  3. STM32?
STM32?
82 Posts 19 Posters 47.2k Views 19 Watching
  • U Uhrheber
    I said boards, not chips. Chips I can get a dime a dozen.
    And as there aren't any cheap STM32L0 boards now, most people will stay with the blue pill.
    @Uhrheber yep
    • Nca78N
      And neither is there an arduino core available for those chips, they use and m0 core and not m3 like in the F103 versions.
      U 1 Reply Last reply
      • Nca78N Nca78
        U
        U
        Uhrheber
        @Nca78 The Arduino Zero is also an M0, so this shouldn't be too complicated.
        Peripherals are completely different, though.
        Nca78N 1 Reply Last reply
        • U Uhrheber
          @Uhrheber said in STM32?:
          Yes and NRF51822 is too and the core is based on SAMD core which is from the Zero.
          But it's still a lot of work to adapt it first for Arduino and then add support in MySensors, when an NRF52832 already has a core, support in MySensors and is available at a similar price but with better performance (Cortex M4 with FPU) and includes the radio.
          And now there's an Arduino using nrf52832 (Primo), I'm pretty sure we will "soon" find some nrf52832 boards on AliExpress at a reasonable price.
          • U
            U
            Uhrheber
            How does the NRF52832 fare, compared to a classical solution using Arduino Nano and nRF24?
            Is it usable for a sleeping node with a (window) switch, or a remote environmental sensor, when it comes to range and power consumption?
            Is the software already stable enough?
            • U Uhrheber
              @Uhrheber see this thread
              https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/805
              There's still progress to make but it works, and with DCDC enabled power consumption is much lower than on nrf24.
              • O
                O
                ooznerol
                Hi all,
                I successfully compiling and flashing my STM32 blue pill, but don't know where is the Serial output?
                Do you use SWO or physical UART? if UART on which one?
                Thanks a lot for this great work
                • O
                  O
                  ooznerol
                  Hi all, Can somebody help me please?
                  I add also some STM32 blue pill and try to run mysensors on them.
                  I use the devlopment branch. Compilation is OK and I successfully flash it on my board with STLink.
                  But I don't see any message/log. I am not sure that the software is runnning.
                  How can I debug that?
                  thansk
                  F 1 Reply Last reply
                    I guess you are one of the very few using the STM32 at the moment.
                    • O ooznerol
                      thansk
                      F
                      F
                      freynder
                      wrote on last edited by freynder
                      #54
                      @ooznerol : it's been a while but I've had some issues with this as well. Here are some pointers that may help you:
                      If I remember correctly, it depends on the upload method which may set particular build flags. In my platformio configuration for example, I'm setting the following build flags:
                      build_flags = -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER when using the stlink upload method. CONFIG_MAPLE_MINI_NO_DISABLE_DEBUG was necessary to preserve the SWD pins and SERIAL_USB creates a virtual UART for serial output to the USB port. If Serial_USB is not set then the hardware serial is being used. Which one? According to https://github.com/rogerclarkmelbourne/STM32duino-bootloader/issues/8 it depends on the fact that you are using a bootloader or not, so serial1 (PA9/PA10) or serial2 (PA2/PA3).
                      Also, if you experience issues with the USB connection, check the pullup resistor on D+ as indicated in http://wiki.stm32duino.com/index.php?title=Blue_Pill .
                      I'm not sure what IDE/upload method/board library you are using. In any case, watching the output during upload to find out the build flags may be useful. If that does not help, then pls send me the details of your setup and I will try to test it myself.
                      • O
                        O
                        ooznerol
                        wrote on last edited by ooznerol
                        #55
                        Hi @freynder , and thanks for your help.
                        I use Arduino IDE with stm32duino library to compile and upload . I haven't change the bootloader.
                        This setup works without problem on my bluepill ( I had run several example without porblem, specialy to found which uart pin are used by stm32duino).
                        I had a STLink connected to my blue pin (JTAG Clk/Data and SWO (and GND of course)).
                        I have enable debug option : #define MY_DEBUG and #define MY_DEBUG_VERBOSE_RF24
                        Here is the output of my compilation/upload :
                        C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ooznerol\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ooznerol\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ooznerol\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10803 -build-path C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727 -warnings=none -build-cache C:\Users\ooznerol\AppData\Local\Temp\arduino_cache_402979 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ooznerol\Documents\Arduino\STM32Duino_MysensorsLightSensor\STM32Duino_MysensorsLightSensor.ino
                        C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ooznerol\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ooznerol\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ooznerol\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10803 -build-path C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727 -warnings=none -build-cache C:\Users\ooznerol\AppData\Local\Temp\arduino_cache_402979 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ooznerol\Documents\Arduino\STM32Duino_MysensorsLightSensor\STM32Duino_MysensorsLightSensor.ino
                        Using board 'genericSTM32F103C' from platform in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1
                        Using core 'maple' from platform in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1
                        Detecting libraries used...
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
                        Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM\EEPROM.cpp
                        Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM\flash_stm32.c
                        Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp
                        Generating function prototypes...
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\preproc\ctags_target_for_gcc_minus_e.cpp"
                        "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\preproc\ctags_target_for_gcc_minus_e.cpp"
                        Compiling sketch...
