  3. [security] Introducing signing support to MySensors
security
491 Posts 48 Posters 470.8k Views 30 Watching
  • AnticimexA Anticimex
    @ahmedadelhosni what do you mean? All cryptography is performed inside the chip. The hmac key never leaves the chip after it has been programmed and locked. Thats the whole point with the atsha204a.
    ahmedadelhosniA
    ahmedadelhosniA
    ahmedadelhosni
    @Anticimex aha okay I understand a bit now. So we put s special hmac that does all cryptography jobs then it gives us something that is used for transmision?
    Looks like i have to read the datasheet also :D
    AnticimexA 1 Reply Last reply
      AnticimexA
      AnticimexA
      Anticimex
      @ahmedadelhosni I'd suggest you start by reading the documentation on signing linked at the very top of this post. It explains in detail how the signing security is implemented.
        ahmedadelhosniA
        ahmedadelhosniA
        ahmedadelhosni
        @Anticimex yeah I read it several times before but maybe didnt pay attention to tge technical stuff 😂
          AnticimexA
          AnticimexA
          Anticimex
          @ahmedadelhosni :) not really needed to be able to use it, but it hopefully helps in understanding it ;)
            ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            @Anticimex yeah I know. I have already managed to use Siging in my network and it works.
            I just wanted to understand more about how the code works and the technical stuff.
              AnticimexA
              AnticimexA
              Anticimex
              @ahmedadelhosni You mean this? :)
                ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                @Anticimex Yeah actually I have read this post like 20 times before but I guess I begun to really understand the "technical" stuff today.
                So basically what I understood is that we have a HMAC Key, which is generated and is saved in all devices, this is when we do step 1 'generate key' and step 2 'personalize'. Thus when the gateway needs to send to node X, it send to node X asking for a nonce from the ATSHA on Node 2 board. Then node 2 sends the nonce over the air. THe gateway then uses this nonce to produce signed message by first applying SHA then use the HMAC key to produce the signed data. Then the signed data is transmitted over the air to the node X again which does the same operations again and verify that the nonce produces the same signed message in small period of time ( to avoid replay block attacks)
                Is my understanding correct :D ?
                  AnticimexA
                  AnticimexA
                  Anticimex
                  @ahmedadelhosni yes
                    @ahmedadelhosni yes
                    ahmedadelhosniA
                    ahmedadelhosniA
                    ahmedadelhosni
                    @Anticimex finally I understood it. Actually I don't like using just the code without fully understanding the implementation. Thanks for support.
                    I will come with more questions maybe ;)
                      AnticimexA
                      AnticimexA
                      Anticimex
                      #463
                      @ahmedadelhosni Feel free to ask, but it is all documented. If what I say does not correspond to what the documentation says, please let me know so it can be improved.
                        ahmedadelhosniA
                        ahmedadelhosniA
                        ahmedadelhosni
                        @Anticimex The documentation is great regarding how to enable the signing and make the nodes work. My questions were related more to technical stuff.
                        Actually I still have a problem that I shall only use the hardware in private places. I know we have whitelist but I don't like the idea of having to re program node to add or revoke other stolen nodes.
                        If I need to put a motion sensor outside then I will have to make sure that all other nodes inside my house accept messages from only my gateway for example. Because if this node is stolen I don't want someone to send same commands to my private nodes.
                        What do you suggest to solve this ?
                        Do I have to set all private nodes to accept signed data from gateway only ?
                          AnticimexA
                          AnticimexA
                          Anticimex
                          @ahmedadelhosni The documentation DO cover the technical aspects as well. I just linked directly to that chapter. What is missing from it?
                          What do you mean with "only use the hardware in private places"? If you only do that, then you don't need to revoke anything since the nodes most likely won't be stolen, right? Revoking is intended for "exposed" nodes.
                          You typically only need to reprogram your gateway since normally that is the node all other nodes talk to, and hence is the node that would carry the whitelist.
                          If you put a motion sensor outside, then enable signing and whitelisting on your nodes and then you can inform each and every node exactly what devices are permitted to communicate to it. If your other nodes only typically talk to your gateway, just have the gateway serial in their whitelist and they won't accept other nodes even if they would have the correct HMAC key to base their signatures on.
