  3. 💬 Stamp size MySensor node
atmega328atsha204acoincellmysensor
50 Posts 13 Posters 17.7k Views 11 Watching
    #31
    @alexsh1 do you plan to use this so small coincell with rfm69? very curious to see results regarding internal res during RX-Tx times...1.8V brownout should not be far i think..or maybe not :) because the voltage won't stay at 3v ;) but to counter effect, a nice capa at input with a current limiting resistor could help. reading/waiting voltage stabilize before transmitting can help too (I'm doing this with some CR2032 based nodes)
    alexsh1A 1 Reply Last reply
    • AWIA AWI
      @alexsh1 :+1: (although pretty expensive...) building on your reference I found this
      Should do the job..
      alexsh1A
      alexsh1A
      alexsh1
      @AWI I only needed one or two and ordering 30 despite it is cheaper per unit, was probably too much for me.
      • scalzS scalz
        alexsh1A
        alexsh1A
        alexsh1
        @scalz Yes, that's the plan, but I think I'll come across many difficulties. For now I have the nrf24l01+ version fully working. And started scratching the surface with RFM69. This is nrf24l01+ SMD version and swapping it for RFM69 is not going to be easy. So far I have not seen any adapters for the SMD version.
        • alexsh1A
          alexsh1A
          alexsh1
          I have just updated a stamp size node to MySensors 2.1.1 and had to include the following into the sketch:
          #define MY_RF24_CE_PIN 9
          #define MY_RF24_CS_PIN 10
          #define MY_SOFTSPI
          #define MY_SOFT_SPI_SCK_PIN 13
          #define MY_SOFT_SPI_MISO_PIN 12
          #define MY_SOFT_SPI_MOSI_PIN 11
          The fist two lines are not required (it is in the MyConfig.h), but for me to understand how nrf24l01+ is connected.
          I hope it helps
          Regards
          Alex
          • henninneH
            henninneH
            henninne
            Hi @GertSanders, @alexsh1
            I'm considering to build a few nodes with this design, could anyone that have done and tested these give some feedback on how it work? Battery life etc. In my case I will mostly use it as window/door sensor and water leakage sensor so it would not send data to frequently.
            Thanks for any input.
            • R
              R
              reinhold
              @GertSanders,
              Thank you for the nice, small design. I'm trying to build one myself, but I'm running into issues burning the bootloader using the ArduinoISP sketch on an Arduino Nano (328). Looking at the schematics, the pins of the ICSP header (from left to right, if the headers are facing you) are:
              Reset => Pin 10 of Nano
              SCK => Pin 13 of Nano
              MISO => Pin 12 of Nano
              MOSI => Pin 11
              VCC => VCC on Nano
              GND => Gnd on Nano
              I set the board to Arduino Pro or Pro Mini in the Arduino IDE, selected Arduino as ISP and tried to burn the bootloader, but there always is the error message:
              avrdude: Expected signature for ATmega328P is 1E 95 0F
              Double check chip, or use -F to override this check.
              Any idea what's wrong?
              I built two copies of the board, and I get the same message with both. (mirroring the connectors of the ICSP header doesn't work, either).
              Thanks a lot!
              GertSandersG alexsh1A 2 Replies Last reply
              • R reinhold
                @GertSanders,
                MOSI => Pin 11
                VCC => VCC on Nano
                GND => Gnd on Nano
                Thanks a lot!
                GertSandersG
                GertSandersG
                GertSanders
                @reinhold
                Hi, the first thing I would check is to see if you can burn a boot loader on a standard 328P DIP format with the Nano. I'm not sure the ISP sketch, when running on a Nano matches the exact physical pins for MISO, MOSI and SCK. So check that.
                I also burnt the boot loader with the sketch, but on a classic Arduino UNO as ISP. Never tried to do this from a Nano as ISP.
                GertSandersG R 2 Replies Last reply
                • GertSandersG GertSanders
                  @reinhold
                  GertSandersG
                  GertSandersG
                  GertSanders
                  @reinhold
                  Something else I was thinking about. I did burn the boo loader before I mounted a NRF24L01+ board on my stamp size board.
                  I made another board recently and found that burning a boot loader while the radio is connected, gives me issues like the one you mention: sometimes an unexpected signature error, sometimes it starts and stop loading midway ... That was on a different board, but with basically the same connections between processor and radio.
                  So I think that you do need to load the boot loader before mounting the radio on the board. As for my newer board where I first found this issue, it was a robot control board I now need to redesign so that I can refresh the boot loader (ro anything else via ISP) with a mounted radio, by providing a "switch" of some kind to isolate the radio when I do not want it to interfere with the ISP loading.
                  • henninneH henninne
                    alexsh1A
                    alexsh1A
                    alexsh1
                    @henninne sorry for a late reply. The battery life is excellent. I have one node working as a door sensor and another one I'm testing as a battery voltage sensor - just sends voltage every 60 mins. The door sensor is powered by two AAA batteries and has been working for 5-6 months and still shows 3.1V+
                    The battery sensor is running on a coin cell and consumes around 6uA while sleeping.
