  3. PiDome
  4. PiDome Domotica/Home Automation
Scheduled Pinned Locked Moved PiDome
controllerserialgatewayraspberrymqttpidome
199 Posts 17 Posters 144.4k Views 5 Watching
  • C ceburge
    Tested build 517 with serial gateway. Everything with the device discovery did as expected. Just can't beat the dynamics of this! I'm not sure if this has anything to do with the build or maybe something else, but I am using the Relay Actuator sketch to test with. Everything seems to work fine with the exception of when the light is toggled with the button. The status of Off and On in the control view never gets updated. I had this problem with an earlier build I think it was Alpha build 493, but with 493 I could turn the relay On from the controller and then toggle the push button to turn it Off and the controller would update to Off but never would to On now it's not doing either one. Do you have any ideas why? I see the serial monitor sending to the gateway the update with an OK but never see it get passed to the controller inside the driver page.
    JohnJ
    JohnJ
    John
    @ceburge Good to hear that the disocvery does what it has to do.
    Reagrding the toggle button, this one listens very carefully, could you send a printscreen of the control details of this button in the device editor to support@pidome.org?
    @tortoisedoc Please let me know your findings! I must day that every test i did when i had the gateway running (before it became a IR relay) was always with the nano.
    • JohnJ John
      tortoisedoc
      wrote on last edited by tortoisedoc
      #154
      @John Okay! Making progress here; after digging and digging, it appears my FTDI module is funky; as in, 115200 Baud seem to somehow be a problem for it.
      I made a quick test sketch where arduino increases a counter and writes out the current value, and i have the possibility to reset the value (between 1 and 9). Well, it works properly only up to 57600 baud. Weird. I will test a version of the mysensors @ 57600 Baud now.
      EDIT AND IT WORKS! COME ON :D!
      This is interesting indeed. I wonder how it comes baud rate 115k fails the FTDI (note : both on PC AND RPi)...
      JohnJ 1 Reply Last reply
      • T tortoisedoc
        JohnJ
        JohnJ
        John
        wrote on last edited by John
        #155
        @tortoisedoc Good that it's working, please take a look at this page regarding higher speed, not much text, but explaines a lot: http://forum.arduino.cc/index.php?topic=26044.0 It could be an issue more often with for example cheap clones?
        [edit]Self note: change the text at new nodes presentation, it does not appear on the driver page anymore[/edit]
        • JohnJ John
          tortoisedoc
          #156
          @John both board and FTDI are from sparkfun...I believe that is the official maker? But yes, this is exactly the same type of problem I have.
          • T tortoisedoc
            JohnJ
            JohnJ
            John
            @tortoisedoc The solution then would be build one with a crystal, or keep on using the lower speed. I personally had no problems with data running at 57k
            • JohnJ John
              tortoisedoc
              @John I will definietly keep the 57 K ; it should be enough as the data transfered is minimal. I plan to add another 5 sensors at least, but I believe it should be ok.
              • R
                R
                ricardot
                Hello John
                When I try to save a trigger I am getting this error:
                Message:
                java.lang.Integer cannot be cast to java.lang.Float
                Trace:
                java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.Float\n at org.pidome.server.services.triggerservice.rules.RuleIfNumberFloat.equalsTo(RuleIfNumberFloat.java:74)\n at org.pidome.server.services.triggerservice.rules.RuleIf.equalsTo(RuleIf.java:141)\n at org.pidome.server.services.triggerservice.rules.RuleIf.run(RuleIf.java:113)\n at org.pidome.server.services.triggerservice.rules.RuleSubject.run(RuleSubject.java:92)\n at org.pidome.server.services.triggerservice.TriggerEvent.createRuleSubjects(TriggerEvent.java:353)\n at org.pidome.server.services.triggerservice.TriggerEvent.createSimpleRuleSet(TriggerEvent.java:277)\n at org.pidome.server.services.triggerservice.TriggerEvent.createRulesetFromJSON(TriggerEvent.java:225)\n at org.pidome.server.services.triggerservice.TriggerEvent.(TriggerEvent.java:211)\n at org.pidome.server.services.triggerservice.TriggerService.saveTrigger(TriggerService.java:229)\n at org.pidome.server.system.rpc.TriggerServiceJSONRPCWrapper.saveTrigger(TriggerServiceJSONRPCWrapper.java:240)\n at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)\n at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)\n at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)\n at java.lang.reflect.Method.invoke(Method.java:483)\n at org.pidome.server.system.rpc.AbstractRPCMethodExecutor.execMethod(AbstractRPCMethodExecutor.java:166)\n at org.pidome.server.system.rpc.AbstractRPCMethodExecutor.execMethod(AbstractRPCMethodExecutor.java:121)\n at org.pidome.server.system.rpc.PidomeJSONRPC.handleRequest(PidomeJSONRPC.java:358)\n at org.pidome.server.system.rpc.PidomeJSONRPC.handle(PidomeJSONRPC.java:245)\n at org.pidome.server.system.webservice.webclient.Webclient_jsonrpc.collect(Webclient_jsonrpc.java:55)\n at org.pidome.server.services.clients.http.HTTPClientHandler.run(HTTPClientHandler.java:186)\n
                Am I doing anything wrong? Thanks!
                • E
                  E
                  ericvdb
                  wrote on last edited by ericvdb
                  #160
                  Hi John,
                  I'm trying to create a custom device that sends RF codes to a RF433 Mhz node, but I can't seem to send the additional fields I added to the device.
                  upload-1d6be592-ff63-4988-858a-109f7f124626
                  The additional fields:
                  upload-bfb3a8dc-b918-4e24-97e1-e08efd14a13a
                  Am I trying something here that is simply not possible?
