  3. nRF5 action!
nRF5 action!
1.9k Posts 49 Posters 2.1m Views 44 Watching
  • rmtuckerR rmtucker
    I'm realizing now that I can get a decent temperature reading from just the nRF5x chip itself. With calibration it should get even better.
    I used the internal temperature in the past but i can not remember how i did it?
    Do you have some example code to remind me?
    #1259
     * This example sketch shows how you can manage the nRF5 pin mapping as part of your code.
     * You can use the method for any nRF51822 or nRF52832 board or module.
     * Most components, like UART, SPI, Wire Bus, of the nRF5 series chips don't
     * have a fixed pin mapping. There are some pins with restrictions like analog
     * inputs, NFC or pins near the radio module. Please refer the latest
     * documentation about pin restrictions at http://infocenter.nordicsemi.com
     * To use the custom pin mapping you have to do following steps:
     * 1. Install "arduino-nrf5" like described at
     *    https://github.com/sandeepmistry/arduino-nRF5/
     * 2. Install the "My Sensors nRF5 Boards" with the board manager like
     *    explained at https://github.com/mysensors/ArduinoBoards
     * 3. Copy the files "MyNRF5Board.cpp" and "MyNRF5Board.h" from
     *    "MyNRF5Board" example into your sketch.
     * 4. Modify pin mappings in "MyNRF5Board.cpp" and "MyNRF5Board.h" to fit
     *    your requirements.
     * 5. Select "MyNRF5Board nrf52832" or "MyNRF5Board nrf52822" as your board.
     *    Choose the correct parameters and programmer in the Tools menu.
    // Many thanks to d00616 for this framework!
    //Simple program to demonstrate that both the LED and Serial  and Temperature are working correctly on the breakout board:
    // https://www.openhardware.io/view/471/Ebyte-nRF52832-Small-Breakout-Board
    //Note: Compile and upload from Arduino IDE using "MyNRF5Board nRF51822" as the board and with 16K RAM, RC Oscillator, and no bootloader as the options.
    #define MY_CORE_ONLY
    #include <nrf.h>
      Serial.begin(9600);
      Serial.println();
      NRF_TEMP->TASKS_STOP;
      NRF_TEMP->EVENTS_DATARDY=0;
      NRF_TEMP->INTENSET=1;  //enable EVENTS_DATARDY temperature interrupt
      while (!(NRF_TEMP->INTENSET==1)) {} //wait until completed
    uint32_t blinkCounter=0;
    uint32_t rawTemperature=0;
    float celsius=0.0;  //rawTemperature converted to Celsius
      NRF_TEMP->TASKS_START=1;
      while (!(NRF_TEMP->EVENTS_DATARDY)) {} //wait until temperature measurement is complete
      rawTemperature=NRF_TEMP->TEMP;
      celsius=((float)rawTemperature)/4.0;
      Serial.print(celsius);
      Serial.println(" degrees Celsius");
      Serial.print(blinkCounter++);
      Serial.println(", HIGH");
      delay(500);
      Serial.println(", LOW");
      delay(500);
      #1260
      I made a prototype of my CR2032 buttoncell project using the earlier small nRF51822-4 beakout board. I have it running the MySensors passive sensor code. It reports to the serial gatewaqy once every minute.
        cool.
        you could add some clearance for the antenna, better I think for antenna radiation.
        • scalzS scalz
          cool.
          OK, I adjusted it. How about now?
          • ahmedadelhosniA
            ahmedadelhosniA
            ahmedadelhosni
            I dont have access to the source code now. Can someone please tell which pins are configured as Tx and Rx for serial communication ?
              @ahmedadelhosni Do you mean in general? In the general case, you can select which pins are meant for Rx and Tx using your software.
                ahmedadelhosniA
                ahmedadelhosniA
                ahmedadelhosni
                Yes I read this from the datasheet but I thought maybe MySensors defines some Pins for debugging.
                How can I set them ? Any ApI refrences ?