                    • R reinhold
                      @GertSanders,
                      MOSI => Pin 11
                      VCC => VCC on Nano
                      GND => Gnd on Nano
                      Thanks a lot!
                      alexsh1A
                      alexsh1A
                      alexsh1
                      @reinhold The error message means that AvrDude could not communicate with target processor. Ttiple check your wiring. Can you try a different target board to make sure Nano works as expected?
                        @reinhold
                        R
                        R
                        reinhold
                        @GertSanders Thanks for the response.
                        I had already used the nano to install the bootloader on the linbus analyzer and linbus injector boards, so apparently the nano can be used with the ArduinoISP sketch. I also tried re-installing a bootloader to another nano via the ICSP pins and it worked.
                        I also tried building my last PCB for your stamp-sized nodes without the wireless module installed, but I get the exact same behaviour. (You are right, it's not so far-fetched that the radio module might interfere with the bootloader installation, since the ICSP header also just breaks out the SPI headers. On the other hand, the slave select for the nrf24l01+ is not pulled low by the arduinoISP, so it should not interfere on the SPI bus...).
                        @alexsh1
                        I already tripple checked my wiring (even tried switching MISO/MOSI), but I can't find any problem. In fact, only with this very wiring do I get the "Expected signature for ATmega328P is 1E 95 0F" error message, as only with this wiring, the signature is different from 0x000000. Here's the verbose log of the bootloader burning:
                        https://pastebin.com/Lw3Ri6wg
                        Strangely, I do not get the same signature when I try to burn the bootloader again (0x040404 => 0x0e0808 => 0x080808; 0x820202 => 0xc10101 => 0x820202).
                        So it seems that communication is somehow possible, but only garbage is observed.
                        FWIW, I'm using the "Arduino Pro or Pro Mini" (like I did with the linbus boards) with processor ATmega328P (3.3V, 8MHz).
                        The only difference I can see between the working linbus and nano boards and this stamp-sized node is that the linbus boards have an external crystal, while this stamp-sized node appears to use the internal crystal of the chip. Can this be the difference?
                        • R
                          R
                          reinhold
                          The bootloader burning issue was indeed a problem with the crystal: It seems that the atmega328p that I bought on aliexpress came with the fuse set to external crystal, so they worked fine on all boards with an external crystal, but this stamp-sized node didn't react because the internal oscillator was disabled in the chip. I had some 16MHz SMD crystal lying around, soldered jumper wires to them and manually held them to pins 7 & 8 of the atmega328p while trying to burn the bootloader. That's quite delicate as the pins are so small, but it works astonishingly well.
                          As boards I used the "MiniCore atmega328" board that allowed me to select the internal crystal and also lower the black-out voltage.
                          With the external crystal held to the atmega's pins, I was able to properly burn the bootloader and activate the internal oscillator. Now, the board seems to work just fine.
                          The only issue is that I just realized I don't have any CR1632 batteries. I suppose CR1620 will also work, but that a shorter battery life?
                          Thanks again,
                          Reinhold
                          • R reinhold
                            Thanks again,
                            Reinhold
                            GertSandersG
                            GertSandersG
                            GertSanders
                            @reinhold
                            Glad you found the issue. I'm not sure there are 1616 batteries, but two on top of each other might fit ?
                            R 1 Reply Last reply
                              @reinhold
                              R
                              R
                              reinhold
                              @GertSanders Am I missing something, or wouldn't two 3V batteries in series fry the atmega and in particular the nrf24 with 6V?
                              • R reinhold
                                GertSandersG
                                GertSandersG
                                GertSanders
                                #45
                                @reinhold
                                Totally correct. Very dumb suggestion on my part. You would get 6V, which is above spec for the atmega328p and the nrf24
                                • K
                                  K
                                  krisha
                                  wrote on last edited by krisha
                                  #46
                                  what about adding a step-up converter to drain the battery more? or does it waste too much power?
                                  thx for design and this small battery powered node ;-)
                                  • K
                                    K
                                    krisha
                                    I think for this node an ISP programmer is needed. It might be nice, if you can put a notice for that on mysensors.org.
                                    Maybe also mention that you should not use the VCC of your programmer. In most cases it will deliver 5V which will fry the NRF chip :-)
                                    • K
                                      K
                                      krisha
                                      another thing, I ordered the PCB at OSH park...
                                      Is there any possibility that you and/or MySensors will gain something (affiliate)?
                                      the pin holes are a bit small for standard pin headers. Would be nice if you could increase the diameter a bit on version 3 :-)
                                      • K krisha
                                        GertSandersG
                                        GertSandersG
                                        GertSanders
                                        @krisha
                                        I use a 3V3 programmer. I also use standard pin headers, they fit without a problem.
                                        K 1 Reply Last reply
                                          @krisha
                                          K
                                          K
                                          krisha
                                          @GertSanders
                                          ok, strange. standard pin headers fit for me only into FTDI and ICSP pin holes. Into the other two 8 pin rows it does not fit.
