  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 66.3k Views 21 Watching
  • Ricardo RibeiroR
    Ricardo RibeiroR
    Ricardo Ribeiro
    Hello! I followed instructions by SdeWeb on my Orange Pi Lite with Armbian, and gateway is working fine, I can see debug messages from other node. But when I try to add a serial port in node-red I can't find the gateway one. Can you help me?
    • Ricardo RibeiroR
      Ricardo RibeiroR
      Ricardo Ribeiro
      FYI i configure like this:
      ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB10 --my-serial-baudrate=115200
        NOTE for Armbian and Orange Pi Zero.
        Set static IP address or the device will lose connection on next DHCP request. I use only the LAN and was having problems for few days.
        • 8 8667
          @8667 I didn't know it was possibe to set ip address for the Pi gateway. How did you do that?
            SdeWeb
            wrote on last edited by SdeWeb
            #88
            You should set your gateway as a ethernet / network gateway. By default, it run on port 5003 (ex : [gwipadresse]:5003.
            If you controler is hosted on the same machine that the gateway, then you can call the ip adresse : 127.0.0.1:5003. (the localhost adress) whatever the real IP adresse of your PI.
            if you got a good router on u'r network, that it running DHCP server and give IP adresses of your devices on the network, then you can define static IP adresse for the MAC adresse of your PI.
            Regards.
            • Ricardo RibeiroR
              Ricardo RibeiroR
              Ricardo Ribeiro
              I had to use spidev0.0 and not spidev1.0:
              opilite@orangepilite:~/MySensors$ sudo ./bin/mysgw -d
              mysgw: Starting gateway...
              mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
              mysgw: TSF:LRT:OK
              mysgw: TSM:INIT
              mysgw: TSF:WUR:MS=0
              mysgw: TSM:INIT:TSP OK
              mysgw: TSM:INIT:GW MODE
              mysgw: MCO:REG:NOT NEEDED
              mysgw: MCO:BGN:STP
              mysgw: MCO:BGN:INIT OK,TSP=1
              opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
              • Ricardo RibeiroR
                Ricardo RibeiroR
                Ricardo Ribeiro
                With mqtt gateway I got further ahead:
                opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=my_mqtt_gateway
                mysgw: TSF:LRT:OK
                mysgw: TSM:INIT
                mysgw: TSF:WUR:MS=0
                mysgw: MCO:BGN:STP
                mysgw: connected to 127.0.0.1
                mysgw: MQTT connected
                mysensors-out/0/255/0/0/18 : msg.payload : string[10]
                "2.2.0-beta"
                • Ricardo RibeiroR
                  Ricardo RibeiroR
                  Ricardo Ribeiro
                  Ok, now I load a sketch into an arduino nanowith nrf24l01+ and this is all I got:
                  mysgw: TSF:LRT:OK
                  mysgw: TSM:INIT
                  mysgw: TSF:WUR:MS=0
                  mysgw: MCO:BGN:STP
                  mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:MSG:FPAR REQ,ID=255
                  mysgw: TSF:CKU:OK,FCTRL
                  mysgw: TSF:MSG:GWL OK
                  mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                  mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                  mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
                  mysgw: TSF:MSG:BC
                  mysgw: TSF:PNG:SEND,TO=0
                  mysgw: TSF:CKU:OK
                  Stuck again.
                  • Ricardo RibeiroR Ricardo Ribeiro
                    mysgw: TSF:LRT:OK
                    mysgw: TSM:INIT
                    mysgw: TSF:WUR:MS=0
                    mysgw: MCO:BGN:STP
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:MSG:BC
                    mysgw: TSF:CKU:OK
                    Stuck again.
                    #92
                    @Ricardo-Ribeiro that looks normal. Is this different from what you expected? If so, how does it differ?
                      Had anyone succeeded using signing+encryption on OrangePi MQTT gateway? I managed to make Arduino gateway and it worked but I can not replicate the same thing with Pi. What file should be edited to enter the keys? and the whitelist?
