  3. MyS Network Scanner (4 sec.)
10 Posts 3 Posters 3.4k Views 5 Watching
  • berkseoB Offline
    berkseoB Offline
    berkseo
    An example of a subroutine for finding MyS networks
    If you need a test, I compiled the HEX file for atmega 328p | 5V | 16MHz
    https://youtu.be/cSM2GSkM_-k
    HEX - https://drive.google.com/open?id=1EX71EtDABLdwosYLlc8GkebO-WdkX1aF
      Does it scan each channel until it finds a response? Encrypted networks are not detected, right?
      berkseoB 1 Reply Last reply
        berkseoB Offline
        berkseoB Offline
        berkseo
        @gohan Logic is not like you imagine it. The scanner not waits for activity on the MyS network, it will be very long. The scanner alternately on each channel queries the gateway (3,7) and waiting for confirmation of departure to the first node.Test 126 channels takes 4-5 seconds
        • berkseoB Offline
          berkseoB Offline
          berkseo
          The subprogramme(part of a larger program) exclusively to search for a channel number which has a network of MySensors.
          • berkseoB Offline
            berkseoB Offline
            berkseo
            You can also check the quality of the radio. In the first tests (I have one network on channel 76), networks were also found on channels 44, 74. 75, 108. ... cheap quality from China :)
              But can it find encrypted networks?
              berkseoB 2 Replies Last reply
              • S Offline
                I don't think so..
                why the .hex instead of the sources??
                  berkseoB Offline
                  berkseoB Offline
                  berkseo
                  @gohan Encrypted Mysensors network? I do not know, did not test. You can try. If the gateway in the encrypted MySensors network can receive (do not process) the message, the scanner will find out about it. I think so.
                  • S scalz
                    I don't think so..
                    berkseoB Offline
                    berkseoB Offline
                    berkseo
                    @scalz http://mysensors.ru/forum/viewtopic.php?f=5&t=379
                      berkseoB Offline
                      berkseoB Offline
                      berkseo
                      @gohan The encrypted network on radio modules nrf24 .. is recognized, the channel is determined
                      12.1k
