  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
  • gusG gus
    Hi!
    Starting to learn signing. I use a parallell system (with another channel) where I could test signing before I went on my live system. For now I just use soft signing, it works perfect!
    Now, I just want to test a node (motionsensor) that include:
    The gateway has no signing feature (it has not gone thru personalition process) In my head, the node shall reject to connect to this gateway, but after the signing fails, it start to send data to the gateway. Did I miss something here?
    Debug text on node:
    0 MCO:BGN:INIT NODE,CP=RNNNAS--,VER=2.2.0-beta
    49 SGN:PER:OK
    83 SGN:INI:BND OK
    83 TSM:INIT
    86 TSF:WUR:MS=0
    94 TSM:INIT:TSP OK
    96 TSM:INIT:STATID=101
    98 TSF:SID:OK,ID=101
    100 TSM:FPAR
    102 SGN:SGN:NREQ=255
    139 TSF:MSG:SEND,101-101-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    684 TSF:MSG:READ,0-0-101,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    690 SGN:SKP:MSG CMD=3,TYPE=8
    692 TSF:MSG:FPAR OK,ID=0,D=1
    2148 TSM:FPAR:OK
    2148 TSM:ID
    2150 TSM:ID:OK
    2152 TSM:UPL
    2154 SGN:SGN:NREQ=0
    2158 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    2168 TSF:MSG:READ,0-0-101,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    2174 SGN:SKP:MSG CMD=3,TYPE=25
    2177 TSF:MSG:PONG RECV,HP=1
    2181 TSM:UPL:OK
    2183 TSM:READY:ID=101,PAR=0,DIS=1
    2187 SGN:PRE:SGN REQ
    2189 SGN:PRE:WHI NREQ
    2191 SGN:SGN:NREQ=0
    2195 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
    2203 SGN:PRE:XMT,TO=0
    2205 SGN:PRE:WAIT GW
    2207 TSF:MSG:READ,0-0-101,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    2213 SGN:SKP:MSG CMD=3,TYPE=15
    2217 SGN:SGN:NREQ=0
    2222 TSF:MSG:SEND,101-101-0-0,s=255,c=0,t=17,pt=0,l=10,sg=0,ft=0,st=OK:2.2.0-beta
    2232 SGN:SGN:NREQ=0
    2234 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    2248 TSF:MSG:READ,0-0-101,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    2254 !SGN:VER:NSG
    2256 !TSF:MSG:SIGN VERIFY FAIL
    2258 SGN:SGN:NREQ=0
    2263 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=11,pt=0,l=13,sg=0,ft=0,st=OK:Motion Sensor
    2273 SGN:SGN:NREQ=0
    2277 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    2285 SGN:SGN:NREQ=0
    2289 TSF:MSG:SEND,101-101-0-0,s=1,c=0,t=1,pt=0,l=0,sg=0,ft=0,st=OK:
    2295 MCO:REG:REQ
    2297 SGN:SGN:NREQ=0
    2301 TSF:MSG:SEND,101-101-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    2310 TSF:MSG:READ,0-0-101,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    2316 !SGN:VER:NSG
    2318 !TSF:MSG:SIGN VERIFY FAIL
    2322 MCO:BGN:STP
    2324 MCO:BGN:INIT OK,TSP=1
    2326 SGN:SGN:NREQ=0
    2330 TSF:MSG:SEND,101-101-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:1
    2338 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
    2344 TSF:TDI:TSL
    2347 MCO:SLP:WUP=1
    2349 TSF:TRI:TSB
    2351 SGN:SGN:NREQ=0
    2355 TSF:MSG:SEND,101-101-0-0,s=1,c=1,t=16,pt=0,l=1,sg=0,ft=0,st=OK:0
    2363 MCO:SLP:MS=120000,SMS=0,I1=1,M1=1,I2=255,M2=255
    2367 TSF:TDI:TSL
    AnticimexA
    AnticimexA
    Anticimex
    #416
    @gus what is it that you think is not working? Just because your node require signatures does not prevent the node from sending data to your gateway which does not require signatures.
    And as you can see in the log you get errors about missing signatures (and hence failed verifications) so it looks as expected to me.