                      • P
                        P
                        pii
                        #94
                        Am getting this error:
                        ERROR Could not open /sys/class/gpio/gpio24/direction
                        My config is:
                        ./configure --spi-spidev-device=/dev/spidev1.0 --my-node-id=1 --my-transport=rfm95 --my-rfm95-cs-pin=13 --my-rfm95-irq-pin=10 --my-rfm69-frequency=915E6
                        Whole output is:
                        root@ttn-gateway:~/MySensors# sudo ./bin/mysgw
                        May 23 09:37:31 INFO  Starting gateway...
                        May 23 09:37:31 INFO  Protocol version - 2.3.0-alpha
                         __  __       ____
                                |___/                      2.3.0-alpha
                        May 23 09:37:31 DEBUG MCO:BGN:INIT NODE,CP=RLNNL---,VER=2.3.0-alpha
                        May 23 09:37:31 DEBUG TSM:INIT
                        May 23 09:37:31 DEBUG TSF:WUR:MS=0
                        May 23 09:37:42 ERROR Could not open /sys/class/gpio/gpio24/direction
                        pansenP 1 Reply Last reply
                        • P pii
                          My config is:
                          Whole output is:
                           __  __       ____
                                  |___/                      2.3.0-alpha
                          pansenP
                          pansenP
                          pansen
                          @pii
                          • Does /sys/class/gpio/gpio24/direction exists?
                          • Does /sys/class/gpio/gpio24 exists?
                          • Can you write to them using echo?
                          Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                          P 2 Replies Last reply
                          • pansenP pansen
                            @pii
                            P
                            P
                            pii
                            @pansen No.... nothing... /sys/class/gpio/gpio24doesn't exist.
                            even "echo "24" > /sys/class/gpio/export doesn't work.
                            But, yes otherwise if I try the same with 13 i.e "echo "13" > /sys/class/gpio/export Then a directory is created and then /sys/class/gpio/gpio24/direction do exist.
                            • pansenP pansen
                              @pii
                              P
                              P
                              pii
                              @pansen Thank you sooooooo much for your reply.!!! By the way, What I actually have to do is "Make an MQTT based LoRa(RA-02) receiver gateway on OrangePi Zero". And I'm stuck since whole week :'( of course spent time trying code without solid base. :/
                              Yes, yet I'm trying to first set up a LoRa receiver(not MQTT, not gateway)
                                marceloaqno
                                Code Contributor
                                @pii --my-rfm95-cs-pin and --my-rfm95-irq-pin options are not currently supported by the configure script.
                                Until we fix this, could you please try adding the following to your examples_linux/mysgw.cpp (before the #include <MySensors.h>)
                                #define MY_RFM95_CS_PIN 13
                                #define MY_RFM95_IRQ_PIN 10
                                #define MY_RFM95_FREQUENCY RFM95_915MHZ
                                and run the make command again.
                                • M marceloaqno
                                  P
                                  P
                                  pii
                                  @marceloaqno said in 💬 Building a Orange Pi Gateway:
                                  Thank you sooo much. I just did this. But, Now got a new error.
                                   ERROR Could not open /sys/class/gpio/gpio10/direction
                                  and when I tried to export pin 10 it says:
                                  :/sys/class/gpio# echo '10' > export
                                  -bash: echo: write error: Device or resource busy
                                  Though yes still I'm able to export/unexport pin 13(just for testing)
                                  • vladikomsV
                                    vladikomsV
                                    vladikoms
                                    @pii Try my library for Orange Pi Zero and Semtech SX1278 radio (RA-02 module)
                                    • P pii
                                      marceloaqno
                                      Code Contributor
                                      @pii Try to connect the IRQ pin from the radio to another GPIO on your Orange Pi, for example the GPIO2.
                                      #define MY_RFM95_IRQ_PIN 2
                                      • G
                                        G
                                        ghck
                                        There is an issue now with spi interfaces. With the current armbian image we are stuck at the prepare the system part, no /dev/spidev* available, the old method does not work. (There is no /boot/script.bin file, for example.) Does anyone know the solution, could this guide be updated, please?
                                        • G
                                          G
                                          ghck
                                          More info: https://docs.armbian.com/User-Guide_Allwinner_overlays/
