  3. STM32?
STM32?
82 Posts 19 Posters 47.2k Views 19 Watching
  • O
    O
    ooznerol
    Hi all,
    I successfully compiling and flashing my STM32 blue pill, but don't know where is the Serial output?
    Do you use SWO or physical UART? if UART on which one?
    Thanks a lot for this great work
    • O
      O
      ooznerol
      Hi all, Can somebody help me please?
      I add also some STM32 blue pill and try to run mysensors on them.
      I use the devlopment branch. Compilation is OK and I successfully flash it on my board with STLink.
      But I don't see any message/log. I am not sure that the software is runnning.
      How can I debug that?
      thansk
      F 1 Reply Last reply
        I guess you are one of the very few using the STM32 at the moment.
        • O ooznerol
          thansk
          F
          F
          freynder
          wrote on last edited by freynder
          #54
          @ooznerol : it's been a while but I've had some issues with this as well. Here are some pointers that may help you:
          If I remember correctly, it depends on the upload method which may set particular build flags. In my platformio configuration for example, I'm setting the following build flags:
          build_flags = -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER when using the stlink upload method. CONFIG_MAPLE_MINI_NO_DISABLE_DEBUG was necessary to preserve the SWD pins and SERIAL_USB creates a virtual UART for serial output to the USB port. If Serial_USB is not set then the hardware serial is being used. Which one? According to https://github.com/rogerclarkmelbourne/STM32duino-bootloader/issues/8 it depends on the fact that you are using a bootloader or not, so serial1 (PA9/PA10) or serial2 (PA2/PA3).
          Also, if you experience issues with the USB connection, check the pullup resistor on D+ as indicated in http://wiki.stm32duino.com/index.php?title=Blue_Pill .
          I'm not sure what IDE/upload method/board library you are using. In any case, watching the output during upload to find out the build flags may be useful. If that does not help, then pls send me the details of your setup and I will try to test it myself.
          • O
            O
            ooznerol
            wrote on last edited by ooznerol
            #55
            Hi @freynder , and thanks for your help.
            I use Arduino IDE with stm32duino library to compile and upload . I haven't change the bootloader.
            This setup works without problem on my bluepill ( I had run several example without porblem, specialy to found which uart pin are used by stm32duino).
            I had a STLink connected to my blue pin (JTAG Clk/Data and SWO (and GND of course)).
            I have enable debug option : #define MY_DEBUG and #define MY_DEBUG_VERBOSE_RF24
            Here is the output of my compilation/upload :
            C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ooznerol\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ooznerol\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ooznerol\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10803 -build-path C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727 -warnings=none -build-cache C:\Users\ooznerol\AppData\Local\Temp\arduino_cache_402979 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ooznerol\Documents\Arduino\STM32Duino_MysensorsLightSensor\STM32Duino_MysensorsLightSensor.ino
            C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -hardware C:\Users\ooznerol\AppData\Local\Arduino15\packages -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -tools C:\Users\ooznerol\AppData\Local\Arduino15\packages -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\ooznerol\Documents\Arduino\libraries -fqbn=Arduino_STM32:STM32F1:genericSTM32F103C:device_variant=STM32F103C8,upload_method=STLinkMethod,cpu_speed=speed_72mhz,opt=osstd -ide-version=10803 -build-path C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727 -warnings=none -build-cache C:\Users\ooznerol\AppData\Local\Temp\arduino_cache_402979 -prefs=build.warn_data_percentage=75 -verbose C:\Users\ooznerol\Documents\Arduino\STM32Duino_MysensorsLightSensor\STM32Duino_MysensorsLightSensor.ino
            Using board 'genericSTM32F103C' from platform in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1
            Using core 'maple' from platform in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1
            Detecting libraries used...
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "nul"
            Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM\EEPROM.cpp
            Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM\flash_stm32.c
            Using cached library dependencies for file: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src\SPI.cpp
            Generating function prototypes...
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11  -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -w -x c++ -E -CC -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\preproc\ctags_target_for_gcc_minus_e.cpp"
            "C:\Program Files (x86)\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\preproc\ctags_target_for_gcc_minus_e.cpp"
            Compiling sketch...
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -c -g -Os -w -DDEBUG_LEVEL=DEBUG_NONE -std=gnu++11 -MMD -ffunction-sections -fdata-sections -nostdlib --param max-inline-insns-single=500 -fno-rtti -fno-exceptions -DBOARD_generic_stm32f103c -DVECT_TAB_ADDR=0x8000000 -DERROR_LED_PORT=GPIOB -DERROR_LED_PIN=1 -mcpu=cortex-m3 -DF_CPU=72000000L -DARDUINO=10803 -DARDUINO_GENERIC_STM32F103C -DARDUINO_ARCH_STM32F1  -DCONFIG_MAPLE_MINI_NO_DISABLE_DEBUG=1 -DSERIAL_USB -DGENERIC_BOOTLOADER -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ -DMCU_STM32F103C8  -mthumb  -march=armv7-m -D__STM32F1__ "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/include" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/stm32f1/include"                                                           "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/stm32f1" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\system/libmaple/usb/usb_lib" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\cores\maple" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c" "-IC:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM" "-IC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI\src" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp" -o "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp.o"
            Compiling libraries...
