  3. Step-by-step procedure to connect the NRF24L01+ to the GPIO pins and use the Raspberry as a Serial Gateway (MySensors 1.x)
nrf24raspberry piraspberryraspberry nrf24l01 gpiogateway
168 Posts 47 Posters 214.4k Views 36 Watching
  • _Rooky__
    _Rooky__
    _Rooky_
    maybe someone could give me a hint. I installed everything and it looks like it is working, but no sensors are displayed in Domoticz. Any idea what's wrong?
    I used this sensor before with a ESP Wifi gateway and it was working fine. The DallasTemp Sensors got visible in Domoticz right after the gateway was added in the Hardware section.
    After installing the NRF24l01 on the Rasperry Pi 3 and follwing the instructions above, I added MySensorsGateway USB with /dev/ttyUSB20, but nothing happend.
    Would be nice, if I could get this smart thing working. Else I would need to go back to the ESP Wifi gateway.
    Domoticz log:
    2016-12-30 00:31:01.610 Domoticz V3.5877 (c)2012-2016 GizMoCuz
    2016-12-30 00:31:01.611 Build Hash: 15b013c, Date: 2016-11-10 16:44:33
    2016-12-30 00:31:01.611 System: Raspberry Pi
    2016-12-30 00:31:01.611 Startup Path: /home/pi/domoticz/
    2016-12-30 00:31:02.327 Sunrise: 08:18:00 SunSet:15:59:00
    2016-12-30 00:31:02.327 EventSystem: reset all events...
    2016-12-30 00:31:02.411 Active notification subsystems: (0/12)
    2016-12-30 00:31:02.448 WebServer(HTTP) started on address: :: with port 8080
    2016-12-30 00:31:02.479 WebServer(SSL) started on address: :: with port 443
    2016-12-30 00:31:02.481 Proxymanager started.
    2016-12-30 00:31:02.516 Starting shared server on: :::6144
    2016-12-30 00:31:02.516 TCPServer: shared server started...
    2016-12-30 00:31:02.517 RxQueue: queue worker started...
    2016-12-30 00:31:04.520 EventSystem: reset all events...
    2016-12-30 00:31:04.520 EventSystem: reset all device statuses...
    2016-12-30 00:31:04.521 EventSystem: Started
    2016-12-30 00:31:05.519 MySensors: Using serial port: /dev/ttyUSB20
    2016-12-30 00:33:06.145 Incoming connection from: 127.0.0.1
    pi@raspberrypi:~ $ sudo /usr/local/sbin/PiGatewaySerial
    Starting PiGatewaySerial...
    Protocol version - 1.4
    Created PTY '/dev/pts/2'
    Gateway tty: /dev/ttyMySensorsGateway
    ================ SPI Configuration ================
    CSN Pin = CE0 (PI Hardware Driven)
    CE Pin = Custom GPIO25
    Clock Speed = 8 Mhz
    ================ NRF Configuration ================
    STATUS = 0x0e RX_DR=0 TX_DS=0 MAX_RT=0 RX_P_NO=7 TX_FULL=0
    RX_ADDR_P0-1 = 0xa8a8e1fc02 0xa8a8e1fc00
    RX_ADDR_P2-5 = 0xff 0xc4 0xc5 0xc6
    TX_ADDR = 0xa8a8e1fc02
    RX_PW_P0-6 = 0x20 0x20 0x20 0x00 0x00 0x00
    EN_AA = 0x3b
    EN_RXADDR = 0x06
    RF_CH = 0x4c
    RF_SETUP = 0x23
    CONFIG = 0x0e
    DYNPD/FEATURE = 0x3f 0x06
    Data Rate = 250KBPS
    Model = nRF24L01+
    CRC Length = 16 bits
    PA Power = PA_LOW
    read: 2-2-0 s=255,c=3,t=24,pt=1,l=1:1
    read: 2-2-255 s=255,c=3,t=7,pt=0,l=0:
    send: 0-0-2-2 s=255,c=3,t=8,pt=1,l=1,st=ok:0
    pi@raspberrypi:~ $ sudo cat /dev/ttyMySensorsGateway
    2;255;3;0;24;1
    2;255;3;0;24;1
    2;255;3;0;24;1
    2;255;3;0;24;1
    2;255;3;0;24;1
    1;255;3;0;24;1
    2;255;3;0;24;1
    1;255;3;0;24;1
    2;255;3;0;24;1
    1;255;3;0;24;1
    2;255;3;0;24;1
    1;255;3;0;24;1
    2;255;3;0;24;1
    2;255;3;0;24;1
    2;255;3;0;24;1
    Traces from sensor node:
    TSM:INIT
    TSM:RADIO:OK
    TSP:ASSIGNID:OK (ID=2)
    TSM:FPAR