    You could try to paste your log into the log parser to get a easier to read output.
    gusG 1 Reply Last reply
    • AnticimexA Anticimex
      gusG
      gusG
      gus
      @Anticimex Ok, just thought when signing failed, the node was halted :confused:
      So that control mechanism need to be implemented in my sketch then?
      Great, I will use the log parser!
      AnticimexA 1 Reply Last reply
      • gusG gus
        AnticimexA
        AnticimexA
        Anticimex
        @gus no, when signing verification fail, the message is just discarded
          gusG
          gusG
          gus
          @Anticimex Ahh, now I get it!! Thanks for helping me out here!
          • gusG gus
            AnticimexA
            AnticimexA
            Anticimex
            @gus always :) nice to hear that you have a fully functional signing rig. Happy signing!
            • ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              Hello @Anticimex
              Sometimes it happens that the Serial printing is not correct and it is okay when the baud rate is lower to 57600. I guess the default is 115200 when this error happens.
              ⸮ M⸮Se⸮so⸮s security p⸮r⸮o⸮alizer ⸮
              ⸮ C⸮n⸮igur⸮t⸮on set⸮i⸮g⸮ ⸮
              | * G⸮i⸮e⸮ ⸮e⸮s⸮nali⸮ation/⸮t⸮ra⸮e of key⸮ ⸮n AT⸮H⸮204A |
              | * ⸮T⸮HA204A based ⸮e⸮s⸮n⸮l⸮z⸮t⸮o⸮ ⸮
              ⸮ * Will l⸮ck ATSH⸮204⸮ c⸮n⸮i⸮u⸮atio⸮ |
              ⸮ * W⸮ll no⸮ req⸮i⸮e any UA⸮T co⸮fi⸮m⸮ti⸮ns ⸮
              | * ⸮i⸮l ⸮to⸮e ⸮MA⸮ key to A⸮SH⸮204A |
              | * Will store ⸮ES ke⸮ to ⸮E⸮R⸮M ⸮
              AnticimexA magpernM 2 Replies Last reply
                Hello @Anticimex
                AnticimexA
                AnticimexA
                Anticimex
                @ahmedadelhosni yes, this can happen on some targets. It depend on the quality and precision of the oscillator. If output looks garbled, reducing the baud rate is a good place to start.
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  @Anticimex so this has nothing to do with the quality of my overall node ? I mean as a reference that this node will be stable or not during operation.
                  I ordered my atmega smd from mouser and all passive componets too. Only pcbs are from dirtypcbs. I thought getting high quality from mouser would be better.
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @ahmedadelhosni
                    That is hard to say. There are many reports of atmega not being really good at handling 115200 at certain oscillator frequencies. So no, I don't think it directly hints at something being wrong with your hardware. But I cannot be sure of course :)
                      Hello @Anticimex
                      magpernM
                      magpernM
                      magpern
                      @ahmedadelhosni I had the same problem with serial speed on a few PCBs that I designed myself, design was based on existing mysensors PCBs. I could only run on 38k baud.
                      In my case it turned out to be a problem with the with of signal lines and power lines on the PCB. They where to small, and probably caused noise and bad through put, because when I widened the lines on the PCB, reordered them from fab house, then 115k baud worked again.
                      • magpernM magpern
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @Magnus-Pernemark I have also a modified version of Mysensebender node and the issue happened with some of the pcbs, not all of them. In your case I understood that it was a problem in all your pcbs. So maybe pcb quality from dirtypcbs was not that good with some of mine due to small width of lines.
