  2. Feature Requests
  3. RFM69 RSSI value report
Scheduled Pinned Locked Moved Feature Requests
41 Posts 11 Posters 22.4k Views 12 Watching
  • G gieemek
    @gohan I use V_VAR1 type of variable.
    @gieemek ok, but how about when you present the child? S_CUSTOM is not accepted by Domoticz S_SOUND could be an option
    • N
      N
      napo7
      wrote on last edited by napo7
      #30
      I see in the domoticz code that there are some fields to record Signal Level for other sensors types.
      Making domoticz handle the signal level would then be possible.
      There is 2 enhancements to do so :
      • Handle a standard variable or subtype in MySensors to carry the signal or RSSI level (github issue 581 : https://github.com/mysensors/MySensors/issues/581)
      • Modify the domoticz code to show somewhere the Signal Level for MySensors devices. (no github issue yet)
      That would be interresting, since it would also allow to trigger some custom scripts if a device falls in a poor level...
      • G
        G
        gieemek
        I do not know Domotich - I am working with openHAB through MQTT protocol, which simply reads the sent value of variable and does not wonder what type they are. Yes, I use S_CUSTOM variable to send RSSI value.
        But it really doesn't matter what kind of variable you use. The variable type tells to MySensors that its value is for example: light level, temperature, or voltage, but you can send a temperature value using the S_POWER variable - no problem with that.
        RSSI should be expressed as an integer, so what is realy important that you choose the variable type declared as integer value, such as i.e. S_LIGHT_LEVEL.
        Once you have that value in the controller (openHAB), you can do whatever you want with it.
        So it is in openHAB, and I hope in Domoticz the same.
          I used S_SOUND so it will report it as 'db', so for now I am happy with it.
          • J jpaulin
            @rmtucker Here's the complete sketch. It's a DHT22 temp/humidity battery powered sensor node with an RFM69 radio.
             * Version 1.0 - Henrik EKblad
             * This sketch provides an example how to implement a humidity/temperature
             * sensor using DHT11/DHT-22
            // Enable debug prints
            //#define MY_RADIO_NRF24
            #define MY_RADIO_RFM69
            #define MY_RFM69_FREQUENCY   RF69_433MHZ
            #define MY_NODE_ID 13                        // Identity for temp/hum sensor
            // Set blinking period
            #define MY_DEFAULT_LED_BLINK_PERIOD 50
            // Flash leds on rx/tx/err
            //#define MY_DEFAULT_ERR_LED_PIN 7           // Error led pin  red
            //#define MY_DEFAULT_RX_LED_PIN  6           // Receive led pin  yellow
            #define MY_DEFAULT_TX_LED_PIN  9             // Transmit led pin  green
            const byte BATT_ADC = 1;                     // ADC Pin to measure battery level
            unsigned long SLEEP_TIME = 300000;           // Sleep time between reads (in milliseconds)
            #define CHILD_ID_HUM 0
            #define CHILD_ID_TEMP 1
            #define DHTPIN 18                            // Input pin from DHT22
            #define DHT22_PWR 6                          // Vdc pin DHT22 to get it to sleep
            #define DHTTYPE DHT22
            DHT dht(DHTPIN, DHTTYPE);
            #define CHILD_ID_RSSI_HIGH  7                // RSSI received signal level
            #define CHILD_ID_RSSI_LOW   8                // RSSI background noise level
            #define CHILD_ID_TEMP2      9                // internal temperature RFM69 chip
            int rssi;                                    // RSSI RFM69 chip
            int temp2;                                   // Internal temperature RFM69 chip
            int batteryLevel;                            // measured battery level
            int batteryPcnt;                             // measured battery level in percentage
            MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_VAR1);
            MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_VAR1);
            MyMessage msgTemp2(CHILD_ID_TEMP2, V_TEMP);
              pinMode(DHT22_PWR,OUTPUT);
              digitalWrite(DHT22_PWR,HIGH);              // power-on dht22
              wait(2000);
              dht.begin();                               // Start-up DHT22 sensor Temperature/Humidity
              sendSketchInfo("Temp_Hum", "1.0");
              present(CHILD_ID_HUM, S_HUM);
              present(CHILD_ID_RSSI_HIGH, S_CUSTOM);
              present(CHILD_ID_RSSI_LOW, S_CUSTOM);
              present(CHILD_ID_TEMP2, S_TEMP);
              float humidity = dht.readHumidity();       // get dht22 humidity
              if (isnan(humidity)) {
                send(msgHum.set(humidity, 1));           // send dht22 humidity
                wait(200);
              float temperature = dht.readTemperature(); // get dht22 temperature
              if (isnan(temperature)) {
                send(msgTemp.set(temperature, 1));       // send dht22 temperature
