  2. Announcements
  3. 💬 Building a Orange Pi Gateway
110 Posts 24 Posters 63.6k Views 21 Watching
  • 8 8667
    @Anticimex said in 💬 Building a Orange Pi Gateway:
    @8667 no, it won't. As it is for the moment, whitelisting works no different compared to Arduino based devices. You will have to recompile your GW if you add new nodes as you will need to add their serials to the whitelist in the GW.
    So how personalization works on the orange and how to pass the list of serials?
    AnticimexA
    AnticimexA
    Anticimex
    @8667 not sure. I have not been involved in the rPi port. I suggest you pass --help to the configure command. It should give a list of options.
      This should be in the wiki
      root@pi0:~/MySensors# ./configure --help
      configure script for MySensors gateway.
      Options:
      Help:
          -h, --help                  print this message
      SPI driver options:
          --spi-driver=[BCM|SPIDEV]
          --spi-spidev-device=<DEVICE>
                                      Device path. [/dev/spidev0.0]
      Building options:
          --soc=[BCM2835|BCM2836|BCM2837|AM33XX|A10|A13|A20|H3]
                                      SoC type to be used. [configure autodetected]
          --cpu-flags=<CPUFLAGS>      CPU defining/optimizing flags to be used. [configure autodetected]
          --extra-cflags=<CFLAGS>     Extra C flags passed to C compilation. []
          --extra-cxxflags=<CXXFLAGS> Extra C++ flags passed to C++ compilation. []
          --extra-ldflags=<LDFLAGS>   Extra C flags passed to linking. []
          --c_compiler=<CC>           C compiler. [arm-linux-gnueabihf-gcc][gcc]
          --cxx_compiler=<CXX>        C++ compiler. [arm-linux-gnueabihf-g++][g++]
          --build-dir=<DIR>           Compiler directory to store object files. [build]
          --bin-dir=<DIR>             Compiler directory to store binary files. [bin]
          --arduino-lib-dir=<DIR>     Arduino library directory.
          --no-clean                  Don't clean previous build artifacts.
      Installation options:
          --prefix=<PREFIX>           Installation prefix path. [/usr/local]
          --gateway-dir=<DIR>         Gateway files installation directory. [PREFIX/bin]
      MySensors options:
          --my-debug=[enable|disable] Enables or disables MySensors core debugging. [enable]
          --my-config-file=<FILE>     Config file path. [/etc/mysensors.dat]
          --my-gateway=[none|ethernet|serial|mqtt]
                                      Set the protocol used to communicate with the controller.
                                      [ethernet]
          --my-node-id=<ID>           Disable gateway feature and run as a node with the specified id.
                                      Controller or MQTT broker ip.
          --my-serial-port=<PORT>     Serial port. [/dev/ttyACM0]
          --my-serial-baudrate=<BAUD> Serial baud rate. [115200]
          --my-serial-is-pty          Set the serial port to be a pseudo terminal. Use this if you want
                                      to connect to a controller running on the same device.
          --my-serial-pty=<NAME>      Symlink name for the PTY device. [/dev/ttyMySensorsGateway]
          --my-serial-groupname=<GROUP>
                                      Grant access to the specified system group for the serial device.
          --my-mqtt-user=<UID>        MQTT user id.
          --my-mqtt-password=<PASS>   MQTT password.
          --my-mqtt-publish-topic-prefix=<PREFIX>
                                      MQTT publish topic prefix.
          --my-mqtt-subscribe-topic-prefix=<PREFIX>
                                      MQTT subscribe topic prefix.
          --my-transport=[none|nrf24|rs485|rfm95|rfm69]
                                      Set the transport to be used to communicate with other nodes.
                                      [nrf24]
          --my-rf24-channel=<0-125>   RF channel for the sensor net. [76]
          --my-rf24-pa-level=[RF24_PA_MAX|RF24_PA_LOW]
                                      RF24 PA level. [RF24_PA_MAX]
          --my-rf24-ce-pin=<PIN>      Pin number to use for rf24 Chip-Enable.
