  3. Noob : Cant get Sensor talking to gateway
38 Posts 7 Posters 8.4k Views 6 Watching
  • A angeloS
    Hey all,
    This is my first Mysensors adventure and I cant seem to get things working..
    I have a trivially simple sketch, just to test its working but the arduino doesnt event get to my "loop".. Im baffled.. i think im doing something wrong software wise but... bafled.. Oh I know the arduino is on 2.1.1 and the Pi on 2.2.0-rc.1 but I cant work out how to burn the same version to the arduino....
    thanks in advance
    Angelo
    #define CHILD_ID_TEMP 1
    #include <MyConfig.h>
      sendSketchInfo("AngelosTesting", "1.1");
      Serial.println("Init");
        Serial.println("Sending data");
        send(msgTemp.set("42!"));
        sleep (5000);
    However the sensor just says "fail",.. what is interesting that when the sensor says its failure message the gateway does receive something but.. the sensor doesnt like it..
    Arduino Mini Pro sensor
    4 TSM:INIT
    4 TSF:WUR:MS=0
    12 TSM:INIT:TSP OK
    14 TSM:FPAR
    16 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2025 !TSM:FPAR:NO REPLY
    2027 TSM:FPAR
    2029 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4038 !TSM:FPAR:NO REPLY
    4040 TSM:FPAR
    4042 TSF:MSG:SEND,255-255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4636 TSF:MSG:READ,0-0-255,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    4642 TSF:MSG:FPAR OK,ID=0,D=1
    6051 TSM:FPAR:OK
    6051 TSM:ID
    6053 TSM:ID:REQ
    6057 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    8065 TSM:ID
    8065 TSM:ID:REQ
    8069 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    10076 TSM:ID
    10076 TSM:ID:REQ
    10080 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    12089 TSM:ID
    12089 TSM:ID:REQ
    12093 TSF:MSG:SEND,255-255-0-0,s=255,c=3,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    14102 !TSM:ID:FAIL
    14104 TSM:FAIL:CNT=1
    14106 TSM:FAIL:PDT
    Raspberry Pi Gateway
    mysgw: Starting gateway...
    mysgw: Protocol version - 2.2.0-rc.1
    mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-rc.1
    mysgw: TSF:LRT:OK
    mysgw: TSM:INIT
    mysgw: TSF:WUR:MS=0
    mysgw: TSM:INIT:TSP OK
    mysgw: TSM:INIT:GW MODE
    mysgw: MCO:REG:NOT NEEDED
    mysgw: MCO:BGN:STP
    mysgw: MCO:BGN:INIT OK,TSP=1
    mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:MSG:FPAR REQ,ID=255
    mysgw: TSF:CKU:OK,FCTRL
    mysgw: TSF:MSG:GWL OK
    mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
    mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
    mysgw: TSF:MSG:BC
    mysgw: TSF:PNG:SEND,TO=0
    mysgw: TSF:CKU:OK
    manutremo
    @Angelo-Santagata the log parser is useful in these situations.
    https://www.mysensors.org/build/parserlink text
    In your case, it calls my attention that the gw seems to be answering the requests for an ID from the node with an empty payload. I would start the investigation here.
    For a check, assign an static node Id to the node and try see what happens.
    • A
      angeloS
      thanks for the pointer guys, I'll check this out when I get home..
      • R
        R
        r-nox
        If you have used this same sensors as a test in the past you may need to clear the eeprom data also.
        Just a guess...
        A 1 Reply Last reply
        • R r-nox
          Just a guess...
          angeloS
          @manutremo thanks, I have used the parselink text utility but I should have paid more attention
          mm Ive used the same hardware but never got it working. .. your right maybe its stored a dud nodeID.. Looking at the docs https://www.mysensors.org/download/sensor_api_20 I can set a nodeID manually.. I'll give that a go
          • R
            R
            r-nox
            Here's the clear eeprom sketch if you need it.
            https://github.com/mysensors/MySensors/blob/master/examples/ClearEepromConfig/ClearEepromConfig.ino
            • R r-nox
              angeloS
              @r-nox AWESOME! thank you!
              Nice to see this OS library is well supported... cool
              • A
                angeloS
                @manutremo , you hit it bang on.. The NODE_ID wasnt being sent, setting a node id to a number using
                #define MY_NODE_ID 42
                worked.
                Curious, so I can debug this myself in the future, which line indicated the NODE_ID was blank?
                was it this line?
                • A angeloS
                  worked.
                  was it this line?
                  manutremo
                  @Angelo-Santagata happy to know that you got it working. Yes I think that's the line which in the log parser showed an empty payload. It would be interesting to know why the gw is returning an empty payload when an ID is requested, though, since that's not usual behavior with the default settings. Let us know what you find out!
                    If there is no controller assigning an ID, the gw can't make up one out of nothing. 😀
                      manutremo
                      That's certainly the most probable cause, Angelo didn't mention any controller so I assumed there is one... which controller are you using (if any) Angelo?
                        There could be a controller but if it is not assigning any ID is it just as it wasn't any 😁
                          manutremo
                          Yes, the fact that it works with a static node id seems to point in that direction - should that not be the case, i sincerely wouldn't have a clue on where to look at.
                          • A
                            angeloS
                            Hi all,
                            ok this is the embarrassing bit, no the controller wasnt attached.. Im using home assistant and what I didnt realise that was that a) the controller sends the IDs and b) the controller couldnt talk to the Gateway..
                            BTW Why do we need a controller to assign the unique sensor IDs? I thought the Gateway would do this?
                            • A angeloS
                              Hi all,
                              @Angelo-Santagata the gateways are designed to be stateless. The stateless design makes it easy to implement a gateway on low-power hardware. It also makes it easier to correctly implement and verify the gateway functionality, and to troubleshoot if there are problems. If gateways had to remember which ids had been assigned, they would no longer be stateless.
                                angeloS
                                wrote on last edited by angeloS
                                @mfalkvidd thanks, very impressive this mySensors stuff BTW
                                • A angeloS
                                  @angeloS thanks. I agree. I can't take credit for it though, most of the stuff was designed before I found the project :)
                                    manutremo
                                    Mistery solved :satisfied:
                                    • mfalkviddM
                                      Does anyone have suggestions on a clearer log message? One that would make it easy to understand what is happening? If we could make the log clearer, other people could understand the reason quicker, saving time and frustration.
                                        angeloS
                                        @mfalkvidd In my case I think if the log had said, No Controller provided SensorID, that would have been my first clue
                                        • A angeloS
                                          manutremo
                                          @angeloS Fully agree - a warning instead of just sending a message with an empty payload would have been easier to spot. Maybe something to propose in Github?