                        • ahmedadelhosniA
                          ahmedadelhosniA
                          ahmedadelhosni
                          Hello @Anticimex
                          I was testing HW signing using latest dev and I got the following :+1:
                          My setup > GW : 8 Mhz internal clock
                          My node > : 8 Mhz internal clock ( with MySysBootloader OTA)
                          From Gateway debug:
                          0;255;3;0;9;53 MCO:BGN:INIT GW,CP=RNNGAA--,VER=2.2.0-beta
                          0;255;3;0;9;129 !SGN:PER:TAMPERED
                          0;255;3;0;9;161 SGN:INI:BND OK
                          0;255;3;0;9;169 TSM:INIT
                          0;255;3;0;9;178 TSF:WUR:MS=0
                          0;255;3;0;9;190 TSM:INIT:TSP OK
                          0;255;3;0;9;198 TSM:INIT:GW MODE
                          0;255;3;0;9;208 TSM:READY:ID=0,PAR=0,DIS=0
                          0;255;3;0;9;221 MCO:REG:NOT NEEDED
                          0;255;0;0;18;2.2.0-beta
                          0;255;3;0;9;231 MCO:BGN:STP
                          0;255;3;0;9;253 MCO:BGN:INIT OK,TSP=1
                          When I try to add node 4 : This happens
                          0;255;3;0;9;180430 TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=1,l=0,sg=0:0
                          0;255;3;0;9;180449 TSF:MSG:BC
                          0;255;3;0;9;180457 TSF:MSG:FPAR REQ,ID=4
                          0;255;3;0;9;180469 TSF:PNG:SEND,TO=0
                          0;255;3;0;9;180480 TSF:CKU:OK
                          0;255;3;0;9;180488 TSF:MSG:GWL OK
                          0;255;3;0;9;180768 SGN:SKP:MSG CMD=3,TYPE=8
                          0;255;3;0;9;180783 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          0;255;3;0;9;187224 TSF:MSG:READ,4-4-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
                          0;255;3;0;9;187244 !SGN:PRE:SGN NREQ,FROM=4 REJ
                          0;255;3;0;9;187256 SGN:PRE:SGN NREQ,TO=4
                          0;255;3;0;9;187269 SGN:PRE:WHI NREQ,TO=4
                          0;255;3;0;9;187279 SGN:SKP:MSG CMD=3,TYPE=15
                          0;255;3;0;9;187293 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          0;255;3;0;9;187316 SGN:PRE:XMT,TO=4
                          0;255;3;0;9;187576 TSF:MSG:READ,4-4-0,s=255,c=4,t=0,pt=6,l=10,sg=0:1E000100B0031E310102
                          4;255;4;0;0;1E000100B0031E310102
                          0;255;3;0;9;194334 TSF:MSG:READ,4-4-0,s=255,c=4,t=0,pt=6,l=10,sg=0:1E000100B0031E310102
                          0;255;3;0;9;201091 TSF:MSG:READ,4-4-0,s=255,c=4,t=0,pt=6,l=10,sg=0:1E000100B0031E310102
                          0;255;3;0;9;208238 TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          0;255;3;0;9;208257 TSF:MSG:BC
                          0;255;3;0;9;208265 TSF:MSG:FPAR REQ,ID=4
                          0;255;3;0;9;208275 TSF:PNG:SEND,TO=0
                          0;255;3;0;9;208285 TSF:CKU:OK
                          0;255;3;0;9;208293 TSF:MSG:GWL OK
                          0;255;3;0;9;208736 SGN:SKP:MSG CMD=3,TYPE=8
                          0;255;3;0;9;208750 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          0;255;3;0;9;210298 TSF:MSG:READ,4-4-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                          0;255;3;0;9;210317 TSF:MSG:PINGED,ID=4,HP=1
                          0;255;3;0;9;210329 SGN:SKP:MSG CMD=3,TYPE=25
                          0;255;3;0;9;210343 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                          0;255;3;0;9;210364 TSF:MSG:READ,4-4-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                          0;255;3;0;9;210384 SGN:PRE:SGN REQ,FROM=4
                          0;255;3;0;9;210397 SGN:PRE:SGN NREQ,TO=4
                          0;255;3;0;9;210407 SGN:PRE:WHI NREQ,TO=4
                          0;255;3;0;9;210417 SGN:SKP:MSG CMD=3,TYPE=15
                          0;255;3;0;9;210432 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
                          0;255;3;0;9;210454 SGN:PRE:XMT,TO=4
                          0;255;3;0;9;210464 TSF:MSG:READ,4-4-0,s=255,c=0,t=18,pt=0,l=10,sg=0:2.2.0-beta
                          4;255;0;0;18;2.2.0-beta
                          0;255;3;0;9;210487 TSF:MSG:READ,4-4-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
                          4;255;3;0;6;0
                          0;255;3;0;9;212459 TSF:MSG:READ,4-4-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Relay Signing
                          4;255;3;0;11;Relay Signing
                          0;255;3;0;9;212484 TSF:MSG:READ,4-4-0,s=255,c=3,t=12,pt=0,l=5,sg=0:1.2.1
                          4;255;3;0;12;1.2.1
                          0;255;3;0;9;212510 TSF:MSG:READ,4-4-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
                          4;3;0;0;3;
                          0;255;3;0;9;212531 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          0;255;3;0;9;212551 !SGN:SGN:STATE
