  3. Serial Gateway Sketch with si7021
18 Posts 2 Posters 4.3k Views 2 Watching
  • M Offline
    M Offline
    Markus.
    Hi All,
    I have biuld a Serial Gateway based on RFM69 and a ProMini. Its working great so far. But I want to implement in this Sketch also a Sensor si7021. I have currently no idea how i can implent the sensor part into the Gateway Sketch. Hope someone can help me there.
    Markus
      Just add the code of a node in presentation, setup and loop, nothing fancy
      • M Offline
        M Offline
        Markus.
        Well the Problem seems to be in the first step to get a working SI7021 Sketch for MySensors 2.2.0 Beta or 2.1.1.
        I did Try to complie this one now:
        by m26872, 20151109
        #define MY_NODE_ID 5             // <<<<<<<<<<<<<<<<<<<<<<<<<<<   Enter Node_ID
        #define MY_BAUD_RATE 115200
        #include <SI7021.h>
        #include <RunningAverage.h>
        //#define DEBUG
        #ifdef DEBUG
        #define CHILD_ID_TEMP 0
        #define CHILD_ID_HUM 1
        // #define SLEEP_TIME 15000 // 15s for DEBUG
        #define SLEEP_TIME 300000   // 5 min
        #define FORCE_TRANSMIT_CYCLE 36  // 5min*12=1/hour, 5min*36=1/3hour
        #define BATTERY_REPORT_CYCLE 2880   // Once per 5min   =>   12*24*7 = 2016 (one report/week)
        #define VMIN 1900
        #define VMAX 3300
        #define AVERAGES 2
        int batteryReportCounter = BATTERY_REPORT_CYCLE - 1;  // to make it report the first time.
        int measureCount = 0;
        float lastTemperature = -100;
        int lastHumidity = -100;
        SI7021 humiditySensor;
          sendSketchInfo("EgTmpHumBat5min", "1.0 151106");
          present(CHILD_ID_TEMP, S_TEMP);   // Present sensor to controller
          present(CHILD_ID_HUM, S_HUM);
          DEBUG_SERIAL(115200);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
          DEBUG_PRINT("Voltage: ");
          DEBUG_PRINT(readVcc());
          DEBUG_PRINTLN(" mV");
          delay(500);
          DEBUG_PRINTLN(" *C");
          DEBUG_PRINT("Node and "); DEBUG_PRINTLN("2 children presented.");
          raHum.clear();
          measureCount ++;
          batteryReportCounter ++;
          bool forceTransmit = false;
          if (measureCount > FORCE_TRANSMIT_CYCLE) {
            forceTransmit = true;
          // Read and print internal temp
          float temperature0 = static_cast<float>(static_cast<int>((GetInternalTemp()+0.5) * 10.)) / 10.;
          DEBUG_PRINT("Internal Temp: "); DEBUG_PRINT(temperature0); DEBUG_PRINTLN(" *C");
          // Check battery
          if (batteryReportCounter >= BATTERY_REPORT_CYCLE) {
            long batteryVolt = readVcc();
            DEBUG_PRINT("Battery voltage: "); DEBUG_PRINT(batteryVolt); DEBUG_PRINTLN(" mV");
            uint8_t batteryPcnt = constrain(map(batteryVolt,VMIN,VMAX,0,100),0,255);
            DEBUG_PRINT("Battery percent: "); DEBUG_PRINT(batteryPcnt); DEBUG_PRINTLN(" %");
            batteryReportCounter = 0;
          sleep(SLEEP_TIME);
        // function for reading Vcc by reading 1.1V reference against AVcc. Based from http://provideyourown.com/2012/secret-arduino-voltmeter-measure-battery-voltage/
        // To calibrate reading replace 1125300L with scale_constant = internal1.1Ref * 1023 * 1000, where internal1.1Ref = 1.1 * Vcc1 (per voltmeter) / Vcc2 (per readVcc() function)
        long readVcc() {
        // function for reading internal temp. From http://playground.arduino.cc/Main/InternalTemperatureSensor
        double GetInternalTemp(void) {  // (Both double and float are 4 byte in most arduino implementation)
          unsigned int wADC;
          double t;
          // The internal temperature has to be used with the internal reference of 1.1V. Channel 8 can not be selected with the analogRead function yet.
