  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
    Hi @Anticimex Actually there is something that I can not understand regarding cryptograhpy. I want to know how other products like Fibaro, Smartthings, etc handles the security ?
    Here in our library the SW is not a good idea, why ? I thought beacuse someone can dump the memory .. but is it that easy ? Can't we lock the code and memory ? Also in the hardware ATSHA solution, someone can easily take the chip and intercept our network and sniff it or even send commands as it is explained in the documentation and that's why we don't use security for public nodes as it usualy reports states. But can't we lock the chip ? and by some way only the atmega can communicate with it to get the key by some way ?
    I read online that some people are using private and public keys .. if this is the case, then the private key is offcourse saved in the memory. How do they handle this problem ?
    Do they use AES , SHA ? which encyption way ?
    Also the nRF52, I tried to read a lot and they use private and public keys i guess.
    lots of questions and I am confused but I want to know how do they handle protection for public nodes.
    Can you please explain this to me ?
    AnticimexA
    AnticimexA
    Anticimex
    @ahmedadelhosni some devices, like the atmega, doss not support locking the memory, so the software based signing is inherently insecure in terms of hw theft.
    Atsha204a based signing protection specifically against this because the personalizer locks the chip from readout. It is not possible to extract the hmac key from the atsha204a memory and the key is never transmitted OTA (unless you deploy the personalizer OTA).
      AnticimexA
      AnticimexA
      Anticimex
      @ahmedadelhosni and regarding reusing a node/atsha204a for attack purpose, we have whitelisting to protect against that. The serials used for whitelisting are also never send OTA (again, unless you send the personalizer OTA).
      • AnticimexA Anticimex
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        @Anticimex
        1- So if we have a microcontroller that supports locking the memory then the problem is solved ? I know that SAM is being introduced now, Does it support this ?
        2- what is then the purpose of locking the ATSHA if we can't extract the HMAC which we depend on it ?
        AnticimexA 1 Reply Last reply
          @Anticimex
          AnticimexA
          AnticimexA
          Anticimex
          #451
          @ahmedadelhosni
          We lock the atsha to make sure it can't be readable.
          It does not matter that samd supports locking or not. The atmega328p does not. For now, we have a security scheme that supports any target, so we have to have a system that works for all.
          For MySensors v3, an entirely new security scheme is under consideration. But it will mean dropping support for the atmga328p as it is not powerful enough.
          As for what others do, I suggest you ask them :)
          Security can be implemented in many ways. Each with drawbacks and benefits. The one currently in use is a scheme that can work on basically any target with reasonable security and performance. It has drawbacks, yes, but at the time of implementation, these were considered acceptable.
          For the future, more sophisticated schemes can be used which are easier to use, arguably more secure but more complex in terms of computational power and protocol. The core team is investigating various solutions.
          ahmedadelhosniA skywatchS 2 Replies Last reply
            @ahmedadelhosni
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            @Anticimex Sorry but I didn't understand the benefit of locking the ATSHA to be unreadable ? :expressionless:
            I know we do not lock it so that we can read the HMAC and use it during verification, but what is the usage of a locked ATSHA ?
              AnticimexA
              AnticimexA
              Anticimex
              @ahmedadelhosni what do you mean? All cryptography is performed inside the chip. The hmac key never leaves the chip after it has been programmed and locked. Thats the whole point with the atsha204a.
                ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                @Anticimex aha okay I understand a bit now. So we put s special hmac that does all cryptography jobs then it gives us something that is used for transmision?
                Looks like i have to read the datasheet also :D
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @ahmedadelhosni I'd suggest you start by reading the documentation on signing linked at the very top of this post. It explains in detail how the signing security is implemented.
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    @Anticimex yeah I read it several times before but maybe didnt pay attention to tge technical stuff 😂
                      AnticimexA
                      AnticimexA
                      Anticimex
                      @ahmedadelhosni :) not really needed to be able to use it, but it hopefully helps in understanding it ;)
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @Anticimex yeah I know. I have already managed to use Siging in my network and it works.
                        I just wanted to understand more about how the code works and the technical stuff.
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @ahmedadelhosni You mean this? :)
                            ahmedadelhosniA
                            ahmedadelhosniA
                            ahmedadelhosni
                            @Anticimex Yeah actually I have read this post like 20 times before but I guess I begun to really understand the "technical" stuff today.