          --my-rf24-cs-pin=<PIN>      Pin number to use for rf24 Chip-Select.
          --my-rf24-irq-pin=<PIN>     Pin number connected to nRF24L01 IRQ pin.
          --my-rf24-encryption-enabled
                                      Enables RF24 encryption.
                                      All nodes and gateway must have this enabled, and all must be
                                      personalized with the same AES key
          --my-rx-message-buffer-size=<SIZE>
                                      Buffer size for incoming messages when using rf24 interrupts. [20]
          --my-rfm69-frequency=[315|433|868|915]
                                      RFM69 Module Frequency. [868]
          --my-is-rfm69hw             Enable high-powered rfm69hw.
          --my-rfm69-cs-pin=<PIN>     Pin number to use for RFM69 Chip-Select.
          --my-rs485-serial-port=<PORT>
                                      RS485 serial port. You must provide a port.
          --my-rs485-baudrate=<BAUD>  RS485 baudrate. [9600]
          --my-rs485-de-pin=<PIN>     Pin number connected to RS485 driver enable pin.
          --my-rs485-max-msg-length=<LENGTH>
                                      The maximum message length used for RS485. [40]
          --my-leds-err-pin=<PIN>     Error LED pin.
          --my-leds-rx-pin=<PIN>      Receive LED pin.
          --my-leds-tx-pin=<PIN>      Transmit LED pin.
          --my-leds-blinking-inverse  Inverse the blinking feature.
          --my-signing=[none|software|password]
                                      Message signing. [none]
          --my-signing-debug          Enable signing related debug.
          --my-signing-request-signatures
                                      Enable signature request from nodes that in turn requested
                                      gateway signature.
          --my-signing-weak_security  Enable this to permit downgrade of security preferences and
                                      relaxed gateway signing requirements.
          --my-signing-password=<PASSWORD>
                                      If you are using password as the signature type, set your password here.
      root@pi0:~/MySensors# sudo ./bin/mysgw -h
      mysgw: Config file /etc/mysensors.dat does not exist, creating new config file.
      Usage: mysgw [options]
      Options:
      AnticimexA mfalkviddM 2 Replies Last reply
      • 8 8667
        Options:
        Help:
        SPI driver options:
        Building options:
        MySensors options:
                                        [ethernet]
                                        [nrf24]
                                        gateway signature.
        Options:
        AnticimexA
        AnticimexA
        Anticimex
        @8667 if there is no option for the whitelist, you should still be able to set it using the same #define as mentioned in the signing documentation. The implementation is shared.
        It makes sense to keep it like that since the list could be quite long.
        • 8 8667
          Options:
          Help:
          SPI driver options:
          Building options:
          MySensors options:
                                          [ethernet]
                                          [nrf24]
                                          gateway signature.
          Options:
          #83
          @8667 a first try of making the help text available online is now available at https://ci.mysensors.org/job/MySensors/job/MySensors/job/PR-952/12/Doxygen_HTML/group__RaspberryPiGateway.html
          If/when the pull request is accepted, a link can be added on the build page.
          • Ricardo RibeiroR
            Ricardo RibeiroR
            Ricardo Ribeiro
            Hello! I followed instructions by SdeWeb on my Orange Pi Lite with Armbian, and gateway is working fine, I can see debug messages from other node. But when I try to add a serial port in node-red I can't find the gateway one. Can you help me?
            • Ricardo RibeiroR
              Ricardo RibeiroR
              Ricardo Ribeiro
              FYI i configure like this:
              ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyUSB10 --my-serial-baudrate=115200
                NOTE for Armbian and Orange Pi Zero.
                Set static IP address or the device will lose connection on next DHCP request. I use only the LAN and was having problems for few days.
                • 8 8667
                  @8667 I didn't know it was possibe to set ip address for the Pi gateway. How did you do that?
