  3. Wemos + RFM95 + MQTT gateway
8 Posts 2 Posters 2.5k Views 3 Watching
  • martijn13M Offline
    martijn13M Offline
    martijn13
    Can someone help me with installing a wemos as a rfm95 gateway?
    I used this pinout:
    Wemos - RFM95
    3v -> 3v
    D8 - > NSS
    D7 -> MISO
    D6 -> MOSI
    D5 -> SCK
    D1 -> DI00
    GND - > GND
    I changed the Wifi credentials and the mqtt adres. When i watch the serial monitor i see this:
    scandone
    no Anoniem found, reconnect after 1s
    reconnect
    f r0, scandone
    reconnect
    f 0, 0;255;3;0;9;TSM:FAIL:RE-INIT
    0;255;3;0;9;TSM:INIT
    0;255;3;0;9;TSM:FAIL:CNT=6
    0;255;3;0;9;TSM:FAIL:PDT
    scandone
    reconnect
    f -180, scandone
    reconnect
    f r0, scandone
    reconnect
    f 0,
    On my access point i don't see that the Wemos connect to the Wifi
     * Version 1.0 - Henrik Ekblad
     * The ESP8266 MQTT gateway sends radio network (or locally attached sensors) data to your MQTT broker.
     * The node also listens to MY_MQTT_TOPIC_PREFIX and sends out those messages to the radio network
     * LED purposes:
     * - To use the feature, uncomment any of the MY_DEFAULT_xx_LED_PINs in your sketch
     * See http://www.mysensors.org/build/esp8266_gateway for wiring instructions.
     * nRF24L01+  ESP8266
     * VCC        VCC
     * CE         GPIO4
     * CSN/CS     GPIO15
     * SCK        GPIO14
     * MISO       GPIO12
     * MOSI       GPIO13
      * Inclusion mode button:
    #define MY_BAUD_RATE 9600
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    // Set MQTT client id
    #define MY_MQTT_USER "username"
    #define MY_MQTT_PASSWORD "password"
    // Set WIFI SSID and password
    #define MY_ESP8266_SSID "MySSID"
    #define MY_ESP8266_PASSWORD "MyVerySecretPassword"
    // #define MY_ESP8266_HOSTNAME "mqtt-sensor-gateway"
    #define MY_IP_ADDRESS 192,168,178,87
    #define MY_IP_GATEWAY_ADDRESS 192,168,178,1
    // MQTT broker ip address.
    #define MY_CONTROLLER_IP_ADDRESS 192, 168, 178, 68
    #define MY_PORT 1883
    // Enable inclusion mode
    // Set blinking period
    // Flash leds on rx/tx/err
    #include <ESP8266WiFi.h>
    Can someone help me?
    • martijn13M martijn13
      I used this pinout:
      Wemos - RFM95
      3v -> 3v
      D8 - > NSS
      D7 -> MISO
      D6 -> MOSI
      D5 -> SCK
      D1 -> DI00
      GND - > GND
      scandone
      reconnect
      f r0, scandone
      reconnect
      scandone
      reconnect
      f -180, scandone
      reconnect
      f r0, scandone
      reconnect
      f 0,
       * LED purposes:
       * nRF24L01+  ESP8266
       * VCC        VCC
       * CE         GPIO4
       * CSN/CS     GPIO15
       * SCK        GPIO14
       * MISO       GPIO12
       * MOSI       GPIO13
      Welcome to the MySensors community @martijn13 !
      "no Anoniem found, reconnect after 1s" means that the esp8266 is unable to find the wifi network called "Anoniem". Is there such a 2.4GHz wifi network within range? Does it broadcast its SSID?
        martijn13M Offline
        martijn13
        Thnxs @mfalkvidd . This is the SSID i don't give up in this sketch but it was from the last sketch i used on my work.
        connected with Anoniem, channel 1
        dhcp client start...
        ip:10.10.10.112,mask:255.255.255.0,gw:10.10.10.254
        0;255;3;0;9;TSM:FAIL:CNT=2
        Is the only error i still got
          @martijn13 !TSM:INIT:TSP FAIL means the esp8266 is unable to communicate with the rfm radio.
          From your wiring description above it looks like mosi and miso have been swapped.
            martijn13M Offline
            martijn13
            I swapped the 2 wires
            ⸮dOX⸮⸮B⸮L⸮DxtH⸮⸮0;255;3;0;9;MCO:BGN:INIT GW,CP=RLNGE--,VER=2.1.1
            0;255;3;0;9;TSF:LRT:OK
            0;255;3;0;9;TSF:WUR:MS=0
            scandone
            state: 0 -> 2 (b0)
            state: 2 -> 3 (0)
            state: 3 -> 5 (10)
            add 0
            aid 1
            cnt
            0;255;3;0;9;TSM:FAIL:CNT=1
            pm open,type:2 0
            0;255;3;0;9;TSM:FAIL:PDT```
              scandone
              state: 0 -> 2 (b0)
              state: 2 -> 3 (0)
              state: 3 -> 5 (10)
              add 0
              aid 1
              cnt
              pm open,type:2 0
              @martijn13 so still no contact with the radio.
              See if the suggestion in https://forum.mysensors.org/post/78406 helps, along with https://www.mysensors.org/apidocs-beta/group__RFM95SettingGrpPub.html
              Maybe defining MY_DEBUG_VERBOSE_RFM95 can give more detailed information on why it fails.
                martijn13M Offline
                martijn13
                I'm so sorry, i maked a mistake when i was swapping the wires. It work's now :+1:
                Thnxs!!
                  Thnxs!!
                  @martijn13 great! Tanks for reporting back.
                  12.2k