    TSP:MSG:SEND 2-2-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
    TSP:MSG:READ 0-0-2 s=255,c=3,t=8,pt=1,l=1,sg=0:0
    TSP:MSG:PAR OK (ID=0, dist=1)
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=2)
    TSM:UPL
    TSP:PING:SEND (dest=0)
    TSP:MSG:SEND 2-2-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
    TSP:CHKUPL:FAIL (hops=255)
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=2)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=2)
    TSM:UPL
    !TSM:UPL:FAIL
    TSM:FPAR
    TSM:FPAR:OK
    TSM:ID
    TSM:CHKID:OK (ID=2)
    TSM:UPL
    !TSM:UPL:FAIL
    • _Rooky__ _Rooky_
      Domoticz log:
      Clock Speed = 8 Mhz
      EN_AA = 0x3b
      EN_RXADDR = 0x06
      RF_CH = 0x4c
      RF_SETUP = 0x23
      CONFIG = 0x0e
      Data Rate = 250KBPS
      Model = nRF24L01+
      PA Power = PA_LOW
      2;255;3;0;24;1
      2;255;3;0;24;1
      2;255;3;0;24;1
      2;255;3;0;24;1
      2;255;3;0;24;1
      1;255;3;0;24;1
      2;255;3;0;24;1
      1;255;3;0;24;1
      2;255;3;0;24;1
      1;255;3;0;24;1
      2;255;3;0;24;1
      1;255;3;0;24;1
      2;255;3;0;24;1
      2;255;3;0;24;1
      2;255;3;0;24;1
      TSM:INIT
      TSM:RADIO:OK
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=2)
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=2)
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=2)
      TSM:UPL
      !TSM:UPL:FAIL
      TSM:FPAR
      TSM:FPAR:OK
      TSM:ID
      TSM:CHKID:OK (ID=2)
      TSM:UPL
      !TSM:UPL:FAIL
      @_Rooky_ congratulations on your first post in the forum, welcome!
      The gateway uses MySensors 1.4 and the node uses version 2. These versions are not compatible.
      You probably want to use version 2 for the gateway as well. https://www.mysensors.org/build/raspberry describes how to create a gateway for version 2 (the gateway was completely rewritten for version 2)
      _Rooky__ 1 Reply Last reply
        _Rooky__
        _Rooky__
        _Rooky_
        @mfalkvidd many thanks for the very quick and polite reply.
        It is working now and this solution is much better way, than using an additional ESP as gateway.
        Even though I got on the wrong lane, I learned more details from your excellent guide, than from the "make", "make install" from the MySensors page ... and still got a lot to learn
        • ronnyandreR
          ronnyandreR
          ronnyandre
          Thanks for this thorough guide, it works perfect :)
          Newbie with RPi and Domoticz, trying to automate my home.
          • S Scala
            @mfalkvidd Hi there and thanks for a great and super detailed step-by-step tutorial.
            I've got mine running in no time with your instructions, but after a couple of minutes I've got the following error:
            2015-12-30 20:51:30.356 Error: MySensors: Unhandled sensor (sub-type=32), please report with log!
            2015-12-30 20:52:01.390 Error: Serial Port closed!... Error: End of file
            2015-12-30 20:52:02.315 MySensors: retrying in 30 seconds...
            2015-12-30 20:52:31.319 MySensors: Using serial port: /dev/ttyUSB20
            2015-12-30 20:52:31.320 Error: MySensors: Error opening serial port!
            2015-12-30 20:52:32.321 MySensors: retrying in 30 seconds...
            2015-12-30 20:53:01.324 MySensors: Using serial port: /dev/ttyUSB20
            I also attached a partial screen capture showing that it was working before 8-)
            Any idea on why is this happening and how to solve it?
            Southern regards and happy new year to all!
            ronnyandreR
            ronnyandreR
            ronnyandre
            @Scala I have the same error as you. Worked perfectly first time, and after reboot the "/dev/ttyMySensorsGateway: No such file or directory" error message appear. Did you solve this?
            • MrRikkieM MrRikkie
              Hello, If followed the instruction and everything seemed to work without any problem.
              However when I enter the command : sudo cat /dev/ttyMySensorsGateway
              I get the message : cat: /dev/ttyMySensorsGateway: No such file or directory
              Does anybody have any idea how to solve this ?
              ronnyandreR
              ronnyandreR
              ronnyandre
              @MrRikkie Did you solve this issue? I got the same error as you..
              • J
                J
                javad arji
                hi
                when that run this code
                sudo /etc/init.d/PiGatewaySerial start
                error:
                [....] Starting PiGatewaySerial (via systemctl): PiGatewaySerial.serviceFailed to start PiGatewaySerial.service: Unit PiGatewaySerial.service failed to load: No such file or directory.
                can you help me??
                  Note: This guide is only applicable to MySensors 1.x. For MySensors 2, use this guide.
                  I noticed that a step-by-step procedure to connect the NRF24L01 to the GPIO pins and use the Raspberry as a Serial Gateway was listed in the document for MySensors 1.6.
                  Since I have three gateways configured this way, and I need to set up 3 more for covering different offices around the world, and I had already written the instructions in Swedish for Datormagazin, I thought I'd help out.
                  This is the first draft. Any feedback is welcome.
                  INTRODUCTION
                  The radio module NRF24L01+ is cheap and power efficient, but it is unable to communicate with regular wifi. The bridge between NRF24L01+ nodes and the "computer world" is called a Gateway. You can use other types of gateways, but connecting the NRF24L01+ module directly to the Raspberry Pi is a simple and cheap alternative.
                  Wiring Things Up
                  Connect the NRF20L01+ radio module to the Raspberry Pi like this:
                  Raspberry Pi NRF24L01+ Color
                  6 / GND GND Black
                  1 / 3.3V DC VCC Red
                  22 / GPIO25 CE Orange
                  24 / GPIO 8 CSN/CS Yellow
                  23 / GPIO11 / SPI_CLK SCK Green
                  19 / GPIO10 / SPI_MOSI MOSI Blue
                  21 / GPIO9 / SPI_MISO MISO Violet
                  The IRQ pin on NRF24L01 is not currently used.
                  For a comprehensive view of the Raspberry Pi pins, see http://pinout.xyz/
                  You should also connect a decoupling capacitor to the radio. See this guide.
                  COMPILING THE GATEWAY
                  Login to your Raspberry Pi (using SSH or open a terminal on the graphical console) and run these commands:
                  git clone https://github.com/TMRh20/RF24.git
                  cd RF24
                  make all && sudo make install
                  cd ..
                  git clone https://github.com/mysensors/Raspberry.git
                  cd Raspberry
                  If you get the following error:
                  pi@raspberrypi ~/RF24 $ make all && sudo make install
                  g++ -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c RF24.cpp
                  gcc -Wall -fPIC -Ofast -mfpu=vfp -mfloat-abi=hard -mtune=arm1176jzf-s -march=armv7-a -D BCM2835_PERI_BASE=0x -c bcm2835.c
                  bcm2835.c: In function ‘bcm2835_init’:
                  bcm2835.c:1207:28: error: invalid suffix "x" on integer constant
                  You've probably run into the problem discussed in this thread. People have had luck with different solutions. The simplest is to make the following change to ~/Raspberry/librf24-bcm/Makefile
                  #IOBASE := $(shell cat /proc/iomem | grep bcm2708_vcio | cut -f 1 -d "-")
                  IOBASE := 3F000000
                  VERIFY THE GATEWAY
                  Run sudo /usr/local/sbin/PiGatewaySerial. The output should look like this:
                  pi@raspberrypi ~/Raspberry $ sudo /usr/local/sbin/PiGatewaySerial
                  Created PTY '/dev/pts/1'
                  Clock Speed      = 8 Mhz
                  RX_ADDR_P0-1     = 0xe7e7e7e7e7 0xc2c2c2c2c2
                  TX_ADDR          = 0xe7e7e7e7e7
                  RX_PW_P0-6       = 0x00 0x00 0x20 0x00 0x00 0x00
                  EN_AA            = 0x3b
                  EN_RXADDR        = 0x07
                  RF_CH            = 0x4c
                  RF_SETUP         = 0x23
                  CONFIG           = 0x0e
                  Data Rate        = 250KBPS
                  Model            = nRF24L01+
                  PA Power         = PA_LOW
                  If the NRF24L01+ isn't correctly wired, the following error will be shown
                  pi@raspberrypi ~ $ sudo /usr/local/sbin/PiGatewaySerial
                  check wires
                  If this happens, double-check your wiring and correct any problems. Press Ctrl+Z and type
                  sudo killall PiGatewaySerial
                  to get rid of the non-functioning Gateway. Then run sudo /usr/local/sbin/PiGatewaySerial again
                  If all is well, exit PiGatewaySerial by pressing Ctrl+C. Then run
                  to start the gateway as a background process. Verify that it started correctly by running
                  You should see the message "Gateway startup complete". Exit by typing Ctrl+C.
