  3. Gateway spamming Domoticz log file
9 Posts 5 Posters 3.4k Views 2 Watching
  • John MälarströmJ Offline
    John Mälarström
    Hi
    I have been running Domoticz for about 6 months.
    I am running a Rpi3, mys Serial gateway (USB) original sketch and RFlink gateway (USB)
    Recently the log file is showing the following entries:
    2017-09-14 08:40:22.230 MySensors: Gateway Version: 2.1.1
    2017-09-14 08:40:24.215 MySensors: Gateway Ready...
    2017-09-14 08:40:24.291 MySensors: Gateway Version: 2.1.1
    2017-09-14 08:40:26.234 MySensors: Gateway Ready...
    2017-09-14 08:40:26.309 MySensors: Gateway Version: 2.1.1
    2017-09-14 08:40:27.557 MySensors: Gateway Ready...
    2017-09-14 08:40:27.632 MySensors: Gateway Version: 2.1.1
    2017-09-14 08:40:30.428 MySensors: Gateway Ready...
    2017-09-14 08:40:30.504 MySensors: Gateway Version: 2.1.1
    2017-09-14 08:40:32.329 MySensors: Gateway Ready...
    etc etc ...
    To me It looks like the Mys Serial gateway is constantly rebooting, but it is not.
    Any ideas?
    /John
    • John MälarströmJ John Mälarström
      Hi
      etc etc ...
      Any ideas?
      /John
      Välkommen to the MySensors community @John-Mälarström
      Is this from /var/log/domoticz.log ?
      Which version of Domoticz are you using?
      What is your "Data Timeout" setting for the gateway? (Setup->Hardware->Click on your gateway and look at the settings beneath the gateway list)
      I am using Domoticz 3.8153 with two MySensors 2 ethernet gateways and one MySensors 1 USB gateway and I don't get these messages.
      John MälarströmJ 1 Reply Last reply
        John Mälarström
        @mfalkvidd
        Hi I cannot see that I have a file called domoticz.log in /var/log.
        I am still at version 3.5877, to chicken to upgrade...
        The data timeout is set to disabled. Is it better to put a value?
        S 1 Reply Last reply
          @mfalkvidd
          @John-Mälarström - I have data timout to disabled which I think is correct.
          Are you sure the GW isnt rebooting? If you have a rebooting GW my guess would be a power issue.
          If not, maybe try another usb cable?
          • S sundberg84
            John Mälarström
            @sundberg84
            Hi
            I change the usb cable and are now supplying the Arduino Uno Rev3 with external 12v, 2A
            Unfortunately that did not help. If the gateway keeps rebooting, shouldent my sensors loose the connection and the ability to function and not update values in Domoticz?
            When I manually reboot the gateway I can see the power led go on and off and when it is ready,
            only the tx/rx led has activity.
              John Mälarström
              Hi
              Yesterday I noticed that the log was "normal again". I can not tell if it has to do with the addition of power supply or changing the usb cable or something else. Thank you guys for all help.
              /John
                John Mälarström
                Update... Solved!
                Again I got the entry:
                in the log.
                I found that I had a broken sensor. When checking the sketch for this sensor
                i noticed that I had enabled repeater function. After removing this faulty sensor, there are no more
                spamming in the Domoticz log file.
                  Update... Solved!
                  in the log.
                  shabba
                  @John-Mälarström I hit the same a while back. I had to disable all acks on my network to solve it on 2.1.1 - worked ok previously. I opened a thread about it here somewhere. Sounds like repeater/ack related.
                  • T Offline
                    T Offline
                    Tranber
                    wrote on last edited by Tranber
                    Dear all,
                    I encoutered te same issue with my USB Gateway.
                    I'm now powering it with an external 7.2V supply (VIN/GND), but still the same log list as mentionned up.
                    Any idea ?
                    //EDIT//
                    I've build on a bredboard a new one with other component. When power on, the Gateway reboot (I can see that in Domoticz). could it be a Sensor problem ?
                    2017-10-03 20:35:36.864 MySensors: Gateway Ready...
                    2017-10-03 20:35:36.939 MySensors: Gateway Version: 2.1.0
