  3. Domoticz
  4. different information
9 Posts 2 Posters 3.0k Views 2 Watching
  • BarnaB
    BarnaB
    Barna
    Could you help me, what the problem is ?
    The log and detailed data time-stamps are not some.
    LOG:
    2017-12-09 22:27:01.131 (mysensor_gate) Temp + Humidity (Udvar)
    2017-12-09 22:57:03.681 (mysensor_gate) Temp + Humidity (Udvar)
    DATA:
    2017-12-09 22:00:00 63 1
    2017-12-09 22:05:00 63 1
    2017-12-09 22:10:00 63 1
    2017-12-09 22:15:00 63 1
    2017-12-09 22:20:00 63 1
    2017-12-09 22:25:00 63 1
    2017-12-09 22:30:00 59 0.7
    2017-12-09 22:35:00 59 0.7
    2017-12-09 22:40:00 59 0.7
    2017-12-09 22:45:00 59 0.7
    2017-12-09 22:50:00 59 0.7
    2017-12-09 22:55:00 59 0.7
    2017-12-09 23:00:00 56 0.8
    2017-12-09 23:05:00 56 0.8
    2017-12-09 23:10:00 56 0.8
    code:
    unsigned long SLEEP_TIME = 900000;
    send(msgTemp.set(DHT.temperature, 1));
    send(msgHum.set(DHT.humidity, 1));
    delay(SLEEP_TIME);
    The node must send data by 15min, Domonicz receives it by 30min, detailed data contains 5min data.
    Does the Domonicz feel 30min gap every 5min ?
    thanks
    Barna
    M 2 Replies Last reply
    • BarnaB Barna
      LOG:
      DATA:
      code:
      delay(SLEEP_TIME);
      thanks
      Barna
      manutremo
      @barna Domoticz always saves the data in 5 minutes summaries, regardless of at which frequency it is actually received.
      I'm not sure I understand the part "Domonicz receives it by 30min". Regardless of what is finally stored, you should still see the values in the devices displayed correctly when a new data point arrives.
      • BarnaB
        BarnaB
        Barna
        The 5min summaries was new for me, thanks the info.
        But I do not understand if the node wakes up in every 15min, why the Domonicz receives data only by 30min only.
        • BarnaB Barna
          LOG:
          DATA:
          code:
          delay(SLEEP_TIME);
          thanks
          Barna
          manutremo
          @barna In order to do understand that we'd need to see the node and gateway logs, and the full sketch.
          • BarnaB
            BarnaB
            Barna
            I have checked the node log, the Domonicz is correct, the node sends message every 30min, but why if 900000 = 15min ?
            • BarnaB
              BarnaB
              Barna
              #include <dht.h>
              #define CHILD_ID_HUM 14
              #define CHILD_ID_TEMP 15
              #define HUMIDITY_SENSOR_DIGITAL_PIN 5
              int BATTERY_SENSE_PIN = A0; // select the input pin for the battery sense point
              int oldBatteryPcnt = 0;
              dht DHT;
              float lastTemp;
              float lastHum;
              boolean metric = true;
              sendSketchInfo("TemperatureAndHumidity DHT21", "1.1");
              present(CHILD_ID_HUM, S_HUM);
              Serial.println("DHT TEST PROGRAM ");
              Serial.print("LIBRARY VERSION: ");
              Serial.println(DHT_LIB_VERSION);
              #if defined(AVR_ATmega2560)
              analogReference(INTERNAL1V1);
              analogReference(INTERNAL);
              //-------------------- battery
              // get the battery Voltage
              #ifdef MY_DEBUG
              Serial.println(sensorValue);
              #ifdef MY_DEBUG
              float batteryV = sensorValue * 0.003363075;
              Serial.print(batteryV);
              Serial.println(" V");
              Serial.print(batteryPcnt);
              Serial.println(" %");
                  // Power up radio after sleep
                  oldBatteryPcnt = batteryPcnt;
              //-------------------- DHT
              // READ DATA
              Serial.print("DHT21, \t");
              int chk = DHT.read21(HUMIDITY_SENSOR_DIGITAL_PIN);
              switch (chk)
              case DHTLIB_OK:
                  Serial.print("OK,\t");
              case DHTLIB_ERROR_CHECKSUM:
                  Serial.print("Checksum error,\t");
              case DHTLIB_ERROR_CONNECT:
                  Serial.print("Connect error,\t");
              case DHTLIB_ERROR_ACK_L:
                  Serial.print("Ack Low error,\t");
              case DHTLIB_ERROR_ACK_H:
                  Serial.print("Ack High error,\t");
              default:
                  Serial.print("Unknown error,\t");
              // DISPLAY DATA
              Serial.print(DHT.humidity, 1);
              Serial.print(",\t");
              Serial.println(DHT.temperature, 1);
              delay(SLEEP_TIME);
                manutremo
                @barna I just noticed you are using delay() for the wait. It is recommended to use the mysensors function wait() instead of delay().
                See here.
                If using wait() doesn't fix it, the only option I can think of at this moment is if you were using a 8Mhz board but compiled the program for a 16MHz...
                • BarnaB
                  BarnaB
                  Barna
                  I have replaced the delay() by sleep() and every problem was resolved :)
                    manutremo
                    Yes, sleep is the equivalent to wait if you want to put the arduino to sleep. If it fixed it, wait should too.
