  3. Serial Gateway Sketch with si7021
18 Posts 2 Posters 4.5k Views 2 Watching
    Just add the code of a node in presentation, setup and loop, nothing fancy
      Markus.
      Well the Problem seems to be in the first step to get a working SI7021 Sketch for MySensors 2.2.0 Beta or 2.1.1.
      I did Try to complie this one now:
      by m26872, 20151109
      #define MY_NODE_ID 5             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
      #define MY_BAUD_RATE 115200
      #include <SI7021.h>
      #include <RunningAverage.h>
      //#define DEBUG
      #ifdef DEBUG
      #define CHILD_ID_TEMP 0
      #define CHILD_ID_HUM 1
      // #define SLEEP_TIME 15000 // 15s for DEBUG
      #define SLEEP_TIME 300000   // 5 min
      #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
      #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
      #define VMIN 1900
      #define VMAX 3300
      #define AVERAGES 2
      int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
      int measureCount = 0;
      float lastTemperature = -100;
      int lastHumidity = -100;
      SI7021 humiditySensor;
        sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
        present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
        present(CHILD_ID_HUM, S_HUM);
        DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
        DEBUG_PRINT("Voltage: ");
        DEBUG_PRINT(readVcc());
        DEBUG_PRINTLN(" mV");
        delay(500);
        DEBUG_PRINTLN(" *C");
        DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
        raHum.clear();
        measureCount ++;
        batteryReportCounter ++;
        bool forceTransmit = false;
        if (measureCount > FORCE_TRANSMIT_CYCLE) {
          forceTransmit = true;
        // Read and print internal temp
        float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
        DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
        // Check battery
        if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
          long batteryVolt = readVcc();
          DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
          uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
          DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
          batteryReportCounter = 0;
        sleep(SLEEP_TIME);
      // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
      // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
      long readVcc() {
      // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
      double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
        unsigned int wADC;
        double t;
        // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
        ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
        ADCSRA |= _BV(ADEN);  // enable the ADC
        delay(20);            // wait for voltages to become stable.
        ADCSRA |= _BV(ADSC);  // Start the ADC
        while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
        wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
        t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
        return (t);   // The returned temperature in degrees Celcius.
       * Parameters
        bool tx = force;
        float temperature = data.celsiusHundredths / 100.0;
        if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
          send(msgTemp.set(temperature,1));
          measureCount = 0;
          DEBUG_PRINTLN("T sent!");
        raHum.addValue(humidity);
        if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
          send(msgHum.set(humidity));
          lastHumidity = humidity;
          measureCount = 0;
          DEBUG_PRINTLN("H sent!");
      But I get always follwoing error...
      exit status 1
      'si7021_env' has no member named 'humidityPercent'
      So I am a bit lost at the Moment due to my limited coding Knowledge.. :-(
        wrote on last edited by gohan
        Why don't you start with a much simpler sketch? And that is for a node, it is missing all the defines for the gateway. Start with the gateway sketch and add only the code needed by the sensor. The error you get is probably a mismatch between the code and the library: check in the library examples how do you retrive humidity from the sensor
        • M Markus.
          by m26872, 20151109
          #include <SI7021.h>
          //#define DEBUG
          #ifdef DEBUG
          #define VMIN 1900
          #define VMAX 3300
          #define AVERAGES 2
            delay(500);
            raHum.clear();
            measureCount ++;
            // Check battery
            sleep(SLEEP_TIME);
          long readVcc() {
            unsigned int wADC;
            double t;
           * Parameters
            bool tx = force;
              measureCount = 0;
              measureCount = 0;
          exit status 1
          Markus.
          Did a mistake with the Libary. Used now the SI7021 from MySensorsArduinoExamples-master and this seems to be okay now
            Markus.
            the Problem is I cnnaot find any simple Mysensors Sketch to read a SI7021 :-(
            Only with battery Monitoring which I don't Need...
              Markus.
              wrote on last edited by Markus.
              can it work like this?
              #define MY_RADIO_RFM69
              #define MY_RFM69_FREQUENCY RFM69_868MHZ
              #include <SI7021.h>
              #ifdef MY_DEBUG
              #define AVERAGES 2
              // Enable serial gateway
              #define MY_GATEWAY_SERIAL
              #if F_CPU == 8000000L
              #define MY_BAUD_RATE 38400
              // Enable inclusion mode
              // Set blinking period
              // Flash leds on rx/tx/err
                DEBUG_SERIAL(38400);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                 raHum.clear();
                sendSketchInfo("Gateway_SI7021", "1.0 161017");
                measureCount ++;
                sleep(SLEEP_TIME);
               * Parameters
                bool tx = force;
                  measureCount = 0;
                  measureCount = 0;
                Did you try it?