            Compiling library "MySensors-development"
            Compiling library "EEPROM"
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\flash_stm32.c.o
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\EEPROM.cpp.o
            Compiling library "SPI"
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\SPI\SPI.cpp.o
            Compiling core...
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start.S.o
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start_c.c.o
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\syscalls.c.o
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\board.cpp.o
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards.cpp.o
            Using previously compiled file: C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards_setup.cpp.o
            Using precompiled core
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-g++" -Os -Wl,--gc-sections  -mcpu=cortex-m3 "-TC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c/ld/jtag_c8.ld" "-Wl,-Map,C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.map" "-LC:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\variants\generic_stm32f103c/ld" -o "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.elf" "-LC:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727" -lm -lgcc -mthumb -Wl,--cref -Wl,--check-sections -Wl,--gc-sections -Wl,--unresolved-symbols=report-all -Wl,--warn-common -Wl,--warn-section-align -Wl,--warn-unresolved-symbols -Wl,--start-group "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\sketch\STM32Duino_MysensorsLightSensor.ino.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\flash_stm32.c.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\EEPROM\EEPROM.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\libraries\SPI\SPI.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start.S.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\start_c.c.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\syscalls.c.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\board.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\core\wirish\boards_setup.cpp.o" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/..\arduino_cache_402979\core\core_Arduino_STM32_STM32F1_genericSTM32F103C_device_variant_STM32F103C8,upload_method_STLinkMethod,cpu_speed_speed_72mhz,opt_osstd_dd5e5f7edaf4f0539408738d9cfc05e4.a" -Wl,--end-group
            "C:\Users\ooznerol\AppData\Local\Arduino15\packages\arduino\tools\arm-none-eabi-gcc\4.8.3-2014q1/bin/arm-none-eabi-objcopy" -O binary  "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.elf" "C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.bin"
            Multiple libraries were found for "MySensors.h"
             Used: C:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development
             Not used: C:\Users\ooznerol\Documents\Arduino\libraries\Mysensors-rfm69_update2
            Using library MySensors-development at version 2.2.0-beta in folder: C:\Users\ooznerol\Documents\Arduino\libraries\MySensors-development
            Using library EEPROM in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\EEPROM (legacy)
            Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\Arduino_STM32\STM32F1\libraries\SPI
            Sketch uses 46576 bytes (71%) of program storage space. Maximum is 65536 bytes.
            Global variables use 4432 bytes (21%) of dynamic memory, leaving 16048 bytes for local variables. Maximum is 20480 bytes.
            C:\Program Files (x86)\Arduino\hardware\Arduino_STM32/tools/win/stlink_upload.bat COM8 {upload.altID} {upload.usbID} C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727/STM32Duino_MysensorsLightSensor.ino.bin
            STM32 ST-LINK CLI v2.1.0
            STM32 ST-LINK Command Line Interface
            ST-LINK SN : 49FF6E065178505040351687
            ST-LINK Firmware version : V2J28S0
            Connected via SWD.
            SWD Frequency = 1800K.
            Connection mode : Normal.
            Device ID:0x446
            Device flash Size : 512 Kbytes
            Device family :STM32F302xE/F303xE/F398xx
            Loading file...
            Flash Programming:
              File : C:\Users\ooznerol\AppData\Local\Temp\arduino_build_618727\STM32Duino_MysensorsLightSensor.ino.bin
              Address : 0x08000000
            Flash memory programming...
            ±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±±± 0%
             0%ÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛÛ 100%
            Flash memory programmed in 2s and 995ms.
            Programming Complete.
            MCU Reset.
            Application started.
            F 2 Replies Last reply
            • O ooznerol
              Compiling sketch...
              Compiling core...
              Connected via SWD.
              Device ID:0x446
              Loading file...
              Flash Programming:
              MCU Reset.
              F
              F
              freynder
              #56
              Hi @ooznerol ,
              Your output shows build tag SERIAL_USB so I would assume Serial outputs to USB.
              Did you connect the board using USB and try to read output from there? is USB recognized as a serial device? Is the pullup resistor on D+ correct (http://wiki.stm32duino.com/index.php?title=Blue_Pill)?
              • O ooznerol
                Compiling sketch...
                Compiling core...
