  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • T
    tortoisedoc
    @John thanks for the fix, will test it later today. Is the latest build still good to go?
    • JohnJ
      JohnJ
      John
      @tortoisedoc Sending and receiving data is not influenced by the discovery utilities. It is possible new devices are not found (which have an ID assigned). But this should not be the case for nodes which are requesting an id (this is still handled by the driver).
      The path to the hardware is now completely open after receiving of the gateway started message. I will in the meantime ask an other user if he has an issue with the request for the version number from the gateway
      • FrancoisF Francois
        @John yes it is also not in discovery
        JohnJ
        JohnJ
        John
        @Francois I have continued the normal development path of this feature. Otherwise i would be "hacking" the code and then remove this to be able to continue normally. I do have a quick build ready, could you check the latest build (510) if it is working for you?
        • FrancoisF
          FrancoisF
          Francois
          @John This version (510) fix the issue and it did discovered the sensor. Thanks
          JohnJ 1 Reply Last reply
            JohnJ
            JohnJ
            John
            @Francois Good!
            @tortoisedoc Are you able to use the node assignment?
            • FrancoisF
              FrancoisF
              Francois
              @John I must say that you product is getting better with every release. This new discovery process that you now add is making things ever easier to add sensors to the system Thanks for all the hard work that you are putting into this project. I real appreciate this. Keep up the good work. You product just work and I don't have to worries about it.
                JohnJ
                JohnJ
                John
                @Francois Thanks for your kind words! Too bad you didn't download the release on the builder this evening, you have fallen in a test sequence ;).
                When the routine is completely implemented i will post a follow up on this feature.
                • FrancoisF
                  FrancoisF
                  Francois
                  @John I never skip an release the moment there is new release I installed.
                  • JohnJ John
                    @Francois Good!
                    tortoisedoc
                    wrote on last edited by tortoisedoc
                    #134
                    Unfortunately not.
                    See here: appLog.txt
                    At this point, im starting to suspect about the PI. The miniterm shows correctly the gateway startup tho.
                    • C
                      C
                      ceburge
                      • T tortoisedoc
                        Unfortunately not.
                        JohnJ
                        JohnJ
                        John
                        @tortoisedoc The only thing i see is a gateway ready message, i do not see any node presenting or asking for a node address. I suspect that this information is also not available in miniterm. If it is, you have to try again without miniterm cause this then is interfering.
                        • C ceburge
                          JohnJ
                          JohnJ
                          John
                          wrote on last edited by John
                          #137
                          @ceburge Is this a fresh install or an update? If this is an update please clear the browser cache and re-open the browser
                          C 1 Reply Last reply
                          • JohnJ John
                            C
                            C
                            ceburge
                            It was indeed an update. The clearing of the browser cache did the trick. Thanks alot.
                            By the way. Love your work you are doing with PiDome. It is user friendly and something that most people can funtion in. Keep up
                            the good work.
                            • C ceburge
                              the good work.
                              JohnJ
                              JohnJ
                              John
                              #139
                              @ceburge Thanks! And that's exactly the thought behind the project (not in the beginning because it was a personal thingy, but has grown in to), try to create something most people would be able to use. It still needs a lot of work, but it's getting there. We have planned very exciting stuff!
                              PiDome relies heavily on the browser cache, one of the reasons why it responds relatively quick in most situations. So if there is any error with title "Interface error", clear the cache ;).
                              Cheers!
                              P.S. the reason for this error is due to the fact the messaging has been optimized, where possible device values which can be updated are now in one single message instead of four (if a device has four controls and/or data fields).
                              • JohnJ John
                                tortoisedoc
                                #140
                                @John Ok, here more logging:
                                appLog.txt
                                There is actually data coming in - but the visual part is empty both in the driver's section as well as the "new" section for non-discovered devices.
                                PS I tested this in Chrome as well as in Firefox;
                                and the result is empty : capture.png
                                • C
                                  C
                                  ceburge
                                  I believe there may be something wrong with the serial driver now. It was working like a charm in a previous build. Not sure what that build was though. I decided to update to the 510 version build due to the fact that I could never get my MQTT Gateway to auto discover devices. However I decided to go ahead and test what I already had working in the new build and it doesn't function correctly.
                                  I am including an image of the drivers page I now see when using a serial connection. App log i there to if you want to look at it
                                  appLog.txt
                                  • T tortoisedoc
                                    appLog.txt
                                    JohnJ
                                    JohnJ
                                    John
                                    #142
                                    @tortoisedoc and @ceburge The builds on the build server are still test builds regarding discovery and driver web front end API. They are getting more stable but is still a work in progress. The builds which are following up are tests to test the progress of the current development roadmap regarding these.
                                    This is a known issue and am working on it while the development progresses.
                                    Excuse for any inconvenience, hope to have this functionality done asap.
                                    P.S. I'm looking into the possibility to also have the node address requests being passed to the discovery collection page, all though it is a complete different internal process trying to make it coherent.
                                    • JohnJ John
                                      tortoisedoc
                                      Sounds great !
                                      Thank you for your efforts!
                                      • T tortoisedoc
                                        Sounds great !
                                        JohnJ
                                        JohnJ
                                        John
                                        #144
                                        @tortoisedoc It has to work correctly, so will continue on it until it does.
                                        Today there will be sequential builds which will introduce new discovery options. The new method will also include discovery of mysensors devices which do not have an address assigned yet.
                                        Build number 511 (just build) will/should include the visibility of these nodes, but can not be added yet. It is safe to use build 511 as long as predefined node addresses are used. This will be included in build 512 (which i hope will be available on a couple of hours).
                                        • JohnJ
                                          JohnJ
                                          John
                                          #145
                                          Build 513 is out there (it includes the inclusion mode available for testing).
                                          Please be notified about the fact that this build has to be tested. More builds can become available in a rapid tempo, When the MySensors transition to the new discovery method is complete i will post it here.