                    SdeWeb
                    wrote on last edited by SdeWeb
                    #88
                    You should set your gateway as a ethernet / network gateway. By default, it run on port 5003 (ex : [gwipadresse]:5003.
                    If you controler is hosted on the same machine that the gateway, then you can call the ip adresse : 127.0.0.1:5003. (the localhost adress) whatever the real IP adresse of your PI.
                    if you got a good router on u'r network, that it running DHCP server and give IP adresses of your devices on the network, then you can define static IP adresse for the MAC adresse of your PI.
                    Regards.
                    • Ricardo RibeiroR
                      Ricardo RibeiroR
                      Ricardo Ribeiro
                      I had to use spidev0.0 and not spidev1.0:
                      opilite@orangepilite:~/MySensors$ sudo ./bin/mysgw -d
                      mysgw: Starting gateway...
                      mysgw: MCO:BGN:INIT GW,CP=RNNGL---,VER=2.2.0-beta
                      mysgw: TSF:LRT:OK
                      mysgw: TSM:INIT
                      mysgw: TSF:WUR:MS=0
                      mysgw: TSM:INIT:TSP OK
                      mysgw: TSM:INIT:GW MODE
                      mysgw: MCO:REG:NOT NEEDED
                      mysgw: MCO:BGN:STP
                      mysgw: MCO:BGN:INIT OK,TSP=1
                      opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=serial --my-serial-is-pty --my-serial-pty=/dev/ttyMySensorsGateway
                      • Ricardo RibeiroR
                        Ricardo RibeiroR
                        Ricardo Ribeiro
                        With mqtt gateway I got further ahead:
                        opilite@orangepilite:~/MySensors$ ./configure --spi-spidev-device=/dev/spidev0.0 --my-transport=nrf24 --my-rf24-ce-pin=2 --my-rf24-cs-pin=67 --my-gateway=mqtt --my-controller-ip-address=127.0.0.1 --my-mqtt-publish-topic-prefix=mysensors-out --my-mqtt-subscribe-topic-prefix=mysensors-in --my-mqtt-client-id=my_mqtt_gateway
                        mysgw: TSF:LRT:OK
                        mysgw: TSM:INIT
                        mysgw: TSF:WUR:MS=0
                        mysgw: MCO:BGN:STP
                        mysgw: connected to 127.0.0.1
                        mysgw: MQTT connected
                        mysensors-out/0/255/0/0/18 : msg.payload : string[10]
                        "2.2.0-beta"
                        • Ricardo RibeiroR
                          Ricardo RibeiroR
                          Ricardo Ribeiro
                          Ok, now I load a sketch into an arduino nanowith nrf24l01+ and this is all I got:
                          mysgw: TSF:LRT:OK
                          mysgw: TSM:INIT
                          mysgw: TSF:WUR:MS=0
                          mysgw: MCO:BGN:STP
                          mysgw: TSF:MSG:READ,255-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0:
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:MSG:FPAR REQ,ID=255
                          mysgw: TSF:CKU:OK,FCTRL
                          mysgw: TSF:MSG:GWL OK
                          mysgw: TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=8,pt=1,l=1,sg=0,ft=0,st=OK:0
                          mysgw: TSF:MSG:READ,255-255-0,s=255,c=3,t=3,pt=0,l=0,sg=0:
                          mysgw: Sending message on topic: mysensors-out/255/255/3/0/3
                          mysgw: TSF:MSG:BC
                          mysgw: TSF:PNG:SEND,TO=0
                          mysgw: TSF:CKU:OK
                          Stuck again.
                          • Ricardo RibeiroR Ricardo Ribeiro
                            mysgw: TSF:LRT:OK
                            mysgw: TSM:INIT
                            mysgw: TSF:WUR:MS=0
                            mysgw: MCO:BGN:STP
                            mysgw: TSF:MSG:BC
                            mysgw: TSF:MSG:BC
                            mysgw: TSF:CKU:OK
                            Stuck again.
