  3. 💬 10+ years wireless PIR Sensor (on just one set of 3 AA's!)
nrf52832nrf52840am612pir
16 Posts 5 Posters 6.1k Views 4 Watching
  • openhardware.ioO
    openhardware.ioO
    openhardware.io
    https://www.openhardware.io/view/499/10-years-wireless-PIR-Sensor-on-just-one-set-of-3-AAs
      I just now uploaded Version 602, which uses thru-hole battery holders (see BOM) instead of surface mount battery holders. The result is a more compact board and, perhaps, better mechanical strength as well.
      • korttomaK
        korttomaK
        korttoma
        Where can I buy the nRF52832 with the correct footprint for your board?
        • Tomas
        • sundberg84S
          sundberg84S
          Is the AM612 a complete PIR sensor? Ie, generates a HIGH without any additional circuit (except the 4 resistors)?
          Edit: Never mind - found your other thread.
          • korttomaK korttoma
            @korttoma said in 💬 nRF52832 AM612 PIR Sensor:
            http://www.fanstel.com/buy/
            korttomaK 1 Reply Last reply
            • sundberg84S sundberg84
              @sundberg84 said in 💬 nRF52832 AM612 PIR Sensor:
              For the benefit of other readers, the answers are: yes and yes
                korttomaK
                korttomaK
                korttoma
                @NeverDie said in 💬 nRF52832 AM612 PIR Sensor:
                43$ shipping to Finland 🤤 know of any other options?
                • Tomas
                NeverDieN sundberg84S 2 Replies Last reply
                  Toyman had some suggestions on this thread: https://forum.mysensors.org/topic/6961/nrf5-bluetooth-action/1204
                    sundberg84S
                    sundberg84S
                      I just now uploaded version 603, which includes a 32.678KHz crystal oscillator.
                        I just now uploaded version 604, which uses an LDO better suited to meet the current requirements of the BT832X, in case that is installed. I have shipped the files to the fab, so I'll post an update after I've received and tested the board.
                        I expect that upgrading to use the nRF52840, when it becomes available, will be a simple drop-in replacement upgrade. :)
                          I've just now uploaded a demo sketch whereby the PIR reports its voltage as a heartbeat once every 5 minutes. However, if motion is detected, it's immediately reported wirelessly. :)
                          berkseoB 1 Reply Last reply
                            Because this is a compact design, the battery clips may touch. So, to prevent any short-circuiting, you may wish to use a bit of Kapton tape, or similar insulating tape (maybe even electrical tape) on the outside of the inside clips to prevent contact with the outer clips):
                              Project completed. I've just now uploaded the files for version 607. I've tested this board, and it works. :)
                                berkseoB
                                berkseoB
                                berkseo
                                @neverdie
                                Hi, it is not clear from the message, if a movement occurs, will the battery data transmission interval be saved?
                                • berkseoB berkseo
                                  @neverdie
                                  @berkseo Good question. The code seemed good at the time I wrote it, but I can't say that it was extensively tested. I may circle back to it at a future date, and if so, I'll take a closer look. Even with more than 500 downloads of the code, no one has posted any feedback on how well (or not) it has run. Also, I not sure how compatible the posted code is with newer releases of the mysensors library.
                                  12.5k
