  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
    Hello @Anticimex
    Sometimes it happens that the Serial printing is not correct and it is okay when the baud rate is lower to 57600. I guess the default is 115200 when this error happens.
    ⸮ M⸮Se⸮so⸮s security p⸮r⸮o⸮alizer ⸮
    ⸮ C⸮n⸮igur⸮t⸮on set⸮i⸮g⸮ ⸮
    | * G⸮i⸮e⸮ ⸮e⸮s⸮nali⸮ation/⸮t⸮ra⸮e of key⸮ ⸮n AT⸮H⸮204A |
    | * ⸮T⸮HA204A based ⸮e⸮s⸮n⸮l⸮z⸮t⸮o⸮ ⸮
    ⸮ * Will l⸮ck ATSH⸮204⸮ c⸮n⸮i⸮u⸮atio⸮ |
    ⸮ * W⸮ll no⸮ req⸮i⸮e any UA⸮T co⸮fi⸮m⸮ti⸮ns ⸮
    | * ⸮i⸮l ⸮to⸮e ⸮MA⸮ key to A⸮SH⸮204A |
    | * Will store ⸮ES ke⸮ to ⸮E⸮R⸮M ⸮
    AnticimexA
    AnticimexA
    Anticimex
    @ahmedadelhosni yes, this can happen on some targets. It depend on the quality and precision of the oscillator. If output looks garbled, reducing the baud rate is a good place to start.
    • AnticimexA Anticimex
      ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      @Anticimex so this has nothing to do with the quality of my overall node ? I mean as a reference that this node will be stable or not during operation.
      I ordered my atmega smd from mouser and all passive componets too. Only pcbs are from dirtypcbs. I thought getting high quality from mouser would be better.
      AnticimexA 1 Reply Last reply
        AnticimexA
        AnticimexA
        Anticimex
        @ahmedadelhosni
        That is hard to say. There are many reports of atmega not being really good at handling 115200 at certain oscillator frequencies. So no, I don't think it directly hints at something being wrong with your hardware. But I cannot be sure of course :)
          Hello @Anticimex
          magpernM
          magpernM
          magpern
          @ahmedadelhosni I had the same problem with serial speed on a few PCBs that I designed myself, design was based on existing mysensors PCBs. I could only run on 38k baud.
          In my case it turned out to be a problem with the with of signal lines and power lines on the PCB. They where to small, and probably caused noise and bad through put, because when I widened the lines on the PCB, reordered them from fab house, then 115k baud worked again.
          • magpernM magpern
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            @Magnus-Pernemark I have also a modified version of Mysensebender node and the issue happened with some of the pcbs, not all of them. In your case I understood that it was a problem in all your pcbs. So maybe pcb quality from dirtypcbs was not that good with some of mine due to small width of lines.
