  3. MySensors library install on Linux Mint (Arduino 2.1.0)
15 Posts 3 Posters 3.9k Views 2 Watching
  • Y Offline
    Y Offline
    Yannoo
    I just make a fresh install of the Arduino environment on a Linux Mint box and discover that I have to rename the MySensor-master.zip archive to MySensors.zip for to can load this library, cf. delete the -master part of the archive name for to can load it.
    Why have I to make this ?
    (the version of the Arduino environment is 2.1.0.5)
    • Y Yannoo
      @Yannoo that's just the way github works. Github adds the branch name to the zip file name.
      Is there a reason you don't use the library manager in the Arduino IDE to install MySensors?
      • Y Offline
        Y Offline
        Yannoo
        I don't find the library manager on this version, only "Add library ..." and the list of alls already installed libraries on the "Importer Bibliothèque ..." submenu of the "Croquis" menu :(
        Y 1 Reply Last reply
        • Y Yannoo
          Y Offline
          Y Offline
          Yannoo
          wrote on last edited by Yannoo
          I don't have the "Manage Library" menu on my Linux version, I only found tutorials for to manage librairies on Macs and Windows plateforms, but not for Linux :(
          • Y Yannoo
            @Yannoo interesting. The newest version of the Arduino IDE is 1.8.5 according to github and the arduino download page.
            Do you remember where you got your version?
              Y Offline
              Y Offline
              Yannoo
              sudo apt-get install arduino :)
              • Y Offline
                Y Offline
                Yannoo
                i have make a "sudo ap-get uninstall arduino" and it say this :
                yannoo@ThinkStation ~ $ sudo apt-get remove arduino
                [sudo] password for yannoo:
                Lecture des listes de paquets... Fait
                Construction de l'arbre des dépendances
                Lecture des informations d'état... Fait
                Les paquets suivants ont été installés automatiquement et ne sont plus nécessaires :
                arduino-core avr-libc avrdude binutils-avr cabextract gcc-avr
                gstreamer0.10-ffmpeg ibm-java80-jdk lib32ncurses5 lib32tinfo5 lib32z1-dev
                libc6-dev-i386 libftdi1 libhal1-flash libjna-java libjna-jni libmspack0
                librxtx-java libunshield0 unshield
                Veuillez utiliser « sudo apt autoremove » pour les supprimer.
                Les paquets suivants seront ENLEVÉS :
                arduino
                0 mis à jour, 0 nouvellement installés, 1 à enlever et 11 non mis à jour.
                Après cette opération, 1 727 ko d'espace disque seront libérés.
                Souhaitez-vous continuer ? [O/n]
                (Lecture de la base de données... 375367 fichiers et répertoires déjà installés.)
                Suppression de arduino (2:1.0.5+dfsg2-4) ...
                Traitement des actions différées (« triggers ») pour man-db (2.7.5-1) ...
                Traitement des actions différées (« triggers ») pour shared-mime-info (1.5-2ubuntu0.1) ...
                Traitement des actions différées (« triggers ») pour hicolor-icon-theme (0.15-0ubuntu1) ...
                Traitement des actions différées (« triggers ») pour gnome-menus (3.13.3-6ubuntu3.1) ...
                Traitement des actions différées (« triggers ») pour desktop-file-utils (0.22+linuxmint1) ...
                Traitement des actions différées (« triggers ») pour mime-support (3.59ubuntu1) ...
                • Y Yannoo
                  arduino
                  Y Offline
                  Y Offline
                  Yannoo
                  @Yannoo said in MySensors library install on Linux Mint (Arduino 2.1.0):
                  2:1.0.5+dfsg2-4
                  So this was the 2:1.0.5+dfsg2-4 version
                  I just make an "sudo apt-get autoremove" :+1:
                  yannoo@ThinkStation ~ $ sudo apt-get autoremove
                  0 mis à jour, 0 nouvellement installés, 20 à enlever et 11 non mis à jour.
                  Après cette opération, 185 Mo d'espace disque seront libérés.
                  Souhaitez-vous continuer ? [O/n] O
                  (Lecture de la base de données... 375327 fichiers et répertoires déjà installés.)
                  Suppression de arduino-core (2:1.0.5+dfsg2-4) ...
                  Suppression de avr-libc (1:1.8.0+Atmel3.5.0-1) ...
                  Suppression de avrdude (6.2-5) ...
                  Suppression de gcc-avr (1:4.9.2+Atmel3.5.0-1) ...
                  Suppression de binutils-avr (2.25+Atmel3.5.0-2) ...
                  Suppression de cabextract (1.6-1) ...
                  Suppression de gstreamer0.10-ffmpeg:amd64 (0.10.13-5ubuntu1~trusty2) ...
                  Suppression de ibm-java80-jdk:amd64 (8.0.4.1-0ubuntu1) ...
                  Suppression de lib32ncurses5 (6.0+20160213-1ubuntu1) ...
                  Suppression de lib32tinfo5 (6.0+20160213-1ubuntu1) ...
                  Suppression de lib32z1-dev (1:1.2.8.dfsg-2ubuntu4.1) ...
                  Suppression de libc6-dev-i386 (2.23-0ubuntu9) ...
                  Suppression de libftdi1:amd64 (0.20-4build1) ...
                  Suppression de libhal1-flash (0.3.1) ...
                  Suppression de libjna-java (4.2.2-1) ...
                  Suppression de libjna-jni (4.2.2-1) ...
                  Suppression de libmspack0:amd64 (0.5-1ubuntu0.16.04.1) ...
                  Suppression de librxtx-java (2.2pre2-13) ...
                  Suppression de unshield (1.0-1) ...
                  Suppression de libunshield0:amd64 (1.0-1) ...
                  Traitement des actions différées (« triggers ») pour libc-bin (2.23-0ubuntu9) ...
                  Traitement des actions différées (« triggers ») pour doc-base (0.10.7) ...
                  Processing 2 removed doc-base files...
                  Registering documents with scrollkeeper...
                  • Y Offline
                    Y Offline
                    Yannoo
                    And reinstall the Arduino IDE using "'sud apt-get install arduino"
                    yannoo@ThinkStation ~ $ sudo apt-get install arduino
                    The following additional packages will be installed:
                    arduino-core avr-libc avrdude binutils-avr gcc-avr libftdi1 libjna-java
                    libjna-jni librxtx-java
                    Paquets suggérés :
                    arduino-mk avrdude-doc task-c-devel gcc-doc libjna-java-doc
                    Paquets recommandés :
                    extra-xdg-menus
                    Les NOUVEAUX paquets suivants seront installés :
                    arduino arduino-core avr-libc avrdude binutils-avr gcc-avr libftdi1
                    libjna-java libjna-jni librxtx-java
                    0 mis à jour, 10 nouvellement installés, 0 à enlever et 11 non mis à jour.
                    Il est nécessaire de prendre 0 o/20,9 Mo dans les archives.
                    Après cette opération, 123 Mo d'espace disque supplémentaires seront utilisés.
                    Sélection du paquet libjna-jni précédemment désélectionné.
                    (Lecture de la base de données... 369017 fichiers et répertoires déjà installés.)
                    Préparation du dépaquetage de .../libjna-jni_4.2.2-1_amd64.deb ...
                    Dépaquetage de libjna-jni (4.2.2-1) ...
                    Sélection du paquet libjna-java précédemment désélectionné.
                    Préparation du dépaquetage de .../libjna-java_4.2.2-1_all.deb ...
                    Dépaquetage de libjna-java (4.2.2-1) ...
                    Sélection du paquet librxtx-java précédemment désélectionné.
                    Préparation du dépaquetage de .../librxtx-java_2.2pre2-13_amd64.deb ...
                    Dépaquetage de librxtx-java (2.2pre2-13) ...
                    Sélection du paquet binutils-avr précédemment désélectionné.
                    Préparation du dépaquetage de .../binutils-avr_2.25+Atmel3.5.0-2_amd64.deb ...
                    Dépaquetage de binutils-avr (2.25+Atmel3.5.0-2) ...
                    Sélection du paquet gcc-avr précédemment désélectionné.
                    Préparation du dépaquetage de .../gcc-avr_1%3a4.9.2+Atmel3.5.0-1_amd64.deb ...
                    Dépaquetage de gcc-avr (1:4.9.2+Atmel3.5.0-1) ...
                    Sélection du paquet libftdi1:amd64 précédemment désélectionné.
                    Préparation du dépaquetage de .../libftdi1_0.20-4build1_amd64.deb ...
                    Dépaquetage de libftdi1:amd64 (0.20-4build1) ...
                    Sélection du paquet avrdude précédemment désélectionné.
                    Préparation du dépaquetage de .../avrdude_6.2-5_amd64.deb ...
                    Dépaquetage de avrdude (6.2-5) ...
                    Sélection du paquet avr-libc précédemment désélectionné.
                    Préparation du dépaquetage de .../avr-libc_1%3a1.8.0+Atmel3.5.0-1_all.deb ...
                    Dépaquetage de avr-libc (1:1.8.0+Atmel3.5.0-1) ...
                    Sélection du paquet arduino-core précédemment désélectionné.
                    Préparation du dépaquetage de .../arduino-core_2%3a1.0.5+dfsg2-4_all.deb ...
                    Dépaquetage de arduino-core (2:1.0.5+dfsg2-4) ...
                    Sélection du paquet arduino précédemment désélectionné.
                    Préparation du dépaquetage de .../arduino_2%3a1.0.5+dfsg2-4_all.deb ...
                    Dépaquetage de arduino (2:1.0.5+dfsg2-4) ...
                    Processing 2 added doc-base files...
                    Paramétrage de libjna-jni (4.2.2-1) ...
                    Paramétrage de libjna-java (4.2.2-1) ...
                    Paramétrage de librxtx-java (2.2pre2-13) ...
                    Paramétrage de binutils-avr (2.25+Atmel3.5.0-2) ...
                    Paramétrage de gcc-avr (1:4.9.2+Atmel3.5.0-1) ...
                    Paramétrage de libftdi1:amd64 (0.20-4build1) ...
                    Paramétrage de avrdude (6.2-5) ...
                    Paramétrage de avr-libc (1:1.8.0+Atmel3.5.0-1) ...
                    Paramétrage de arduino-core (2:1.0.5+dfsg2-4) ...
                    Paramétrage de arduino (2:1.0.5+dfsg2-4) ...
                    => exactely the same problem, version 2.1.0.5+dfsg2-4 :(
                    • Y Offline
                      Y Offline
                      Yannoo
                      I test the version given at https://www.arduino.cc/en/main/software ...
                      • Y Offline
                        Y Offline
                        Yannoo
                        Resolved, I have the Croquis/Inclure Une Bibliothèque/Gérer les bibliothèques ,now :)
                        • Y Yannoo
                          Y Offline
                          Y Offline
                          Yannoo
                          This is the version 1.8.5 and this work well
                          • Y Offline
                            Y Offline
                            Yannoo
                            This is certainly a repository problem because "sudo apt-get install arduino" give a bad version of it on my Linux Mint 18.2 Cinnamon 64 bits fresh install ...
                            • Y Yannoo
                              @Yannoo strange. But great that you found a solution, thanks for reporting back.
                              • sundberg84S Offline
                                sundberg84S Offline
                                Sorry to jump into this duscussion late... I had this issue as well on some linux version. I downloaded it using sudo-apt-get install arduino and It didnt work for me either so I had to manual download it to get it to work. This was about 34-6 months ago though.
                                11.9k
                                113.3k