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp.o"
                        Compiling libraries...
                        Compiling library "MySensors-development"
                        Compiling library "EEPROM"
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\flash_stm32.c.o
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\EEPROM.cpp.o
                        Compiling library "SPI"
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\SPI\SPI.cpp.o
                        Compiling core...
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start.S.o
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start_c.c.o
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\syscalls.c.o
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\board.cpp.o
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards.cpp.o
                        Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards_setup.cpp.o
                        Using precompiled core
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections  -mcpu=cortex-m3 "-TC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c/ld/jtag_c8.ld" "-Wl,-Map,C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.map" "-LC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c/ld" -o "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.elf" "-LC:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\flash_stm32.c.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\EEPROM.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\SPI\SPI.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start.S.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start_c.c.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\syscalls.c.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\board.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards_setup.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/..\arduino_cache_402979\core\core_Arduino_STM32_STM32F1_genericSTM32F103C_device_variant_STM32F103C8,upload_method_STLinkMethod,cpu_speed_speed_72mhz,opt_osstd_dd5e5f7edaf4f0539408738d9cfc05e4.a" -Wl,--end-group
                        "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.elf" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.bin"
                        Multiple libraries were found for "MySensors.h"
                         Used: C:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development
                         Not used: C:\Users\ooznerol\Documents\Arduino\libraries\Mysensors-rfm69_update2
                        Using library MySensors-development at version 2.2.0-beta in folder: C:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development
                        Using library EEPROM in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM (legacy)
                        Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI
                        Sketch uses 46576 bytes (71%) of program storage space. Maximum is 65536 bytes.
                        Global variables use 4432 bytes (21%) of dynamic memory, leaving 16048 bytes for local variables. Maximum is 20480 bytes.
                        C:\Program Files (x86)\Arduino\hardware\Arduino_STM32/tools/win/stlink_upload.bat COM8 {upload.altID} {upload.usbID} C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.bin
                        STM32 ST-LINK CLI v2.1.0
                        STM32 ST-LINK Command Line Interface
                        ST-LINK SN : 49FF6E065178505040351687
                        ST-LINK Firmware version : V2J28S0
                        Connected via SWD.
                        SWD Frequency = 1800K.
                        Connection mode : Normal.
                        Device ID:0x446
                        Device flash Size : 512 Kbytes
                        Device family :STM32F302xE/F303xE/F398xx
                        Loading file...
                        Flash Programming:
                          File : C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\STM32Duino_MysensorsLightSensor.ino.bin
                          Address : 0x08000000
                        Flash memory programming...
                        ±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
                         0%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 100%
                        Flash memory programmed in 2s and 995ms.
                        Programming Complete.
                        MCU Reset.
                        Application started.
                        F 2 Replies Last reply
                        • O ooznerol
                          Compiling sketch...
                          Compiling core...
                          Connected via SWD.
                          Device ID:0x446
                          Loading file...
                          Flash Programming:
                          MCU Reset.
                          F
                          F
                          freynder
                          #56
                          Hi @ooznerol ,
                          Your output shows build tag SERIAL_USB so I would assume Serial outputs to USB.
                          Did you connect the board using USB and try to read output from there? is USB recognized as a serial device? Is the pullup resistor on D+ correct (http://wiki.stm32duino.com/index.php?title=Blue_Pill)?
                          • O ooznerol
                            Compiling sketch...
                            Compiling core...
                            Connected via SWD.
                            Device ID:0x446
                            Loading file...
                            Flash Programming:
                            MCU Reset.
                            F
                            F
                            freynder
                            @ooznerol : when you say the examples ran without a problem, do you mean you had serial output from the examples but not from mysensors specifically?
                            • O
                              O
                              ooznerol
                              #58
                              HI @freynder ,
                              I just realize that when you speak about SERIAL_USB you really speak about.....Serial through USB connector :grinning: .
                              I believe you speak about Virtual Com Port through USB in ST-LINK.
                              So I had change R10 on my blue pill and install maple driver.
                              Now I have a Maple Serial COM mounted when I connect my blue pill with the USB connector :grinning: .
                              And......................TADA.................It is working. I had output on my terminal.
                              Thanks again:+1:
                              • O
                                O
                                ooznerol
                                Hi it's me again...............
                                I have no problem with sensors sketch using RFM69.
                                But I have a strange problem with the serial gateway ino.
                                If I select the NRF24 radio (#define MY_RADIO_NRF24), I have some debug info on my terminal.
                                But If I select RFM69 (#define MY_RADIO_RFM69), I have nothing.
                                Is it normal?
                                  do you have #define MY_DEBUG enabled?
                                  O 1 Reply Last reply
                                    O
                                    O
                                    ooznerol
                                    @gohan Yes of course
                                    I only modified the radio
                                      I have no idea then... I never used serial GW
                                      • O ooznerol
                                        HI @freynder ,
                                        Thanks again:+1:
                                        F
                                        F
                                        freynder
                                        Hi @ooznerol,
                                        Glad serial output is working now. Unfortunately I have no experience with serial gateway either, sorry.
                                        • F freynder
                                          Hi @ooznerol,
                                          O
                                          O
                                          ooznerol
                                          @freynder
                                          Too bad...... Do you have any idea how we can debug this?
