  2. Announcements
  3. 💬 Building a Serial Gateway
52 Posts 21 Posters 33.5k Views 20 Watching
  • Michel - ItM Michel - It
    you have been very kind, you also tell me, where can I find the old serial sketches compatible for mysensors version 1.5?
    @Michel---It you're welcome :)
    Download 1.5.4 from https://www.mysensors.org/download or select the 1.5.4 tag on Github, https://github.com/mysensors/MySensors/tree/1.5.4
    Michel - ItM 1 Reply Last reply
      Michel - ItM
      Michel - ItM
      Michel - It
      wrote on last edited by Michel - It
      @mfalkvidd I wanted to see if you were ready :satisfied: It can help someone
      • carlekiC
        carlekiC
        carleki
        I have 2 gateways : one with 1.5.4 and one with 2.0 :
        I have tested with 2 temp nodes : one with 1.5.4 version and one with 2.0 : the 2 gateways can see the 2 nodes !
        • A
          AndreD
          • meanmrgreenM
            meanmrgreenM
            meanmrgreen
            If i want to update the gateway to 2.1, do i just need to download the master and reupload this scetch to it?
            Do i need to do that to all my sensors aswell?
            i am on 2.0 right now
            • meanmrgreenM meanmrgreen
              @meanmrgreen yes re-uploading after updating the MySensors library is all you need to do. I recommend updating through the Library Manager (if you use the Arduino IDE) instead of manually downloading from github though.
              You can mix nodes with 2.0 and 2.1 so there is no immediate need to update your nodes.
              See https://forum.mysensors.org/topic/5691/upgrade-to-2-1-0/2 and https://forum.mysensors.org/topic/5651/mysensors-2-1-0-released for more information.
              • agtigA
                agtigA
                agtig
                I don't seem to be able to get it to work when loading the SerialGateway sketch onto a Mega 2560 board... I have tried to find out where to change the pins for the SPI connection, as the pin location is different than on the Nano, but can't seem to find it. Does the library autodetect which pins to use on various boards?
                • agtigA agtig
                  @agtig no it does not autodetect. The instructions for SPI on the Mega are linked from the connecting the radio page.
                  • ronnyandreR
                    ronnyandreR
                    ronnyandre
                    Is it possible to update the article with a code example for a gateway that also uses NodeManager?
                    Newbie with RPi and Domoticz, trying to automate my home.
                      sineverba
                      Is it possible to use an Arduino Mini Pro instead of a UNO? I did try with a Mini + FTDI232 (the red card) but cannot see nothing on PI serial. Thank you!
                      • S sineverba
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @sineverba I had issues incorporating the Sensebender Gateway, as originally planned so used one a Pro-mini as a stopgap gateway to the Pi, and it hasn't skipped a beat... It is a 3.3v 16MHz version however, you would need a level shifter on the serial if you were to use a 5v Pro-mini...
                        S 1 Reply Last reply
                        • zboblamontZ zboblamont
                          sineverba
                          @zboblamont It is a 3.3v 8mhz. So do you mean use It connected via GPIO of PI? How do you power It?
                          • S sineverba
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @sineverba Serial Tx to Rx and vice versa, ground and 3.3 from Pi...
                              sineverba
                              @zboblamont ok, and PI can safely Power It with his radio? If right Remember, max of PI are 50mA .... From a GPIO.....
                              Another question, please, what the port serial name? Pi recognises It out of the box?
                              zboblamontZ 2 Replies Last reply
                              • S sineverba
                                zboblamontZ
                                zboblamontZ
                                zboblamont
                                @sineverba You are not powering the gateway from the Pi's data pins, you are tapping off the 3v3 power on the Pi's power supply.
                                On the Pi3 (same as the Pi2), the 3v3, gnd, tx, and rx are grouped on the outside row making it all neat.
                                • S sineverba
                                  zboblamontZ
                                  zboblamontZ
                                  zboblamont
                                  @sineverba I forgot to add, this gateway has a RFM69, so powers it no problem.
                                  If I remember correctly the input was selected on the Pi in Domoticz as ttyS0...
                                    sineverba
                                    wrote on last edited by sineverba
                                    #21
                                    @zboblamont ok. I did not know cause I have a PI1. Btw, what about serial port name and out of the box working? Or need some edit on PI config?
                                    Edit: I did read your answer late ;-)
                                    • skywatchS
                                      skywatchS
                                      skywatch
                                      Is MY_RX_MESSAGE_BUFFER_FEATURE auto enabled for a gw using serial or do I need to add #define MY_RX_MESSAGE_BUFFER_FEATURE in the sketch before uploading?
                                      I have looked this page + https://www.mysensors.org/build/connect_radio + https://www.mysensors.org/download/sensor_api_20#configuration and still not sure.....Anyone know?
                                      • skywatchS skywatch
                                        #23
                                        @skywatch it is not enabled by default.
                                        https://www.mysensors.org/apidocs-beta/group__RF24SettingGrpPub.html#gafe2f4565dfa8473846dfc82d417c8147
                                        The default value is in parenthesis after the name, if there is a default value. Example:
                                        0_1509484366694_upload-e0d86b02-49e5-4ec6-a04d-13a042607e53
                                        means that the default value for MY_RF24_PA_LEVEL is RF24_PA_HIGH
                                        There is nothing after
                                        0_1509484464746_upload-27141c5e-db60-422e-b853-d70097b7829e
                                        which means it is not set by default.
                                        • skywatchS
                                          skywatchS
                                          skywatch
                                          Thanks for reply. Maybe I wasn't too clear, so here is more info.
                                          Today I made a serial gw with a pro mini as the nrf24 attached to pi directly is suspected of problems with MyController.
                                          In the wiring diagram on the build page it shows the IRQ from the nrf24 to the promini as connected. But this is not enabled by default in the MYSGW code.
                                          So, to make the NRF24 IRQ work, I need to add #define MY_RX_MESSAGE_BUFFER_FEATURE and #define MY_RF24_IRQ_PIN.......Or is it #define MY_RX_MESSAGE_BUFFER_FEATURE(ENABLED) #define MY_RF24_IRQ_PIN(D2) ???
                                          I just want to enable the irq from the nrf24 to help with message flow.