                Connected via SWD.
                Device ID:0x446
                Loading file...
                Flash Programming:
                MCU Reset.
                F
                F
                freynder
                @ooznerol : when you say the examples ran without a problem, do you mean you had serial output from the examples but not from mysensors specifically?
                • O
                  O
                  ooznerol
                  #58
                  HI @freynder ,
                  I just realize that when you speak about SERIAL_USB you really speak about.....Serial through USB connector :grinning: .
                  I believe you speak about Virtual Com Port through USB in ST-LINK.
                  So I had change R10 on my blue pill and install maple driver.
                  Now I have a Maple Serial COM mounted when I connect my blue pill with the USB connector :grinning: .
                  And......................TADA.................It is working. I had output on my terminal.
                  Thanks again:+1:
                  • O
                    O
                    ooznerol
                    Hi it's me again...............
                    I have no problem with sensors sketch using RFM69.
                    But I have a strange problem with the serial gateway ino.
                    If I select the NRF24 radio (#define MY_RADIO_NRF24), I have some debug info on my terminal.
                    But If I select RFM69 (#define MY_RADIO_RFM69), I have nothing.
                    Is it normal?
                      do you have #define MY_DEBUG enabled?
                      O 1 Reply Last reply
                        O
                        O
                        ooznerol
                        @gohan Yes of course
                        I only modified the radio
                          I have no idea then... I never used serial GW
                          • O ooznerol
                            HI @freynder ,
                            Thanks again:+1:
                            F
                            F
                            freynder
                            Hi @ooznerol,
                            Glad serial output is working now. Unfortunately I have no experience with serial gateway either, sorry.
                            • F freynder
                              Hi @ooznerol,
                              O
                              O
                              ooznerol
                              @freynder
                              Too bad...... Do you have any idea how we can debug this?
                              • O ooznerol
                                @freynder
                                F
                                F
                                freynder
                                #65
                                @ooznerol
                                In general: isolating the problem and then tracing through the code. I understand you already isolated the problem to the combination of serial gateway and RFM69. First make sure this actually the case by uploading a sketch again you knew was working before with RFM69 (to eliminate any hardware / wiring issues that may have happened between your tests). If you can confirm that, you can start by looking at the code and find what is specific for the combination of these specific directives.
                                • F freynder
                                  @ooznerol
                                  O
                                  O
                                  ooznerol
                                  @freynder
                                  Instead facing through the code , I think about compile with a debugger (like IAR ou Keil for example). Do you think it is possible?
                                  • O ooznerol
                                    @freynder
                                    F
                                    F
                                    freynder
                                    @ooznerol No experience with those I'm afraid. From my notes I see I did experiment with using GDB in combination with a Black Magic Probe (BMP) to debug the blue pill. You can probably convert your SWD adapter to a BMP device:
                                    https://madnessinthedarkness.transsys.com/blog:2017:0122_black_magic_probe_bmp_on_st-link_v2_clones
                                    https://github.com/blacksphere/blackmagic/wiki
                                    • F freynder
                                      O
                                      O
                                      ooznerol
                                      #68
                                      Hi all, it's me again.
                                      So finally Gateway is working fine. The problem was that the driver (specially on windows) seems little bit unstable (I must open the serial just after strating and close it after I finish my test).
                                      So now I am playing with consumption.
                                      I take the low power implementation from freynder and reach 860uA. This implemenation used STOP mode. If I change this to STANDBY mode I reach 4.1uA. But in this case when I wake up, the CPU react as it has been reseted and relaunch all mysensors init and presenation etc etc . So the trick will be to check the wake up reason, and in case of wake up from standby not relaunch mysensors init. Do you think it is possible inside mysensors architecture?
                                      • O ooznerol
                                        F
                                        F
                                        freynder
                                        @ooznerol I suppose you intend to run on battery? I desoldered the power led and voltage regulator on mine to reach 100uA (if readings were correct) using STOP mode. It ran on 2 AAA batteries for several months.
                                        I'm unsure about using the STANDBY mode. Since RAM and registers contents are lost and pins are high impedance, full reinitialization seems necessary. Do you want to prevent the presentation communication specifically from happening? You can control that from your sketch directly in the presentation function I suppose...
                                        • F freynder
                                          O
                                          O
                                          ooznerol
                                          @freynder Yes I have of course remove unless hardware. ( i can't reach 3.3uA with it). In STOP mode, we are suppose to reach around 20-30uA (from datasheet). I will try yo investigate
                                          I can of course handle reset cause into presentation, but I don't know if other init are done inside mysensors architecture.
                                          For STANDBY mode , we can save usefull data for mysensors into backup register. I had done something similar in the past but not in stm32duino environnement.
                                          Nca78N 1 Reply Last reply