                  MAKE THE GATEWAY AUTOSTART
                  To make sure the Gateway is started when your Raspberry Pi boots up, run the following command:
                  sudo make enable-gwserial
                  Enable the gateway for use with Domoticz
                  Domoticz (and maybe other home automation systems) has trouble reading from the default path created by PiGatewaySerial. You might need to run the following command:
                  sudo ln -s /dev/ttyMySensorsGateway /dev/ttyUSB20
                  And change /etc/rc.local from this
                  exit 0
                  to this
                  exit 0
                  OTHER NOTES
                  • The 3.3V power on the Raspberry Pi is rated for a maximum of 50mA. A regular NRF24L01+ only needs 15mA, but if you are using a power amplified version you might exceed what the Raspberry Pi can output. In that case, an external power supply might be required. If you use an external power source gnd must be connected to the Raspberry Pi's gnd.
                  • Connecting the NRF24L01+ directly to your Raspberry Pi will prevent you from using the Raspberry Pi's gpio ports for other things, like a Z-wave board.
                  • A user experienced slow data transfer compared to USB-to-Serial(ttl)<-->MySensors Gateway connection, especially on OTA firmware update. If you think this will cause a problem for you, an ethernet gateway might be a better alternative.
                  As always, I stand on the shoulders of giants. Related posts:
                  • http://forum.mysensors.org/topic/1151/tutorial-raspberry-pi-nrf24l01-direct-connection
                  • http://forum.mysensors.org/topic/1974/domoticz-as-controller-and-a-gateway-for-mysensor-nodes-running-on-a-raspberry-pi-2
                  TROUBLESHOOTING
                  If you get this error
                  pi@Domoticz3:~/Raspberry$ sudo /etc/init.d/PiGatewaySerial start
                   failed!
                  or this error
                  sudo: /usr/local/sbin/PiGatewaySerial: command not found
                  you have probably forgotten to run sudo make install. Read the instructions again, and follow them this time :-) User @sineverba reported that a reboot of the Pi after running make install helped.
                  sineverba
                  TROUBLESHOOTING
                   failed!
                  or this error
                  In my case I did need simply to restart. I did "make install" but I did need to restart ;) ;)
                  • T
                    Toyman
                    wrote on last edited by Toyman
                    #166
                    I know this thread is ancient, but why it was needed to add
                    into rc.local if you could just change a line in makefile from
                    TTY_NAME := /dev/ttyMySensorsGateway
                    to
                    TTY_NAME := /dev/ttyUSB20
                    and create "proper" name from the start
                    • R
                      R
                      ricorico94
                      I plan using a gateway with Mydomoticz and this solution seems great. However, I might want to use later signing or the high Amplifier NRF24 or even the version 2 which seem not suitable for this project.
                      How easy is it to start with this gateway, then migrate to an external ethernet gateway ?
                      I saw this gateway can be uninstalled, but should I then modify anything on sensors to move them to new gateway ? will I lose log datas in Domoticz ?
                      br,
                      Ricorico94
                      • R ricorico94
                        br,
                        Ricorico94
                        #168
                        @ricorico94 welcome to the MySensors commu ity! All you need to do when switching from raspberry pi gateway to ethernet gateway is change the "hardware" configuration in Domoticz.
                        However, if you are just starting out, don't use this gateway. It works for MySensors 1.x only. Use the new raspberry pi gateway instead.
                        12.5k