                          0;255;3;0;9;212561 !TSF:MSG:SIGN FAIL
                          0;255;3;0;9;214489 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          0;255;3;0;9;214507 !SGN:SGN:STATE
                          0;255;3;0;9;214517 !TSF:MSG:SIGN FAIL
                          0;255;3;0;9;216510 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          0;255;3;0;9;216528 !SGN:SGN:STATE
                          0;255;3;0;9;216539 !TSF:MSG:SIGN FAIL
                          0;255;3;0;9;218533 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
                          0;255;3;0;9;218552 !SGN:SGN:STATE
                          0;255;3;0;9;218560 !TSF:MSG:SIGN FAIL
                          My gateway sketch ::
                          // Enable serial gateway
                          #define MY_GATEWAY_SERIAL
                          #if F_CPU == 8000000L
                          #define MY_BAUD_RATE 38400
                          #define MY_SIGNING_ATSHA204
                          // SETTINGS FOR MY_SIGNING_ATSHA204
                          #define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
                          Node code :
                          //#define MY_RADIO_NRF5_ESB
                          //#define MY_RADIO_RFM95
                          #define MY_REPEATER_FEATURE
                          // normal function call is here
                          I do personalized my nodes with the same HMAC as described in the docs.
                          I got this and I run the same sketch on all node including the gateway :
                          | This device has now been personalized. Run this sketch with its current settings   |
                          | on all the devices in your network that have security enabled.
                          First question :
                          I have searched for similar issues for 0;255;3;0;9;129 !SGN:PER:TAMPERED but I couldn't find.
                          Second one : Was signing tested recently with the latest dev branch ? because I guess I read in one of the posts that it has not been tested since a while.
                          THanks for the help.
                            Hello @Anticimex
                            From Gateway debug:
                            4;255;3;0;6;0
                            4;255;3;0;12;1.2.1
                            4;3;0;0;3;
                            Node code :
                            First question :
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @ahmedadelhosni
                            First answer: TAMPERED suggest that either you have had your personalized data altered between the time of personalization and usage. Or, you personalized your device using the personalizer from the official release or a early development version. The integrity check is a relatively new addition on the development branch.
                            Second answer: to my knowledge, signing works fine on the development branch.
                            ahmedadelhosniA 2 Replies Last reply
                              @ahmedadelhosni
                              ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              @Anticimex Okay I managed to get it working .. I guess :dancer:
                              After I posted here I decided to go through the code to see when this TAMPERED is printed, so I thought from debugging that this is related to hwReadConfigBlock so I decided to clear the EEPROM, re personilize the gateway and reflash the GW sketch ... Now I get SGN:PER:OK
                              I then reflashed my sensor node again and I guess it is working now .. I tried sending 1;1;1;1;2;1 through serial and this is the result
                              0;255;3;0;9;429250 SGN:SKP:MSG CMD=3,TYPE=16
                              0;255;3;0;9;429266 TSF:MSG:SEND,0-0-1-1,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                              0;255;3;0;9;429287 SGN:SGN:NCE REQ,TO=1
                              0;255;3;0;9;429391 TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                              0;255;3;0;9;429412 SGN:NCE:FROM=1
                              0;255;3;0;9;429422 SGN:BND:NONCE=882805C056A850AF00469170FEB702EB5B09EC1FEE51D2F22DAAAAAAAAAAAAAA
                              0;255;3;0;9;429557 SGN:BND:HMAC=6DB4F3CF2F17E42A5508B4A411CA1478582D052A249A278689D26A7A0B96FBA2
                              0;255;3;0;9;429584 SGN:SGN:SGN
                              0;255;3;0;9;429594 TSF:MSG:SEND,0-0-1-1,s=1,c=1,t=2,pt=0,l=1,sg=1,ft=0,st=OK:1
                              0;255;3;0;9;429740 TSF:MSG:READ,1-1-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                              0;255;3;0;9;429758 TSF:MSG:ACK
                              1;1;1;1;2;1
                              I guess this means that signing is working .. I did try also to add another gateway with no signing and it only discovered my node (1) but I got NACK when trying to send to it.