          ADMUX = (_BV(REFS1) | _BV(REFS0) | _BV(MUX3));   // Set the internal reference and mux.
          ADCSRA |= _BV(ADEN);  // enable the ADC
          delay(20);            // wait for voltages to become stable.
          ADCSRA |= _BV(ADSC);  // Start the ADC
          while (bit_is_set(ADCSRA,ADSC));   // Detect end-of-conversion
          wADC = ADCW;   // Reading register "ADCW" takes care of how to read ADCL and ADCH.
          t = (wADC - 88.0 ) / 1.0;   // The default offset is 324.31.
          return (t);   // The returned temperature in degrees Celcius.
         * Parameters
          bool tx = force;
          float temperature = data.celsiusHundredths / 100.0;
          if (diffTemp > TEMP_TRANSMIT_THRESHOLD || tx) {
            send(msgTemp.set(temperature,1));
            measureCount = 0;
            DEBUG_PRINTLN("T sent!");
          raHum.addValue(humidity);
          if (diffHum > HUMI_TRANSMIT_THRESHOLD || tx) {
            send(msgHum.set(humidity));
            lastHumidity = humidity;
            measureCount = 0;
            DEBUG_PRINTLN("H sent!");
        But I get always follwoing error...
        exit status 1
        'si7021_env' has no member named 'humidityPercent'
        So I am a bit lost at the Moment due to my limited coding Knowledge.. :-(
          wrote on last edited by gohan
          Why don't you start with a much simpler sketch? And that is for a node, it is missing all the defines for the gateway. Start with the gateway sketch and add only the code needed by the sensor. The error you get is probably a mismatch between the code and the library: check in the library examples how do you retrive humidity from the sensor
          • M Markus.
            by m26872, 20151109
            #include <SI7021.h>
            //#define DEBUG
            #ifdef DEBUG
            #define VMIN 1900
            #define VMAX 3300
            #define AVERAGES 2
              delay(500);
              raHum.clear();
              measureCount ++;
              // Check battery
              sleep(SLEEP_TIME);
            long readVcc() {
              unsigned int wADC;
              double t;
             * Parameters
              bool tx = force;
                measureCount = 0;
                measureCount = 0;
            exit status 1
            M Offline
            M Offline
            Markus.
            Did a mistake with the Libary. Used now the SI7021 from MySensorsArduinoExamples-master and this seems to be okay now
            • M Offline
              M Offline
              Markus.
              the Problem is I cnnaot find any simple Mysensors Sketch to read a SI7021 :-(
              Only with battery Monitoring which I don't Need...
              • M Offline
                M Offline
                Markus.
                wrote on last edited by Markus.
                can it work like this?
                #define MY_RADIO_RFM69
                #define MY_RFM69_FREQUENCY RFM69_868MHZ
                #include <SI7021.h>
                #ifdef MY_DEBUG
                #define AVERAGES 2
                // Enable serial gateway
                #define MY_GATEWAY_SERIAL
                #if F_CPU == 8000000L
                #define MY_BAUD_RATE 38400
                // Enable inclusion mode
                // Set blinking period
                // Flash leds on rx/tx/err
                  DEBUG_SERIAL(38400);    // <<<<<<<<<<<<<<<<<<<<<<<<<< Note BAUD_RATE in MySensors.h
                   raHum.clear();
                  sendSketchInfo("Gateway_SI7021", "1.0 161017");
                  measureCount ++;
                  sleep(SLEEP_TIME);
                 * Parameters
                  bool tx = force;
                    measureCount = 0;
                    measureCount = 0;
                  Did you try it?
                  • M Offline
                    M Offline
                    Markus.
                    not yet ;-) Will try it later....
                    • M Offline
                      M Offline
                      Markus.
                      tried now the Sketch... Seems that something is wrong with the sensor.