            • ahmedadelhosniA
              ahmedadelhosniA
              ahmedadelhosni
              Hello @Anticimex
              I was testing HW signing using latest dev and I got the following :+1:
              My setup > GW : 8 Mhz internal clock
              My node > : 8 Mhz internal clock ( with MySysBootloader OTA)
              From Gateway debug:
              0;255;3;0;9;53 MCO:BGN:INIT GW,CP=RNNGAA--,VER=2.2.0-beta
              0;255;3;0;9;129 !SGN:PER:TAMPERED
              0;255;3;0;9;161 SGN:INI:BND OK
              0;255;3;0;9;169 TSM:INIT
              0;255;3;0;9;178 TSF:WUR:MS=0
              0;255;3;0;9;190 TSM:INIT:TSP OK
              0;255;3;0;9;198 TSM:INIT:GW MODE
              0;255;3;0;9;208 TSM:READY:ID=0,PAR=0,DIS=0
              0;255;3;0;9;221 MCO:REG:NOT NEEDED
              0;255;0;0;18;2.2.0-beta
              0;255;3;0;9;231 MCO:BGN:STP
              0;255;3;0;9;253 MCO:BGN:INIT OK,TSP=1
              When I try to add node 4 : This happens
              0;255;3;0;9;180430 TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=1,l=0,sg=0:0
              0;255;3;0;9;180449 TSF:MSG:BC
              0;255;3;0;9;180457 TSF:MSG:FPAR REQ,ID=4
              0;255;3;0;9;180469 TSF:PNG:SEND,TO=0
              0;255;3;0;9;180480 TSF:CKU:OK
              0;255;3;0;9;180488 TSF:MSG:GWL OK
              0;255;3;0;9;180768 SGN:SKP:MSG CMD=3,TYPE=8
              0;255;3;0;9;180783 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              0;255;3;0;9;187224 TSF:MSG:READ,4-4-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
              0;255;3;0;9;187244 !SGN:PRE:SGN NREQ,FROM=4 REJ
              0;255;3;0;9;187256 SGN:PRE:SGN NREQ,TO=4
              0;255;3;0;9;187269 SGN:PRE:WHI NREQ,TO=4
              0;255;3;0;9;187279 SGN:SKP:MSG CMD=3,TYPE=15
              0;255;3;0;9;187293 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              0;255;3;0;9;187316 SGN:PRE:XMT,TO=4
              0;255;3;0;9;187576 TSF:MSG:READ,4-4-0,s=255,c=4,t=0,pt=6,l=10,sg=0:1E000100B0031E310102
              4;255;4;0;0;1E000100B0031E310102
              0;255;3;0;9;194334 TSF:MSG:READ,4-4-0,s=255,c=4,t=0,pt=6,l=10,sg=0:1E000100B0031E310102
              0;255;3;0;9;201091 TSF:MSG:READ,4-4-0,s=255,c=4,t=0,pt=6,l=10,sg=0:1E000100B0031E310102
              0;255;3;0;9;208238 TSF:MSG:READ,4-4-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
              0;255;3;0;9;208257 TSF:MSG:BC
              0;255;3;0;9;208265 TSF:MSG:FPAR REQ,ID=4
              0;255;3;0;9;208275 TSF:PNG:SEND,TO=0
              0;255;3;0;9;208285 TSF:CKU:OK
              0;255;3;0;9;208293 TSF:MSG:GWL OK
              0;255;3;0;9;208736 SGN:SKP:MSG CMD=3,TYPE=8
              0;255;3;0;9;208750 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
              0;255;3;0;9;210298 TSF:MSG:READ,4-4-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
              0;255;3;0;9;210317 TSF:MSG:PINGED,ID=4,HP=1
              0;255;3;0;9;210329 SGN:SKP:MSG CMD=3,TYPE=25
              0;255;3;0;9;210343 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
              0;255;3;0;9;210364 TSF:MSG:READ,4-4-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
              0;255;3;0;9;210384 SGN:PRE:SGN REQ,FROM=4
              0;255;3;0;9;210397 SGN:PRE:SGN NREQ,TO=4
              0;255;3;0;9;210407 SGN:PRE:WHI NREQ,TO=4
              0;255;3;0;9;210417 SGN:SKP:MSG CMD=3,TYPE=15
