  3. OpenHAB
  4. Openhab MQTT Example
openhab mqtt ex
49 Posts 8 Posters 74.9k Views 1 Watching
  • M Marcus
    Is there a big difference between serial and ethernet?
    C
    C
    C.r.a.z.y.
    @Marcus it works fine for me
      Marcus
      @Crazy Do u need Mosquitto?
      C 1 Reply Last reply
      • C
        C
        ceburge
        I to have had this same problem using openhab and MQTT Gateway. I could toggle relays and such but could not receive any information back from the gateway things such as sketch info or versions. So I decided to pull from that and try PiDome. I like the way PiDome works with the Serial Gateway. Everything seems to be more dynamic. I did try PiDome with the MQTT Gateway and got the same results as with Openhab I could publish information to the gateway but couldn't receive for some reason. Would like to find out what could be happening myself. However right now I'm waiting on parts.
        • M Marcus
          C
          C
          C.r.a.z.y.
          @Marcus serial is working fine with piDome, openHab and Vera. No need for mosquito which i never installed and used before.
            Marcus
            wrote on last edited by Marcus
            #31
            Thank u for your answers.
            I love the look of openhab. So i will try the it with mosquitto.
            If it will not work then i will try pidome and serial gateway.
            If i have new infos i will post them here!
            JohnJ 1 Reply Last reply
              Marcus
              Good morning community.
              Here is what i did now for installing mosquitto on my raspberry pi.
              This infos are from here (http://jpmens.net/2013/09/01/installing-mosquitto-on-a-raspberry-pi/).
                curl -O http://repo.mosquitto.org/debian/mosquitto-repo.gpg.key
                sudo apt-key add mosquitto-repo.gpg.key
                rm mosquitto-repo.gpg.key
                cd /etc/apt/sources.list.d/
                sudo curl -O http://repo.mosquitto.org/debian/mosquitto-repo.list
                sudo apt-get update
                sudo apt-get install mosquitto mosquitto-clients python-mosquitto
              Now mosquitto is running.
              With:
              sudo /etc/init.d/mosquitto stop
              I can stop it.
              With
              sudo /etc/init.d/mosquitto start
              I can start it.
              But what to do now???
              How do i connect mosquitto to my MQTT-Ethernet-Gateway?
              How do i connect mosquitto to Openhab?
              Please help!
              • b0rmannB
                b0rmannB
                b0rmann
                MQTT-Ethernet-Gateway is mqtt brocker, not client :(
                to connect mosquitto try use MQTTClientGateway http://forum.mysensors.org/topic/524/mqtt-client-gateway
                  Marcus
                  #34
                  @b0rmann Please read the whole thread and tell me what to do now!!! I only want openhab and mysensors work together. But i want to use my mqtt-ethernet-gateway. Not the serial way.
                  b0rmannB 1 Reply Last reply
                  • M Marcus
                    JohnJ
                    JohnJ
                    John
                    @Marcus PiDome also supports the mqtt gateway next to the serial gateway, so no need to switch. As far as i know, but i'm not an openhab expert, it should work fine as a mqtt client to connect to the mysensors mqtt gateway.
                    See this thread for some examples: http://forum.mysensors.org/topic/303/mqtt-broker-gateway
                    The developer of the MQTT gateway has posted some examples in the above thread on how you should be able to use it.
                    Cheers!
                      Marcus
                      @John Thank u very much. I think i will stop with Openhab and give PiDome a try. it seems to be better described what to do to get it run.
                      In the thread u mentioned i looked for some examples but didnt get them to work and no one could help.
                      • M Marcus
                        b0rmannB
                        b0rmannB
                        b0rmann
                        @Marcus mqtt client gateway is not serial way :)
                        i have mqtt-client-gateway + raspi (mosquitto + openhab + nodered)
                        • M Marcus
                          JohnJ
                          JohnJ
                          John
                          @Marcus Wish i could help, too bad it doesn't work. Others are using it successfully as far as i know. Maybe different openhab version install. Well, let me know if there are any issues or help needed with PiDome.
                          • T
                            tboha
                            @Marcus: Sorry I'm in a hurry so...
                            But what to do now??? -> is your broker really ok?
                            1. open two terminal windows on your Raspberry.
                            2. one window:
                              mosquitto_sub -t /test -v
                            3. second window:
                              mosquitto_pub -t /test -m "test message"
                            If it's all fine, the test message should show up in the first window.
                            OpenHab -> mosquitto
                            If your still got the OpenHab sitemap from above, the swtiches 1+3 should be functional like desribed, switch 2 will result in an errormessage in the log (as "intended").
                            Reverse direction (mosquitto -> Openhab).
                            You may populate your broker with some messages for the given topic.
                            e.g. mosquitto_pub -t MyMQTT/20/255/V_SKETCH_NAME -m "fake sketch name"
                            I use the serial Gateway connected via USB to my Raspberry and a little Node.js script.
                            If you are interested - let me know.
                              Marcus
                              Thank u anyway for your help @tboha . I think this is too much complicated. I tried ur last idea, but i got connection refused error. Really frustrating.... I want to see results. I hope pidome gave me faster results than openhab.
                              • T
                                tboha
                                Connection refused means (in 99%) your broker is not up or you got the wrong address.
                                I supposed you to run mosquitto_sub/pub on the same machine your broker runs on.
                                On a different machine you have to add the host address like:
                                mosquitto_sub -h 192.168.1.10 -t /topic -m "message".
                                No - at last its not really complicated, but I think you had just a bad start. MySensors and OpenHab tend to start right out of the box - but you need the right box......
                                  Marcus
                                  #42
                                  Please stop helping me now. Now i have pidome and the first sensor is running after 30 minutes with my ethernet mqtt gateway ;-)
                                  That is what i want. Maybe one day there are nice tutorials for Openhab. Thank u very much for trying to help. If i now start with mosquitto to get openhab run is the same as when i make a patch for a patch....
                                  It seems that pidome has wait for me it is really nice and not much complicated.
                                  • M Marcus
                                    C
                                    C
                                    C.r.a.z.y.
                                    @Marcus Try Tim's files and JAR file for serial openHab http://forum.mysensors.org/topic/655/serial-gateway-connection-to-openhab/2
                                    I added a motion sensor and its fine.
                                    • C C.r.a.z.y.
                                      JohnJ
                                      JohnJ
                                      John
                                      wrote on last edited by John
                                      #44
                                      @Marcus Good to see you have it working! The MySensors MQTT plugin and serial drivers are quite stable. Some parts of the server can behave a little strange, cause still in heavy development.
                                      • JohnJ John
                                        C
                                        C
                                        C.r.a.z.y.
                                        @John There was a problem with serial....1.6.1.jar it doesnt show this correctly;
                                        ArduinoUpdate -> 0;0;3;0;9;read: 14-14-0 s=1,c=1,t=16,pt=0,l=1:0
                                        14;1;1;0;16;0
                                        i think its related with baud rate for jar file because i saw  these kind of things in terminal ����BO�"U��²e��B&��i�
                                        • C C.r.a.z.y.
                                          14;1;1;0;16;0
                                          JohnJ
                                          JohnJ
                                          John
                                          @C.r.a.z.y. That's highly possible, or there was a wrong choice of encoding at the wrong moment.
