  2. Announcements
  3. 💬 Building a Serial Gateway
52 Posts 21 Posters 25.3k Views 20 Watching
  • H Offline
    H Offline
    wrote on last edited by hek
    This thread contains comments for the article "Building a Serial Gateway" posted on MySensors.org.
    • Michel - ItM Offline
      Michel - It
      I have two questions ...
      one) this sketch only works with version mysensors_v2.0 it?
      two) all the old skeck are no longer usable?
      thank you
      • Michel - ItM Michel - It
        thank you
        Correct
        They are still usable. All nodes in a sensor network need to run the same major MySensor version. If you want to stay on version 1.5, you can continue using the 1.5 sketches.
          Michel - It
          wrote on last edited by Michel - It
          you have been very kind, you also tell me, where can I find the old serial sketches compatible for mysensors version 1.5?
            @Michel---It you're welcome :)
            Download 1.5.4 from https://www.mysensors.org/download or select the 1.5.4 tag on Github, https://github.com/mysensors/MySensors/tree/1.5.4
            Michel - ItM 1 Reply Last reply
              Michel - It
              @mfalkvidd I wanted to see if you were ready :satisfied: It can help someone
              • C Offline
                C Offline
                carleki
                I have 2 gateways : one with 1.5.4 and one with 2.0 :
                I have tested with 2 temp nodes : one with 1.5.4 version and one with 2.0 : the 2 gateways can see the 2 nodes !
                • A Offline
                  A Offline
                  AndreD
                  • meanmrgreenM Offline
                    meanmrgreen
                    If i want to update the gateway to 2.1, do i just need to download the master and reupload this scetch to it?
                    Do i need to do that to all my sensors aswell?
                    i am on 2.0 right now
                    • meanmrgreenM meanmrgreen
                      @meanmrgreen yes re-uploading after updating the MySensors library is all you need to do. I recommend updating through the Library Manager (if you use the Arduino IDE) instead of manually downloading from github though.
                      You can mix nodes with 2.0 and 2.1 so there is no immediate need to update your nodes.
                      See https://forum.mysensors.org/topic/5691/upgrade-to-2-1-0/2 and https://forum.mysensors.org/topic/5651/mysensors-2-1-0-released for more information.
                      • agtigA Offline
                        agtigA Offline
                        agtig
                        I don't seem to be able to get it to work when loading the SerialGateway sketch onto a Mega 2560 board... I have tried to find out where to change the pins for the SPI connection, as the pin location is different than on the Nano, but can't seem to find it. Does the library autodetect which pins to use on various boards?
                        • agtigA agtig
                          @agtig no it does not autodetect. The instructions for SPI on the Mega are linked from the connecting the radio page.
                          • ronnyandreR Offline
                            ronnyandreR Offline
                            ronnyandre
                            Is it possible to update the article with a code example for a gateway that also uses NodeManager?
                            Newbie with RPi and Domoticz, trying to automate my home.
                            • S Offline
                              sineverba
                              Is it possible to use an Arduino Mini Pro instead of a UNO? I did try with a Mini + FTDI232 (the red card) but cannot see nothing on PI serial. Thank you!
                              • S sineverba
                                zboblamontZ Offline
                                zboblamontZ Offline
                                zboblamont
                                @sineverba I had issues incorporating the Sensebender Gateway, as originally planned so used one a Pro-mini as a stopgap gateway to the Pi, and it hasn't skipped a beat... It is a 3.3v 16MHz version however, you would need a level shifter on the serial if you were to use a 5v Pro-mini...
                                S 1 Reply Last reply
                                • zboblamontZ zboblamont
                                  sineverba
                                  @zboblamont It is a 3.3v 8mhz. So do you mean use It connected via GPIO of PI? How do you power It?
                                  • S sineverba
                                    zboblamontZ Offline
                                    zboblamontZ Offline
                                    zboblamont
                                    @sineverba Serial Tx to Rx and vice versa, ground and 3.3 from Pi...
                                      sineverba
                                      @zboblamont ok, and PI can safely Power It with his radio? If right Remember, max of PI are 50mA .... From a GPIO.....
                                      Another question, please, what the port serial name? Pi recognises It out of the box?
                                      zboblamontZ 2 Replies Last reply
                                      • S sineverba
                                        zboblamontZ Offline
                                        zboblamontZ Offline
                                        zboblamont
                                        @sineverba You are not powering the gateway from the Pi's data pins, you are tapping off the 3v3 power on the Pi's power supply.
                                        On the Pi3 (same as the Pi2), the 3v3, gnd, tx, and rx are grouped on the outside row making it all neat.
                                        • S sineverba
                                          zboblamontZ Offline
                                          zboblamontZ Offline
                                          zboblamont
                                          @sineverba I forgot to add, this gateway has a RFM69, so powers it no problem.
                                          If I remember correctly the input was selected on the Pi in Domoticz as ttyS0...
                                          12.0k
