  3. OpenHAB
  4. Beginner - what is wrong
45 Posts 6 Posters 17.3k Views 6 Watching
  • X
    X
    xmonika
    wrote on last edited by xmonika
    #32
    Could be but the same I get on my second computer (win 10 as well). Will experiment with that.
    • tbowmoT
      tbowmoT
      tbowmo
      But still using the same USB device on the second computer?
      • Z
        Z
        zeroxdeadbeef
        wrote on last edited by zeroxdeadbeef
        #34
        Hello!
        I was hoping I would find a solution here as I basically have the same problem. I ordered two Sensebender Micros like two months ago and flashing a sketch onto them is failing with the same avrdude: stk500_getsync() attempt X of Y: not in sync error. (Noteworthy: I only assembled one Sensebender so far, I haven't tried the second one).
        In my case: I am using ArchLinux with kernel 4.13, so drivers should not be the issue here. I am using this FTDI flash module and the same USB cable for other projects and was able to successfully flash an ESP 8266, a Arduino Pro Mini and a Nano.
        Executing the self-test on the Sensebender Micro does also work and with serial attached I even get the output that all tests have passed. Still, i am not able to flash something onto this device using the IDE. Instead of selecting the board option Sensebender Micro (using both 8 and 1 MHz options) I even tried some odd choices like Arduino Pro Mini or Arduino Nano. Nevertheless, none of those did work.
        Regarding FTDI to Sensebender connection: VCC <-> VCC, GND <-> GND, RX and TX are swapped. I even tried replacing the cables and tried to connect DTR without luck.
        Any further hints are appreciated, thank you.
        • X
          X
          xmonika
          Unfortunately I didn't solved it, I just gave it up and am waiting for new ISP programmer to arrive. That is the last piece I didn't changed (I have changed computer/SW, sensebender Micro and it didn't helped). Hope you will be more successfull.
          • tbowmoT
            tbowmoT
            tbowmo
            Only thing that is left, that I can think about, is if itead had somehow forgotten to write the bootloader..
            But then again, I have supplied them with a binary including both bootloader, and default sensebender micro sketch, so it should have the bootloader. Unless they have made some mistakes..
            I haven't bought any sensebenders for the last couple of years, so unfortunately I can't verify this.
            • Z
              Z
              zeroxdeadbeef
              Thank you for you input. I had luck and we have an AVRISP mk2 lying around in my company that I can borrow for the weekend. So my plan would be to try to re-flash DualOptiboot first or another bootloader (maybe the stock Arduino Pro Mini one) in further tries and see if this helps.
              The only two things I am trying to figure out in this very moment are:
              1. in which direction the ISP cable has to be mounted so that nothing is damaged
              2. and I do not know yet for sure if the AVRISP mk2 is actually suppyling power or not to the board (for cases where e.g. it may feed 5 volts).
              • Z
                Z
                zeroxdeadbeef
                Okay, I have soldered the second Sensebender too and tried to burn the bootloader via Arduino IDE onto both devices. The verbose log was the following:
                /home/x/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/home/x/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v2 -Pusb -Uflash:w:/home/x/.arduino15/packages/MySensors/hardware/avr/1.0.1/bootloaders/DualOptiboot/optiboot_atmega328_pro_8MHz.hex:i -Ulock:w:0x0F:m
                avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
                         System wide configuration file is "/home/x/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/etc/avrdude.conf"
                         User configuration file is "/home/x/.avrduderc"
                         Using Programmer              : stk500v2
                avrdude: usbdev_open(): Found AVRISP mkII, serno: redacted
                         Programmer Type : STK500V2
                         Description     : Atmel STK500 Version 2.x firmware
                         Programmer Model: AVRISP mkII
                         Hardware Version: 1
                         Firmware Version Master : 1.23
                         Vtarget         : 3.0 V
                         SCK period      : 8.00 us
                avrdude: erasing chip
                avrdude: reading input file "/home/x/.arduino15/packages/MySensors/hardware/avr/1.0.1/bootloaders/DualOptiboot/optiboot_atmega328_pro_8MHz.hex"
                avrdude: writing flash (32768 bytes):
                avrdude: 32768 bytes of flash written
                avrdude: verifying flash memory against /home/x/.arduino15/packages/MySensors/hardware/avr/1.0.1/bootloaders/DualOptiboot/optiboot_atmega328_pro_8MHz.hex:
                avrdude: load data flash data from input file /home/x/.arduino15/packages/MySensors/hardware/avr/1.0.1/bootloaders/DualOptiboot/optiboot_atmega328_pro_8MHz.hex:
                avrdude: input file /home/x/.arduino15/packages/MySensors/hardware/avr/1.0.1/bootloaders/DualOptiboot/optiboot_atmega328_pro_8MHz.hex contains 32768 bytes
                avrdude: verifying ...