                  Markus.
                  not yet ;-) Will try it later....
                    Markus.
                    tried now the Sketch... Seems that something is wrong with the sensor.
                     __  __       ____
                            |___/                      2.2.0-beta
                    0;255;3;0;9;53 MCO:BGN:INIT GW,CP=RRNGA---,VER=2.2.0-beta
                    0;255;3;0;9;83 TSM:INIT
                    0;255;3;0;9;92 TSF:WUR:MS=0
                    0;255;3;0;9;100 TSM:INIT:TSP OK
                    0;255;3;0;9;108 TSM:INIT:GW MODE
                    0;255;3;0;9;118 TSM:READY:ID=0,PAR=0,DIS=0
                    0;255;3;0;9;129 MCO:REG:NOT NEEDED
                    0;255;0;0;18;2.2.0-beta
                    0;255;3;0;11;Gateway_SI7021
                    0;255;3;0;12;1.0 161017
                    0;0;0;0;6;
                    0;1;0;0;7;
                    0;255;3;0;9;159 MCO:BGN:STP
                    Serial started
                    Node and 2 children presented.
                    0;255;3;0;9;684 MCO:BGN:INIT OK,TSP=1
                    Also the issue with the attached sensor blocks completly the Gateway function.Means that the Gateway didn't receive anything. Is it possible to prevent such issue? what I mean, is it possible to seperate both functions in the Sketch in that way If something is wrong with the sensor, the Gateway can still operate?
                    THX
                    Markus
                      add some more serial prints around to see where the code stops
                        Markus.
                        @gohan how can i do this ? :-(
                          Look at the "DEBUG_PRINTLN" you have in your code, add some of those where you see there aren't.
                            Markus.
                            the Code stops here
                            Anything wrong with the sensor I guess. But how can I handle such things?
                              did you try an example sketch from the library to see if you can read the values correctly?
                                Markus.
                                the sensor conenction was the Problem at the end. Changed SCD and SCL and now it Looks good so far. At the Moment is the Gateway not connected to a Controller. Hope the sensor will be then also send the values...
                                 __  __       ____
                                        |___/                      2.2.0-beta
                                0;0;0;0;6;
                                0;1;0;0;7;
                                Serial started
                                Loop1 started
                                T: 21.49
                                TempDiff :121.49
                                0;0;1;0;0;21.5
                                T sent!
                                H: 64
                                HumDiff  :164.00
                                0;1;1;0;1;64
                                H sent!
                                Before first sleep
                                0;255;3;0;9;733 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                0;255;3;0;9;768 !MCO:SLP:REP
                                0;255;3;0;9;124672 TSF:MSG:READ,106-106-0,s=0,c=1,t=1,pt=7,l=5,sg=0:63.3
                                106;0;1;0;1;63.3
                                0;255;3;0;9;124702 TSF:MSG:READ,106-106-0,s=255,c=3,t=0,pt=1,l=1,sg=0:90
                                106;255;3;0;0;90
                                0;255;3;0;9;124735 TSF:MSG:READ,106-106-0,s=3,c=1,t=38,pt=7,l=5,sg=0:3.71
                                106;3;1;0;38;3.71
                                After first sleep
                                Loop1 started
                                T: 21.64
                                TempDiff :0.15
                                H: 65
                                HumDiff  :0.00
                                Before first sleep
                                0;255;3;0;9;300797 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                0;255;3;0;9;300830 !MCO:SLP:REP
                                0;255;3;0;9;428443 TSF:MSG:READ,106-106-0,s=255,c=3,t=0,pt=1,l=1,sg=0:90
                                106;255;3;0;0;90
                                0;255;3;0;9;428476 TSF:MSG:READ,106-106-0,s=3,c=1,t=38,pt=7,l=5,sg=0:3.72
                                106;3;1;0;38;3.72
                                But how can I prevent the Situation that a defect or missing sensor on the Gateway blocks also the Gateway function ?
                                Markus
                                  You need to make a check in the code that if the sensor read is fails it should keep going
                                    Markus.
                                    @gohan ;-) will try it.... -> Learning leasson... :-)