                  I want to add that device over and over with different House- and Device Codes:
                  upload-77754828-1553-4625-9d14-7d00137c6301
                  So in the end i need to send 4;3;1;0;2;3A1 to turn a light on at Housecode 3 and Devicecode A (and 1 is turn on, 0 is turn off)
                  Is this currently possible?
                  Many thanks and keep up the good work, really love PiDome.
                  • R ricardot
                    Hello John
                    Message:
                    Trace:
                    JohnJ
                    JohnJ
                    John
                    @ricardot
                    Hard to see from only the stack trace. Is it possible that you send me a screenshot of how you setup the trigger and send this to support@pidome.org? The trigger system has become quite mature, so the message you have posted should not occur in any case. Need to take a close look into it.
                    R 1 Reply Last reply
                    • E ericvdb
                      Hi John,
                      JohnJ
                      JohnJ
                      John
                      #162
                      @ericvdb said:
                      Hi eric,
                      try to set the on command to 3A1 and the off command to 3A0 in the V_LIGHT toggle control. I know this is not what you want because this means you have to create a device for every address. And with flexible addresses you want to use the options so users can enter them.
                      You are using the device editor the correct way, it currently only is not implemented yet. There is a task on my to-do list to take a look on how common fields for controls can use the options created in the editor.
                      You know what, send an email to support@pidome.org with some of your device details, and I will come up with something. (If the programming API was ready i could have given some guidelines, but unfortunately it is not yet).
                      P.S. it is 00:46 here, so expect an answer tomorrow ;).
                      [edit]typo's[/edit]
                      B 1 Reply Last reply
                      • JohnJ John
                        @ricardot
                        R
                        R
                        ricardot
                        I also Install the android client, but I can't make it works. I receive a login error: Could not connect/login: Authentication needs to be verified (202)
                        But the client never ask me for a username and password.
                        • R ricardot
                          JohnJ
                          JohnJ
                          John
                          #164
                          @ricardot Is not needed. On the server create an user. Then connect with the client to the server. On the page Connected clients you will see your android device. Click on it, select the user you just created and confirm your selection. The android client receives the confirmation and will continu starting. This device is now bound to this user.
                          • J
                            J
                            jonnyfishman
                            Hi John,
                            Happy Xmas and enjoying the new updates.
                            I can't seem to get the 'Send data to an url' tab to work in automation anymore. Is this a bug or do I need to change the way it functions (it was working in an earlier version with the same settings).
                            Jon
                            • J jonnyfishman
                              Hi John,
                              Jon
                              JohnJ
                              JohnJ
                              John
                              #166
                              @jonnyfishman Thnx! Hope you enjoyed Christmas as much as i did.
                              There has been some streamlining done of code. This is the second report and i'm currently looking into it.
                              If possible, Stop the server and start it with "./server.sh trace". Keep it running for a couple of minutes (so it can do a couple of http send commands). then go to "Server settings" in the web interface and turn of debug logging (bot trace and debug are turned of with this). Send me the file "logs/system/appLog.txt" to support@pidome.org with a reference to this post.
                              Cheers,
                              John.
                              [EDIT]The other reported issue was a timeout on the remote host. Please take a look in the log file if this is also the case for you[/edit]
                              • R
                                R
                                ricardot
                                John,
                                I would like to know what I need to do to create a rule to turn on an off a mysensors relay in a specific time of the day. And also If is possible Pidome to send me a email when it happens.
                                • JohnJ
                                  JohnJ
                                  John
                                  @ricardot At the automation rules create a new rule:
                                  • At the left side you can select rules logic and select an if block. put this on the field
                                  • Click on Time/Date/Dayparts on the left and select the block when time is, and fill in the time.
                                  • Click on devices on the left and select your MySensors device and choose the action.
                                  • Give your rule a name and description.
                                  Currently there is no option to send an email but there are messaging (which send messages to clients, pushbullet and sms. Email will follow asap.
                                  P.S. Note to all: Will be on leave until the 5th of januari next year (sounds long...). There will be support but this is at a minimal level.
                                  • J
                                    J
                                    jonnyfishman
                                    wrote on last edited by jonnyfishman
                                    #169
                                    Hi John,
                                    Checked the appLog.txt and the request was going through (it received a HTTP 200 code). The problem was the automation rule. It was no longer happy with having a variable as a parameter, I had to change it back to a string for it to work [examples below]?
                                    **ricardot **- This might also work for you. I'm using the 'URL hits' under 'miscellaneous' to email myself using the code below. Essentially it sends out a form to a waiting page on my website that automatically emails me when it receives the correct data, using the PHP mail function.
                                    This works.
                                    This doesn't
                                    • JohnJ
                                      JohnJ
                                      John
                                      @jonnyfishman
                                      Sorry for the late response, the holidays consumed us all quite a lot, and i'm still on a sort of holiday leave, Could you send me the log, i'm interested in why the variable is not handled.
                                      Cheer,
                                      John.
                                      P.S. Happy new year!
                                      • J
                                        J
                                        jonnyfishman
                                        Happy new year to you,
                                        I've attached the appLog. Relevant lines appear to be 2495 and 1555.
                                        I recreated the error several times to make it show up. At 2495 the variable is listed as null, whereas at 1555 the variable is passing what it should.
                                        appLog.txt
                                        Jon
                                        JohnJ 2 Replies Last reply
                                        • J jonnyfishman
                                          appLog.txt
                                          Jon
                                          JohnJ
                                          JohnJ
                                          John
                                          @jonnyfishman Currently i'm not in the position to check it. I'm back at 5th of January. I will pick it up that day.
