  3. [solved] RS485 nodes stop sending data after some hours or days
74 Posts 11 Posters 31.1k Views 18 Watching
    @nofox try to remove code as much as you can. Does it still work if you operate it with the button? Is relay opto isolated?
    nofoxN
    nofoxN
    nofox
    wrote on last edited by nofox
    #27
    @gohan No I can't operate it with button. Relays are not optoisolated, i don't isolate them because my node board are powered by 5V and i can't provide external power only for relays.
      I know that turning on and off loads can generate emi that arduino doesn't like. Maybe you could try with an optocoupler between arduino and the relay
      • K
        K
        kimot
        Check position of nodes on the bus to in failure conditions.
        With RS485 bus drivers is easy possible for one node to block communication on entire bus sending dominant state.
        In this situation, nodes near the gateway can "push" their messages to the gateway, other nodes not.
          How do you determine the bus failure?
          • nofoxN
            nofoxN
            nofox
            Hi! Everything working pretty well, but sometimes some random node stops to communicate and react for pressing buttons. I have watchdogs in every nodes so I think that only communication is hanging.. Is it possible that only altsoftserial library hanging inside arduino code ??
            • rejoe2R
              rejoe2R
              rejoe2
              As I could nail down some more parts (but still do not have a reliably network), also a short update from my side:
              • Node_1 (Multi DS18B20 (*12@three pins) + other things) is the biggest troublemaker. It just pulled the Voltage between a+b to +2.8V after some time. There is some hours of delay between the last messages and the node stopping also the pir functionality (no wdt code implemented).
              • Node_2 (also Multi DS18B20 (*5@three pins) and other stuff) also stopps communication after some time (it originally worked, this may be related to whatever change happened in between). But this one doesn't kill the entire bus communication and seems to work internally (switches relay on in case a rise of temperature is detected). This also holds my pullpup+pulldown-resistors for RS485.
              Yesterday I switched over Node_1 to use HW_SERIAL, as I also suspected altsoftserial to be part of the root causes. At first sight this seems to improve things a lot.
              Next, I will review Node_2 for the use of HW_SERIAL.
              What I have in mind (may not be correct):
              • HW_SERIAL uses less memory. So this may prevent the node to have some kind of overflow
              • there may be an conflict in internal timers, as 1wire may also need a timer (I use amongst others also PIN10 for 1wire).
              • nofoxN
                nofoxN
                nofox
                There is one thing that we all need to try. When you using RS485 than you have power supply somewhere far far away from nodes. Longer power lines means higher inductance and far more noise on power lines. I think we need to try to put some 10 - 100uF electrolitic cap on all nodes (i have 10uF on each node) and few ceramic 100nF near the microprocessor on every node. If you use atmega328p you need at least 3 of 100nF caps ( i forget to put them on my nodes). I’we read that this 100nF caps are very big improvement in power supplying the atmega.
                  Stefan_NE
                  Hi to all,
                  i have the same problem since i changes some node to RS485. Setup
                  Fhem 5.8
                  Mysensors 2.2rc1
                  Gateway Arduino Nano USB to Fhem.
                  Nodes 5PC all Ardunino MiniPro; Energymeter, Relay,Temp DS18B20
                  What I found out is, the nodes are not hanging. There is no communication to the gateway. Reboot the node does not help. After a reboot of the node pairing does not work.
                  Reconnect the gateway to Fhen does not help.
                  AFhem restart works ( shudown restart). After the restart all nodes are appearing them self.
                  Today I will build a new gateway, using ESP8266 and RS485.
                  I have used USB gateway before, with several problems. After i changes the gateway for NFR24 and RFM69 from USB to ESP8266 most of the problems are gone.
                  I hope this will work. If not RS485 ist history and for this case Myssensors will be exchanges to 1-Wire.
                  It takes one or two days to get the first results.
                  Have a good day
                  Stefan
                  rejoe2R 1 Reply Last reply
                  • S Stefan_NE
                    Hi to all,
                    Fhem 5.8
                    Mysensors 2.2rc1
                    Have a good day
                    Stefan
                    rejoe2R
                    rejoe2R
                    rejoe2
                    @Stefan_NE
                    Strange, imo using a serial GW is the most reliable option. (May be different in case the nano is a bad fake and problems with CH340G-nanos are also reported in VM environments.
                    Are all nodes reffering to the korrect IO and how is the RS485-WG defined?
                    Explanation: I also use a second GW and in some cases nodes are assigned to the wrong GW. If you use several /dev/ttyUSBx-defines, the IO may not be functional. See output of "ls -l /dev/serial/by-id".
                    Most likely there is a electrical problem on your bus. Did you measure voltages, esp. between A+B? What type of modules or pcb's do you use?
