  3. GatewayESP8266 compile error: request for member 'read' in 'source'
5 Posts 3 Posters 1.4k Views 3 Watching
  • F
    F
    fkunzler
    I purchased what was described as a NodeMCU. It looks just like a photo of a LoLin V3 except that the name "LoLin" is not printed on the breakout board has an ESP-12N module mounted on it. When I first got it I compiled the GatewayESP8266 sketch including a relay node on the gateway. I installed the Vera MySensors plugin. In added a LED to stand-in for the relay. Everything went well and I was able to turn the LED on and off from the Vera GUI. Some time passed and the gateway no longer was working so I attempted to recompile the sketch without changes. It compiles without error. If I uncomment the line :#define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68" I get errors. I have gone so far at to completely uninstall the Arduino IDE and all the Arduino files and directories belonging to me. Nothing helps. I cannot figure out what has changed. Any help will be greatly appreciated.
    Here is the sketch:
     * Version 1.0 - Henrik EKblad
     * Contribution by Ivo Pullens (ESP8266 support)
     * The EthernetGateway sends data received from sensors to the WiFi link.
     * VERA CONFIGURATION:
     * LED purposes:
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
     * GND        GND
      * Inclusion mode button:
    #include <EEPROM.h>
    #define MY_BAUD_RATE 9600
    #define MY_GATEWAY_ESP8266
    #define MY_ESP8266_SSID "MySSID"
    #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
    // Enable UDP communication
    //#define MY_USE_UDP
    // #define MY_ESP8266_HOSTNAME "sensor-gateway"
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    #define MY_PORT 5003
    // Enable inclusion mode
    // #define MY_INCLUSION_BUTTON_FEATURE
    // Flash leds on rx/tx/err
    // #define MY_LEDS_BLINKING_FEATURE
    // Set blinking period
    // #define MY_DEFAULT_LED_BLINK_PERIOD 300
    #if defined(MY_USE_UDP)
      #include <WiFiUDP.h>
      #include <ESP8266WiFi.h>
    Here is the output from the compiler:
    C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Fred\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Fred\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Users\Fred\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10804 -build-path C:\Users\Fred\AppData\Local\Temp\arduino_build_776913 -warnings=none -build-cache C:\Users\Fred\AppData\Local\Temp\arduino_cache_20910 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -verbose C:\Users\Fred\AppData\Local\Temp\arduino_modified_sketch_948243\GatewayESP8266.ino
    C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\Fred\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\Fred\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries D:\Users\Fred\Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10804 -build-path C:\Users\Fred\AppData\Local\Temp\arduino_build_776913 -warnings=none -build-cache C:\Users\Fred\AppData\Local\Temp\arduino_cache_20910 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.esptool.path=C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -verbose C:\Users\Fred\AppData\Local\Temp\arduino_modified_sketch_948243\GatewayESP8266.ino
    Using board 'nodemcuv2' from platform in folder: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
    Using core 'esp8266' from platform in folder: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
    Detecting libraries used...
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "nul"
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-ID:\Users\Fred\Documents\Arduino\libraries\MySensors" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "nul"
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM\EEPROM.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI\SPI.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFi.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiAP.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiGeneric.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiMulti.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiSTA.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\ESP8266WiFiScan.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClient.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiClientSecure.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiServer.cpp
    Using cached library dependencies for file: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src\WiFiUdp.cpp
    Generating function prototypes...
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11  -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-ID:\Users\Fred\Documents\Arduino\libraries\MySensors" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\preproc\ctags_target_for_gcc_minus_e.cpp"
    "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\preproc\ctags_target_for_gcc_minus_e.cpp"
    Compiling sketch...
    "C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\Users\Fred\AppData\Local\Temp\arduino_build_776913/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC   -DARDUINO=10804 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU"  -DESP8266 "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI" "-IC:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src" "-ID:\Users\Fred\Documents\Arduino\libraries\MySensors" "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp" -o "C:\Users\Fred\AppData\Local\Temp\arduino_build_776913\sketch\GatewayESP8266.ino.cpp.o"
    In file included from C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/ESP8266WiFi.h:39:0,
                     from C:\Users\Fred\AppData\Local\Temp\arduino_modified_sketch_948243\GatewayESP8266.ino:134:
    C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h: In instantiation of 'size_t WiFiClient::write(T&, size_t) [with T = char*; size_t = unsigned int]':
    D:\Users\Fred\Documents\Arduino\libraries\MySensors/core/MyGatewayTransportEthernet.cpp:207:58:   required from here
    C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:123:36: error: request for member 'available' in 'source', which is of non-class type 'char*'
         size_t left = source.available();
    C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi\src/WiFiClient.h:127:5: error: request for member 'read' in 'source', which is of non-class type 'char*'
         source.read(buffer.get(), will_send);
    Using library EEPROM at version 1.0 in folder: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\EEPROM
    Using library SPI at version 1.0 in folder: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\SPI
    Using library ESP8266WiFi at version 1.0 in folder: C:\Users\Fred\AppData\Local\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\libraries\ESP8266WiFi
    Using library MySensors at version 2.1.1 in folder: D:\Users\Fred\Documents\Arduino\libraries\MySensors
    exit status 1
    Error compiling for board NodeMCU 1.0 (ESP-12E Module).
      I don't think that define is necessary in your case anyway.
      • F fkunzler
        Here is the sketch:
         * LED purposes:
         * nRF24L01+  ESP8266
         * VCC        VCC
         * CE         GPIO4
         * CSN/CS     GPIO15
         * SCK        GPIO14
         * MISO       GPIO12
         * MOSI       GPIO13
         * GND        GND
        #include <EEPROM.h>
        Compiling sketch...
        exit status 1
        @fkunzler You're missing a hash on the define:
        instead of
        Apart from that the sketch compiles just fine, with and without MY_CONTROLLER_IP_ADDRESS defined.
        F 1 Reply Last reply
        • YveauxY Yveaux
          instead of
          F
          F
          fkunzler
          @Yveaux
          Thanks for your reply.
          The missing hash was a cut & paste error. Apparently there is a problem with my installation somewhere. What versions of the Arduino IDE, esp8266 library and MySensors libraries are you running?
          • F fkunzler
            @Yveaux
            @fkunzler MySensors development, Arduino IDE 1.8.1, ESP8266 2.3.0