                              Am I correct in my analysis ?
                              Thanks for the help.
                                1;1;1;1;2;1
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @ahmedadelhosni that looks good to me. You can use the log parser on the homepage to get a more readable interpretation of the debug log.
                                  ahmedadelhosniA
                                  ahmedadelhosniA
                                  ahmedadelhosni
                                  @Anticimex thanks a lot.
                                  I have another question please. I use atsha hw, do this setup save anything in the eeprom ?
                                    @ahmedadelhosni
                                    ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    @Anticimex sorry for lots of questions but can u explain in more details what you meant by " that either you have had your personalized data altered between the time of personalization and usage" ?
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @ahmedadelhosni if you use atsha204a then only AES key for encryption is stored in eeprom by the personalizer. It is not used unless you activate encryption.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @ahmedadelhosni the integrity check that could emit a TAMPERED message is intended to ensure that signing backend does not use corrupted data.
                                        This is done by having the personalizer calculate a checksum of the data it wrote. Then the signing backend validates the data read against the checksum and of there is a mismatch then it reports that personalization has been tampered.
                                        This is to ensure that users don't get confused by signing not working if they have accidentally erased or manipulated the personalization data.
                                        • P
                                          P
                                          Proyectos Integrasoft
                                          wrote on last edited by gohan
                                          #435
                                          Hello! I'm new to this and I've been using MySensors to communicate a few nodes in my house with a gateway ... Everything I've done without problems until now that I want to sign the data ...
                                          I have done the following:
                                          1. Ah my sketch (node) simply added the following statement:
                                          #define MY_SIGNING_SOFT
                                          #define MY_SIGNING_SOFT_RANDOMSEED_PIN A3
                                          (It's a mini pro 3.3 v)
                                          1. My GW added this:
                                            #define MY_SIGNING_SOFT_RANDOMSEED_PIN A7
                                            (Nano 5v)
                                          and already ... everything else I left it still, as I was working.
                                          Now ... This is what the log of my node shows me:
                                          0 MCO:BGN:INIT NODE,CP=RNNNAS-,VER=2.1.1
                                          4 TSM:INIT
                                          4 TSF:WUR:MS=0
                                          12 TSM:INIT:TSP OK
                                          14 TSM:INIT:STATID=110
                                          16 TSF:SID:OK,ID=110
                                          18 TSM:FPAR
                                          55 TSF:MSG:SEND,110-110-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          698 TSF:MSG:READ,0-0-110,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          704 TSF:MSG:FPAR OK,ID=0,D=1
                                          2064 TSM:FPAR:OK
                                          2064 TSM:ID
                                          2066 TSM:ID:OK
                                          2068 TSM:UPL
                                          2074 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          2084 TSF:MSG:READ,0-0-110,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          2091 TSF:MSG:PONG RECV,HP=1
                                          2093 TSM:UPL:OK
                                          2095 TSM:READY:ID=110,PAR=0,DIS=1
                                          2119 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                          2129 TSF:MSG:READ,0-0-110,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                          2154 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                                          2177 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=0:543E0871819CBE4290536346F5231CBEF4C8F70A344B289CEA
                                          2394 !TSF:MSG:SEND,110-110-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=NACK:2.1.1
                                          2451 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                                          2459 !TSF:MSG:SIGN FAIL
                                          4509 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                                          4569 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=5,st=NACK:
                                          4577 !TSF:MSG:SIGN FAIL
                                          4612 TSF:MSG:SEND,110-110-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=7,st=OK:
                                          4632 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=1:5D4997715396BEFB979106A93EF22C9E1DBAE516012E040FAE
                                          4851 !TSF:MSG:SEND,110-110-0-0,s=2,c=0,t=3,pt=0,l=11,sg=1,ft=0,st=NACK:Water Valve
                                          4909 !TSF:MSG:SEND,110-110-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                                          4915 !TSF:MSG:SIGN FAIL
                                          4966 !TSF:MSG:SEND,110-110-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                                          4974 !TSF:MSG:SIGN FAIL
                                          5025 !TSF:MSG:SEND,110-110-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=5,st=NACK:
                                          5033 !TSF:MSG:SIGN FAIL
                                          5083 !TSF:MSG:SEND,110-110-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=7,st=NACK:
                                          5091 !TSF:MSG:SIGN FAIL
                                          5142 !TSF:MSG:SEND,110-110-0-0,s=6,c=3,t=16,pt=0,l=0,sg=1,ft=9,st=NACK:
                                          5150 !TSF:MSG:SIGN FAIL
                                          5199 !TSF:MSG:SEND,110-110-0-0,s=7,c=3,t=16,pt=0,l=0,sg=1,ft=11,st=NACK:
                                          5208 !TSF:MSG:SIGN FAIL
                                          5212 MCO:REG:REQ
                                          5261 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=13,st=NACK:2
                                          5269 !TSM:READY:UPL FAIL,SNP
                                          5273 TSM:FPAR
                                          5308 TSF:MSG:SEND,110-110-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=14,st=OK:
                                          7270 !TSF:SND:TNR
                                          7319 !TSM:FPAR:NO REPLY
                                          7321 TSM:FPAR
                                          7358 TSF:MSG:SEND,110-110-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                                          8204 TSF:MSG:READ,0-0-110,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                                          8210 TSF:MSG:FPAR OK,ID=0,D=1
                                          9271 !TSF:SND:TNR
                                          9367 TSM:FPAR:OK
                                          9367 TSM:ID
                                          9369 TSM:ID:OK
                                          9371 TSM:UPL
                                          9375 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          9385 TSF:MSG:READ,0-0-110,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                                          9392 TSF:MSG:PONG RECV,HP=1
                                          9394 TSM:UPL:OK
                                          9396 TSM:READY:ID=110,PAR=0,DIS=1
                                          9412 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                          9420 TSF:MSG:READ,0-0-110,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                          9457 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                                          9480 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=1:20169962FD569DAE7F6D69702C2AD69B8492264A3FC2450E50
                                          9697 !TSF:MSG:SEND,110-110-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=NACK:2.1.1
                                          9754 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                                          9762 !TSF:MSG:SIGN FAIL
                                          11812 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                                          11821 !TSF:MSG:SIGN FAIL
                                          11872 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=5,st=NACK:
                                          11880 !TSF:MSG:SIGN FAIL
                                          11931 !TSF:MSG:SEND,110-110-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=7,st=NACK:
                                          11939 !TSF:MSG:SIGN FAIL
                                          11988 !TSF:MSG:SEND,110-110-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=9,st=NACK:
                                          11997 !TSF:MSG:SIGN FAIL
                                          12048 !TSF:MSG:SEND,110-110-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=11,st=NACK:
                                          12056 !TSF:MSG:SIGN FAIL
                                          12107 !TSF:MSG:SEND,110-110-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=13,st=NACK:
                                          12115 !TSF:MSG:SIGN FAIL
                                          12167 !TSF:MSG:SEND,110-110-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=15,st=NACK:
                                          12175 !TSF:MSG:SIGN FAIL
                                          12224 !TSF:MSG:SEND,110-110-0-0,s=6,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                                          12232 !TSF:MSG:SIGN FAIL
                                          12283 !TSF:MSG:SEND,110-110-0-0,s=7,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                                          12292 !TSF:MSG:SIGN FAIL
                                          12294 MCO:REG:REQ
                                          12343 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=5,st=OK:2