              digitalWrite(DHT22_PWR,LOW);               // save some power
              rssi = _radio.readRSSI();                  // read RSSI in RFM69. Measure reception signal from gw
              send(msgRSSI1.set(rssi));                  // send RSSI level
              wait(500);                                 // wait to get idle
              rssi = _radio.readRSSI();                  // read RSSI in RFM69. Wait and measure background noise
              send(msgRSSI2.set(rssi));                  // send RSSI level
              wait(200);                                 // wait for next send
              temp2 = _radio.readTemperature(1);         // read temperature in RFM69
              send(msgTemp2.set(temp2));                 // send temperature
              batteryLevel = analogRead(BATT_ADC);       //  (* 0.0032225806)
              batteryPcnt = batteryLevel / 10;           // battery percentage
              sendBatteryLevel(batteryPcnt);             // send battery level in percentage to controller
              // if (oldBatteryPcnt != batteryPcnt) {    // use if not to send every cycle
              //     sendBatteryLevel(batteryPcnt);
              //     oldBatteryPcnt = batteryPcnt;
              sleep(SLEEP_TIME);                         // sleep a bit
              digitalWrite(DHT22_PWR,HIGH);              // wake up DHT sensor
              wait(2000);                                // warm up DHT sensor
              Serial.println("something came in");
              if (message.type==V_VAR1) {                // reception to change SLEEP_TIME.
                 SLEEP_TIME = message.getULong();        // send topic: eg. my_RFM69_gw1-in/3/1/1/0/24 30000 (payload in ms)
               }                                         // MQTT_publish_topic_prefix/Node_Id/Sensor_Id/Cmd_Type/Ack_flag/type(V_VAR1=24) payload
            readRSSI(); is an internal function in the RFM69.h / RFM69.cpp library that I'm calling in the sketch to get the RSSI and background noise level.
            zboblamontZ
            zboblamontZ
            zboblamont
            @jpaulin I can see the value of obtaining Gateway RSSI for individual battery powered nodes to inform programmed power settings on them in the absence of ATC implementation at the Node itself, but not sure I understand the purpose of RSSI readings at the node other than to establish noise thresholds on the Gateway signal.
            Although the function of the Gateway is to forward messages to the Controller, is it possible for the Gateway to read and forward RSSI readings for nodes as if locally attached sensors?
              Reading rssi and power on the node it gives you an idea of how much signal that node is getting and if there are interferences around it
                zboblamontZ
                zboblamontZ
                zboblamont
                @gohan Yes, I understood that aspect. I can imagine certain environments where the SNR might inform change of Node location or shielding or directivity of antenna, or increased output from the Gateway, but I would have thought that a one-off task unless the node noise background changes frequently...
                  You can always put a counter to send rssi reports after X amount of other data being sent
                    zboblamontZ
                    zboblamontZ
                    zboblamont
                    @gohan True, but if no change to the environment is anticipated, why use battery power to convey it at all?
                    My own interest in what RSSI the Gateway is receiving should also be a one-time exercise, but is more difficult to implement I suppose.
                    Until such time the 2.2 version is released, and what it provides becomes clearer, I might just do the checking with two portable nodes...
                      I can show you how background noise rssi and power output changes during the day and I'm not moving things around
                        zboblamontZ
                        zboblamontZ
                        zboblamont
                        @gohan Not disputing SNRs vary, what I meant by change to the environment at the node was unforeseen pollution influences, such as somebody working with a welder right beside the node after you had already established the peak diurnal noise and set everything up.
                        The Gateway usually can run permanently at high gain, the Node can only do so at the expense of battery life...
                          ACS helps a lot, but by recording rssi and tx power I noticed why thenode occasionally was going offline
                            zboblamontZ
                            zboblamontZ
                            zboblamont
                            @gohan Fair comment, it was the best tool to resolve the problem.
                            I spent 3 days reviewing what I had programmed, inspected wiring, and testing all DS18B20s, two of which are in the loft, only to discover that a faulty telephone socket had partially dislodged it's pins, my tool to resolve? A magnifying glass.... Isn't technology wonderful...:snail:
