  3. Home Assistant
  4. MySensor on Hass.io - can't get it work
28 Posts 6 Posters 12.8k Views 6 Watching
  • archiijsA archiijs
    @maty said in MySensor on Hass.io - can't get it work:
    e code isn't mine (made by my friend), I've been using it with Domoticz for almost a year, and it worked perfectly. But recently i decided to give a try to Hass.io, and I really like it. But I still have a problem with lights connected via MySensors (Arduino Mega conected to Rpi via USB), can't get it work with Hass.io. Config part in configuration.yaml look
    Hi @MaTy
    I have no experience with hass.io, but some comments arise.
    1. Your configuration.yaml file path seems to be incorrect. You have to edit this to real path, something like "/user/.homeassistant/mysensors.json" or whatever. The path should exist, file there will be created if it is correct and writeable.
    2. You should check if your USB port is really /dev/ttyUSB0 usually command "lsusb" is used, but I'm not sure how to do this in hass.io
    3. Also, check if USB port speed is the same as in mysensors gateway and your configuration. 38400 seems different than the standard what usually is 115200 if I'm not mistaken.
      EDIT: Ok, baud seems to match, so that should not be an issue.
    MaTyM
    MaTyM
    MaTy
    @archiijs said in MySensor on Hass.io - can't get it work:
    Hi @MaTy
    Ad.1. I tried different path too (default one '/config/mysensors.json') - still wrong. I'm not sure how these .json files works, so maybe I'm still makeing sthg wrong. (Maybe someone can share me a link with an explanation or write a few words about it?)
    Ad.2. USB is correct I checked (besides i have RFLink on the ttyUSB1 and it works great).
    Ad.3. As You said at the end ... baud should be OK.
    • archiijsA
      archiijsA
      archiijs
      /config/mysensor
      Default path seems to be generic and not really useful, at the beginning I had problems with understanding this as well. Take a look at the full location where your home assistant configuration files are located, this could be a good location. and add "mysensors.json" at the end (this file will be created and you can name it anything.yson).
      like mine is "/root/.homeassistant/mysensors.json"
      MaTyM 1 Reply Last reply
      • MaTyM
        MaTyM
        MaTy
        Wait, do I need to install an addon from reposytory, to make it work? Isn't it included in Hass.io? I cant see any repo :/
          /config/mysensor
          MaTyM
          MaTyM
          MaTy
          wrote on last edited by MaTy
          I think i found the answer ... https://forum.mysensors.org/topic/7360/hass-io-and-ethernet-gateway-on-pi
          It looks like I need docker add-on to run MySensors gateway on Hass.io, and it doesn't exist so far, what a shame :(
          • Tom CarpenterT
            Tom CarpenterT
            Tom Carpenter
            I don't have a light switch on my sensors but I do have a couple of temp sensors running on my hassio installation with no problem.
            • Tom CarpenterT Tom Carpenter
              MaTyM
              MaTyM
              MaTy
              @tom-carpenter
              How did You make it? Is it via serial gateway?
              Tom CarpenterT 1 Reply Last reply
              • MaTyM MaTy
                martinhjelmareM
                martinhjelmareM
                martinhjelmare
                @maty
                That thread is about attaching the radio directly to the RPi GPIO in combination with Hass.io. You're using an arduino as gateway that has the radio if I understand correctly. So you shouldn't need an addon for your case.
                I suggest looking at the Z-wave documentation for Hass.io where they also connect a USB device. It's the same principle as the mysensors serial gateway when you use an arduino as gateway.
                https://home-assistant.io/hassio/zwave/
                  @maty
                  MaTyM
                  MaTyM
                  MaTy
                  @martinhjelmare
                  Oh, sorry, im so confused after I moved from domoticz to Hass.io. But I don't need Z-wave. What I have is serial gateway based on arduino mega 2560, with a sketch (example) https://hastebin.com/cinokiraka.cpp which controles all lights in my house. The arduino mega is connected to my RPI3 (with Hass.io) via usb (ttyUSB0). It worked perfectly on Domoticz, all lights was discovered automatically. I've checked the documentation of MySensors implementation on Hass.io web site, and read plenty of forums and still nothing :/
                  I'm still getting errors. https://pastebin.com/VDaVRKkV
                  • N
                    N
                    nelsonov
                    Are you sure that's the right device? It's /dev/ttyUSB0 that is the source of the error in your output. Maybe the device is something like /dev/ttyAMA0 or /dev/ttyACM0?
                    https://keybase.io/nelsonov
                    • N nelsonov
                      MaTyM
                      MaTyM
                      MaTy
                      @nelsonov
                      when i use "hassio homeassistant hardware" command it displays only ttyUSB0 and ttyUSB1. I have RFLink connected to USB1 and it works great, so MySensors gateway must be the ttyUSB0.
                      https://pastebin.com/wTn72d1D Am I right?