                avrdude: 32768 bytes of flash verified
                avrdude: reading input file "0x0F"
                avrdude: verifying lock memory against 0x0F:
                avrdude: load data lock data from input file 0x0F:
                avrdude: input file 0x0F contains 1 bytes
                avrdude: WARNING: invalid value for unused bits in fuse "lock", should be set to 1 according to datasheet
                This behaviour is deprecated and will result in an error in future version
                You probably want to use 0xcf instead of 0x0f (double check with your datasheet first).
                avrdude done.  Thank you.
                Interesting in this log is the warning about the invalid value for some fuse bits...
                Flashing a sketch after re-burning the bootloader sadly did not work, the same not in sync error occured again. Next, I tried to burn the bootloader using the board setting of the Arduino Pro Mini (3.3v, 8mhz). Strange enough, this does not work anymore now, yielding a pretty generic error:
                avrdude: stk500v2_command(): command failed
                avrdude: stk500v2_program_enable(): bad AVRISPmkII connection status: Unknown status 0x00
                         this check.
                I do not know, I can only assume that maybe burning another bootloader does not work because of the invalid value warning while burning the default bootloader. I also tried to burn the original Optiboot without success.
                X 1 Reply Last reply
                • Z zeroxdeadbeef
                           Hardware Version: 1
                           Vtarget         : 3.0 V
                           this check.
                  X
                  X
                  xmonika
                  I just have this problem with "programming" solved. I bought this USBISP programmer, downloaded libUSBk drivers from here and pushed it into SBmicro via programmer USBasp. I don't know why but from some reason two UART programmers were not working.
                  It may save frustration and time to somebody in future.
                  Z 1 Reply Last reply
                  • X xmonika
                    Z
                    Z
                    zeroxdeadbeef
                    @xmonika
                    Thanks, I just ordered the same programmer. Let's see if this is working. How did you wire the programmer to the Sensebender? Just asking because the programmer has more pins available than the Arduino board.
                    • tbowmoT
                      tbowmoT
                      tbowmo
                      @zeroxdeadbeef
                      the SB micro is using the standard 6pin AVR-ISP header.
                      Would be interesting to get a memory dump from a fresh SB micro that exhibits the problems with programming.. One of my theories is that it lacks the bootloader, or are misconfigured somehow from the factory.
                      • X
                        X
                        xmonika
                        The programmer has 10 pins but the GND is presented 4x. Check the picture [here](http://www.avrfreaks.net/forum/adapter-program-10-pin-6-pin-socket-cable-computer-pc-led-reset-power for wiring, this is how I did it.
                        • Z
                          Z
                          zeroxdeadbeef
                          Thanks for your responses. Sadly, both of my devices are not in factory state anymore. Nevertheless, I will report back after I have received this USBISP programmer.
                          • Z
                            Z
                            zeroxdeadbeef
                            Hello!
                            Finally, I have received this USB programmer... I wired everything up, but flashing the Sensebender Micros does not work, sadly. According to avrdude they do not seem to respond:
                            avrdude: warning: cannot set sck period. please check for usbasp firmware update.
                            avrdude: error: program enable: target doesn't answer. 1
                                     this check.
                            I managed to program and burn the bootloader of a normal Arduino Pro Mini using this programmer and the same cable, so the programmer is working as expected.
                            • sinczeS
                              sinczeS
                              sincze
                              MySensors Evangelist
                              Mmm i think I received a DOA... No pling pling sound in windows...