              0;255;3;0;9;210432 TSF:MSG:SEND,0-0-4-4,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
              0;255;3;0;9;210454 SGN:PRE:XMT,TO=4
              0;255;3;0;9;210464 TSF:MSG:READ,4-4-0,s=255,c=0,t=18,pt=0,l=10,sg=0:2.2.0-beta
              4;255;0;0;18;2.2.0-beta
              0;255;3;0;9;210487 TSF:MSG:READ,4-4-0,s=255,c=3,t=6,pt=1,l=1,sg=0:0
              4;255;3;0;6;0
              0;255;3;0;9;212459 TSF:MSG:READ,4-4-0,s=255,c=3,t=11,pt=0,l=13,sg=0:Relay Signing
              4;255;3;0;11;Relay Signing
              0;255;3;0;9;212484 TSF:MSG:READ,4-4-0,s=255,c=3,t=12,pt=0,l=5,sg=0:1.2.1
              4;255;3;0;12;1.2.1
              0;255;3;0;9;212510 TSF:MSG:READ,4-4-0,s=3,c=0,t=3,pt=0,l=0,sg=0:
              4;3;0;0;3;
              0;255;3;0;9;212531 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              0;255;3;0;9;212551 !SGN:SGN:STATE
              0;255;3;0;9;212561 !TSF:MSG:SIGN FAIL
              0;255;3;0;9;214489 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              0;255;3;0;9;214507 !SGN:SGN:STATE
              0;255;3;0;9;214517 !TSF:MSG:SIGN FAIL
              0;255;3;0;9;216510 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              0;255;3;0;9;216528 !SGN:SGN:STATE
              0;255;3;0;9;216539 !TSF:MSG:SIGN FAIL
              0;255;3;0;9;218533 TSF:MSG:READ,4-4-0,s=255,c=3,t=26,pt=1,l=1,sg=0:2
              0;255;3;0;9;218552 !SGN:SGN:STATE
              0;255;3;0;9;218560 !TSF:MSG:SIGN FAIL
              My gateway sketch ::
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              #if F_CPU == 8000000L
              #define MY_BAUD_RATE 38400
              #define MY_SIGNING_ATSHA204
              // SETTINGS FOR MY_SIGNING_ATSHA204
              #define MY_SIGNING_ATSHA204_PIN 17 //!< A3 - pin where ATSHA204 is attached
              Node code :
              //#define MY_RADIO_NRF5_ESB
              //#define MY_RADIO_RFM95
              #define MY_REPEATER_FEATURE
              // normal function call is here
              I do personalized my nodes with the same HMAC as described in the docs.
              I got this and I run the same sketch on all node including the gateway :
              | This device has now been personalized. Run this sketch with its current settings   |
              | on all the devices in your network that have security enabled.
              First question :
              I have searched for similar issues for 0;255;3;0;9;129 !SGN:PER:TAMPERED but I couldn't find.
              Second one : Was signing tested recently with the latest dev branch ? because I guess I read in one of the posts that it has not been tested since a while.
              THanks for the help.
                Hello @Anticimex
                From Gateway debug:
                4;255;3;0;6;0
                4;255;3;0;12;1.2.1
                4;3;0;0;3;
                Node code :
                First question :
                AnticimexA
                AnticimexA
                Anticimex
                @ahmedadelhosni
                First answer: TAMPERED suggest that either you have had your personalized data altered between the time of personalization and usage. Or, you personalized your device using the personalizer from the official release or a early development version. The integrity check is a relatively new addition on the development branch.
                Second answer: to my knowledge, signing works fine on the development branch.
                ahmedadelhosniA 2 Replies Last reply
                  @ahmedadelhosni
                  ahmedadelhosniA
                  ahmedadelhosniA
                  ahmedadelhosni
                  @Anticimex Okay I managed to get it working .. I guess :dancer:
                  After I posted here I decided to go through the code to see when this TAMPERED is printed, so I thought from debugging that this is related to hwReadConfigBlock so I decided to clear the EEPROM, re personilize the gateway and reflash the GW sketch ... Now I get SGN:PER:OK
                  I then reflashed my sensor node again and I guess it is working now .. I tried sending 1;1;1;1;2;1 through serial and this is the result
                  0;255;3;0;9;429250 SGN:SKP:MSG CMD=3,TYPE=16
                  0;255;3;0;9;429266 TSF:MSG:SEND,0-0-1-1,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                  0;255;3;0;9;429287 SGN:SGN:NCE REQ,TO=1
                  0;255;3;0;9;429391 TSF:MSG:READ,1-1-0,s=255,c=3,t=17,pt=6,l=25,sg=0:<NONCE>
                  0;255;3;0;9;429412 SGN:NCE:FROM=1
                  0;255;3;0;9;429422 SGN:BND:NONCE=882805C056A850AF00469170FEB702EB5B09EC1FEE51D2F22DAAAAAAAAAAAAAA
                  0;255;3;0;9;429557 SGN:BND:HMAC=6DB4F3CF2F17E42A5508B4A411CA1478582D052A249A278689D26A7A0B96FBA2
                  0;255;3;0;9;429584 SGN:SGN:SGN
                  0;255;3;0;9;429594 TSF:MSG:SEND,0-0-1-1,s=1,c=1,t=2,pt=0,l=1,sg=1,ft=0,st=OK:1
                  0;255;3;0;9;429740 TSF:MSG:READ,1-1-0,s=1,c=1,t=2,pt=0,l=1,sg=0:1
                  0;255;3;0;9;429758 TSF:MSG:ACK
                  1;1;1;1;2;1
                  I guess this means that signing is working .. I did try also to add another gateway with no signing and it only discovered my node (1) but I got NACK when trying to send to it.
                  Am I correct in my analysis ?
                  Thanks for the help.
                    1;1;1;1;2;1
                    AnticimexA
                    AnticimexA
                    Anticimex
                    @ahmedadelhosni that looks good to me. You can use the log parser on the homepage to get a more readable interpretation of the debug log.
                      ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      @Anticimex thanks a lot.
                      I have another question please. I use atsha hw, do this setup save anything in the eeprom ?
                        @ahmedadelhosni
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @Anticimex sorry for lots of questions but can u explain in more details what you meant by " that either you have had your personalized data altered between the time of personalization and usage" ?
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @ahmedadelhosni if you use atsha204a then only AES key for encryption is stored in eeprom by the personalizer. It is not used unless you activate encryption.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @ahmedadelhosni the integrity check that could emit a TAMPERED message is intended to ensure that signing backend does not use corrupted data.
                            This is done by having the personalizer calculate a checksum of the data it wrote. Then the signing backend validates the data read against the checksum and of there is a mismatch then it reports that personalization has been tampered.
                            This is to ensure that users don't get confused by signing not working if they have accidentally erased or manipulated the personalization data.
                            • P
                              P
                              Proyectos Integrasoft
                              wrote on last edited by gohan
                              #435
                              Hello! I'm new to this and I've been using MySensors to communicate a few nodes in my house with a gateway ... Everything I've done without problems until now that I want to sign the data ...
                              I have done the following:
                              1. Ah my sketch (node) simply added the following statement:
                              #define MY_SIGNING_SOFT
                              #define MY_SIGNING_SOFT_RANDOMSEED_PIN A3
                              (It's a mini pro 3.3 v)
                              1. My GW added this:
                                #define MY_SIGNING_SOFT_RANDOMSEED_PIN A7
                                (Nano 5v)
                              and already ... everything else I left it still, as I was working.
