  3. nRF5 action!
nRF5 action!
    Yes I read this from the datasheet but I thought maybe MySensors defines some Pins for debugging.
    How can I set them ? Any ApI refrences ?
    d00616D
    d00616D
    d00616
    @ahmedadelhosni said in nRF5 Bluetooth action!:
    Most NRF5 pins are freely configurable. MySensors only uses the definition of the Arduino variant. If you are not lucky with the pins defined with the Arduino board variants, you can use the ArduinoHwNRF5 board. There are examples to redefine pins.
    This repository has the release 0.1.0 its usable and stable, but I have plans to rename the files to MyBoardNRF5 and change the g_ADigitalPinMap to the more flexible Arduino primo format in the near future. I think this is required to support NRF52840 MCUs in the future.
    scalzS 1 Reply Last reply
    • ahmedadelhosniA
      ahmedadelhosniA
      ahmedadelhosni
      Thanks both for the guiding. I will look through them.
      • Nca78N
        @NeverDie how is the battery voltage doing on your existing test node ?
        I think you should include a strong capacitor to help the battery during TX/RX sequences. It's probably less necessary on NRF5 boards, but on atmega+nrf24 a board without a 100-200µF (meaning only around half of that available with a 3V bias) capacitor has a very poor battery life.
        • Nca78N Nca78
          #1270
          No real data as of yet, though I haven't noticed any problems per se. What size capacitor do you recommend?
          Here's why I was hoping I could maybe sidestep the issue:
          http://data.energizer.com/pdfs/cr2032.pdf
          i.e. very short pulses might have stable voltage. I'm not sure what amount of current is assumed by that Energizer graph though.
          • d00616D d00616
            #1271
            Again, you've done a nice a work on ESB driver :+1:
            At least we can confirm that nrf52840 works with regular variant boards, and basic MySensors features, as it was a part of an intense traffic setup yesterday.
            That's the proof MySensors is getting better week after week :)
              #1272
              I would use 100 to 200uf like said above. That's what i'm doing with all my coincell nodes too.
              This is regarding the internal resistance of coincells which is not great >5mA, especially when coincell will be more aged. So it is recommanded to increase lifetime.
              But not too strong capacitor value, else that won't be better (you don't want to waste energy, and increase internal coincell res, by charging caps, else you would need a current limiting resistor lol).
              I would not be too cheap by omitting decoupling and buffering capa, on my boards I prefer to have footprints (optional or not) because sure it can work well at the beginning but as soon as lifetime goes, it can change..
                Thank you @nca78 and @scalz . Per your suggestions, I added a 100uF ceramic cap to version 8 of the multi-sensor board:
                https://www.openhardware.io/view/510/Multi-Sensor-TempHumidity-LeakMagnetLightAccel
                  #1274
                  Anyone tried building a bluetooth stack on the nRF5x from within the Arduino IDE? I can see how running it simultaneously with the mySensors code would be tricky, but maybe one could switch back and forth between the two? e.g. if you want to output debug text to a terminal window on your smart phone via bluetooth If so, anyone have any demo code for doing that?
                  For that matter, has anyone here tried the Arduino Primo? And if so, how did it go?
                  Nca78N d00616D 2 Replies Last reply
                    From what I understand this is not possible, the NRF5 Core used by @d00616 is not using the soft device to have better access to the hardware, while the Arduino IDE version is using soft device to run bluetooth stack. So you have to flash one or the other, not the two at the same time.
                      d00616D
                      d00616D
                      d00616
                      The parts of the SDK to disable and enable the SoftDevice are not included into the arduino-nrf5 port, but on the Primo port.
                      The Arduino-NVM library is not compatible. This results in a crash. My first try to use the SoftDevice API was not successful.
                      • d00616D d00616
                        Toyman
                        @d00616 have you looked at https://mynewt.apache.org/?
                        NeverDieN d00616D scalzS 3 Replies Last reply
                        • T Toyman
                          Does it have any worthwhile demo apps running on it?
                          • T Toyman
                            d00616D
                            d00616D
                            d00616
                            Yes, I have seen the documentation and some parts of the source code. It's a good project. I like the concepts.
                            • T Toyman
                              on my side, i tested it. agree with d00616, it's interesting.
                              yes there are examples.
                                How would you all rate the mynewt's stage of development? Pre-alpha? Or, is it already fairly well tested and production ready?
                                  #1282
                                  latest release is 1.2.0, it's not prealpha. for production I think, easiest is to read docs and try ;)
                                  Note it's an OS (which means shared resources etc..), not arduino integrated, nor mysensors compatible actually. If you want to use MySensors, you would need to port the code and check what's in use by the OS etc..
                                  If I would like to use a RTOS+BLE with NRF5, I would use this one.
                                  For other mcus, not sure, there are others nice OS.
                                  Hard to find one fits for all, and not very handy to have x toolchains&libraries to handle (I already have arduino, espressif, apache, TI.. OS&frameworks installed and this can be too much!). And i don't mention rpi/linux stuff..
                                  That depends on the project.
                                  But for my HA project, as MySensors targets arduino actually, and I prefer the NRF5 ESB driver than BLE for multiple reasons (security etc), it's easier to stick to arduino environment and I can use all mcus for that in Visual Studio.
                                    How are people here preferring to connect to their nRF5x node for programming/debugging? I had been using a 10-pin IDE boxed connector on the PCB's I was making, but I just recently tried a micro-USB OTG connector (just as a 5-pin connector, not for anything truly USB protocol related), and I find that I like it a lot. For one thing, it's a lot more compact:
                                    It does require making an adapter, but once you've made it (once and done), it's easy.
                                    Any thoughts on this? I'm tentatively leaning toward switching over to it for everything.
                                    Nca78N 1 Reply Last reply
                                      The other cool thing is that the side access allows me to make a very compact PIR motion sensor that's still re-programmable:
                                        @NeverDie I think it's ok only if you keep those only for yourself, and/or make an enclosure hiding this plug.
                                        Because if you give to someone like a friend and an USB plug is visible one day or another they'll plug it and fry the board with 5V :)
                                        • Nca78N Nca78
                                          #1286
                                          Good point. To avoid that as a potential problem then, can anyone suggest a better connector to use?
                                          NeverDieN JokgiJ 2 Replies Last reply