                      Stefan_NE
                      @rejoe2
                      good idea, that's what is thought meanwile, and i setup a serial gateway with an original Arduino Mega using hardware serial for the rs485. This is running now for 90 min. Let's see what happens. The serial gateway is the only one i use. All other nodes gateway are using wireless gateways.
                      • rejoe2R
                        rejoe2R
                        rejoe2
                        If you have more than one MySensors-GW's defined, imo it doesn't matter what type they are. Under some circumstances, nodes may be routed through the "wrong" GW. I would recommend to check that first (may be irritating, but even with the wrong GW assinged as IO, some readings are nevertheless updated when node is reset (presentation info)).
                        Hardware serial is a good idea, but at least according to my personal experience (and opposite to my estimations in the beginning) my (FTDI-Nano-) GW is one of the most reliable parts in my MySensors-RS485-environment.
                        Node_2 - my "troublemaker Nr. 1" - also performs reliably now (running without issues since 5+ days) since switched to HW-serial. But also a altsoftserial-Node with BME280 works at the same level of reliability for several weeks now (with less free memory left!) .
                        Powering issues and capacitors may also be helpful as @nofox suggested. I may do some tests wrt this after switching to HW-serial for Node_2 in case it's still not performing as expected.
                        Last: What modules do you use? In case of the LC-Tech ones, I would recommend to desolder at least the 120Ohm resistor on the "middle" nodes.
                          Stefan_NE
                          New status:
                          the serial gateway based on the Arduino Mega with HW Serial failed after 27 hours. Same way to fix. I needed to restart FHEM and all nodes started working without any reboot e.g.
                          I don't think about any bus problem.
                          Next try is the gateway with an esp8266. Setup is done and all nodes are online. The major difference is the serial buffer of 256 bytes.
                          Since i have changed my wireless nodes to the ESP8266 the failure of these nodes decreases a lot.
                            Do you have an ethernet shield? If so try to make an ethernet gateway with the mega and when it hangs try to connect to it with myscontroller and see if you get a response.
                            • S Stefan_NE
                              New status:
                              rejoe2R
                              rejoe2R
                              rejoe2
                              @Stefan_NE Did you measure voltage A-B before restarting FHEM/the attached Arduino?
                              I also had very strange effects and was convinced not to have any electrical problem on the bus - I was completely wrong (see reports above).
                              • rejoe2R
                                rejoe2R
                                rejoe2
                                One more update: This night my BME280-Node (Node_3 using altsoftserial) stopped transmitting - after around 8 days of operation... Strange!
                                As Node_2 didn't crash completely in the past, I just desoldered my pullup- and pulldown-resistors that had been placed on that node (1k each). As I use the LC-Tech-Modules, now there are remaining only the full set of resistors on the GW (also the 2*20k) and at the last module in line.
                                Communication seems to be stable from all nodes. As this is just one more snapshot wrt just around one hour of operation, I'm pretty interested what will happen next - or if that's just another small step in whatever direction.
                                • nofoxN
                                  nofoxN
                                  nofox
                                  Hi! My nodes stops working random once a week, once a month etc. I now upgrade my nodes sketch with watchdog timers. But not with avr/wdt library but with some code i’ve found in the internet. I dont upload the code to nodes but I’ve checked that the watchdog function working as I set some delay() into sketch. Its not a problem that the node hanging, the problem is They don’t restarting it self.
                                    Stefan_NE
                                    New update, no good news
                                    It was working for 10 hours, and after restart for another 4 hours. I will stop now the use of the RS485. It is to weak for my use case. I have spend to much time for this.
                                    A couple of weeks ago, i switched from NFR24 to RFM 69, this is very stable. I will go for a secound RFM69 Network for this use case.
                                    • rejoe2R
                                      rejoe2R
                                      rejoe2
                                      One more: Node_2 has stopped transmission, so I resoldered for the use of HW-serial...
                                      I really suspect AltSoftSerial to be incompatible with 1wire (at least using PIN10).
                                        Stefan_NE
                                        Hi to all,
                                        after the change to RFM69 last sunday all 7 nodes are running without any connection lost. I added an alive message every 2min to the sketch. No messages have been lost.
                                        • rejoe2R
                                          rejoe2R
                                          rejoe2
                                          @Stefan_NE Good to hear you finally succeded in having a reliable network.
                                          News from my side:
                                          After 5 days of operation it seems Node_2 is back in a mode of relaible communication, no more issues also with Node_1. These both are the ones sending a lot of data and use HW-serial + "triple-headed" message initialisation.
                                          BUT: Node_3 (BME280) is no longer continously present now, and also Node_4 (sw-serial + "single-headed") seems to have communication problems (didn't yet investigate in depth). So next step will be to first change these sketches also for the use of the triple initialisation. If that works, I'll report - it then may be a good idea to change the defaults in the MySensors-lib (to be discussed).