                              Now ... This is what the log of my node shows me:
                              0 MCO:BGN:INIT NODE,CP=RNNNAS-,VER=2.1.1
                              4 TSM:INIT
                              4 TSF:WUR:MS=0
                              12 TSM:INIT:TSP OK
                              14 TSM:INIT:STATID=110
                              16 TSF:SID:OK,ID=110
                              18 TSM:FPAR
                              55 TSF:MSG:SEND,110-110-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              698 TSF:MSG:READ,0-0-110,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              704 TSF:MSG:FPAR OK,ID=0,D=1
                              2064 TSM:FPAR:OK
                              2064 TSM:ID
                              2066 TSM:ID:OK
                              2068 TSM:UPL
                              2074 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              2084 TSF:MSG:READ,0-0-110,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              2091 TSF:MSG:PONG RECV,HP=1
                              2093 TSM:UPL:OK
                              2095 TSM:READY:ID=110,PAR=0,DIS=1
                              2119 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                              2129 TSF:MSG:READ,0-0-110,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                              2154 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=0,ft=0,st=OK:
                              2177 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=0:543E0871819CBE4290536346F5231CBEF4C8F70A344B289CEA
                              2394 !TSF:MSG:SEND,110-110-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=NACK:2.1.1
                              2451 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                              2459 !TSF:MSG:SIGN FAIL
                              4509 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                              4569 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=5,st=NACK:
                              4577 !TSF:MSG:SIGN FAIL
                              4612 TSF:MSG:SEND,110-110-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=7,st=OK:
                              4632 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=1:5D4997715396BEFB979106A93EF22C9E1DBAE516012E040FAE
                              4851 !TSF:MSG:SEND,110-110-0-0,s=2,c=0,t=3,pt=0,l=11,sg=1,ft=0,st=NACK:Water Valve
                              4909 !TSF:MSG:SEND,110-110-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                              4915 !TSF:MSG:SIGN FAIL
                              4966 !TSF:MSG:SEND,110-110-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                              4974 !TSF:MSG:SIGN FAIL
                              5025 !TSF:MSG:SEND,110-110-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=5,st=NACK:
                              5033 !TSF:MSG:SIGN FAIL
                              5083 !TSF:MSG:SEND,110-110-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=7,st=NACK:
                              5091 !TSF:MSG:SIGN FAIL
                              5142 !TSF:MSG:SEND,110-110-0-0,s=6,c=3,t=16,pt=0,l=0,sg=1,ft=9,st=NACK:
                              5150 !TSF:MSG:SIGN FAIL
                              5199 !TSF:MSG:SEND,110-110-0-0,s=7,c=3,t=16,pt=0,l=0,sg=1,ft=11,st=NACK:
                              5208 !TSF:MSG:SIGN FAIL
                              5212 MCO:REG:REQ
                              5261 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=13,st=NACK:2
                              5269 !TSM:READY:UPL FAIL,SNP
                              5273 TSM:FPAR
                              5308 TSF:MSG:SEND,110-110-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=14,st=OK:
                              7270 !TSF:SND:TNR
                              7319 !TSM:FPAR:NO REPLY
                              7321 TSM:FPAR
                              7358 TSF:MSG:SEND,110-110-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
                              8204 TSF:MSG:READ,0-0-110,s=255,c=3,t=8,pt=1,l=1,sg=0:0
                              8210 TSF:MSG:FPAR OK,ID=0,D=1
                              9271 !TSF:SND:TNR
                              9367 TSM:FPAR:OK
                              9367 TSM:ID
                              9369 TSM:ID:OK
                              9371 TSM:UPL
                              9375 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
                              9385 TSF:MSG:READ,0-0-110,s=255,c=3,t=25,pt=1,l=1,sg=0:1
                              9392 TSF:MSG:PONG RECV,HP=1
                              9394 TSM:UPL:OK
                              9396 TSM:READY:ID=110,PAR=0,DIS=1
                              9412 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                              9420 TSF:MSG:READ,0-0-110,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                              9457 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=OK:
                              9480 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=1:20169962FD569DAE7F6D69702C2AD69B8492264A3FC2450E50
                              9697 !TSF:MSG:SEND,110-110-0-0,s=255,c=0,t=17,pt=0,l=5,sg=1,ft=0,st=NACK:2.1.1
                              9754 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                              9762 !TSF:MSG:SIGN FAIL
                              11812 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                              11821 !TSF:MSG:SIGN FAIL
                              11872 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=5,st=NACK:
                              11880 !TSF:MSG:SIGN FAIL
                              11931 !TSF:MSG:SEND,110-110-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=7,st=NACK:
                              11939 !TSF:MSG:SIGN FAIL
                              11988 !TSF:MSG:SEND,110-110-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=9,st=NACK:
                              11997 !TSF:MSG:SIGN FAIL
                              12048 !TSF:MSG:SEND,110-110-0-0,s=3,c=3,t=16,pt=0,l=0,sg=1,ft=11,st=NACK:
                              12056 !TSF:MSG:SIGN FAIL
                              12107 !TSF:MSG:SEND,110-110-0-0,s=4,c=3,t=16,pt=0,l=0,sg=1,ft=13,st=NACK:
                              12115 !TSF:MSG:SIGN FAIL
                              12167 !TSF:MSG:SEND,110-110-0-0,s=5,c=3,t=16,pt=0,l=0,sg=1,ft=15,st=NACK:
                              12175 !TSF:MSG:SIGN FAIL
                              12224 !TSF:MSG:SEND,110-110-0-0,s=6,c=3,t=16,pt=0,l=0,sg=1,ft=1,st=NACK:
                              12232 !TSF:MSG:SIGN FAIL
                              12283 !TSF:MSG:SEND,110-110-0-0,s=7,c=3,t=16,pt=0,l=0,sg=1,ft=3,st=NACK:
                              12292 !TSF:MSG:SIGN FAIL
                              12294 MCO:REG:REQ
                              12343 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=5,st=OK:2
                              12351 TSF:MSG:READ,0-0-110,s=255,c=3,t=16,pt=0,l=0,sg=0:
                              12435 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=NACK:EC4D4496E138DD8C83E9837D130B8AD51D0B5BE66E9CC103EB14399 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=1,st=NACK:2
                              16427 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=26,pt=1,l=1,sg=1,ft=2,st=OK:2
                              16437 TSF:MSG:READ,0-0-110,s=255,c=3,t=16,pt=0,l=0,sg=0:
                              16519 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:CE22C6ECF337A5713AD0677785547E59FB49FB964B79EFAB88
                              16609 TSF:MSG:READ,0-0-110,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                              16773 !TSF:MSG:SIGN VERIFY FAIL
                              16777 TSF:MSG:READ,0-0-110,s=255,c=3,t=27,pt=1,l=1,sg=1:1
                              16783 !TSF:MSG:SIGN VERIFY FAIL
                              16787 MCO:BGN:STP
                              16836 !TSF:MSG:SEND,110-110-0-0,s=1,c=3,t=16,pt=0,l=0,sg=1,ft=0,st=NACK:
                              16844 !TSF:MSG:SIGN FAIL
                              16896 !TSF:MSG:SEND,110-110-0-0,s=2,c=3,t=16,pt=0,l=0,sg=1,ft=2,st=NACK:
                              16904 !TSF:MSG:SIGN FAIL
                              16906 MCO:BGN:INIT OK,TSP=1
                              Valve Change Detected ,
                              Reporting battery
                              Main Battery reported: 1076
                              16959 !TSF:MSG:SEND,110-110-0-0,s=6,c=3,t=16,pt=0,l=0,sg=1,ft=4,st=NACK:
                              16967 !TSF:MSG:SIGN FAIL
                              Bridge Battery reported: 0
                              17018 !TSF:MSG:SEND,110-110-0-0,s=7,c=3,t=16,pt=0,l=0,sg=1,ft=6,st=NACK:
                              17027 !TSF:MSG:SIGN FAIL
                              next BATT report TIME selected
                              17037 TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=16,pt=0,l=0,sg=1,ft=8,st=OK:
                              17059 TSF:MSG:READ,0-0-110,s=255,c=3,t=17,pt=6,l=25,sg=1:A49B044E02033467D7D7220BA28FBFEA6C9ED2EFA7C4DE16CD
                              17276 !TSF:MSG:SEND,110-110-0-0,s=255,c=3,t=0,pt=1,l=1,sg=1,ft=0,st=NACK:100
                              Both to Low in Bridge .....
