  2. Feature Requests
  3. RFM69 RSSI value report
Scheduled Pinned Locked Moved Feature Requests
41 Posts 11 Posters 22.4k Views 12 Watching
  • G gieemek
    In the 2.2 version of MySensors (development branch) the new driver for RFM69 is built. It has new command for reading RSSI value: RFM69_getSendingRSSI() and RFM69_getReceivingRSSI(), so now is very easy to get RSSI value.
    You can get some more information from ATC Signal Report which are useful - look at RFM69_RFM95_ATC_SignalReport example.
    G
    G
    gieemek
    • G gieemek
      @gieemek
      what kind of variable and type are better for reporting RSSI?
      G 1 Reply Last reply
        @gieemek
        G
        G
        gieemek
        @gohan I use V_VAR1 type of variable.
        gohanG 1 Reply Last reply
        • G gieemek
          @gieemek ok, but how about when you present the child? S_CUSTOM is not accepted by Domoticz S_SOUND could be an option
          • N
            N
            napo7
            wrote on last edited by napo7
            #30
            I see in the domoticz code that there are some fields to record Signal Level for other sensors types.
            Making domoticz handle the signal level would then be possible.
            There is 2 enhancements to do so :
            • Handle a standard variable or subtype in MySensors to carry the signal or RSSI level (github issue 581 : https://github.com/mysensors/MySensors/issues/581)
            • Modify the domoticz code to show somewhere the Signal Level for MySensors devices. (no github issue yet)
            That would be interresting, since it would also allow to trigger some custom scripts if a device falls in a poor level...
            • G
              G
              gieemek
              I do not know Domotich - I am working with openHAB through MQTT protocol, which simply reads the sent value of variable and does not wonder what type they are. Yes, I use S_CUSTOM variable to send RSSI value.
              But it really doesn't matter what kind of variable you use. The variable type tells to MySensors that its value is for example: light level, temperature, or voltage, but you can send a temperature value using the S_POWER variable - no problem with that.
              RSSI should be expressed as an integer, so what is realy important that you choose the variable type declared as integer value, such as i.e. S_LIGHT_LEVEL.
              Once you have that value in the controller (openHAB), you can do whatever you want with it.
              So it is in openHAB, and I hope in Domoticz the same.
                I used S_SOUND so it will report it as 'db', so for now I am happy with it.
                • J jpaulin
                  @rmtucker Here's the complete sketch. It's a DHT22 temp/humidity battery powered sensor node with an RFM69 radio.
                   * Version 1.0 - Henrik EKblad
                   * This sketch provides an example how to implement a humidity/temperature
                   * sensor using DHT11/DHT-22
                  // Enable debug prints
                  //#define MY_RADIO_NRF24
                  #define MY_RADIO_RFM69
                  #define MY_RFM69_FREQUENCY   RF69_433MHZ
                  #define MY_NODE_ID 13                        // Identity for temp/hum sensor
                  // Set blinking period
                  #define MY_DEFAULT_LED_BLINK_PERIOD 50
                  // Flash leds on rx/tx/err
                  //#define MY_DEFAULT_ERR_LED_PIN 7           // Error led pin  red
                  //#define MY_DEFAULT_RX_LED_PIN  6           // Receive led pin  yellow
                  #define MY_DEFAULT_TX_LED_PIN  9             // Transmit led pin  green
                  const byte BATT_ADC = 1;                     // ADC Pin to measure battery level
                  unsigned long SLEEP_TIME = 300000;           // Sleep time between reads (in milliseconds)
                  #define CHILD_ID_HUM 0
                  #define CHILD_ID_TEMP 1
                  #define DHTPIN 18                            // Input pin from DHT22
                  #define DHT22_PWR 6                          // Vdc pin DHT22 to get it to sleep
                  #define DHTTYPE DHT22
                  DHT dht(DHTPIN, DHTTYPE);
                  #define CHILD_ID_RSSI_HIGH  7                // RSSI received signal level
                  #define CHILD_ID_RSSI_LOW   8                // RSSI background noise level
                  #define CHILD_ID_TEMP2      9                // internal temperature RFM69 chip
                  int rssi;                                    // RSSI RFM69 chip
                  int temp2;                                   // Internal temperature RFM69 chip
                  int batteryLevel;                            // measured battery level
                  int batteryPcnt;                             // measured battery level in percentage
                  MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_VAR1);
                  MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_VAR1);
                  MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP);
                    pinMode(DHT22_PWR,OUTPUT);
                    digitalWrite(DHT22_PWR,HIGH);              // power-on dht22
                    wait(2000);
                    dht.begin();                               // Start-up DHT22 sensor Temperature/Humidity
                    sendSketchInfo("Temp_Hum", "1.0");
                    present(CHILD_ID_HUM, S_HUM);
                    present(CHILD_ID_RSSI_HIGH, S_CUSTOM);
                    present(CHILD_ID_RSSI_LOW, S_CUSTOM);
                    present(CHILD_ID_TEMP2, S_TEMP);
                    float humidity = dht.readHumidity();       // get dht22 humidity
                    if (isnan(humidity)) {
                      send(msgHum.set(humidity, 1));           // send dht22 humidity
                      wait(200);
                    float temperature = dht.readTemperature(); // get dht22 temperature
                    if (isnan(temperature)) {
                      send(msgTemp.set(temperature, 1));       // send dht22 temperature
                    digitalWrite(DHT22_PWR,LOW);               // save some power
                    rssi = _radio.readRSSI();                  // read RSSI in RFM69. Measure reception signal from gw
                    send(msgRSSI1.set(rssi));                  // send RSSI level
                    wait(500);                                 // wait to get idle
                    rssi = _radio.readRSSI();                  // read RSSI in RFM69. Wait and measure background noise
                    send(msgRSSI2.set(rssi));                  // send RSSI level
                    wait(200);                                 // wait for next send
                    temp2 = _radio.readTemperature(1);         // read temperature in RFM69
                    send(msgTemp2.set(temp2));                 // send temperature
                    batteryLevel = analogRead(BATT_ADC);       //  (* 0.0032225806)
                    batteryPcnt = batteryLevel / 10;           // battery percentage
                    sendBatteryLevel(batteryPcnt);             // send battery level in percentage to controller
                    // if (oldBatteryPcnt != batteryPcnt) {    // use if not to send every cycle
                    //     sendBatteryLevel(batteryPcnt);
                    //     oldBatteryPcnt = batteryPcnt;
                    sleep(SLEEP_TIME);                         // sleep a bit
                    digitalWrite(DHT22_PWR,HIGH);              // wake up DHT sensor
                    wait(2000);                                // warm up DHT sensor
                    Serial.println("something came in");
                    if (message.type==V_VAR1) {                // reception to change SLEEP_TIME.
                       SLEEP_TIME = message.getULong();        // send topic: eg. my_RFM69_gw1-in/3/1/1/0/24 30000 (payload in ms)
                     }                                         // MQTT_publish_topic_prefix/Node_Id/Sensor_Id/Cmd_Type/Ack_flag/type(V_VAR1=24) payload
                  readRSSI(); is an internal function in the RFM69.h / RFM69.cpp library that I'm calling in the sketch to get the RSSI and background noise level.
                  zboblamontZ
                  zboblamontZ
                  zboblamont
                  @jpaulin I can see the value of obtaining Gateway RSSI for individual battery powered nodes to inform programmed power settings on them in the absence of ATC implementation at the Node itself, but not sure I understand the purpose of RSSI readings at the node other than to establish noise thresholds on the Gateway signal.
                  Although the function of the Gateway is to forward messages to the Controller, is it possible for the Gateway to read and forward RSSI readings for nodes as if locally attached sensors?
                    Reading rssi and power on the node it gives you an idea of how much signal that node is getting and if there are interferences around it
                      zboblamontZ
                      zboblamontZ
                      zboblamont
                      @gohan Yes, I understood that aspect. I can imagine certain environments where the SNR might inform change of Node location or shielding or directivity of antenna, or increased output from the Gateway, but I would have thought that a one-off task unless the node noise background changes frequently...
                        You can always put a counter to send rssi reports after X amount of other data being sent
                          zboblamontZ
                          zboblamontZ
                          zboblamont
                          @gohan True, but if no change to the environment is anticipated, why use battery power to convey it at all?
                          My own interest in what RSSI the Gateway is receiving should also be a one-time exercise, but is more difficult to implement I suppose.
                          Until such time the 2.2 version is released, and what it provides becomes clearer, I might just do the checking with two portable nodes...
                            I can show you how background noise rssi and power output changes during the day and I'm not moving things around
                              zboblamontZ
                              zboblamontZ
                              zboblamont
                              @gohan Not disputing SNRs vary, what I meant by change to the environment at the node was unforeseen pollution influences, such as somebody working with a welder right beside the node after you had already established the peak diurnal noise and set everything up.
                              The Gateway usually can run permanently at high gain, the Node can only do so at the expense of battery life...
                                ACS helps a lot, but by recording rssi and tx power I noticed why thenode occasionally was going offline
                                  zboblamontZ
                                  zboblamontZ
                                  zboblamont
                                  @gohan Fair comment, it was the best tool to resolve the problem.
                                  I spent 3 days reviewing what I had programmed, inspected wiring, and testing all DS18B20s, two of which are in the loft, only to discover that a faulty telephone socket had partially dislodged it's pins, my tool to resolve? A magnifying glass.... Isn't technology wonderful...:snail:
