  3. Relay actuator with button and sensor air humidity?
3 Posts 2 Posters 1.3k Views 3 Watching
  • A
    arduino_89_89
    wrote on last edited by gohan
    relay with button and without gateway, and sensor air and humidity.
    How do I insert the temperature sensor skech, within this:
    #define MY_RADIO_NRF24                         // Enable and select radio type attached
    #define MY_NODE_ID 8
    #define RELAY_PIN  4      // Arduino Digital I/O pin number for relay
    #define RELAY_ON 0
    #define RELAY_OFF 1
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long returnWait = 1500;               // how long to wait for return from controller in milliseconds
    void setup(){
      debouncer.interval(5);
    void presentation()  {
      present(CHILD_ID, S_BINARY);
    void loop(){
        if (request( CHILD_ID, V_STATUS)) {       // request the current state of the switch on the controller and check that an ack was received
          wait (returnWait);                      //wait needed to allow request to return from controller
          Serial.println(requestState);
          if (requestState != state) {           // check that controller is corectly showing the current relay state
            send(msg.set(state), false);         // notify controller of current state
        else {
          uplinkAvailable = false;               // no uplink established
          uplinkCheckTime = millis();
        firstStart = false;                     // set firstStart flag false to prevent code from running again
      debouncer.update();
        if (!send(msg.set(state), true)) {                        //Attempt to notify controller of changed state
          uplinkAvailable = false;                                // no uplink available
     oldValue = value;
          case C_SET:
     //message is a set command  from controller to update relay state
    void uplinkCheck() {
      if (request( CHILD_ID, V_STATUS)) {         // request the current state of the switch on the controller and check that the request was succsessful
      what temperature sensor will you be using?
      • A
        arduino_89_89
        Sensor DHT-11
        12.5k