                              And this is what the log of the GW shows me:
                              0;255;3;0;9;TSF:MSG:READ,110-110-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSF:MSG:BC
                              0;255;3;0;9;TSF:MSG:FPAR REQ,ID=110
                              0;255;3;0;9;TSF:PNG:SEND,TO=0
                              0;255;3;0;9;TSF:CKU:OK
                              0;255;3;0;9;TSF:MSG:GWL OK
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=24,pt=1,l=1,sg=0:1
                              0;255;3;0;9;TSF:MSG:PINGED,ID=110,HP=1
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=25,pt=1,l=1,sg=0,ft=0,st=OK:1
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=15,pt=6,l=2,sg=0:0101
                              0;255;3;0;9;!TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=NACK:0101
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=16,pt=0,l=0,sg=0:
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=0,ft=0,st=OK:E36F33C7F0FAB62159035EE11FBC031CE96304C15907FCA866
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:9CB25AA3C9DDAA7EB1D4EC4FEE49B3ADDA743FB87AC1844809
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=6,pt=1,l=1,sg=1:0
                              0;255;3;0;9;!TSF:MSG:SIGN VERIFY FAIL
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:A2FFF069812565DE86C4BE5517F7F497141208817C51412562
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:F2503A2DF3D42714F93FF7386FC7E4087E6FFC31B86D0449BF
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=255,c=3,t=12,pt=0,l=3,sg=1:2.3
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=2,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:3DB72D0ECA0E7C5546CB68782E93D66A0BA86F7DBD05714798
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=2,c=0,t=3,pt=0,l=11,sg=1:Water Valve
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=1,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:272DE6ED5FDDDB14B704CF36D32DA37D3A3C32D4F7F30E4D86
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0101
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:05E7E841D621BB9E5F323082CBF40509B1B9D100C6EF955156
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:89A2A933A3310EE14AF048E3A786FD1432608BBD361B366DC0
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:554A491A49FA49B278B8269CEF0748346A9980A395161F3356
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:6220CC178F89ADD1F7AC819695C344770835A96CBAFB2D6848
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=6,c=3,t=16,pt=0,l=0,sg=1:
                              0;255;3;0;9;TSF:MSG:SEND,0-0-110-110,s=255,c=3,t=17,pt=6,l=25,sg=1,ft=0,st=OK:DA701B4D253E0FC19BB7FA0D2699D1C9CE7F7E7B89586ED8A2
                              0;255;3;0;9;TSF:MSG:READ,110-110-0,s=6,c=0,t=30,pt=0,l=15,sg=1:Main Batt Volts
                              Can you help me please!?
                              I read everything about the signed but the truth I am somewhat confused ... If you could provide me a sketch of a node and a gateway that work for me to guide me I would appreciate it.
                              Thank you very much in advance!
                              • P Proyectos Integrasoft
                                  (Nano 5v)
                                4 TSM:INIT
                                4 TSF:WUR:MS=0
                                12 TSM:INIT:TSP OK
                                18 TSM:FPAR
                                2064 TSM:FPAR:OK
                                2064 TSM:ID
                                2066 TSM:ID:OK
                                2068 TSM:UPL
                                2093 TSM:UPL:OK
                                5212 MCO:REG:REQ
                                5273 TSM:FPAR
                                7270 !TSF:SND:TNR
                                7321 TSM:FPAR
                                9271 !TSF:SND:TNR
                                9367 TSM:FPAR:OK
                                9367 TSM:ID
                                9369 TSM:ID:OK
                                9371 TSM:UPL
                                9394 TSM:UPL:OK
                                12294 MCO:REG:REQ
                                16787 MCO:BGN:STP
                                Reporting battery
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @Proyectos-Integrasoft Hi, as mentioned several places, signing makes messages be a lot bigger and that puts strain on the radio link. You can see many NACKs in the log which means messages don't get through. That's way signing fail. You need to make sure you have properly decoupled radio modules and a solid power supply.