                      • N
                        N
                        nelsonov
                        wrote on last edited by nelsonov
                        What do you get from ls -l /dev/tty*?
                        • N nelsonov
                          MaTyM
                          MaTyM
                          MaTy
                          @nelsonov resault
                          https://ibb.co/cyPQqG
                          • MaTyM
                            MaTyM
                            MaTy
                            After I disconnected gateway and connected it again, I checked command "dmesg | grep usb" and this showed up
                            https://hastebin.com/leqocowaco.vbs before there was nothing after command. Command ls -l /dev/tty* still the same.
                            • N
                              N
                              nelsonov
                              You might need to take this to the [Home Assistant Forum]
                              (https://community.home-assistant.io). Something strange is going on at the OS level. Your kernel is recognizing the USB device, but the OS isn't creating the tty. You can try lsusb just to see if it's still there, but beyond that I'm out of advice. The error you are getting from Home Assistant has awkward wording, but it means that it can't find the serial device.
                              • MaTyM MaTy
                                @martinhjelmare
                                martinhjelmareM
                                martinhjelmareM
                                martinhjelmare
                                @maty
                                If you read the Z-wave documentation I linked to you will get instructions how to add a specific USB device to Hass.io docker. My guess is this could solve your problem.
                                For some devices the /dev/ttyAMA0 device is not detected by udev and is therefore not mapped by Docker. To explicitly set this device for mapping to Home-Assistant, execute the following command using the ssh add-on:
                                $ curl -d '{"devices": ["ttyAMA0"]}' http://hassio/homeassistant/options
                                Replace ttyAMA0 above with the correct device in your case.
                                  @maty
                                  MaTyM
                                  MaTyM
                                  MaTy
                                  @martinhjelmare
                                  I did It. resault But I'm still getting errors :/
                                  I guess I'm hopeless. It's probably sthg silly as always.
                                  update:
                                  after trying different solutions i typed hardware check command and new serial appeared 'AMA0' but I did nothing physically with RPi (din't attach any devices). I tried to check mysensors config with ttyAMA0 instead of USB0, but I still got the same resault.
                                  ps. of course when I was trying your command ($ curl -d '{"devices": ["ttyAMA0"]}' http://hassio/homeassistant/options), I did it with USB0 parameter, not AMA0.
                                  • MaTyM
                                    MaTyM
                                    MaTy
                                    Yesterday I accidentally restarted Hass.io with all that errors in config. I was afraid that it'll crush after restart but it actually worked. After restart I turned on switch on the wall, and Switch (light relay) appeared on Hass.io home screen.
                                    There are still the same errors in config, and I have some issues with those light switches. Most annoying issue is that Hass.io doesn't update switch state after change via gui. Switch state changes in Hass.io when i use manual switch on the wall but when I use gui it doesn't
                                    http://ibb.co/f8Rvum
                                    • MaTyM MaTy
                                      martinhjelmareM
                                      martinhjelmareM
                                      martinhjelmare
                                      @maty
                                      You should send feedback of state changes to home assistant from your device. This is done from the receive function. The switch in home assistant will switch as soon as the feedback comes in.
                                      Also set optimistic to false in your mysensors config section.
                                        @maty
                                        MaTyM
                                        MaTyM
                                        MaTy
                                        #21
                                        @martinhjelmare
                                        You mean in my sketch, something like this?
                                          if (message.type==V_LIGHT) {
                                             // Change relay state
                                             // Store state in eeprom
                                        I had optimistic set false.
                                        BTW: Strange thing, baud rate in my sketch is 38400, but when I set it up in Hass.io, lights won't work, when I changed to 115200 in .yaml (in sketch is still 38400), all works fine, except the states update.
                                        • MaTyM MaTy
                                          @martinhjelmare
                                          martinhjelmareM
                                          martinhjelmareM
                                          martinhjelmare
                                          @maty
                                          In your example above you never send the feedback from receive. Use the send method
                                          from within receive to do that.
                                          In what sketch have you set baud rate to 38400? For the light device or for the gateway? It's only the gateway baud rate that is relevant for home assistant config, since it's the gateway that interfaces via the serial connection to home assistant.
