  3. How to detect if the node became unresponsive?
5 Posts 3 Posters 1.3k Views 3 Watching
  • rzyliusR Offline
    rzyliusR Offline
    rzylius
    I developed mysensors actuator for controlling ventilation device (power on/off and speed). I use openhab as controller.
    I would like to be sure that I notice if mysensors actuator become unresponsive. please suggest how controller should recognize if actuator is unresponsive.
    regards,
    Rimantas
    S 1 Reply Last reply
    • rzyliusR rzylius
      regards,
      Rimantas
      @rzylius I don't know if your controller supports it but you can check out heartbeat function in MySensors and how that works.
      • rzyliusR Offline
        rzyliusR Offline
        rzylius
        @sundberg84 said in How to detect if the node became unresponsive?:
        in
        Thanks, I guess then it is more OpenHab group question, than general one?
        • rzyliusR rzylius
          in
          @rzylius - there are many ways probably, so its fine as a general one. I would also google arduino watchdog which can be a good tool if you suspect your node will go unresponsive.
          • D Offline
            I did some looking on this a while back and found this external solution https://github.com/mattbornski/Arduino-Watchdog-Circuit . It is a hardware watchdog timer based on a 555 timer IC.
