error: #error No forward link or gateway feature activated. This means nowhere to send messages! Pretty pointless.
      Error compiling.
      • N Newzwaver
        Error compiling.
        @Newzwaver could you post the sketch?
        • N
          N
          Newzwaver
          Thank you for your help, the thing is working. It has something to do with the way I have the Arduino software setup, for some reason I can't just copy a sketch and paste it in for a new sketch.
          • B
            B
            benji_lb
            The MySensors library is missing from the arduino library manager again. Should I just log a new issue and reference the previous one?
            • B benji_lb
              @benji_lb yes please do. Could you post the link to the issue here when it has been created so we can follow it?
              B 1 Reply Last reply
                B
                B
                benji_lb
                @mfalkvidd https://github.com/arduino/Arduino/issues/6690
                Done.
                • B benji_lb
                  Done.
                  B
                  B
                  benji_lb
                  @benji_lb
                  Fixed. I noticed I was running an older version of the software. Uninstalled completely and reinstalled, worked fine.
                  Where would be the best place for an Arduino newbie to post to get some assistance? I'm looking at Gateways and i'm unsure which direction to take, and where would be best to post. Would this be OK? https://forum.mysensors.org/category/13/development
                  • B benji_lb
                    @benji_lb
                    @benji_lb great, thanks for reporting back.
                    The development category will be good. Big welcome to the MySensors community :)
                    • rejoe2R
                      rejoe2R
                      rejoe2
                      Today, the "Basic Structure" section contains just a "normal" Arduino structure.
                      Wouldn't it be useful to also add a slightly extended version mentioning the split of the original Arduino-setup() to begin()->presentation()->setup() when using recent MySenors libs (since 2.1.0)?
                      This is not very transparent to quite a few users, and yet some of our examples do either not mention "before()" at all or do not make use of the new logical execution time of setup(), even if this would be helpful (!pcReceived in WaterMeter-Sketch, getControllerConfig(), for metric in Temperature, just to mention some examples) .
                      Also the text order of setup() still beeing above presentation() in at least some examples may be technically irrelevant but nevertheless misleading to some extend.
                      • rejoe2R rejoe2
                        @rejoe2 great feedback, thanks! For the examples, I have created https://github.com/mysensors/MySensors/issues/927
                        I have updated the "Using Arduino " page. I am not 100% sure I got it right and easy to understand so feedback is very welcome.
                        rejoe2R 1 Reply Last reply
                          rejoe2R
                          rejoe2R
                          rejoe2
                          @mfalkvidd
                          Your understanding of my suggestion seems to be 100% correct. I will add some additional comments and some (too complicated but working examples) as links at the github page.
                            3nibble
                            Hi there,
                            I am on Linux - exclusively! Does that mean I am out even before I started?
                            3nibble (puzzled)
                            • N
                              N
                              napo7
                              You're not !
                              I'm also exclusively on linux, and I use MySensors !
                              I was using Arduino IDE, and now I'm using atom.io, but both are working on linux !
                              • K
                                K
                                kayani009
                                hi i am using Lora SX1276 as simple transmitter and receiver.
                                is there any library for sending and receiving the data no gateway involved only simple data transmission and reception.