                NeverDieN d00616D 2 Replies Last reply
                  @ahmedadelhosni said in nRF5 Bluetooth action!:
                  Look at the source code posted at https://www.openhardware.io/view/510/CR2032-Small-Wireless-Temperature-Humidity-Sensor#tabs-source
                  It will be obvious from that.
                    d00616D
                    d00616D
                    d00616
                    Most NRF5 pins are freely configurable. MySensors only uses the definition of the Arduino variant. If you are not lucky with the pins defined with the Arduino board variants, you can use the ArduinoHwNRF5 board. There are examples to redefine pins.
                    This repository has the release 0.1.0 its usable and stable, but I have plans to rename the files to MyBoardNRF5 and change the g_ADigitalPinMap to the more flexible Arduino primo format in the near future. I think this is required to support NRF52840 MCUs in the future.
                    scalzS 1 Reply Last reply
                    • ahmedadelhosniA
                      ahmedadelhosniA
                      ahmedadelhosni
                      Thanks both for the guiding. I will look through them.
                      • Nca78N
                        @NeverDie how is the battery voltage doing on your existing test node ?
                        I think you should include a strong capacitor to help the battery during TX/RX sequences. It's probably less necessary on NRF5 boards, but on atmega+nrf24 a board without a 100-200µF (meaning only around half of that available with a 3V bias) capacitor has a very poor battery life.
                        • Nca78N Nca78
                          #1270
                          No real data as of yet, though I haven't noticed any problems per se. What size capacitor do you recommend?
                          Here's why I was hoping I could maybe sidestep the issue:
                          http://data.energizer.com/pdfs/cr2032.pdf
                          i.e. very short pulses might have stable voltage. I'm not sure what amount of current is assumed by that Energizer graph though.
                          • d00616D d00616
                            #1271
                            Again, you've done a nice a work on ESB driver :+1:
                            At least we can confirm that nrf52840 works with regular variant boards, and basic MySensors features, as it was a part of an intense traffic setup yesterday.
                            That's the proof MySensors is getting better week after week :)
                              #1272
                              I would use 100 to 200uf like said above. That's what i'm doing with all my coincell nodes too.
                              This is regarding the internal resistance of coincells which is not great >5mA, especially when coincell will be more aged. So it is recommanded to increase lifetime.
                              But not too strong capacitor value, else that won't be better (you don't want to waste energy, and increase internal coincell res, by charging caps, else you would need a current limiting resistor lol).
                              I would not be too cheap by omitting decoupling and buffering capa, on my boards I prefer to have footprints (optional or not) because sure it can work well at the beginning but as soon as lifetime goes, it can change..
                                Thank you @nca78 and @scalz . Per your suggestions, I added a 100uF ceramic cap to version 8 of the multi-sensor board:
                                https://www.openhardware.io/view/510/Multi-Sensor-TempHumidity-LeakMagnetLightAccel
                                  #1274
                                  Anyone tried building a bluetooth stack on the nRF5x from within the Arduino IDE? I can see how running it simultaneously with the mySensors code would be tricky, but maybe one could switch back and forth between the two? e.g. if you want to output debug text to a terminal window on your smart phone via bluetooth If so, anyone have any demo code for doing that?
                                  For that matter, has anyone here tried the Arduino Primo? And if so, how did it go?
                                  Nca78N d00616D 2 Replies Last reply
                                    From what I understand this is not possible, the NRF5 Core used by @d00616 is not using the soft device to have better access to the hardware, while the Arduino IDE version is using soft device to run bluetooth stack. So you have to flash one or the other, not the two at the same time.
                                      d00616D
                                      d00616D
                                      d00616
                                      The parts of the SDK to disable and enable the SoftDevice are not included into the arduino-nrf5 port, but on the Primo port.
                                      The Arduino-NVM library is not compatible. This results in a crash. My first try to use the SoftDevice API was not successful.
                                      • d00616D d00616
                                        Toyman
                                        @d00616 have you looked at https://mynewt.apache.org/?
                                        NeverDieN d00616D scalzS 3 Replies Last reply
                                        • T Toyman
                                          Does it have any worthwhile demo apps running on it?