                                    (Nano 5v)
                                  4 TSM:INIT
                                  4 TSF:WUR:MS=0
                                  12 TSM:INIT:TSP OK
                                  18 TSM:FPAR
                                  2064 TSM:FPAR:OK
                                  2064 TSM:ID
                                  2066 TSM:ID:OK
                                  2068 TSM:UPL
                                  2093 TSM:UPL:OK
                                  5212 MCO:REG:REQ
                                  5273 TSM:FPAR
                                  7270 !TSF:SND:TNR
                                  7321 TSM:FPAR
                                  9271 !TSF:SND:TNR
                                  9367 TSM:FPAR:OK
                                  9367 TSM:ID
                                  9369 TSM:ID:OK
                                  9371 TSM:UPL
                                  9394 TSM:UPL:OK
                                  12294 MCO:REG:REQ
                                  16787 MCO:BGN:STP
                                  Reporting battery
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  @Proyectos-Integrasoft another thing you did not mention is if you have personalized your nodes? Signing require personalization to store certain data. Please read the documentation (linked on the top of this thread).
                                  P 1 Reply Last reply
                                    P
                                    P
                                    @Anticimex Thnks!
                                    As you can see in the sketch, I'm using a Nrf24L01 module for the node and for the gateway. They are connected to their designed boards (Node and Gateway) respectively. The power, for now, I am doing through the Ftdi232 that I use to connect it to the PC to do debugging. Before adding the signature to the sketch, they were working perfect. What do you suggest doing then?
                                    Also, I have read about the customization of the nodes, but I feel honest I have not managed to understand how to do it ... Could you explain me easily how to personalize it? Truthfully, I have not been able to use the guide.
                                    Thanks for answering me! : D
                                    • AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @Proyectos-Integrasoft then please let me know what parts are unclear. I try to make it as easy to follow as possible. You can also read the beta documentation but be aware that personalization has been rewritten on the beta track. I have provided a step by step instruction for personalization in the signing module in the documentation. It should give you all information needed.
                                      Regarding powering, have you followed the guides available here in the forum for powering the radio? NACKs is not a signing problem. It is a radio problem.
                                      P 2 Replies Last reply
                                        P
                                        P
                                        @Anticimex What I understand is the following:
                                        1. I must choose the backend that I am going to use. (In my case, I'll use the software firm)
                                        2. Then I must choose a free pin to establish a random seed for the pseudorandom generator. (In my case I chose pin A3 that is completely free on the plate).
                                        3. Then I request that all the messages that enter the node will be signed. (I do this using MY_SIGNING_REQUEST_SIGNATURES on the gateway and on the node)
                                        4. finally says that if I am not going to use MY_SIGNING_SIMPLE_PASSWD, I need to customize the node. This is where I get confused ...
                                        First of all, ask me to enable GENERATE_KEYS_SOFT, saying that this will provide random keys for HMAC and AES, and that I should copy and replace them in the corresponding definitions in "User-defined key data". What do you mean by "user-defined key data"? When I enable this, in the LOG of my node nothing strange comes out, the same thing I posted previously.
                                        Second, you tell me to disable the key generator by software and enable the PERSONALIZE_SOFT ... And that this will keep the keys in the EEPROM ... When you talk about enabling and disabling you mean that I must burn the sketch first with Generate_Keys_Soft and then burn again but now with the hmac and aes keys that were generated, while enabling the Personalize_Soft?
                                        This is what I do not understand. I do not get the keys with the GENERATE_KEYS_SOFT ... And I do not clearly understand what I should do next.
                                        You apologize for my lack of knowledge or understanding. And I thank you for your help.
                                          P
                                          P
                                          @Anticimex And as for the radio. I followed the connection guide that comes out at https://www.mysensors.org/build/serial_gateway, even watching the video. I do not know if you mean another guide? If so, could you give me the link? Thank you for your collaboration.