                            #92
                            @Ricardo-Ribeiro that looks normal. Is this different from what you expected? If so, how does it differ?
                              Had anyone succeeded using signing+encryption on OrangePi MQTT gateway? I managed to make Arduino gateway and it worked but I can not replicate the same thing with Pi. What file should be edited to enter the keys? and the whitelist?
                              • P
                                P
                                pii
                                #94
                                Am getting this error:
                                ERROR Could not open /sys/class/gpio/gpio24/direction
                                My config is:
                                ./configure --spi-spidev-device=/dev/spidev1.0 --my-node-id=1 --my-transport=rfm95 --my-rfm95-cs-pin=13 --my-rfm95-irq-pin=10 --my-rfm69-frequency=915E6
                                Whole output is:
                                root@ttn-gateway:~/MySensors# sudo ./bin/mysgw
                                May 23 09:37:31 INFO  Starting gateway...
                                May 23 09:37:31 INFO  Protocol version - 2.3.0-alpha
                                 __  __       ____
                                        |___/                      2.3.0-alpha
                                May 23 09:37:31 DEBUG MCO:BGN:INIT NODE,CP=RLNNL---,VER=2.3.0-alpha
                                May 23 09:37:31 DEBUG TSM:INIT
                                May 23 09:37:31 DEBUG TSF:WUR:MS=0
                                May 23 09:37:42 ERROR Could not open /sys/class/gpio/gpio24/direction
                                pansenP 1 Reply Last reply
                                • P pii
                                  My config is:
                                  Whole output is:
                                   __  __       ____
                                          |___/                      2.3.0-alpha
                                  pansenP
                                  pansenP
                                  pansen
                                  @pii
                                  • Does /sys/class/gpio/gpio24/direction exists?
                                  • Does /sys/class/gpio/gpio24 exists?
                                  • Can you write to them using echo?
                                  Orange Pi Plus 2e connected to nrf24 PA via SPI running git-development MySensors gateway, OpenHAB2, mosquitto and MySQL persistence.
                                  P 2 Replies Last reply
                                  • pansenP pansen
                                    @pii
                                    P
                                    P
                                    pii
                                    @pansen No.... nothing... /sys/class/gpio/gpio24doesn't exist.
                                    even "echo "24" > /sys/class/gpio/export doesn't work.
                                    But, yes otherwise if I try the same with 13 i.e "echo "13" > /sys/class/gpio/export Then a directory is created and then /sys/class/gpio/gpio24/direction do exist.
                                    • pansenP pansen
                                      @pii
                                      P
                                      P
                                      pii
                                      @pansen Thank you sooooooo much for your reply.!!! By the way, What I actually have to do is "Make an MQTT based LoRa(RA-02) receiver gateway on OrangePi Zero". And I'm stuck since whole week :'( of course spent time trying code without solid base. :/
                                      Yes, yet I'm trying to first set up a LoRa receiver(not MQTT, not gateway)
                                        marceloaqno
                                        Code Contributor
                                        @pii --my-rfm95-cs-pin and --my-rfm95-irq-pin options are not currently supported by the configure script.
                                        Until we fix this, could you please try adding the following to your examples_linux/mysgw.cpp (before the #include <MySensors.h>)
                                        #define MY_RFM95_CS_PIN 13
                                        #define MY_RFM95_IRQ_PIN 10
                                        #define MY_RFM95_FREQUENCY RFM95_915MHZ
                                        and run the make command again.
                                        • M marceloaqno
                                          P
                                          P
                                          pii
                                          @marceloaqno said in 💬 Building a Orange Pi Gateway:
                                          Thank you sooo much. I just did this. But, Now got a new error.
                                           ERROR Could not open /sys/class/gpio/gpio10/direction
                                          and when I tried to export pin 10 it says:
                                          :/sys/class/gpio# echo '10' > export
                                          -bash: echo: write error: Device or resource busy
                                          Though yes still I'm able to export/unexport pin 13(just for testing)
