  3. Noob : Cant get Sensor talking to gateway
38 Posts 7 Posters 8.4k Views 6 Watching
    You need to assign a node ID on your sensor node
    • A angeloS
      Hey all,
      This is my first Mysensors adventure and I cant seem to get things working..
      I have a trivially simple sketch, just to test its working but the arduino doesnt event get to my "loop".. Im baffled.. i think im doing something wrong software wise but... bafled.. Oh I know the arduino is on 2.1.1 and the Pi on 2.2.0-rc.1 but I cant work out how to burn the same version to the arduino....
      thanks in advance
      Angelo
      #define CHILD_ID_TEMP 1
      #include <MyConfig.h>
        sendSketchInfo("AngelosTesting", "1.1");
        Serial.println("Init");
          Serial.println("Sending data");
          send(msgTemp.set("42!"));
          sleep (5000);
      However the sensor just says "fail",.. what is interesting that when the sensor says its failure message the gateway does receive something but.. the sensor doesnt like it..
      Arduino Mini Pro sensor
      4 TSM:INIT
      4 TSF:WUR:MS=0
      12 TSM:INIT:TSP OK
      14 TSM:FPAR
      16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      2025 !TSM:FPAR:NO REPLY
      2027 TSM:FPAR
      2029 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4038 !TSM:FPAR:NO REPLY
      4040 TSM:FPAR
      4042 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
      4636 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
      4642 TSF:MSG:FPAR OK,ID=0,D=1
      6051 TSM:FPAR:OK
      6051 TSM:ID
      6053 TSM:ID:REQ
      6057 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      8065 TSM:ID
      8065 TSM:ID:REQ
      8069 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      10076 TSM:ID
      10076 TSM:ID:REQ
      10080 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      12089 TSM:ID
      12089 TSM:ID:REQ
      12093 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
      14102 !TSM:ID:FAIL
      14104 TSM:FAIL:CNT=1
      14106 TSM:FAIL:PDT
      Raspberry Pi Gateway
      mysgw: Starting gateway...
      mysgw: Protocol version - 2.2.0-rc.1
      mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.1
      mysgw: TSF:LRT:OK
      mysgw: TSM:INIT
      mysgw: TSF:WUR:MS=0
      mysgw: TSM:INIT:TSP OK
      mysgw: TSM:INIT:GW MODE
      mysgw: MCO:REG:NOT NEEDED
      mysgw: MCO:BGN:STP
      mysgw: MCO:BGN:INIT OK,TSP=1
      mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
      mysgw: TSF:MSG:BC
      mysgw: TSF:MSG:FPAR REQ,ID=255
      mysgw: TSF:CKU:OK,FCTRL
      mysgw: TSF:MSG:GWL OK
      mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
      mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
      mysgw: TSF:MSG:BC
      mysgw: TSF:PNG:SEND,TO=0
      mysgw: TSF:CKU:OK
      manutremo
      @Angelo-Santagata the log parser is useful in these situations.
      https://www.mysensors.org/build/parserlink text
      In your case, it calls my attention that the gw seems to be answering the requests for an ID from the node with an empty payload. I would start the investigation here.
      For a check, assign an static node Id to the node and try see what happens.
      • A
        angeloS
        thanks for the pointer guys, I'll check this out when I get home..
        • R
          R
          r-nox
          If you have used this same sensors as a test in the past you may need to clear the eeprom data also.
          Just a guess...
          A 1 Reply Last reply
          • R r-nox
            Just a guess...
            angeloS
            @manutremo thanks, I have used the parselink text utility but I should have paid more attention
            mm Ive used the same hardware but never got it working. .. your right maybe its stored a dud nodeID.. Looking at the docs https://www.mysensors.org/download/sensor_api_20 I can set a nodeID manually.. I'll give that a go
            • R
              R
              r-nox
              Here's the clear eeprom sketch if you need it.
              https://github.com/mysensors/MySensors/blob/master/examples/ClearEepromConfig/ClearEepromConfig.ino
              • R r-nox
                angeloS
                @r-nox AWESOME! thank you!
                Nice to see this OS library is well supported... cool
                • A
                  angeloS
                  @manutremo , you hit it bang on.. The NODE_ID wasnt being sent, setting a node id to a number using
                  #define MY_NODE_ID 42
                  worked.
                  Curious, so I can debug this myself in the future, which line indicated the NODE_ID was blank?
                  was it this line?
                  • A angeloS
                    worked.
                    was it this line?
                    manutremo
                    @Angelo-Santagata happy to know that you got it working. Yes I think that's the line which in the log parser showed an empty payload. It would be interesting to know why the gw is returning an empty payload when an ID is requested, though, since that's not usual behavior with the default settings. Let us know what you find out!
                      If there is no controller assigning an ID, the gw can't make up one out of nothing. 😀
                        manutremo
                        That's certainly the most probable cause, Angelo didn't mention any controller so I assumed there is one... which controller are you using (if any) Angelo?
                          There could be a controller but if it is not assigning any ID is it just as it wasn't any 😁
                            manutremo
                            Yes, the fact that it works with a static node id seems to point in that direction - should that not be the case, i sincerely wouldn't have a clue on where to look at.
                            • A
                              angeloS
                              Hi all,
                              ok this is the embarrassing bit, no the controller wasnt attached.. Im using home assistant and what I didnt realise that was that a) the controller sends the IDs and b) the controller couldnt talk to the Gateway..
                              BTW Why do we need a controller to assign the unique sensor IDs? I thought the Gateway would do this?
                              • A angeloS
                                Hi all,
                                @Angelo-Santagata the gateways are designed to be stateless. The stateless design makes it easy to implement a gateway on low-power hardware. It also makes it easier to correctly implement and verify the gateway functionality, and to troubleshoot if there are problems. If gateways had to remember which ids had been assigned, they would no longer be stateless.
                                  angeloS
                                  wrote on last edited by angeloS
                                  @mfalkvidd thanks, very impressive this mySensors stuff BTW
                                  • A angeloS
                                    @angeloS thanks. I agree. I can't take credit for it though, most of the stuff was designed before I found the project :)
                                      manutremo
                                      Mistery solved :satisfied:
                                      • mfalkviddM
                                        Does anyone have suggestions on a clearer log message? One that would make it easy to understand what is happening? If we could make the log clearer, other people could understand the reason quicker, saving time and frustration.
                                          angeloS
                                          @mfalkvidd In my case I think if the log had said, No Controller provided SensorID, that would have been my first clue