                       __  __       ____
                              |___/                      2.2.0-beta
                      0;255;3;0;9;53 MCO:BGN:INIT GW,CP=RRNGA---,VER=2.2.0-beta
                      0;255;3;0;9;83 TSM:INIT
                      0;255;3;0;9;92 TSF:WUR:MS=0
                      0;255;3;0;9;100 TSM:INIT:TSP OK
                      0;255;3;0;9;108 TSM:INIT:GW MODE
                      0;255;3;0;9;118 TSM:READY:ID=0,PAR=0,DIS=0
                      0;255;3;0;9;129 MCO:REG:NOT NEEDED
                      0;255;0;0;18;2.2.0-beta
                      0;255;3;0;11;Gateway_SI7021
                      0;255;3;0;12;1.0 161017
                      0;0;0;0;6;
                      0;1;0;0;7;
                      0;255;3;0;9;159 MCO:BGN:STP
                      Serial started
                      Node and 2 children presented.
                      0;255;3;0;9;684 MCO:BGN:INIT OK,TSP=1
                      Also the issue with the attached sensor blocks completly the Gateway function.Means that the Gateway didn't receive anything. Is it possible to prevent such issue? what I mean, is it possible to seperate both functions in the Sketch in that way If something is wrong with the sensor, the Gateway can still operate?
                      THX
                      Markus
                        add some more serial prints around to see where the code stops
                          M Offline
                          M Offline
                          Markus.
                          @gohan how can i do this ? :-(
                            Look at the "DEBUG_PRINTLN" you have in your code, add some of those where you see there aren't.
                            • M Offline
                              M Offline
                              Markus.
                              the Code stops here
                              Anything wrong with the sensor I guess. But how can I handle such things?
                                did you try an example sketch from the library to see if you can read the values correctly?
                                • M Offline
                                  M Offline
                                  Markus.
                                  the sensor conenction was the Problem at the end. Changed SCD and SCL and now it Looks good so far. At the Moment is the Gateway not connected to a Controller. Hope the sensor will be then also send the values...
                                   __  __       ____
                                          |___/                      2.2.0-beta
                                  0;0;0;0;6;
                                  0;1;0;0;7;
                                  Serial started
                                  Loop1 started
                                  T: 21.49
                                  TempDiff :121.49
                                  0;0;1;0;0;21.5
                                  T sent!
                                  H: 64
                                  HumDiff  :164.00
                                  0;1;1;0;1;64
                                  H sent!
                                  Before first sleep
                                  0;255;3;0;9;733 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  0;255;3;0;9;768 !MCO:SLP:REP
                                  0;255;3;0;9;124672 TSF:MSG:READ,106-106-0,s=0,c=1,t=1,pt=7,l=5,sg=0:63.3
                                  106;0;1;0;1;63.3
                                  0;255;3;0;9;124702 TSF:MSG:READ,106-106-0,s=255,c=3,t=0,pt=1,l=1,sg=0:90
                                  106;255;3;0;0;90
                                  0;255;3;0;9;124735 TSF:MSG:READ,106-106-0,s=3,c=1,t=38,pt=7,l=5,sg=0:3.71
                                  106;3;1;0;38;3.71
                                  After first sleep
                                  Loop1 started
                                  T: 21.64
                                  TempDiff :0.15
                                  H: 65
                                  HumDiff  :0.00
                                  Before first sleep
                                  0;255;3;0;9;300797 MCO:SLP:MS=300000,SMS=0,I1=255,M1=255,I2=255,M2=255
                                  0;255;3;0;9;300830 !MCO:SLP:REP
                                  0;255;3;0;9;428443 TSF:MSG:READ,106-106-0,s=255,c=3,t=0,pt=1,l=1,sg=0:90
                                  106;255;3;0;0;90
                                  0;255;3;0;9;428476 TSF:MSG:READ,106-106-0,s=3,c=1,t=38,pt=7,l=5,sg=0:3.72
                                  106;3;1;0;38;3.72
                                  But how can I prevent the Situation that a defect or missing sensor on the Gateway blocks also the Gateway function ?
                                  Markus
                                    You need to make a check in the code that if the sensor read is fails it should keep going
                                      M Offline
                                      M Offline
                                      Markus.
                                      @gohan ;-) will try it.... -> Learning leasson... :-)
                                      12.2k