                            So basically what I understood is that we have a HMAC Key, which is generated and is saved in all devices, this is when we do step 1 'generate key' and step 2 'personalize'. Thus when the gateway needs to send to node X, it send to node X asking for a nonce from the ATSHA on Node 2 board. Then node 2 sends the nonce over the air. THe gateway then uses this nonce to produce signed message by first applying SHA then use the HMAC key to produce the signed data. Then the signed data is transmitted over the air to the node X again which does the same operations again and verify that the nonce produces the same signed message in small period of time ( to avoid replay block attacks)
                            Is my understanding correct :D ?
                              AnticimexA
                              AnticimexA
                              Anticimex
                              @ahmedadelhosni yes
                                @ahmedadelhosni yes
                                ahmedadelhosniA
                                ahmedadelhosniA
                                ahmedadelhosni
                                @Anticimex finally I understood it. Actually I don't like using just the code without fully understanding the implementation. Thanks for support.
                                I will come with more questions maybe ;)
                                  AnticimexA
                                  AnticimexA
                                  Anticimex
                                  #463
                                  @ahmedadelhosni Feel free to ask, but it is all documented. If what I say does not correspond to what the documentation says, please let me know so it can be improved.
                                    ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    @Anticimex The documentation is great regarding how to enable the signing and make the nodes work. My questions were related more to technical stuff.
                                    Actually I still have a problem that I shall only use the hardware in private places. I know we have whitelist but I don't like the idea of having to re program node to add or revoke other stolen nodes.
                                    If I need to put a motion sensor outside then I will have to make sure that all other nodes inside my house accept messages from only my gateway for example. Because if this node is stolen I don't want someone to send same commands to my private nodes.
                                    What do you suggest to solve this ?
                                    Do I have to set all private nodes to accept signed data from gateway only ?
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @ahmedadelhosni The documentation DO cover the technical aspects as well. I just linked directly to that chapter. What is missing from it?
                                      What do you mean with "only use the hardware in private places"? If you only do that, then you don't need to revoke anything since the nodes most likely won't be stolen, right? Revoking is intended for "exposed" nodes.
                                      You typically only need to reprogram your gateway since normally that is the node all other nodes talk to, and hence is the node that would carry the whitelist.
                                      If you put a motion sensor outside, then enable signing and whitelisting on your nodes and then you can inform each and every node exactly what devices are permitted to communicate to it. If your other nodes only typically talk to your gateway, just have the gateway serial in their whitelist and they won't accept other nodes even if they would have the correct HMAC key to base their signatures on.
                                      Even so, if a node is stolen I would highly recommend you change HMAC key because an attacker could dig out the serial of your gateway if it is in a whitelist in the stolen node and use that to spoof a gateway.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @ahmedadelhosni in your specific case, I would suggest, in order for you to not risk exposing your gateway serial to a thief, that you don't use whitelisting at the node at risk (the one outside). Then it won't reveal anything about your security if stolen, assuming you use an atsha204a.
                                        Your gateway on the other hand, has a whitelist of every node in your system (if you so choose), so you can, as soon as you notice your node being stolen, remove its entry on the gateway, and it would be rejected. The attacker would then have to try to guess its way into figuring out a serial that match any other node the gateway accept in order to be able to "get in".
                                        That way, your hmac, at least in theory, will still be secure and usable (and you shouldn't need to redo personalization on your network).
                                        ahmedadelhosniA 2 Replies Last reply
                                          ahmedadelhosniA
                                          ahmedadelhosniA
                                          ahmedadelhosni
                                          @Anticimex This seems a good solution.
                                          I have to points to discuss here please.
                                          First : I know that we have an API to specify that node 4 shall send this message to node 7 for example. In our library, does this communication happens without passing by the gateway ?
                                          If for example in order to reach node 7, a repeater node 6 shall be used in between. Thus node 4, send to the gateway then to node 6 then to node 7 ?
                                          In our case when we revoke our stolen node from the Gateway which is now node 4. will the message pass first to the gateway or if the attacker knows node's 7 serial, then node 4 sends it directly to 7 ?
                                          Actually I guess it may pass by the gateway but I am not famailar how is the look up table implemented.