                                          12351 TSF:MSG:READ,0-0-110,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                          12435 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:EC4D4496E138DD8C83E9837D130B8AD51D0B5BE66E9CC103EB14399 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=1,st=NACK:2
                                          16427 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=2,st=OK:2
                                          16437 TSF:MSG:READ,0-0-110,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                          16519 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:CE22C6ECF337A5713AD0677785547E59FB49FB964B79EFAB88
                                          16609 TSF:MSG:READ,0-0-110,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                                          16773 !TSF:MSG:SIGN VERIFY FAIL
                                          16777 TSF:MSG:READ,0-0-110,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                                          16783 !TSF:MSG:SIGN VERIFY FAIL
                                          16787 MCO:BGN:STP
                                          16836 !TSF:MSG:SEND,110-110-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                                          16844 !TSF:MSG:SIGN FAIL
                                          16896 !TSF:MSG:SEND,110-110-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
                                          16904 !TSF:MSG:SIGN FAIL
                                          16906 MCO:BGN:INIT OK,TSP=1
                                          Valve Change Detected ,
                                          Reporting battery
                                          Main Battery reported: 1076
                                          16959 !TSF:MSG:SEND,110-110-0-0,s=6,c=3,t=16,pt=0,l=0,sg=1,ft=4,st=NACK:
                                          16967 !TSF:MSG:SIGN FAIL
                                          Bridge Battery reported: 0
                                          17018 !TSF:MSG:SEND,110-110-0-0,s=7,c=3,t=16,pt=0,l=0,sg=1,ft=6,st=NACK:
                                          17027 !TSF:MSG:SIGN FAIL
                                          next BATT report TIME selected
                                          17037 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=8,st=OK:
                                          17059 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=1:A49B044E02033467D7D7220BA28FBFEA6C9ED2EFA7C4DE16CD
                                          17276 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=NACK:100
                                          Both to Low in Bridge .....
                                          And this is what the log of the GW shows me:
                                          0;255;3;0;9;TSF:MSG:READ,110-110-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSF:MSG:BC
                                          0;255;3;0;9;TSF:MSG:FPAR REQ,ID=110
                                          0;255;3;0;9;TSF:PNG:SEND,TO=0
                                          0;255;3;0;9;TSF:CKU:OK
                                          0;255;3;0;9;TSF:MSG:GWL OK
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                                          0;255;3;0;9;TSF:MSG:PINGED,ID=110,HP=1
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                                          0;255;3;0;9;!TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0101
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:E36F33C7F0FAB62159035EE11FBC031CE96304C15907FCA866
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:9CB25AA3C9DDAA7EB1D4EC4FEE49B3ADDA743FB87AC1844809
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                                          0;255;3;0;9;!TSF:MSG:SIGN VERIFY FAIL
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:A2FFF069812565DE86C4BE5517F7F497141208817C51412562
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F2503A2DF3D42714F93FF7386FC7E4087E6FFC31B86D0449BF
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=12,pt=0,l=3,sg=1:2.3
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:3DB72D0ECA0E7C5546CB68782E93D66A0BA86F7DBD05714798
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=2,c=0,t=3,pt=0,l=11,sg=1:Water Valve
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:272DE6ED5FDDDB14B704CF36D32DA37D3A3C32D4F7F30E4D86
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:05E7E841D621BB9E5F323082CBF40509B1B9D100C6EF955156
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:89A2A933A3310EE14AF048E3A786FD1432608BBD361B366DC0
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:554A491A49FA49B278B8269CEF0748346A9980A395161F3356
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:6220CC178F89ADD1F7AC819695C344770835A96CBAFB2D6848
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=6,c=3,t=16,pt=0,l=0,sg=1:
                                          0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:DA701B4D253E0FC19BB7FA0D2699D1C9CE7F7E7B89586ED8A2
                                          0;255;3;0;9;TSF:MSG:READ,110-110-0,s=6,c=0,t=30,pt=0,l=15,sg=1:Main Batt Volts
                                          Can you help me please!?
                                          I read everything about the signed but the truth I am somewhat confused ... If you could provide me a sketch of a node and a gateway that work for me to guide me I would appreciate it.
                                          Thank you very much in advance!
