PI 3 and Arduino uno: no communcation
I attached a nrf24l01 with 5 -> 3,3 V convertor to a PI3 and a Arduino uno.
Running mysgw on the PI shows no error.
The Arduino uno is also starting fine, but it cant' find the PI.I measured the 3.3V voltage and that's find. I don't see any drops.
I soldered a capacitor on the VCC of both nrf24l01.
Placing the PI and the Arduino closer togeher is also not helping.What else can I try?
PI logs:
mysgw: Starting gateway...
mysgw: TSM:INIT
mysgw: TSF:WUR:MS=0
mysgw: TSM:INIT:TSP OK
mysgw: TSM:INIT:GW MODE
mysgw: MCO:REG:NOT NEEDED
mysgw: MCO:BGN:STP
mysgw: MCO:BGN:INIT OK,TSP=1Arduino log:
3 TSM:INIT
4 TSF:WUR:MS=0
11 TSM:INIT:TSP OK
13 TSM:FPAR
15 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
2022 !TSM:FPAR:NO REPLY
2024 TSM:FPAR
2026 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
4034 !TSM:FPAR:NO REPLY
4036 TSM:FPAR
4038 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
6046 !TSM:FPAR:NO REPLY
6048 TSM:FPAR
6050 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK: -
Capacitor is soldered on both modules.
And I thought the Arduino is broadcasting to the GW to request a node ID?
Stef
I have Openhab running as controller.
But still, shouldn't I see any communication between the PI and Arduino?
Stef
you should, anyway just add the node id and try with mysensors library from development branch.
You may also try to make a USB gateway with another arduino and see if you see any change. If you have more radio modules try them too. Sometimes it is just a faulty radio module and you loose all that time for nothing :D
I finally had some time to do some further testing.
Switching to the development branch of MySensors solved my problem.
I have the feeling that the link is not really stable, but at least I can see data coming in.Stef