                          Even so, if a node is stolen I would highly recommend you change HMAC key because an attacker could dig out the serial of your gateway if it is in a whitelist in the stolen node and use that to spoof a gateway.
                            AnticimexA
                            AnticimexA
                            Anticimex
                            @ahmedadelhosni in your specific case, I would suggest, in order for you to not risk exposing your gateway serial to a thief, that you don't use whitelisting at the node at risk (the one outside). Then it won't reveal anything about your security if stolen, assuming you use an atsha204a.
                            Your gateway on the other hand, has a whitelist of every node in your system (if you so choose), so you can, as soon as you notice your node being stolen, remove its entry on the gateway, and it would be rejected. The attacker would then have to try to guess its way into figuring out a serial that match any other node the gateway accept in order to be able to "get in".
                            That way, your hmac, at least in theory, will still be secure and usable (and you shouldn't need to redo personalization on your network).
                            ahmedadelhosniA 2 Replies Last reply
                              ahmedadelhosniA
                              ahmedadelhosniA
                              ahmedadelhosni
                              @Anticimex This seems a good solution.
                              I have to points to discuss here please.
                              First : I know that we have an API to specify that node 4 shall send this message to node 7 for example. In our library, does this communication happens without passing by the gateway ?
                              If for example in order to reach node 7, a repeater node 6 shall be used in between. Thus node 4, send to the gateway then to node 6 then to node 7 ?
                              In our case when we revoke our stolen node from the Gateway which is now node 4. will the message pass first to the gateway or if the attacker knows node's 7 serial, then node 4 sends it directly to 7 ?
                              Actually I guess it may pass by the gateway but I am not famailar how is the look up table implemented.
                                AnticimexA
                                AnticimexA
                                Anticimex
                                @ahmedadelhosni no, if you directly target another node, I do not believe it will pass through the gateway.
                                I would say that if something like that is desired, you target your controller and have the controller relay the message to the other node. Everything to/from the controller pass through the gateway. That becomes controller specific behavior though.
                                  ahmedadelhosniA
                                  ahmedadelhosniA
                                  ahmedadelhosni
                                  @Anticimex Second : Don't you think that the whitelisting need to be more robust ?
                                  I mean that I don't like the idea of reflashing. Why don't you implement an API that can be used to securely add or revoke serials during run time ?
                                  Also another idea which I would like to discuss. Maybe when a node is started, it sends it's serial number securely to the gateway and it is added to the whitelist for example.
                                  The whole idea is that I don't really know how do other commerial products handle security for private and public nodes. All I know is usually you scan a QR code which is on the box. Do you have any idea ?
                                    ahmedadelhosniA
                                    ahmedadelhosniA
                                    ahmedadelhosni
                                    @Anticimex Actually something now came to my mind. Can't the attacker flash a gateway sketch easier and control all nodes now ? :D He has a trusted ATSHA with HMAC.
                                    Am I missing something ?
                                      AnticimexA
                                      AnticimexA
                                      Anticimex
                                      @ahmedadelhosni signing has no (and will not have) a dependency to encryption so serial will never be sent OTA.
                                      For MySensors v3 a complete new security scheme will obsolete the current one, so I won't make significant changes to the existing framework. Of course pull requests are always welcome for review.
                                        AnticimexA
                                        AnticimexA
                                        Anticimex
                                        @ahmedadelhosni nodes still need to be included and your existing gateway needs to be blocked out since they will have conflicting addresses.
                                        But as I already said, if you get your devices stolen, the recommendation is to distrust your network and replace the keys.
                                        These are the limitations when implementing security for systems as limited in resources as the atmga328p.
                                          AnticimexA
                                          AnticimexA
                                          Anticimex
                                          @ahmedadelhosni also, if your public node is stolen and your gateway had a whitelist (and your other nodes has whitelists) the attacker would not know the serials of your other nodes, and therefore not be able to sign messages to them (assuming your other nodes require signed and whitelist enabled messages).
