  3. Relay actuator with button and sensor air humidity?
3 Posts 2 Posters 1.3k Views 3 Watching
  • A
    A
    arduino_89_89
    wrote on last edited by gohan
    relay with button and without gateway, and sensor air and humidity.
    How do I insert the temperature sensor skech, within this:
    #define MY_DEBUG                               // Enable debug prints to serial monitor
    #define MY_RADIO_NRF24                         // Enable and select radio type attached
    #define MY_NODE_ID 8
    #define MY_TRANSPORT_WAIT_READY_MS 5000        //set how long to wait for transport ready in milliseconds
    #include <Bounce2.h>
    #define RELAY_PIN  4      // Arduino Digital I/O pin number for relay
    #define BUTTON_PIN  3     // Arduino Digital I/O pin number for button
    #define CHILD_ID 1        // Id of the sensor child
    #define RELAY_ON 0
    #define RELAY_OFF 1
    Bounce debouncer = Bounce();
    int oldValue = 0;
    bool uplinkAvailable = true;
    bool state = false;
    bool requestState;
    bool firstStart = true;
    unsigned long uplinkCheckTime ;                // holder for uplink checks
    unsigned long uplinkCheckPeriod = 30*1000;     // time between checks for uplink in milliseconds
    unsigned long returnWait = 1500;               // how long to wait for return from controller in milliseconds
    MyMessage msg(CHILD_ID, V_STATUS);
    void setup(){
      pinMode(BUTTON_PIN, INPUT_PULLUP);           // Setup the button pin, Activate internal pull-up
      debouncer.attach(BUTTON_PIN);                // After setting up the button, setup debouncer
      debouncer.interval(5);
      pinMode(RELAY_PIN, OUTPUT);                 // set relay pin in output mode
      digitalWrite(RELAY_PIN, RELAY_OFF);         // Make sure relay is off when starting up
    void presentation()  {
      sendSketchInfo("Relay & Button", "1.0");
      present(CHILD_ID, S_BINARY);
    void loop(){
      if (firstStart) {                            // this code is only run once at startup
        Serial.println("First run started");
        if (request( CHILD_ID, V_STATUS)) {       // request the current state of the switch on the controller and check that an ack was received
          Serial.println("uplink available");
          wait (returnWait);                      //wait needed to allow request to return from controller
          Serial.print("controller state --- ");
          Serial.println(requestState);
          if (requestState != state) {           // check that controller is corectly showing the current relay state
            send(msg.set(state), false);         // notify controller of current state
        else {
          Serial.println("uplink not available");
          uplinkAvailable = false;               // no uplink established
          uplinkCheckTime = millis();
        firstStart = false;                     // set firstStart flag false to prevent code from running again
      debouncer.update();
      int value = debouncer.read();                               // Get the update value
      if (value != oldValue && value == 0) {                      // check for new button push
        state =  !state;                                          // Toggle the state
        digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);    // switch the relay to the new state
        if (!send(msg.set(state), true)) {                        //Attempt to notify controller of changed state
          uplinkAvailable = false;                                // no uplink available
     oldValue = value;
      if (!uplinkAvailable && (millis() - uplinkCheckTime > uplinkCheckPeriod) ) {       // test to see if function should be called
        uplinkCheck();        // call uplink checking function
    /*-------------------start of functions--------------------------*/
      if (message.type == V_STATUS) {                                   // check to see if incoming message is for a switch
        switch (message.getCommand()) {                                 // message.getCommand will give us the command type of the incomming message
          case C_SET:
     //message is a set command  from controller to update relay state
            state = message.getBool();                                  // get the new state
            digitalWrite(RELAY_PIN, state ? RELAY_ON : RELAY_OFF);      // switch relay to new state
            uplinkAvailable = true;                                     //  uplink established
            /*---- Write some debug info----*/
            Serial.print(message.sensor);
            break;
          case C_REQ:                                               // message is a returning request from controller
            requestState = message.getBool();                       // update requestState with returning state
            break;
    void uplinkCheck() {
      if (request( CHILD_ID, V_STATUS)) {         // request the current state of the switch on the controller and check that the request was succsessful
        Serial.println("uplink re-established");
          send(msg.set(state), false);            // notify controller of current state no ack
      uplinkCheckTime = millis();                // reset the checktime
      Serial.println("uplinkchecktime reset");
      what temperature sensor will you be using?
      • A
        A
        arduino_89_89
        Sensor DHT-11
